ANT-GNCP-CA158L160
Active Ceramic Patch GNSS Antenna
The GNCP-CA158L160 is a global navigation satellite system (GNSS) ceramic patch antenna with integrated low noise
amplifier (LNA), supporting GPS, Galileo, Beidou, IRNSS and QZSS systems in the L1/E1/B1 bands. The 15 dB LNA
provides high gain with low noise figure of 2.6 dB (typ.). The antenna has a 60 mm cable terminated in a
U.FL-type plug (female socket) connector.
FEATURES
APPLICATIONS
• Performance at 1575.42 MHz
– VSWR: ≤ 1.7
– Peak Gain: 31.6 dBi
– Axial Ratio: 12.29 dB
• Global navigation
– GPS L1
– Galileo E1
– II L1
– Beidou B1-BOC
– IRNSS
– QZSS L1
• Directional radiation pattern orthogonal to
antenna surface
• Right-hand circularly polarized (RHCP)
• 15 dB (Typ.) LNA
• U.FL-type plug (female socket) compatible with
MHF1, AMC, UMCC
• Timing solutions
ORDERING INFORMATION
Part Number
ANT-GNCP-CA158L160
Description
GNSS ceramic patch antenna with U.FL-type plug (female socket)
on 60 mm of 1.13 mm coaxial cable
Available from Linx Technologies and select distributors and representatives.
DATA AND DEVICES / ANT-GNCP-CA158L160
TABLE 1. ELECTRICAL SPECIFICATIONS, LNA PLUS ANTENNA DATA
GNCP-CA158L160
GPS L1, GALILEO
E1, II L1, Beidou
B1-BOC, QZSS L1
Beidou B1
Beidou B1-2
I L1,
II L1
Center Frequency
1561.098 MHz
1575.42 MHz
1589.74 MHz
1602 MHz
Frequency Range
1559.05 MHz to 1563.14
MHz
1567.24 MHz to 1583.60
MHz
1587.69 MHz to 1591.79
MHz
1593.31 MHz to 1608.68 MHz
VSWR (max)
3.5
2.4
1.5
1.4
Peak Gain* (dBi)
6.7
13.9
13.9
12.4
Axial Ratio (dBi)
6.4
5.0
6.3
9.4
Noise Figure (dB)
2.6
2.6
2.6
2.6
Polarization
Impedance
RHCP
Radiation
Electrical Type
Vertical
Input Voltage
50 Ω
Radiating Patch plus LNA
Min. 2.7 V, Typ. 3.0 V, Max. 3.3 V Current Consumption @3.0V
Typ. 3.0 mA, Max. 5.0 mA
*Applies to antenna, LNA, cable and connector combined.
TABLE 2. MECHANICAL SPECIFICATIONS, LNA PLUS ANTENNA
Parameter
Value
Operating Temp. Range
-40 °C to +85 °C
Connection
U.FL-type plug (female socket) on 60 mm (2.36 in) of 1.13 mm coaxial cable
Dimensions
15.0 mm x 15.0 mm x 6.6 mm (0.59 in x 0.59 in x 0.26 in)
Weight
5.7 g (0.20 oz)
VSWR
1609
1601
1602
1590
1592
1593
1587
1584
1575
1567
5
1559
1561
1563
Figure 1 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power
reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given
frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter
power reflected back from the antenna.
VSWR
4
30
3
1
1550
10
1560
1570
1580
Frequency (MHz)
1590
1600
Reflected Power (%)
40
Figure 1. ANT-GNCP-CA158L160 VSWR with Frequency Band Highlights
2
RETURN LOSS
1609
1601
1602
1590
1592
1593
1587
1584
1575
1567
1561
1563
Return loss (Figure 2), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return
loss value indicates better antenna performance at a given frequency.
-2
Return Loss (dB)
-4
-6
-8
-10
-12
-14
-16
-18
-20
1550
1560
1570
1580
Frequency (MHz)
1590
1600
1610
Figure 2. ANT-GNCP-CA158L160 Return Loss with Frequency Band Highlights
PEAK GAIN
Peak Gain From Best Direction (dBi)
1609
1601
1602
1590
1592
1593
1587
1584
1575
1567
15
1559
1561
1563
The peak gain across the antenna bandwidth is shown in Figure 3. Peak gain represents the maximum antenna input
power concentration across 3-dimensional space, and therefore peak performance at a given frequency, but does not
consider any directionality in the gain pattern
10
5
-10
-15
-20
1550
1560
1570
1580
Frequency (MHz)
1590
1600
1610
Figure 3. ANT-GNCP-CA158L160 Peak Gain with Frequency Band Highlights
3
AXIAL RATIO
1609
1601
1602
1590
1592
1593
1587
1584
1575
100
1567
1559
1561
1563
Axial ratio provides a measure of the quality of circular polarization of an antenna, the lower the value (in dB), the
better the circular polarization. A circularly polarized antenna field comprises two orthogonal E-field components.
These fields are ideally of equal amplitude, resulting in an axial ratio equal to unity (0 dB). In practice, no antenna is
perfectly circular in polarization, the polarization is elliptical as one field has larger magnitude. As the axial ratio
increases the antenna gain degrades away from the main beam orthogonal to the antenna surface. The axial ratio for
the ANT-GNCP-CA158L160 antenna is shown in Figure 4
90
Axial Ratio (dB)
80
70
60
50
40
30
1560
1570
1580
Frequency (MHz)
1590
1600
1610
Figure 4. ANT-GNCP-CA158L160 Antenna Axial Ratio with Frequency Band Highlights
RADIATION PATTERNS
Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna
by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns are shown in Figure 5
using polar plots covering 360 degrees. The antenna graphic at the top of the page provides reference to the plane of
the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is
possible to reveal fine detail.
XZ-Plane Gain
YZ-Plane Gain
XY-Plane Gain
4
1559.05 MHz to 1563.14 MHz (1561 MHz)
34
35
33
32
31
30
29
28
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
18
17
2
3
4
5
6
7
8
9
10
12
25
13
24
14
23
16
15
22
21
18
17
16
1555 MHz
1560 MHz
1565 MHz
XY-Plane Gain
YZ-Plane Gain
XZ-Plane Gain
1
26
15
22
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
16
35
33
13
15
22
1
25
14
23
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
1567.24 MHz to 1583.60 MHz (1576 MHz)
34
35
33
32
31
30
29
28
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
35
16
XZ-Plane Gain
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
16
35
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
YZ-Plane Gain
XY-Plane Gain
YZ-Plane Gain
XY-Plane Gain
17
16
1560 MHz
1575 MHz
1585 MHz
Radiation Patterns
XZ-Plane Gain
5
1587.69 MHz to 1591.79 MHz (1590 MHz)
34
35
33
32
31
30
29
28
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
XZ-Plane Gain
21
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
16
35
33
13
15
22
1
25
14
23
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
1585 MHz
1590 MHz
1595 MHz
XY-Plane Gain
1593.31 MHz to 1608.68 MHz (1601 MHz)
34
35
33
32
31
30
29
28
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
35
16
XZ-Plane Gain
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
35
16
YZ-Plane Gain
36 15
10
5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
16
1590 MHz
1600 MHz
1610 MHz
XY-Plane Gain
Figure 5. ANT-GNCP-CA158L160 Radiation Patterns
Product Dimensions
Figure 6 provides dimensions of the ANT-GNCP-CA158L160.
Figure 6. ANT-GNCP-CA158L160 Antenna Dimensions
6
MOUNTING
The ANT-GNCP-CA158L160 may be mounted by soldering the LNA base to a printed circuit board (PCB) - see
application note, AN-00504 on the Linx website for more information. Alternatively, the antenna may be mounted by
mechanical means (e.g. bracket, not included) or using an adhesive patch (not included).
PACKAGING INFORMATION
The ANT-GNCP-CA158L160 antenna is packaged in a protective plastic tray in quantities of 30. Antenna trays are
bundled and packaged in a carton of 540 antennas. Distribution channels may offer alternative packaging options.
TE TECHNICAL SUPPORT CENTER
USA:
+1 (800) 522-6752
Canada:
+1 (905) 475-6222
Mexico:
+52 (0) 55-1106-0800
Latin/S. America:
+54 (0) 11-4733-2200
Germany:
+49 (0) 6251-133-1999
UK:
+44 (0) 800-267666
France:
+33 (0) 1-3420-8686
Netherlands:
+31 (0) 73-6246-999
China:
+86 (0) 400-820-6015
te.com
TE Connectivity, TE, TE connectivity (logo), Linx and Linx Technologies are trademarks owned or licensed by the TE Connectivity Ltd. family of companies. All other logos,
products and/or company names referred to herein might be trademarks of their respective owners.
The information given herein, including drawings, illustrations and schematics which are intended for illustration purposes only, is believed to be reliable. However,
TE Connectivity makes no warranties as to its accuracy or completeness and disclaims any liability in connection with its use. TE Connectivity‘s obligations shall only be as
set forth in TE Connectivity‘s Standard Terms and Conditions of Sale for this product and in no case will TE Connectivity be liable for any incidental, indirect or consequential
damages arising out of the sale, resale, use or misuse of the product. Users of TE Connectivity products should make their own evaluation to determine the suitability of each
such product for the specific application.
TE Connectivity warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and
limitations TE Connectivity will, at its option, either repair or replace any part of its products that prove defective because of improper workmanship or materials. This limited
warranty is in force for the useful lifetime of the original end product into which the TE Connectivity product is installed. Useful lifetime of the original end product may vary but
is not warrantied to exceed one (1) year from the original date of the end product purchase.
©2022 TE Connectivity. All Rights Reserved.
09/22 Original
很抱歉,暂时无法提供与“ANT-GNCP-CA158L160”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+75.80520
- 200+29.34360
- 500+28.30680
- 1000+27.79920
