KBP310
KBP310
    DY(迪一电子)
    KBP
KBP310 数据手册
KBP3005 THRU KBP310 SINGLE PHASE 3.0AMP GLASS PASSIVATED BRIDGE RECTIFIER Features · · · · · KBP Glass passivated die construction Low forward voltage drop High current capability High surge current capability Plastic material-UL flammability 94V-0 0.581(14.75) 0.561(14.25) 0.043(1.1) 0.031(0.8) 0.144(3.65) 0.132(3.35) 0.417(10.6) 0.402(10.2) Mechanical Data 0.056(1.42) 0.048(1.22) · Case: KBP, molded plastic · Terminals: plated leads solderable per · · · · 0.087(2.2) 0.071(1.8) 0.583(14.8) 0.563(14.3) MIL-STD-202, Method 208 Polarity: as marked on case Mounting position: Any Marking: type number Lead Free: For RoHS / Lead Free Version 0.022(0.55) 0.012(0.3) 0.16(4.06) 0.14(3.56) 0.034(0.86) 0.03(0.76) Dimensions in inches and ( millimeters ) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified. Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SYMBOL KBP 3005 KBP 301 KBP 302 KBP 304 KBP 306 KBP 308 KBP 310 UNITS 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 700 V VRRM Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRWM RMS Reverse Voltage VRMS Average Rectified Output Current (Note 1) @TC=50 ℃ IF(AV) 3.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 60 A I2t Rating for Fusing (t < 8.3ms) I 2t Forward Voltage per element @IF=3.0A VFM 1.1 V Peak Reverse Current At Rated DC Blocking Voltage @TA=25℃ @TA=125℃ IR 5.0 500 uA RθJA 30 RθJL 11 TJ,TSTG -55to+150 Typical Thermal Resistance per leg (Note 2) Operating and Storage Temperature Range VDC A2s 14.94 ℃/W ℃ Note:1. Mounted on glass epoxy PC board with 1.3mm 2 solder pad. 2. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C.. version:02 1 of 3 www.dyelec.com KBP3005 THRU KBP310 Fig. 2 Typical Fwd Characteristics IF, INSTANTANEOUS FWD CURRENT (A) IO, AVERAGE RECTIFIED CURRENT (A) Fig. 1 Forward Current Derating Curve 3.0 2.0 1.0 10 TA= 25°C 1.0 0.1 Pulse Width = 300 µs 0 0 50 0 150 100 0 0.4 0.6 0.8 1.0 100 100 Cj, JUNCTION CAPACITANCE (pF) Single Half Sine-Wave Pulse Width =8.3ms (JEDEC Method) 50 40 30 10 100 TJ = 25°C f = 1MHz 10 0 0 0 1.4 Fig. 4 Typical Junction Capacitance Fig. 3 Max Non-Repetitive Peak Fwd Surge Current 60 1.2 VF, INSTANTANEOUS FWD VOLTAGE (V) T, TEMPERATURE (°C) IFSM , PEAK FWD SURGE CURRENT (A) 0.2 0 100 10 VR, REVERSE VOLTAGE (V) NUMBER OF CYCLES AT 60 Hz IR, INSTANTANEOUS REVERSE CURRENT (µA) Fig. 5 T ypical Reverse Characteristics (per element) 100 TJ = 125°C 10 1.0 TJ = 25°C 0.1 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) version:02 2 of 3 www.dyelec.com KBP3005 THRU KBP310 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3 of3 www.dyelec.com
KBP310 价格&库存
很抱歉,暂时无法提供与“KBP310”相匹配的价格&库存,您可以联系我们找货
