SS8050-H-F2-0000HF
SS8050-H-F2-0000HF
    OTHER
SS8050-H-F2-0000HF 数据手册
SS8050-L THRU SS8050-H RoHS   COMPLIANT   NPN General Purpose Amplifier Features ● Epoxy meets UL-94 V-0 flammability rating ● Halogen free available upon request by adding suffix ”HF” ● Moitsure Sensitivity Level 1 ● High Conductance ● Surface Mount Package Ideally Suited for Automatic Insertion Mechanical Data ● Package: SOT-23 Molding compound meets UL 94 V-0 flammability rating, RoHS-compliant, halogen-free ● Terminals: Tin plated leads, solderable per J-STD-002 and JESD22-B102 ● Marking: SS8050-L SS8050-H Y1ꞏL Y1 ■Maximum Ratings (Ta=25℃ unless otherwise noted) Item Symbol Unit Conditions Value Minimum Collector-Emitter Voltage VCEO V IC=100uAdc, IB=0 25 Minimum Collector-Base Voltage VCBO V IC=100uAdc, IE=0 40 Minimum Emitter-Base Voltage VEBO V IE=100uAdc, IC=0 5.0 IC A Maximum Collector-Emmiter cut-off current ICEO nAdc VCE=20Vdc 100 Maximum Collector-Base cut-off current ICBO nAdc VCB=40Vdc 100 Maximum Emitter-Base cut-off current IEB0 nAdc VEB=5.0Vdc 100 Collector Power Dissipation PC mW 300 Operation Junction Temperature Tj ℃ -55 to +150 Tstg ℃ -55 to +150 Collector Current Storage Temperature 1.5 1/5 S-S1468 Rev.1.5, 10-Dec-19 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com SS8050-L THRU SS8050-H     ■Electrical Characteristics (Ta=25℃ unless otherwise noted) Item Symbol Unit Conditions Min Max Collector-Emitter Voltage VCEO V IC=100uAdc, IB=0 25 Collector-Base Voltage VCBO V IC=100uAdc, IE=0 40 Emitter-Base Voltage VEBO V IE=100uAdc, IC=0 5 Collector-Emitter cut-off current ICEO nAdc VCE=20Vdc 100 Collector-Base cut-off current ICBO nAdc VCB=40Vdc 100 Emitter-Base cut-off current IEB0 nAdc VEB=5.0Vdc 100 hFE(1) IC=100mA VCE=1.0Vdc 120 hFE(2) IC=800mA VCE=1.0Vdc 40 350 DC Current Gain Collector-Emitter Saturation Voltage VCE(sat) Vdc IC=800mA IB =80mA 0.5 Base-Emitter Saturation Voltage VBE(sat) Vdc IC=800mA IB =80mA 1.2 Symbol Unit Conditions MHz IC=50mAdc, VCE=10Vdc,f=30MHz ■Small-signal Characteristics Item Transition frequency fT Min Max 100 ■CLASSIFICATION OF HFE (1) Rank L Range H 120-200 200-350 ■Ordering Information (Example) PREFERED P/N PACKING CODE UNIT WEIGHT(g) MINIMUM PACKAGE(pcs) INNER BOX QUANTITY(pcs) OUTER CARTON QUANTITY(pcs) DELIVERY MODE SS8050 F2 Approximate 0.008 3000 30000 120000 7” reel 2/5 S-S1468 Rev.1.5, 10-Dec-19 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com SS8050-L THRU SS8050-H     ■Characteristics (Typical) 3/5 S-S1468 Rev.1.5, 10-Dec-19 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com SS8050-L THRU SS8050-H     ■SOT-23 Package Outline Dimensions ■SOT-23 Soldering Footprint 4/5 S-S1468 Rev.1.5, 10-Dec-19 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com SS8050-L THRU SS8050-H     Disclaimer The information presented in this document is for reference only. Yangzhou Yangjie Electronic Technology Co., Ltd. reserves the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or design or otherwise. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Yangjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such improper use of sale. This publication supersedes & replaces all information previously supplied. For additional information, please visit our website http:// www.21yangjie.com , or consult your nearest Yangjie’s sales office for further assistance. 5/5 S-S1468 Rev.1.5, 10-Dec-19 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com
SS8050-H-F2-0000HF 价格&库存
很抱歉,暂时无法提供与“SS8050-H-F2-0000HF”相匹配的价格&库存,您可以联系我们找货
