5-1440000-6
5-1440000-6
    OEG
5-1440000-6 数据手册
Power PCB relay OMIH - 1pole 10/16A, 1 form A (NO) or 1 form C (CO) contact - Meet 5000V dielectric voltage between coil and contacts - Meet 10000V surge voltage between coil and contacts - Can provide anti-explosion type (meet IEC-60079-15/GB3836.1-2010/GB3836.8-2014) Typical applications Home appliances (refrigerators, washing machines, microwave ovens), office machines, and room air conditioners Approvals VDE 40005414, UL E58304, CSA LR48471, SEMKO 903200, CQC 08001024660, TUV R50139138 Technical data of approved types on request Contact Data Contact arrangement 1 Form A (NO), 1 Form C (CO) Rated voltage 250VAC / 30VDC Max. switching voltage 250VAC / 30VDC Rated current 16A Contact material Ag alloy Min. recommended contact load 100mA 5VDC Initial contact resistance 100mΩ @ 1A, 6VDC Frequency of operation, with/without load 360 /18000h-1 Operate/Release time Max. standard coil: 15ms/8ms sensitive coil: 20ms/8ms Electrical endurance Type Load Cycles IEC 61810 16 A, 250 VAC, resistive 100×103 at 85℃ 16 A, 30VDC 30×103 room temp UL508 16 A, 250 VAC, resistive 30×103 at 85℃ 100×103 room temp 16 A, 250 VAC general use (anti-explosive type) Keep the vent hole open during test (except anti-explosive type) Mechanical endurance Electrical endurance 10X106 ops Coil Data Coil voltage range Coil insulation system according UL Coil versions, DC coil Rated coil Operate Coil voltage voltage code (VDC) VDC Standard coil, 720mW 05 5 3.5 06 6 4.2 09 9 6.3 12 12 8.4 24 24 16.8 48 48 33.6 Sensitive coil, 540mW 05 5 3.75 06 6 4.5 09 9 6.75 12 12 9.0 24 24 18.0 48 48 36.0 5 to 48VDC class 105 (A) Release voltage VDC Coil resistance Ohm +/-10% Rated coil power mW 0.25 0.3 0.45 0.6 1.2 2.4 36 48.5 115 200 820 3300 720 720 720 720 720 720 0.25 0.3 0.45 0.6 1.2 2.4 49 68.0 155 270 1100 4400 540 540 540 540 540 540 All figures are given for coil without pre-energization, at ambient temperature +23℃ Insulation Data Initial dielectric strength between open contacts between contact and coil Initial surge withstand voltage between contact and coil Initial insulation resistance Clearance/creepage between contact and coil 1000Vms 5000Vms 10000V 1000MΩ ≥5.5mm/8mm Coil temperature rise ©Copyright 2017 by Tyco Electronics(Shenzhen)Co.,Ltd. All rights reserved. Edition: Jan/2017 Rev. E Tyco Electronics Shenzhen office Tower A, World Finance Centre, 4003 East Shennan Road, Luo Hu District, Shenzhen, PRC 518008 Power PCB relay OMIH Other Data Material compliance: EU RoHS/ELV, China RoHS, REACH, Halogen content refer to the product Compliance Support Center at WWW.te.com/customersupport/rohssupportcenter Ambient temperature -40°C to +85°C Category of environmental protection IEC61810 RTII - flux proof RTIII - wash tight Shock resistance(functional) 98m/s2 Shock resistance(destructive) 980m/s2 Resistance to soldering heat THT IEC 60068-2-20 RTII: 270°C/10s RTIII: 260°C/5s Terminal type PCB-THT Weight about 13g Packaging unit Tray/50, Carton/1000 Tube/20, Carton/1000 Terminal Assignment Bottom view on solder pins PCB layout Bottom view on solder pins Dimensions Product code structure Typical product code OMIH -SS -1 12 L M 2 ,XXXXX Type OMIH Power PCB Relay OMIH SS Flux proof 1 1 pole Sealing SH Wash tight Poles Coil Coil code: please refer to coil version table (e.g., 12 = 12VDC) Coil power D Standard 720mW L Sensitive 540mW 1 Form C M 1 Form A ,SPST-NO Contact arrangement Blank Contact material ©Copyright 2017 by Tyco Electronics(Shenzhen)Co.,Ltd. All rights reserved. Edition: Jan/2017 Rev. E Tyco Electronics Shenzhen office Tower A, World Finance Centre, 4003 East Shennan Road, Luo Hu District, Shenzhen, PRC 518008 Blank Standard (1 Form A : AgSnInO; 1 Form C: AgCdO) 1 AgSnInO (Only 1 form C ) ,XXXXX 0 - 9, a - z, A - Z, or blank (which does not represent electrical changes, only for specific customer requirements) 2 Anti-explosion type (Only 1 form A,also used on Flux proof type) Suffix Product Code OMIH-SH-112LM2,0SE2W OMIH-SS-112LM2,0000W OMIH-SS-112LM, 0000M OMIH-SH-112LM,03020 OMIH-SS-112LM,01020 OMIH-SH-112L,000 OMIH-SS-112L,000 OMIH-SH-112L1,300 OMIH-SH-105L,394 OMIH-SH-124LM,000 OMIH-SS-112LM,000 OMIH-SS-124LM,000 OMIH-SS-112LM,000M OMIH-SH-112LM,00E0W OMIH-SH-112L,000 OMIH-SS-112L,000 OMIH-SS-124L,000 Contact arrangement Form A Form A Form A Form A Form A Form C Form C Form C Form C Form A Form A Form A Form A Form A Form C Form C Form C Contact material Anti-Ex Anti-Ex AgSnOInO AgSnOInO AgSnOInO AgCdO AgCdO AgSnOInO AgCdO AgCdO AgCdO AgCdO AgCdO AgCdO/Anti-Ex AgCdO AgCdO AgCdO Coil 12VDC 12VDC 12VDC 12VDC 12VDC 12VDC 12VDC 12VDC 5VDC 24VDC 12VDC 24VDC 12VDC 12VDC 12VDC 12VDC 24VDC Enclosure Wash tight Flux proof Flux proof Wash tight Flux proof Wash tight Flux proof Wash tight Wash tight Wash tight Flux proof Flux proof Flux proof Wash tight Wash tight Flux proof Flux proof Part number 2071446-3 2071514-1 1-1721685-0 1-1721685-1 1-1721685-2 5-1419121-7 8-1419121-0 1-1721535-5 1-1461373-1 6-1419121-9 8-1419121-1 8-1419121-8 1-1721685-0 2071372-1 5-1419121-7 8-1419121-0 8-1419121-7 ©Copyright 2017 by Tyco Electronics(Shenzhen)Co.,Ltd. All rights reserved. Edition: Jan/2017 Rev. E Tyco Electronics Shenzhen office Tower A, World Finance Centre, 4003 East Shennan Road, Luo Hu District, Shenzhen, PRC 518008
5-1440000-6
- 物料型号:OMIH系列,包括不同封装和特性的继电器。 - 器件简介:1极10/16A,1表A(常开)或1表C(常闭)接触,符合5000V介电电压和10000V浪涌电压,可提供防爆型。 - 引脚分配:底部视图显示了焊接引脚的布局。 - 参数特性: - 额定电压:250VAC/30VDC - 最大开关电压:250VAC/30VDC - 额定电流:16A - 接触材料:银合金 - 最小推荐接触负载:100mA 5VDC - 初始接触电阻:100mΩ@1A,6VDC - 操作/释放时间:标准线圈15ms/8ms,灵敏线圈20ms/8ms - 功能详解:包括线圈数据、电气耐久性、线圈温度上升等。 - 应用信息:家用电器(冰箱、洗衣机、微波炉)、办公设备和房间空调。 - 封装信息:包括环境温度、环境保护类别、冲击抵抗力、耐焊热性等。 - 产品代码结构:提供了产品代码的构成和示例产品代码。
5-1440000-6 价格&库存
很抱歉,暂时无法提供与“5-1440000-6”相匹配的价格&库存,您可以联系我们找货
