EA OLEDL128-6LGA
EA OLEDL128-6LGA
    ELECTRONICASSEMBLYGMBH
EA OLEDL128-6LGA 数据手册
EA OLEDL128-6 INCL CONTROLLER SSD1309 FOR SPI AND I²C Dimension 68x51x3.3mm FEATURES          128X64 DOTS (RELATES TO 8x21 CHARACTER OR 4x16 LARGE CHARACTER) HIGH CONTRAST OLED DISPLAY INTEGRATED CONTROLLER SSD1309 SPI INTERFACE: MOSI, CLK, CS, D/C I²C INTERFACE: SDA, SCL WIDE TEMPERATURE RANGE (TOP -40°C - +80°C) NO MOUNTING REQUIRED: JUST PUT INTO PCB 3 VERSIONS (WITH / W.O. POLARISOR AND PROTECTION GLASS) IN VARIOUS COLORS) FAST RESPONSE TIME, NO AFTERGLOW ORDERING CODES      GRAPHIC 128x64, yellow, black background, incl. protection glass GRAPHIC 128x64, yellow, black background, w./o. protection glass GRAPHIC 128x64, white, black background, w./o. protection glass WITH A MINIMUM ORDER QTY. OF 10,000 PCS. GRAPHIC 128x64, yellow, silver background, w./o. protection glass GRAPHIC 128x64, with Polariser (Standard) x: E = Green B = Blue EA OLEDL128-6GGA EA OLEDL128-6LGA EA OLEDL128-6LWA EA OLEDL128-6NGA EA OLEDL128-6LxA ACCESSORIES       TEST BOARD WITH USB-INTERFACE SOCKET 4.8mm HOCH (2 PCS. ARE REQUIRED) TOUCHPANEL, 4-WIRE ANALOGUE SELF-ADHESIVE TOUCHPANEL, PCAP, SELF-ADHESIVE ZIFF CONNECTOR FOR TOUCH, BOTTOM CONTACT ZIFF CONNECTOR FOR TOUCH, BOTTOM CONTACT *) EA 9781-2USB EA FL-20P EA TOUCH128-2*) EA TOUCH128-29C1 EA WF100-04S EA WF100-06S ONLY IN COMBINATION WITH EA OLEDL128-6GGA. DISPLAY VISIONS GmbH Zeppelinstraße 19 D-82205 Gilching Germany Fon: +49 (0)8105-7780 90 Fax: +49 (0)8105-7780 99 e-Mail: info@lcd-module.de Web: www.lcd-module.com Issue 02.2022 EA OLEDL128-6 EA OLED SERIES With its EA OLED series DISPLAY VISIONS launches worldwide the first display family with OLEDtechnology for direct mounting and soldering. In comparison to standard displays there’s no FFC/FPC cable/connector that may loose contact, this OLED series will be soldered directly or put into a standard 2.54 mm precision socket. It is designed for compact handheld equipment and provides a lot real advantages: - Extreme compact (68x51mm) with a large viewing area (64x37mm) - Super flat with 2.4 mm (without frontal protection glass) - SPI and I²C interface - Simple mounting with direct soldering - Ex stock available from 1 pc. off - Long life time (>50,000 h for yellow) - Extreme wide temperature range (-40..+80°C) - Fast response time (10µs), no afterglow VERSIONS The EA OLEDL128-6 is available in 3 different versions: EA OLEDL128-6GGA / Allround This module is perfect for rough environment. An additional frontal glass protects the display against scratch, shock and UV light. Thanks to its integrated polariser there’s no need for an additionally smoked glass. EA OLEDL128-6LGA / Flat This module is the standard module and does fit for the most applications. The flat design (2.4 mm) makes the display perfect for smallest equipment. The background is always deep black for best contrast. EA OLEDL128-6NGA / Design solution (custom made) This version is to become favourite for assembly behind a smoked glass. There’s no protection glass or polariser which makes it with 2.4mm very flat. The advantage is a doubled brightness which makes it perfect in combination with the smoked glass. We recommend to put it behind a fully smoked glass front to make only the graphic visible, no edges, no print, no overhang and hygienic to clean. COLORS (CUSTOM MADE) The standard colors are yellow and white. The flat version EA OLEDL128-6LGA is on customers request available in 3 more colors. The minimum order quantity is 10,000 pcs., lead time is about 20 weeks. Samples are available on request. Interface and software are 100% compatible. The yellow color provides highest brightness and longest life time. EA OLEDL128-6LEA EA OLEDL128-6LBA Printing and typographical errors reserved. DISPLAY VISIONS reserves the right to change specification without prior note. Page 2 EA OLEDL128-6 APPLICATION EXAMPLES 4-Wire SPI 3-Wire SPI I²C Address 0x78 I²C Address 0x7A VCC – Generation: 12 V (FAN5331, LT1935) Printing and typographical errors reserved. DISPLAY VISIONS reserves the right to change specification without prior note. Page 3 EA OLEDL128-6 DATA TRANSFER 4-WIRE SPI (8 BIT) Data transmission for SPI is unidirectional, that means that data can only be written, there’s no data read option. Selection for writing data or command is done with the D/C line. A busy check is not necessary at all. Clock rate may be up to 10 MHz. Data transmission is based on SPI mode 3, MSB first. For more details please refer to the controllers data sheet SSD1309. DATA TRANSFER 4-WIRE SPI (9 BIT) Data transmission for SPI is unidirectional, that means that data can only be written, there’s no data read option. Selection for writing data or command is done with the first bit of the 9 bit data transfer. A busy check is not necessary at all. Clock rate may be up to 10 MHz. Data transmission is based on SPI mode 3, MSB first (9 bit). For more details please refer to the controllers data sheet SSD1309. DATA TRANSFER I²C The I²C mode provides a bi-directional data transmission: That means that data can be written and read. With the pin SA0 the I²C address can be changed (L: 0x78 or 0x3C, H:0x7A or 0x3D), so up to 2 displays may be driven on 1 bus. The clock rate may be up to 400 KHz. Please make sure when defining the pull-up resistors that the internal resistance of the display is 600..1000 . This affects the low level when reading data and ACK bit. Attention: When reading data, after the command for page- or column address there need to be a dummy read (discard the first byte). Control byte: Co (Continuation bit) = 0  Display data do follow; 1  refer D/C bit t Printing and typographical errors reserved. DISPLAY VISIONS reserves the right to change specification without prior note. Page 4 EA OLEDL128-6 GRAPHIC RAM The EA OLEDL128-6 comes with an integrated display RAM. Each byte represents 8 dots. For more details please refer to the controllers data sheet SSD1309, available on our website at http://www.lcd-module.de/fileadmin/eng/pdf/zubehoer/ssd1309.pdf. COMMAND TABLE (ABSTRACT) This is a collection of the most important commands. The data sheet SSD1309 provides the full list plus a detailed description. Command Contrast Control D/ C 0 0 Hex 81 7F D7 1 A7 Command Code D6 D5 D4 D3 0 0 0 0 A6 A4 A5 A3 D2 0 A2 D1 0 A1 D0 1 A0 Display On / Off 0 AE/ AF 1 0 1 0 1 1 1 X0 Set Column address 0 0 0 21 0 7F 0 A7 B7 0 A6 B6 1 A5 B5 0 A4 B4 0 A3 B3 0 A2 B2 0 A1 B1 1 A0 B0 Set Page 0 address 0 0 22 0 7 0 X X 0 X X 1 X X 0 X X 0 X X 0 A2 B2 1 A1 B1 0 A0 B0 Display Start Line 0 40 – 7F 0 1 A5 A4 A3 A2 A1 A0 Segment remap 0 A0/ A1 1 0 1 0 0 0 0 X0 Com output scan direction 0 C0/ C8 1 1 0 0 X3 0 0 0 RAM Data 1 XX D7 D6 D5 D4 D3 D2 D1 D0 Description Double byte command to select 1 out of 256 contrast steps. Contrast increases as the value increases. X0=0: Display OFF (sleep mode) (RESET) X0=1: Display ON in normal mode Setup column start and end address A[7:0] : Column start address, range : 0-127d, (RESET = 0) B[7:0]: Column end address, range : 0-127d, RESET = 127) Note: This command is only for horizontal or vertical addressing mode. Setup page start and end address A[2:0] : Page start Address, range : 0-7d, (RESET = 0) B[2:0] : Page end Address, range : 0-7d, (RESET = 7) Note: This command is only for horizontal or vertical addressing mode. Set display RAM display start line register from 0-63 using X5X3X2X1X0. Display start line register is reset to 0 during RESET. X0=0: column address 0 is mapped to SEG0 (RESET) X0=1: column address 127 is mapped to SEG0 X3=0: normal mode (RESET) Scan from COM0 to COM[N –1] X3=1: remapped mode. Scan from COM[N-1] to COM0 Where N is the Multiplex ratio D7-D0 is written to RAM. Printing and typographical errors reserved. DISPLAY VISIONS reserves the right to change specification without prior note. Page 5 EA OLEDL128-6 INITIALISATION EXAMPLE void init_OLEDL128(void)  {    send_command(0x40);    send_command(0xA0);    send_command(0xC0);    send_command(0xA6);    send_command(0x81); send_command(0xFF);    send_command(0xD5); send_command(0x40);    send_command(0xD9); send_command(0x44);    send_command(0xAF);  }    //Set Display start line  //Bottom View no Segment remap  //Bottom View COM scan direction normal  //Display normal (RAM)  //Set contrast to maximum  //Clock divider/Oscillator frequency  //Pre‐charge Period  //Display on  ACCESSORY: SOCKET EA FL-20P Using a 20-pin socket makes the display replaceable and adapts the height. Those socket may also be soldered automatically by wave soldering or reflow process. Each display requires 2 pcs. Printing and typographical errors reserved. DISPLAY VISIONS reserves the right to change specification without prior note. Page 6 EA OLEDL128-6 ACCESSORY: TOUCHPANEL EA TOUCH128-2 As an accessory there is an analogue touchpanel available. It comes with a self-adhesive glue on its rear side. Connection is done via FFC, pitch 1.0 mm. Any standard ZIFF connector can be used (e.g. EA WF100-04S). Bending radius is minimum 5 mm. Interfacing to a processor can be either done by an external touch panel controller or with a controller that is featured with analogue input. The touch panel is similar to a potentiometer: connecting a voltage of e.g. 3.3 V to the pins Top-Bottom makes it possible to read out a voltage on pin Left or Right which is linear to the Y-coordinate of Specification Value min max Unit the pressed point. The Top-Bottom 100 400 Ω X-coordinate will result Left-Right 110 410 Ω when the voltage will Voltage 3 12 V Current 5 25 mA be supplied to LeftLinearity 1,5 % Right and Force 45 65 G Contact Bounce 5 10 Ms measurement is done Top. -20 +60 °C at Top or Bottom. The TStor. -20 +70 °C pinout of the connecting cable is shown in the drawing. Transmission 75 85 % Lifetime 10000 Cycles Only in combination with the EA OLEDL128-6GGA. TOUCHPANEL EA TOUCH128-29C1 (PCAP, CAPACITIVE) As an accessory we provide a suitable, capacitive touch panel (PCAP). It comes already with controller (FT5316) and integrated I²C bus. It supplies the coordinates in resolution 128x64 directly. The line INT shows, if data are available to be read out. The I²C bus address is 0x70. For connection there is a ZIF connector with pitch 1.0 mm, e.g. EA WF100-06S. Printing and typographical errors reserved. DISPLAY VISIONS reserves the right to change specification without prior note. Pinout Pin 1 2 3 4 5 6 Name SCL SDA VDD RES INT GND Description Int. 4k7 Pull-up Int. 4k7 Pull-up H L Internal Pull-up L Page 7 EA OLEDL128-6 ACCESSORY: ZIFF CONNECTOR EA WF100-04S The ZIFF connector matches perfect to the touch panel EA TOUCH128-2. It provides 4 pins with 1.0 mm pitch. Connection is bottom contact. The top contact version is called EA WF100-04T. USB-TEST BOARD EA 9781-2USB For easy startup, a USB test board is available that can be connected to a PC. A USB cable and Windows software is supplied with the product. It allows text and images (BMP) to displayed directly on the connected display. The board provides many connectors matching different OLED displays from DISPLAY VISIONS. You will find more information on the test board in the data sheet EA 9781-2USB. SIMULATION WITH WINDOWS A little software tool called "OLED Simulator" shows the OLED display with individual content. It also drives the USB test board with the real display to show same content. You can download the software free from our website. Note that all functions of the simulation software do run also without the USB board. https://www.lcd-module.de/fileadmin/downloads/startoled_v20.zip Printing and typographical errors reserved. DISPLAY VISIONS reserves the right to change specification without prior note. Page 8 EA OLEDL128-6 ELECTRICAL SPECIFICATION Unless otherwise specified, VSS = 0V , VDD = 1.8 - 3.3V ( Ta = 25℃) Value Condition Operating Temperature Storage Temperature Storage Humidity Operating Voltage VDD logic supply Operating Voltage VCC OLED supply High Logic input level Low Logic input level Power Supply 1) 2) min max Unit +80 +80 90 °C °C %RH 3.0 3.3 V 12.5 13.0 V -40 -40
EA OLEDL128-6LGA 价格&库存
很抱歉,暂时无法提供与“EA OLEDL128-6LGA”相匹配的价格&库存,您可以联系我们找货
