5500F1 0101000
5500F1 0101000
    BELDEN
5500F1 0101000 数据手册
Product: 5500F1 Security & Sound, #22-2c, TC, Shielded, CM, Water-Blocked Product Description Security & Sound Cable, Rated-CM, 2-22 AWG stranded tinned copper conductors with PVC insulation, waterblocking tape, Beldfoil® shield and PVC jacket with ripcord Technical Specifications Product Overview Suitable Applications: Security System, Intercom/PA, Audio/Speaker, Power-Limited Controls, Noisy & Wet Location, Below-Grade Duct Construction Details Conductor Element Number of Element Size Stranding Conductor(s) 2 22 7x30 Material TC - Tinned Copper Insulation Material Nom. Thickness Nom. Insulation Diameter Color Code PVC - Polyvinyl Chloride 0.011 in (0.28 mm) 0.04 in (1.0 mm) Black, Red Outer Shield Shield Type Tape Material Coverage Bi-Laminate (Alum+Poly) 100% Drainwire Type 24 AWG (7x32) TC Table Notes: Non-woven waterblocking tape Waterblocking: Waterblock Tape Outer Jacket Material Nom. Thickness Nom. Diameter Ripcord PVC - Polyvinyl Chloride 0.025 in (0.64 mm) 0.196 in (4.98 mm) Yes Electrical Characteristics Electricals Nom. Conductor DCR Nom. Capacitance Cond-to-Cond Nom. Capacitance Cond-to-Other (Conds + Shield) 17.8 Ohm/1000ft 46 pF/ft (150 pF/m) Voltage UL Voltage Rating 300 V Mechanical Characteristics Temperature UL Temperature 105°C Operating -20°C To +105°C Bend Radius Stationary Min. Installation Min. 82.8 pF/ft (272 pF/m) Max. Current 2.8 Amps per Conductor at 25ºC 1.96 in (49.8 mm) 1.96 in (49.8 mm) Max. Pull Tension: 19 lbs (8.6 kg) Bulk Cable Weight: 15 lbs/1000ft Standards and Compliance Environmental Suitability: Indoor, Outdoor Sustainability: Product Lens™, Environmental Product Declaration (EPD) Available Flammability / Reaction to Fire: UL1685 UL Loading, IEC 60332-1-2 CPR Compliance: CPR Euroclass: Eca NEC / UL Compliance: Article 800, CM CEC / C(UL) Compliance: CM European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU (RoHS 2 amendment), EU Directive 2011/65/EU (RoHS 2), EU Directive 2012/19/EU (WEEE) UK Regulation Compliance: UKCA Mark APAC Compliance: China RoHS II (GB/T 26572-2011) History Update and Revision: Revision Number: 0.364 Revision Date: 01-04-2023 Part Numbers Variants Item # Color UPC 5500F1 0101000 Black 612825162872 5500F1 0081000 Gray 612825162865 © 2023 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
5500F1 0101000 价格&库存
很抱歉,暂时无法提供与“5500F1 0101000”相匹配的价格&库存,您可以联系我们找货
