USB1030-GF-P-B-B
USB1030-GF-P-B-B
    GCT
USB1030-GF-P-B-B 数据手册
2.50 3.00 H G 12.04 Rear Shield 2.50 3.50 2 1 3 4 10 4.71 4.71 2x Ø0.92±0. 2.71 10 0. 10.30 REF ± 30 2. 2x 10.30 REF 2.71 F Specifications 规格: E 12.10 Front Shield Materials & Plating 物料与电镀: Plastic Housing 塑胶外壳: Thermoplastic, PBT, Glass Fibre Filled, UL94V-0 热塑性塑料, PBT; 玻纤填充,UL94V-0 Contact Terminal 接触端子: Brass (t=0.25mm) 黄铜 Metallic Shell 金属外壳: Brass 黄铜 Metallic Shell Rear 金属外壳后: Steel 钢 Finish表面处理: Underplating 底层电镀: 50µ" Nickel 50µ" 镍 Plating 电镀: Contact Area 接触面积: Gold Flash or 15µ" Gold 闪金或15µ"金 Solder Tails 焊接末端: 50µ" Tin 50µ" 锡 Metallic Shell 金属外壳: Nickel 镍 P.C.B. EDGE RECOMMENDED P.C.B LAYOUT THICKNESS: 1.6mm GENERAL TOLERANCE: ±0.05 2 1 3 4 5.22 0.50 D AS VIEWED FROM COMPONENT SIDE Solder Area Component Outline 3.18 10.95 5.60 Ordering Grid USB1030 C XX P Contact Plating GF = Gold Flash (Standard) 15 = 15µ" Gold X B Request Samples and Quotation Electrical 电气规格: Voltage Rating电压额定值: 30V Current Rating电流额定值: 1.5A Operating Temperature 工作温度: -40°C to +85°C Contact Resistance接触电阻值: 30m Max. Insulating Resistance绝缘电阻值: 1000M Min. Dielectric Withstand Voltage耐电压: 500V AC Packing Options B = Tray (100 per tray) Insulator Colour B = Black (Standard) 16.20 Insulator Material P = PBT Mechanical 机械性规格: Mating Force插入力: 35N (3.57Kgf) Max. Unmating Force拨出力: 10N (1.02Kgf) Min. Durability耐久性: 1,500 Cycles 1500次插拨 B Part Number Product Description USB1030 USB Receptacle, Type B, 4 Pin, Through Hole, R/A, Top Mount, With Kinked Shell Stakes Drawing Date 14th February 2011 A By Detail Revision Date 1 2 3 4 5 CC USB1030 B PCN B1 05/12/16 Tolerances (Except as Noted) Length Angle X.X ± 0.35 X.XX ± 0.25 X.° ± 1° X.X°. ± 0.5° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By SA 8 Sheet No. 1/2 PE Film PE膜 H 1 3 USB PCS/Tray Trays/Carton PCS/Carton Products P/N G USB1030-XX-P-X-B 100 10 1000 Base 下盖 F Packing Rules封裝規則﹕ 1.USB's placed into the tray base. 将USB连接器放入吸塑盘内 2.Tray cover and base taped together to keep USB's in place. USB连接器放好后,加上吸塑盖,并用胶带缠绕好 3.10 trays put into carton. 10吸塑盘一叠,放入纸箱 4.Boxed taped and label stuck on the outer carton. 用胶带封住纸箱;并贴上标签。 5 trays taped together 5盘叠加 2 sets per box 每盒2套 E 2 EPE 珍珠棉 Cover 上盖 10 Trays per box 每盒10盘 标签 PE bag PE袋 D Base 下盖 EPE 珍珠棉 RoHS Label 环保标签 Product Label 产品标签 4 Label 标签 160 C Tape 膠帶 B 31 5 27 0 Inner Carton 內箱 Part Number Product Description USB1030 USB Receptacle, Type B, 4 Pin, Through Hole, R/A, Top Mount, With Kinked Shell Stakes Drawing Date 14th February 2011 A By Detail Revision Date 1 2 3 4 5 CC USB1030 B PCN B1 05/12/16 Tolerances (Except as Noted) Length Angle X.X ± 0.35 X.XX ± 0.25 X.° ± 1° X.X°. ± 0.5° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By SA 8 Sheet No. 2/2
USB1030-GF-P-B-B 价格&库存
很抱歉,暂时无法提供与“USB1030-GF-P-B-B”相匹配的价格&库存,您可以联系我们找货
USB1030-GF-P-B-B
