1N5408G-D1-0000
1N5408G-D1-0000
    OTHER
1N5408G-D1-0000 数据手册
RoHS 1N5400G THRU 1N5408G  COMPLIANT   General Purpose Rectifier Features ● High efficiency ● High current capability ● High reliability ● High surge current capability ● Low power loss ● Glass passivated chip junction ● Solder dip 275 °C max. 7 s, per JESD 22-B106 Typical Applications For use in general purpose rectification of power supplies, inverters, converters, and freewheeling diodes for consumer, and telecommunication. Mechanical Data ● Package:DO-201AD(DO-27) Molding compound meets UL 94 V-0 flammability rating, RoHS-compliant ● Terminals: Tin plated leads, solderable per J-STD002 and JESD22-B102 ● Polarity:Color band denotes cathode end ■Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT 1N5400G 1N5401G 1N5402G 1N5404G 1N5406G 1N5407G 1N5408G 1N5400G 1N5401G 1N5402G 1N5404G 1N5406G 1N5407G 1N5408G Device marking code Maximum Repetitive Peak Reverse Voltage VRRM V 50 100 200 400 600 800 1000 Maximum RMS Voltage VRMS V 35 70 140 280 420 560 700 Maximum DC blocking Voltage VDC V 50 100 200 400 600 800 1000 IF(AV) A IFSM A Average Forward Current @60Hz sine wave, Resistance load, Ta =70℃ Forward Surge Current (Non-repetitive) @60Hz Half-sine wave,1 cycle, Tj=25℃ Forward Surge Current (Non-repetitive) @1ms, square wave, 1 cycle, Tj=25℃ 3.0 200 400 Current squared time @1ms≤t8.3≤ms Tj=25℃,Rating of per diode Typical junction capacitance @Measured at 1MHz and Applied Reverse Voltage of 4.0 V.D.C I2t A2s 166 Cj pF 40 Storage Temperature Tstg ℃ -55 ~ +150 Junction Temperature Tj ℃ -55 ~ +150 ■Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Maximum instantaneous forward voltage drop per diode VF V Maximum DC reverse current at rated DC blocking voltage per diode IR μA TEST CONDITIONS 1N5400G 1N5401G 1N5402G 1N5404G 1N5406G 1N5407G 1N5408G IF=3.0A 1.0 Tj =25℃ 2.5 Tj =125℃ 100 1/4 S-A029 Rev.2.3,30-Jan-21 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com 1N5400G THRU 1N5408G    ■Thermal Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Typical Thermal Resistance RθJ-A ℃/W 1N5400G 1N5401G 1N5402G 1N5404G 1N5406G 1N5407G 1N5408G 30 ■Ordering Information (Example) PREFERED P/N PACKAGE CODE UNIT WEIGHT(g) MINIMUM PACKAGE(pcs) INNER BOX QUANTITY(pcs) OUTER CARTON DELIVERY MODE QUANTITY(pcs) 1N5400G~1N5408G D1 Approximate 1.05 1250 1250 12500 Tape 1N5400G~1N5408G C1 Approximate 1.05 250 250 12500 Bulk ■ Characteristics (Typical) FIG.1: Io-Ta Curve FIG.2: Forward Surge Current Capability Peak Forward Surge Current (A) 200 2.4 1.8 1.2 S Average Forward Output Current (A) 3.0 ingle Phase Half Wave 60HZ Resistive or Inductive Load 0.375''(9.5mm) Lead Length 0.6 0 50 8.3ms Single Half Sine Wave JEDEC Method 120 80 40 0 0 0 1 0 160 100 150 1 2 4 20 40 60 80 100 100 Instantaneous Reverse Current (uA) Instantaneous Forward Current (A) 8 10 FIG.4: Typical Reverse Characteristics FIG.3: Forward Voltage 100 10 1.0 0.1 0.01 0.6 6 Number of Cycles Ambient Temperature (℃) TJ=25℃ Pulse width=300us 1% Duty Cycle 0.8 1.0 1.2 1.4 1.6 1.8 10 Tj=100℃ 1.0 0.1 Tj=25℃ 0.01 0.001 2.0 Tj=125℃ 0 20 Instantaneous Forward Voltage (V) 40 60 80 100 2/4 S-A029 Rev.2.3,30-Jan-21 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com 1N5400G THRU 1N5408G    ■ Outline Dimensions DO-201AD(DO-27) DO-201AD(DO-27) Dim Min Max A 8.50 9.50 B C 5.00 5.60 25.4 / D 1.20 1.30 Dimensions in millimeters 3/4 S-A029 Rev.2.3,30-Jan-21 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com 1N5400G THRU 1N5408G    Disclaimer The information presented in this document is for reference only. Yangzhou Yangjie Electronic Technology Co., Ltd. reserves the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or design or otherwise. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Yangjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such improper use of sale. This publication supersedes & replaces all information previously supplied. For additional information, please visit our website http:// www.21yangjie.com , or consult your nearest Yangjie’s sales office for further assistance. 4/4 S-A029 Rev.2.3,30-Jan-21 Yangzhou Yangjie Electronic Technology Co., Ltd. www.21yangjie.com
1N5408G-D1-0000 价格&库存
很抱歉,暂时无法提供与“1N5408G-D1-0000”相匹配的价格&库存,您可以联系我们找货
