SCM2012HS-900-03
SCM2012HS-900-03
    KOHER(科或)
SCM2012HS-900-03 数据手册
SCM Series Common Mode Filter Size 2012 FEATURES ■ ■ ■ Very high self-resonance frequency enables very high cut-off frequency, and good transmission of very high-speed signals without damage to the signal wave. Small size and low profile. Operating temperature -40~+125℃ (Including self - temperature rise) FEATURES ■ ■ ■ USB3.1G2 AV interfaces, such as HDMI 2.0, DVI and DisplayPort lines High-speed signal lines 1 2 4 3 1.2 ± 0.2 2.0 ± 0.2 0.51 ± 0.1 Dimensions: [mm] 0.50 ± 0.1 0.15 ± 0.1 1.2 ± 0.2 Schematic: 1 2 4 3 Electrical Properties: Part No Impedance @ 100 MHz (Ω) Tolerance DC Resistance Max. (Ω) Rated Current Max. (mA) Rated Volt (V) Withstand Volt (V) IR Min. (MΩ) SCM2012HS-300-04 30 ±25% 0.20 400 50 125 10 SCM2012HS-600-03 60 ±25% 0.30 300 50 125 10 SCM2012HS-900-03 90 ±25% 0.30 300 50 125 10 SCM2012HS-121-03 120 ±25% 0.35 330 50 125 10 KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com Typical Electrical Characteristics: Attenuation VS Frequency SCM2012HS-300-04 SCM2012HS-600-03 M1 M2 -6 -9 -12 0 M1 -3 ATTENUATION(dB) ATTENUATION(dB) -3 -15 SCM2012HS-900-03 0 -6 -9 -12 M1:-1.62@7.088GHz M2:-2.19@15.000GHz START:1.000MHz STOP:15000.000MHz FREQUENCY(MHz) -15 M1 -3 M2 ATTENUATION(dB) 0 M2 -6 -9 -12 M1:-2.18@5.888GHz M2:-4.19@14.963GHz START:1.000MHz STOP:15000.000MHz FREQUENCY(MHz) -15 M1:-2.66@9.113GHz M2:-2.98@14.475GHz START:1.000MHz STOP:15000.000MHz FREQUENCY(MHz) SCM2012HS-121-03 0 M1 -3 ATTENUATION(dB) M2 -6 -9 -12 -15 M1:-2.75@7.088GHz M2:-3.96@15.000GHz START:1.000MHz STOP:15000.000MHz FREQUENCY(MHz) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com
SCM2012HS-900-03 价格&库存
很抱歉,暂时无法提供与“SCM2012HS-900-03”相匹配的价格&库存,您可以联系我们找货
