NBC-20-472-D
NBC-20-472-D
    COSEL
    NBC-20-472-D
NBC-20-472-D 数据手册
Single phase input type (2-Stage filter) NBC/NBM series Ordering information NBC -10 -472 -O 1 2 3 4 1 Series Name 2 Rated Current 3 Line to ground capacitor code: Refer to table 1.1. R Code 000 101 221 331 471 681 102 222 332 472 ● ● ● ● ● NBM NBC table1.1 Line to ground capacitor code ● ● ● ● ● Line to ground Leakage Current capacitor (Input 125/250V 60Hz) (nominal value)   5 A / 10 A max Not Provided 12.5 A / 25 A max  100pF 25 A / 50 A max  220pF 37.5 A / 75 A max  330pF 50 A / 100 A max  470pF 75.5 A / 150 A max  680pF   0.13 mA / 0.25mA max 1,000pF   0.25 mA / 0.5  mA max 2,200pF   0.38 mA / 0.75mA max 3,300pF   0.5 mA / 1.0  mA max 4,700pF When the line to ground capacitor code is * DIN rail installation type is option The terminal cover is retracted inside the unit different, the attenuation characteristic is different. 4 Option D :DIN rail installation type * The dimensions change when the option is set. Refer to External view. Features of NBC/NBM series -Single Phase 250VAC (2-Stage filter) Quick and easy push-down terminal - Just connect the wires, push-down and tighten the screws with a screwdriver NBC : High-attenuation type from 150kHz to 1MHz NBM : Low leakage current, Withstand voltage 4,000 VAC Specifications No. Items 1 2 Rated Voltage[V] Rated Current[A] 3 Test Voltage (Terminal-Mounting Plate) 4 5 6 7 8 9 10 11 12 13 14 Isolation Resistance (Terminal-Mounting Plate) Leakage current Voltage drop Safety agency approval temperatures Operating temperature Operating humidity Storage temperature/humidity Vibration Impact Safety agency approvals Case size (without projection) /Weight NBC-06-472 NBC-10-472 NBC-16-472 NBC-20-472 NBC-30-472 NBM-06-471 NBM-10-471 NBM-16-471 NBM-20-471 NBM-30-471 AC 1f 250 / DC250 6 10 16 20 30 NBC : 2,500 VAC (Cutoff Current = 20mA), 1minute at room temperature and humidity NBM : 4,000 VAC (Cutoff Current = 20mA), 1minute at room temperature and humidity 500 VDC 100MW min at room temperature and humidity Refer to table 1.1 1.0V max -25 to +85C (Refer to Derating Curve) -40 to +85C (Refer to Derating Curve) 20 to 95%RH (Non condensing) -40 to +85C/20 to 95%RH (Non condensing) 10 to 55Hz, 19.6m/s2 (2G), 3min. Period, 1hour each X, Y and Z axis 196.1m/s2 (20G), 11ms Once each X, Y and Z axis UL1283, CSA C22.2 No.8 (C-UL), DIN EN60939 VDE0565 Teil3-1, ENEC (At only AC input) 53X41X92 mm [2.09X1.61X3.62 inches] (WXHXD) /270g max (Option : -D refer to external view) Circuit Diagram Derating Curve Case 1 LINE LI INE 2 CY C Y C Y CY Load Factor [%] 100 3 LOAD L OAD 4 80 60 40 20 0 -40 -30 -20 40 50 55 60 Ambient Temperature [C] CY C Y : Line to ground capacitor NB-3 : Mounting Plate July 21, 2022 70 80 90 NBC/NBM series External view This product is shipped in the following condition, because it is equipped with push-down terminals. 1The terminal cover is retracted inside the unit. 2The screws for connecting the terminals are held in the up right position. Standard Type 92 [3.62] 2.5 82 ±0.5 [3.23] 2-f4.8 2-Protection Earth 80 [0.19] Mounting Hole 30.5 [0.1] [1.2] [1.77] [2.09] [0.47] 53 Output Terminal Name Plate 15 45 ±0.5 Input Terminal [0.59] 8 [0.31] [3.15] 12 Output Terminal Input Terminal 6-M4 2 ¶ Closed the terminal cover [0.08] Mounting Plate Terminal cover Terminal cover ¶ Tolerance : ±1 [±0.04] 41 [1.61] ¶ Weight : 270g max ¶ Mounting Plate : Iron (surface finishing:nickel plating) t=1.0 [0.04] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches ¶ Terminal block screw tightening torque M4:1.6N-m (16.9kgf-cm) max DIN rail installation Type 92 8.2 ±1.5 80 2-Protection Earth [3.62] [0.32] [3.15] 2.5 30.5 [0.1] [1.2] 8 [0.31] Input Terminal 12 [0.47] 53 15 [0.59] Output Terminal Input Terminal 6-M4 Terminal cover Mounting Plate 2 [0.08] Terminal cover [2.09] Output Terminal Name Plate ¶ Closed the terminal cover 41 [1.61] ¶ Tolerance : ±1 [±0.04] ¶ Weight : 270g max ¶ Mounting Plate : Iron (surface finishing:nickel plating) t=1.0 [0.04] ¶ Case : PBT ]=inches ¶ Terminal block screw tightening torque M4:1.6N-m (16.9kgf-cm) max 7 [0.28] (9) [0.35] ¶ Dimensions in mm, [ DIN rail ¡Note when installing the EMI/EMC Filter on a DIN rail. When the EMI/EMC Filter is grounded through the DIN rail, the proper noise attenuation may not be achieved. Be sure to connect the protection earth (PE) of the EMI/EMC Filter body to the earth. At least one PE connection is required. DIN rail Name Plate July 21, 2022 NB-4
NBC-20-472-D 价格&库存
很抱歉,暂时无法提供与“NBC-20-472-D”相匹配的价格&库存,您可以联系我们找货
NBC-20-472-D
    • 1+812.58120
    • 200+324.22680
    • 500+313.39440
    NBC-20-472-D
    • 1+451.019601+58.63110
    • 10+406.0422010+52.78420
    • 25+393.9444025+51.21150
    • 50+387.2727050+50.34420
    • 100+376.57630100+48.95370
