30FLT-SM1-TB
30FLT-SM1-TB
    JST
30FLT-SM1-TB 数据手册
FLT CONNECTOR Emboss Emboss Tape Tape NON- 0.5 mm pitch/Connectors for FPC FLT CONNECTOR Specifications • Current rating: 0.5 A AC/DC • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 50 mΩ max. After environmental tests/ 20 mΩ max. (variation from initial value) • Insulation resistance: 500 MΩ min. • Withstanding voltage: 200 VAC/minute • Applicable FPC: Conductor pitch/ 0.5 mm Conductor width/ 0.35 mm Mating part thickness/0.3 ± 0.05 mm Note: FPC to be actually used should be checked for applicability. * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. ●H  eat resisting design suitable for surface mounting ● Staggered surface mount tails ● Embossed tape for automatic mounting ● FPC insertion is easy ● Compact design ® ® ® Standards ® ® Recognized E60389 PC board layout and Assembly layout 1.0±0.05 Circuit No.1 2.95 1.6 0.5 Note: 1. The above figure is the figure viewed from the connector mounting side.  2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. The dimensions above should serve as a guide line. Contact JST for details. 1 4.15 4.0 1.6 0.5±0.05 FLT CONNECTOR Connector A B Circuit No.1 C 1.0 2.95 0.15 4.0 0.5 3.4 Dimensions (mm) A B C Q'ty/ reel 06FLT-SM2-TB 4.9 3.5 2.5 2,500 08FLT-SM2-TB 5.9 4.5 3.5 2,500 6.9 5.5 4.5 2,500 7.9 6.5 5.5 2,500 14FLT-SM2-TB 8.9 7.5 6.5 2,500 16 16FLT-SM2-TB 9.9 8.5 7.5 2,500 18 18FLT-SM2-TB 10.9 9.5 8.5 2,500 20 20FLT-SM2-TB 11.9 10.5 9.5 2,500 22 22FLT-SM2-TB 12.9 11.5 10.5 2,500 24 24FLT-SM2-TB 13.9 12.5 11.5 2,500 26 26FLT-SM2-TB 14.9 13.5 12.5 2,500 28 28FLT-SM2-TB 15.9 14.5 13.5 2,500 30 30FLT-SM2-TB 16.9 15.5 14.5 2,500 32 32FLT-SM2-TB 17.9 16.5 15.5 2,500 40 40FLT-SM2-TB 21.9 20.5 19.5 2,500 No. of circuits Model No. 6 8 10 10FLT-SM2-TB 12 12FLT-SM2-TB 14 FLT CONNECTOR Material and Finish Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PA 6T, UL94V-0 RoHS2 compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed-tape. Lead section dimensions of FPC 0.5×(N+1)±0.05 0.5±0.1 0.5×(N-1)±0.03 0.5±0.03 0.35±0.04 0.3±0.05 (5.5) 3.0 min. Reinforcing layer Note: N --- Number of circuits 2
30FLT-SM1-TB 价格&库存
很抱歉,暂时无法提供与“30FLT-SM1-TB”相匹配的价格&库存,您可以联系我们找货
