PDQE15-Q24-S5-D
PDQE15-Q24-S5-D
    OTHER
    POWER-MODULE-6P_25.4X25.4MM_TM
PDQE15-Q24-S5-D 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 10/27/2022 page 1 of 8 SERIES: PDQE15-D │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • 15 W isolated output ultra-wide input voltage range single/dual regulated outputs 1500 Vdc isolation extended temperature range (-40~105°C) input under-voltage protection output short circuit, over-current, over-voltage protection DIP package EN 62368-1, UL 62368-1 MODEL input voltage output voltage output current output power ripple & noise1 efficiency2 typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) max (mVp-p) typ (%) PDQE15-Q24-S3-D3 24 9~36 3.3 0 4000 13.2 100 88 PDQE15-Q24-S5-D 24 9~36 5 0 3000 15 100 90 PDQE15-Q24-S12-D3 24 9~36 12 0 1250 15 100 90 3 PDQE15-Q24-S15-D 24 9~36 15 0 1000 15 100 91 PDQE15-Q24-S24-D3 24 9~36 24 0 625 15 100 91 PDQE15-Q24-D5-D 24 9~36 ±5 0 ±1500 15 200 87 PDQE15-Q24-D12-D3 24 9~36 ±12 0 ±625 15 200 90 3 PDQE15-Q24-D15-D 24 9~36 ±15 0 ±500 15 200 90 PDQE15-Q24-D24-D3 24 9~36 ±24 0 ±312 15 200 89 PDQE15-Q48-S3-D 48 18~75 3.3 0 4000 13.2 100 88 PDQE15-Q48-S5-D 48 18~75 5 0 3000 15 100 90 PDQE15-Q48-S12-D 48 18~75 12 0 1250 15 100 91 PDQE15-Q48-S15-D 48 18~75 15 0 1000 15 100 91 PDQE15-Q48-S24-D 48 18~75 24 0 625 15 100 91 PDQE15-Q48-D5-D 48 18~75 ±5 0 ±1500 15 200 86 PDQE15-Q48-D12-D 48 18~75 ±12 0 ±625 15 200 90 PDQE15-Q48-D15-D 48 18~75 ±15 0 ±500 15 200 90 PDQE15-Q48-D24-D 48 18~75 ±24 0 ±312 15 200 90 3 3 Notes: 1. From 5~100% load, nominal input, 20 MHz bandwidth oscilloscope, with 10 µF tantalum and 1 µF ceramic capacitors on the output. From 0~5% load, ripple and noise is
PDQE15-Q24-S5-D 价格&库存
很抱歉,暂时无法提供与“PDQE15-Q24-S5-D”相匹配的价格&库存,您可以联系我们找货
