DATA SHEET
Common Mode Chokes RB series
Current-compensated Chokes
Rated currents from 16 to 50 A
Approvals & Compliances
Up to 600 VAC or 1000 VDC
2- and 3-wire configurations
Horizontal and vertical PCB mounting types
Ruggedized saturation and thermal behavior
Open construction for forced and convection
cooling
Straightforward pin-out for easy PCB design
Performance indicators
RB common-mode chokes are mainly used to filter
EMI noise on AC power lines up to 600 VAC but
they are as well applicable in DC power lines of
photovoltaic installations or similar applications up
to 1000 VDC. EMI noise of electronic equipment
can go to the power lines and disturb the proper
function of other devices like TV sets or radios. Thus
noise generated by the equipment from switched
power electronics or by high slew rates of
controllers needs to be filtered. RB common-mode
chokes are used to suppress EMI noise in PCB
integrated filter designs with line bypass capacitors
or in combination with single phase filters for extra
low leakage filter designs.
Features and Benefits
Cost-effective PCB designs for up to 80 A with
forced cooling *
Compact size and light weight
Low magnetic leakage flux
Excellent winding insulation
Standardized foot print
Broad range of inductance ratings
Custom-specific versions on request
Technical Specifications
Evaluation Board and PCB footprints available
Maximum continuous operating voltage
600 VAC/1000 VDC
Operating frequency
DC to 400 Hz
High potential test voltage
Typical Applications
AC and DC filtering for midsize power range
drives, photovoltaic inverters, fast chargers,
charging stations, UPS and switch mode power
supplies
Temperature range (operation and storage)
-40°C to +125°C (40/125/21) acc. IEC 60068-1
Flammability corresponding to
UL 94 V-0
Cooling
convection/forced cooling
MTBF @ 40°C/230 V (Mil-HB-217F)
>5,000,000 hours
Filter with low leakage current noise or improved
immunity against grid disturbances
Rated currents
16 to 50 A @ 60°C max. convection cooling
Electronic devices, automation
Rated inductance
0.2 to 3 MILLIHENRY
Converters
Typical electrical schematic
2
Common Mode Chokes
Schaffner Group
DATA SHEET
15. Jun 2022
RB Series
Selection table
Buy
convection
*forced cooling
Inductance
Inductance
Resistance
**Choke
Ø Pin
Length
Weight
cooling nominal
3 m/s nominal
Ln @ 25˚C
Ls @ 25˚C
R @ 25˚C
current @ 60˚C
current @ 60˚C
[A]
[A]
[mH/path]
[μH/path]
[mΩ/path]
[size]
D [mm]
L [mm]
[g]
No.
RB6122-16-1M0
16
25
1.00
6.3
4.8
1
2.0 ±0.1
4.5 +0.5/-0
130
1
RB6122-25-0M6
25
39
0.64
4.0
2.7
1
2.4 ±0.1
4.5 +0.5/-0
135
1
RB6122-36-0M5
36
53
0.45
3.6
1.5
2
2.2 ±0.1
4.5 +0.5/-0
180
1
RB6122-50-0M3
50
80
0.25
1.8
0.9
2
2.5 ±0.1
5.0 +0.5/-0
172
1
RB6522-16-1M0
16
25
1.00
6.2
4.6
3
2.0 ±0.1
4.5 +0.5/-0
132
2
RB6522-25-0M6
25
39
0.64
3.9
2.6
3
2.4 ±0.1
4.5 +0.5/-0
126
2
RB6522-36-0M5
36
53
0.45
3.6
1.5
4
2.2 ±0.1
4.5 +0.5/-0
180
2
RB6522-50-0M3
50
80
0.25
2.0
0.9
4
2.5 ±0.1
5.0 +0.5/-0
175
2
RB8522-16-3M0
16
25
3.00
22.2
8.4
4
2.0 ±0.1
4.5 +0.5/-0
172
3
RB8522-25-2M0
25
39
2.00
13.6
4.2
5
2.65 ±0.1
5.0 +0.5/-0
268
3
RB8522-36-1M5
36
53
1.50
12.8
3.0
6
2.2 ±0.1
4.5 +0.5/-0
440
3
RB8522-50-0M8
50
83
0.75
6.5
1.7
6
2.5 ±0.1
5.0 +0.5/-0
430
3
RB6132-16-0M8
16
26.5
0.80
5.8
4.6
7
2.0 ±0.1
4.5 +0.5/-0
162
4
RB6132-25-0M5
25
41
0.47
3.3
2.4
7
2.5 ±0.1
5.0 +0.5/-0
175
4
RB6132-36-0M4
36
60
0.42
2.9
1.4
8
2.2 ±0.1
4.5 +0.5/-0
278
5
RB6132-50-0M2
50
80
0.18
1.9
0.9
8
2.5 ±0.1
5.0 +0.5/-0
765
5
RB6532-16-0M8
16
26.5
0.80
6.9
4.7
9
2.0 ±0.1
4.5 +0.5/-0
165
6
RB6532-25-0M5
25
41
0.47
3.6
2.4
9
2.5 ±0.1
5.0 +0.5/-0
180
6
RB6532-36-0M4
36
60
0.42
4.2
1.5
10
2.2 ±0.1
4.5 +0.5/-0
280
6
RB6532-50-0M2
50
81
0.18
1.5
0.8
10
2.5 ±0.1
5.0 +0.5/-0
168
6
RB8532-16-1M3
16
27
1.30
9.1
5.7
9
2.0 ±0.1
4.5 +0.5/-0
167
7
RB8532-25-0M9
25
41
0.94
6.7
3.0
11
2.65 ±0.1
5.0 +0.5/-0
282
7
RB8532-36-0M8
36
58
0.83
7.3
2.3
12
2.2 ±0.1
4.5 +0.5/-0
478
7
RB8532-50-0M3
50
82
0.33
3.1
1.2
12
2.5 ±0.1
5.0 +0.5/-0
442
7
Pin
Board
Test conditions:
Measuring frequency: 1 kHz; 500 μA >0.16 mH 1.6 mH
很抱歉,暂时无法提供与“RB6122-50-0M3”相匹配的价格&库存,您可以联系我们找货
