HT331VRTZ
HT331VRTZ
    HTCSEMI(海天芯)
    SOT23-5
    HT331V/393V是一款高速、低功耗的比较器。在100mV过驱动电压下,其传播延迟为140ns。HT331V/393V通常为直流耦合,内部包含迟滞(5mV)以确保输出干净切换,迟滞电压的温度漂移超...
HT331VRTZ 数据手册
HT331V General-purpose low voltage comparator Features ■ Supply operation from 2.7 to 5 V ■ Low current consumption: 20 A ■ Input common mode range includes ground ■ Wide temperature range: -40°C to +85°C ■ Low output saturation voltage ■ Propagation delay: 200 ns ■ Open drain output ■ ESD tolerance: 2 kV HBM/200 V MM ■ SMD packages: SC70-5 and SOT23-5 Applications ■ Mobile phones ■ Notebooks and PDAs ■ Battery supplied electronics ■ General-purpose portable devices ■ General-purpose low voltage applications Description The HT331V is a single and low voltage version of industry standard HT339V and HT393V. It can operate with a supply voltage ranging from 2.7 to 5 V, and exhibits a lower current consumption than its predecessors HT339V and HT393V. This device is a perfect choice for low-voltage applications. HT331V SOT23-5/SC70-5 Pin connections (top view) IN + 5 VCC + 1 + VCC - 2 IN - 3 4 OUT The HT331V is designed to operate in the temperature range of -40°C to +85°C. It is then suitable for a large variety of applications. The device is available in both SOT23-5 and SC70-5 packages, making it ideal for applications where space saving is a constraint. The SC70-5 package is approximately half the size of the SOT23-5. Rev. 00 HT331V 1 Absolute maximum ratings and operating conditions Table 1. Symbol VCC Absolute maximum ratings Parameter Value Unit 5.5 V ± 5.5 V (VCC-) - 0.3 to (VCC+) + 0.3 V 205 250 °C/W 172 81 °C/W Supply voltage(1) (2) VID Differential input voltage VIN Input voltage range Rthja Thermal resistance junction to ambient(3) SC70-5 SOT23-5 Rthjc Thermal resistance junction to case SC70-5 SOT23-5 Tstg Storage temperature -65 to +150 °C Tj Junction temperature 150 °C Lead temperature (soldering 10 seconds) 260 °C Human body model (HBM)(4) 2000 TLEAD ESD Machine model (3) (MM)(5) Charged device model (CDM)(6) Latch-up immunity 200 V 1500 200 mA 1. All voltage values, except differential voltage, are referenced to Vcc-. 2. The magnitude of input and output voltages must never exceed the supply rail ±0.3 V. 3. Short-circuits can cause excessive heating. These values are typical. 4. Human body model: a 100 pF capacitor is charged to the specified voltage, then discharged through a 1.5 k resistor between two pins of the device. This is done for all couples of connected pin combinations while the other pins are floating. 5. Machine model: a 200 pF capacitor is charged to the specified voltage, then discharged directly between two pins of the device with no external series resistor (internal resistor < 5 ). This is done for all couples of connected pin combinations while the other pins are floating. 6. Charged device model: all pins and package are charged together to the specified voltage and then discharged directly to ground through only one pin. This is done for all pins. Table 2. Symbol Operating conditions Parameter Value Unit °C Toper Operating temperature range -40 to +85 VCC Supply voltage -40°C < Tamb < +85°C 2.7 to 5.0 V Rev. 00 HT331V 2 Electrical characteristics Table 3. VCC+ = +2.7 V, VCC -= 0 V, Tamb = +25°C, full VICM range (unless otherwise specified) (1) Symbol VIO VIO Parameter Test conditions Min. Input offset voltage Input offset voltage drift IIB Input bias current(2) IIO Input offset current(2) -40°C < Tamb < +85°C Typ. Max. Unit 1 7 mV V/°C 5 25 250 400 nA 1 50 150 nA -40°C < Tamb < +85°C -40°C < Tamb < +85°C -0.1 VICM Common mode input voltage V VOL Output voltage low ISINK = 1 mA ISINK Output sink current VOUT = 1.5 V ICC Supply current No load, output high, VICM =0V IOH Output current leakage TPHL Propagation delay High to low output level VICM =0 V, RL = 5.1 k CL = 50 pF Overdrive = 10 mV Overdrive = 100 mV 300 200 ns TPLH Propagation delay Low to high output level VICM = 0 V, RL = 5.1 k CL = 50 pF Overdrive = 10 mV Overdrive = 100 mV 550 400 ns 2.0 5 20 mV 47 mA 20 A 100 0.003 -40°C < Tamb < +85°C A 1 1. All values over the temperature range are guaranteed through correlation and simulation. No production tests have been performed at the temperature range limits. 2. Maximum values include unavoidable inaccuracies of the industrial tests. Rev. 00 HT331V Table 4. Symbol VIO VIO VCC+ = +5 V, VCC -= 0 V, Tamb = +25°C, full VICM range (unless otherwise specified)(1) Parameter Input offset voltage Input offset voltage drift IIB Input bias current(2) IIO Input offset current(2) Test conditions Min. Typ. Max. Unit 1 7 9 mV -40°C < Tamb < +85°C -40°C < Tamb < +85°C V/°C 5 25 250 400 nA 2 50 150 nA -40°C < Tamb < +85°C -40°C < Tamb < +85°C -0.1 VICM Common mode input voltage V 4.2 AV Voltage gain VOL Output voltage low ISINK < 4 mA -40°C < Tamb < +85°C ISINK Output sink current VOUT < 1.5 V ICC Supply current No load, output high, VICM = 0 V -40°C < Tamb < +85°C IOH Output current leakage TPHL Propagation delay High to low output level VICM = 0 V, RL = 5.1 k CL = 50 pF Overdrive = 10 mV Overdrive = 100 mV 375 275 ns TPLH Propagation delay Low to high output level VICM = 0 V, RL = 5.1 k CL = 50 pF Overdrive = 10 mV Overdrive = 100 mV 550 425 ns 20 50 50 10 V/mV 400 700 93 25 mA 120 150 0.003 -40°C < Tamb < +85°C mV A A 1 1. All values over the temperature range are guaranteed through correlation and simulation. No production tests have been performed at the temperature range limits. 2. Maximum values include unavoidable inaccuracies of the industrial tests. Rev. 00 HT331V Figure 1. Supply current versus supply voltage with output high Figure 2. Supply current versus supply voltage with output low Figure 3. Output voltage versus output current at 5 V supply Figure 4. Output voltage versus output current at 2.7 V supply Figure 5. Input bias current versus supply voltage Figure 6. Response time versus overdrive with negative transition Rev. 00 HT331V Figure 7. Response time versus overdrive with positive transition Figure 9. Response time versus overdrive with positive transition Figure 8. Response time versus overdrive with negative transition Rev. 00 HT331V 3.0 SOT23-5 package Figure 10. SOT23-5 package mechanical drawing Table 5. SOT23-5 package mechanical data Dimensions Ref. A Millimeters Inches Min. Typ. Max. Min. Typ. Max. 0.90 1.20 1.45 0.035 0.047 0.057 A1 0.15 0.006 A2 0.90 1.05 1.30 0.035 0.041 0.051 B 0.35 0.40 0.50 0.013 0.015 0.019 C 0.09 0.15 0.20 0.003 0.006 0.008 D 2.80 2.90 3.00 0.110 0.114 0.118 D1 1.90 0.075 e 0.95 0.037 E 2.60 2.80 3.00 0.102 0.110 0.118 F 1.50 1.60 1.75 0.059 0.063 0.069 L 0.10 0.35 0.60 0.004 0.013 0.023 K 0 degrees 10 degrees Rev. 00 HT331V 3.1 SC70-5 (SOT323-5) package Figure 11. SC70-5 (SOT323-5) package mechanical drawing SIDE VIEW DIMENSIONS IN MM GAUGE PLANE COPLANAR LEADS SEATING PLANE TOP VIEW Table 6. SC70-5 (or SOT323-5) package mechanical data Dimensions Ref Millimeters Min A Typ 0.80 A1 Inches Max Min 1.10 0.315 Typ 0.043 0.10 A2 0.80 b 0.90 Max 0.004 1.00 0.315 0.035 0.15 0.30 0.006 0.012 c 0.10 0.22 0.004 0.009 D 1.80 2.00 2.20 0.071 0.079 0.087 E 1.80 2.10 2.40 0.071 0.083 0.094 E1 1.15 1.25 1.35 0.045 0.049 0.053 e 0.65 0.025 e1 1.30 0.051 L 0.26 < 0° 0.36 0.46 0.010 0.014 0.039 0.018 8° Rev. 00 HT331V 4 Ordering information Table 7. Order codes Part number HT331VRTZ HT331VRCZ Temperature range -40°C, +85°C Package SOT23-5 SC70-5 Packaging Tape & reel Tape & reel Marking R11 R12_ Rev. 00
HT331VRTZ 价格&库存
很抱歉,暂时无法提供与“HT331VRTZ”相匹配的价格&库存,您可以联系我们找货
