1N4148W/1N4448W/1N914BW
Taiwan Semiconductor
150mA, 75V Switching Diode
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
Compliance to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
150
mA
VRRM
75
V
IFSM
2
A
VF at IF=100mA
1.00
V
TJ Max.
150
°C
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
Package
SOD-123F
Configuration
Single die
MECHANICAL DATA
Case: SOD-123F
Molding compound meets UL 94 V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 8.85 ± 0.5mg
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
SYMBOL
VALUE
1N4148W
D1
1N4448W
D2
1N914BW
D3
UNIT
Power dissipation
PD
400
mW
Reverse voltage
VR
100
V
Forward current
Repetitive peak forward current
VRRM
IF
IFRM
75
150
300
V
mA
mA
Non-repetitive peak forward surge current @ t=1.0µs
IFSM
2
A
Junction temperature range
TJ
-65 to +150
°C
Storage temperature range
TSTG
-65 to +150
°C
Repetitive peak reverse voltage
1
Version: K1804
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
SYMBOL
TYP
UNIT
RӨJA
450
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward
voltage
(1)
CONDITIONS
1N4448W, 1N914BW
IF = 5mA, TJ = 25°C
1N4148W
IF = 10mA, TJ = 25°C
1N4448W, 1N914BW
IF = 100mA, TJ = 25°C
IR=100µA, TJ = 25°C
Reverse voltage
Reverse leakage current
IR=5µA, TJ = 25°C
VR=20V TJ = 25°C
(2)
VR=75V TJ = 25°C
1 MHz, VR=0V
Junction capacitance
IF=10mA, IR=60mA,
Reverse recovery time
RL=100Ω, IRR=1mA
SYMBOL
MIN
MAX
0.62
0.72
1.00
1.00
100
75
25
nA
5
µA
CJ
4
pF
trr
4
ns
VF
VR
IR
UNIT
V
V
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
1N4148W RHG
SOD-123F
3K / 7" Reel
1N4148W RH
SOD-123F
3K / 7" Reel
1N4448W RHG
SOD-123F
3K / 7" Reel
1N4448W RH
SOD-123F
3K / 7" Reel
1N914BW RHG
SOD-123F
3K / 7" Reel
1N914BW RH
SOD-123F
3K / 7" Reel
2
Version: K1804
CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig.2 Reverse Current VS. Reverse Voltage
100
10
Reverse Current (µA)
Instantaneous Forward Current (mA)
100
1
0.1
0.01
0.001
10
1
0.1
0.01
0.4
0.6
0.8
1
1.2
1.4
1.6
80
100
120
Reverse Voltage (V)
Instantaneous Forward Voltage (V)
Fig.3 Admissible Power Dissipation Curve
Fig.4 Typical Junction Capacitance
6
500
5
Junction Capacitance (pF)
400
Power Dissipation (mW)
60
300
200
100
4
3
2
1
60
80
100
120
140
Ambient Temperature (oC)
2
4
6
8
10
Reverse Voltage (V)
3
Version: K1804
PACKAGE OUTLINE DIMENSION
SOD-123F
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.50
1.70
0.059
0.067
B
3.30
3.90
0.130
0.154
C
0.50
0.70
0.020
0.028
D
2.50
2.70
0.098
0.106
E
0.80
1.15
0.031
0.045
F
0.05
0.20
0.002
0.008
SUGGEST PAD LAYOUT
DIM.
4
Unit (mm)
Unit (inch)
Typ.
Typ.
C
2.86
0.113
G
1.52
0.060
X
1.34
0.053
X1
4.20
0.165
Y
1.80
0.071
Version: K1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: K1804
很抱歉,暂时无法提供与“1N914BW RH”相匹配的价格&库存,您可以联系我们找货
