HK 3FF
SUBMINIATURE HIGH POWER RELAY
Features
● 15A switching capability
● 1 Form A &C configurations
● Subminiature, standard PCB layout
● Plastic sealed and flux proofed types available
● Environmental friendly product (RoHS compliant)
● Outline Dimensions: (19.0 x 15.5 x 15.8) mm
■ CONTACT DATA
Contact Form
Contact Material
Contact Ratings
1A, 1C
Silver Alloy
10A 277VAC 30VDC
Max Switching Voltage
Max Switching Current
16VDC
15A
Max Switching Power
2770VA 210W
Contact Resistance
100MΩ(at 1A 6VDC)
Electrical Life
1X105Ops(30Ops/min)
Mechanical Life
1X107Ops(300Ops/min)
■ GENERAL DATA
Insulation Resistance
Operate Time
100MΩ 500VDC
1500VAC 1min
750VAC 1min
Max. 10ms
Release Time
Max. 5ms
Between coil & contacts
Between open contacts
Dielectric Strength
- 40℃ to +70℃
Temperature Range
Functional
Shcok Resistance
98m/s2 (10g)
Destructive
980m/s2 (100g)
10 to 55Hz 1.5mm
35% to 85% RH
Approx. 10g
CUL TüV CQC
Vibration Resistance
Humidity
Weight
Safety Standard
■ COIL DATA
Nominal Voltage
(VDC)
Coil Resistance at 20℃ ± 10%(Ω)
Max Operate Voltage
(VDC)
Min Release Voltage
(VDC)
Max Applicate Voltage
(VDC)
3
0.36W
25
0.45W
0.3
3.9
5
70
55
3.75
0.5
6.5
6
100
80
4.50
0.6
7.8
9
225
180
6.75
0.9
11.7
12
400
320
9.00
1.2
15.6
24
1600
1280
18.00
2.4
31.2
48
6400
5100
36.00
4.8
62.4
1
ORDERING INFORMATION
HK3FF
- DC
6V
- S D
X
X
X
Special request code
G: RoHS
Mounting termination
NIL:PCB
Contact Form
1C 1A 1B NIL:1C
Coil Power
H:0.36W D:0.45W
Type of Sealing
NIL: Flow Solder Type
S: Plastic Sealed Type
Coil Voltage
3V,5V,6V,9V,12V,24V,48V
Coil Type
DC
Type
HK3FF
OUTLINE DIMENSIONS, WIRING DIAGRAM AND PCBOARD LAYOUT
Outline Dimensions
Unit: mm
PCB Layout
Wiring Diagram
(Bottom view)
19
6
6
15.8
16.2
1 Form A
(Bottom view)
4-φ1.3
15.5
0.3
2
0.4
4
12.2
3.4
1
5-φ1.3
19
6
15.8
1 Form C
16.2
6
15.5
2
0.3
4
12.2
3.4
0.4
1
Remark: 1) In case of no tolerance shown in outline dimension: outline dimension ≤1mm, tolerance should be ±0.2mm; outline dimension >1mm
and≤5mm, tolerance should be ±0.3mm; outline dimension >5mm, tolerance should be ±0.4mm.
2) The tolerance without indicating for PCB layout is always ±0.1mm.
2
CHARACTERISTIC CURVES
AC(1H)
15
10
AC(1Z)
DC(1Z,1H)
1
250VAC/30VDC Resistiwe Load
100
50
1HT type
1ZT,1H type
10
COIL TEMPERATURE RISE
Temperature rise (K)
100
ENDURANCE CURVE
Operations (X10000 OPS)
Contact Current (A)
MAXIMUM SWITCHING POWER
70
60
50
10A
40
5A
30
1Z type
5
0A
100
1000
Contact Voltage (V)
10
15
Contact Current (A)
90
100
110
120
130
Percentage Of Nominal Coil Voltage
(Relay mounting distance should
be less than 10mm.)
Disclaimer
This datasheet is for the customers’ reference. All the specifications are subject to change without notice.
We could not evaluate all the performance and all the parameters for every possible application. Thus the user should be in a tight position
choose the suitable product for their own application. lf there is any query, please contact Ever-way for the technical service. However, it is the
user’s responsibility to determine which product should be used only.
COPYRIGHT 2011© NINGBO BOLE INTL CO.,LTD. | EVER-WAY INDUSTRY COMPANY LIMITED
3
很抱歉,暂时无法提供与“HK3FF-DC12V-SHG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.82320
- 10+3.11040
- 30+2.79720
- 100+2.20320
- 500+2.04120
