ACMA3225-510Y
ACMA3225-510Y
    KOHER(科或)
ACMA3225-510Y 数据手册
ACMA Series Common Mode Filters For Automotive Signal Line Size 3225 FEATURES ■ ■ ■ ■ Common mode filters for Signal Line 0 Compliant with AEC-Q200 Quan�ty: 2000pcs APPLICATION ■ CAN-BUS, FlexRay system Dimensions: [mm] 3 4 2.8 2 1.2 1 2.5max 3.2±0.2 0.75±0.2 Land Pattern: [mm] 2.4 2.5±0.2 3.7 0.55±0.15 Electrical Properties: Part No L @ 100kHz/0.1V (μH) Tol. IR Max. (mA) RDC Max. (Ω) VDC (Volts) IR (MΩ) ACMA3225-110Y 11 +50/-30% 300 0.4 80 10 ACMA3225-220Y 22 +50/-30% 250 0.5 80 10 ACMA3225-510Y 51 +50/-30% 200 0.7 80 10 ACMA3225-101Y 100 +50/-30% 150 1.5 80 10 ACMA3225-201Y 200 +30/-10% 70 5.5 80 10 IR KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com Typical Electrical Characteristics: ACMA3225-110Y 10000 Common Mode 100 10 1 0.1 1 10 100 1000 1000 100 10 1 10 FREQUENCY(MHz) 1 00000 ACMA3225-101Y 1 00000 1000 100 10 1 100 1000 10000 1 1 10 100 1000 10000 FREQUENCY(MHz) ACMA3225-201Y Common Mode 10000 IMPEDANCE(Ω) IMPEDANCE(Ω) 10000 1 Normal Mode FREQUENCY(MHz) Common Mode 100 Normal Mode 0.1 10000 Common Mode 10 1 Normal Mode ACMA3225-510Y 10000 1000 IMPEDANCE(Ω) IMPEDANCE(Ω) 1000 ACMA3225-220Y Common Mode IMPEDANCE(Ω) 10000 100 1000 FREQUENCY(MHz) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com 100 10 Normal Mode 10 1000 10000 1 1 Normal Mode 10 100 1000 10000 FREQUENCY(MHz) www.kohergroup.com
ACMA3225-510Y 价格&库存
很抱歉,暂时无法提供与“ACMA3225-510Y”相匹配的价格&库存,您可以联系我们找货
