KPCIEX-T98-1BK
KPCIEX-T98-1BK
    KYCON
KPCIEX-T98-1BK 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Check Stock Request a Sample Certificate of Origin Send Us An Email Generated Part Number KPCIEX-T36-1BK Part Number Builder PCI EXPRESS CARD EDGE: KPCIEX Series Product Features Supports 2.5 Gb/s Data Transfer Rate (Per Pair Data Bandwidth) Standard 36, 64, 98,164 Pin 230 and 280 Pin Option Standard 1.0mm Pitch Performance Specifications Materials and Finish Housing High Temperature Thermoplastic Contacts Phosphor Bronze Contact Plating Standard: Gold Flash over 50 Nickel on Contact Area, 100µ" Min. Tin over 50µ" Nickel on Termination End 30: 30µ" Gold over 50µ" Nickel on Contact Area 100µ" Min. Tin over 50µ" Nickel on Termination End Electrical Characteristics Rated Voltage 50V AC (RMS) / DC Rated Current 1.1A Contact Resistance 30 milliohms Max. Insulation Resistance 1000 Megohms Min. Dielectric Strength 500V AC RMS for 1 Minute T KPCIEX Series Mounting Option 36 1 BK Number Option Tail Length Color Option Plating Option Series KPCIEX Mounting Option T - Through Hole Number of Pins 36 - Pins 64 - Pins 98 - Pins 164 - Pins 230 - Pins 280 - Pins Tail Length 1 - 2.30mm 2 - 2.54mm 3 - 3.00mm Color* BK - Black Standard Plating Material* Blank - Gold Flash Standard 30 - 30µ" Gold Contact Kycon for Other Options KPCIEX Series Dimensions in mm Mechanical Characteristics Insertion Force 1.15N Max. Per Contact Pair Extraction Force 0.15N Min. Per Contact Pair Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
KPCIEX-T98-1BK 价格&库存
很抱歉,暂时无法提供与“KPCIEX-T98-1BK”相匹配的价格&库存,您可以联系我们找货
