RS2M
RS2M
    DOESHARE(德芯)
RS2M 数据手册
RS2A THUR RS2M RS2A THUR RS2M 2.0 AMP SURFACE MOUNT FAST RECOVER RECTIFIERS SMB/DO214AA General description 2.0 AMP SURFACE MOUNT FAST RECOVER RECTIFIERS FEATURES • The plastic package carries Underwriters Laboratory • Flammability Classification 94V-0 • For surface mounted applications • Low reverse leakage • Built-in strain relief, ideal for automated placement • High forward surge current capability High temperature soldering guaranteed: • 250 C/10 seconds at terminals MECHANICAL DATA • Case: JEDEC DO-214AA molded plastic • Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 • Polarity: Color band denotes cathode end Mounting • Position: Any • Weight :0.005 ounce, 0.138 grams Rating 25 C ambient temperature unless otherwise specified. TYPE NUMBER SYMBOLS RS2A RS2B RS2D RS2G RS2J RS2K RS2M UNITS RS2A RS2B RS2D RS2G RS2J RS2K RS2M N/A Marking Code Mark Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current at TL=90 C I(AV) 2.0 A IFSM 50.0 A VF 1.3 V IR 5.0 50.0 µA Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Maximum reverse recovery time (NOTE 1) 150 Typical junction capacitance (NOTE 2) pF RθJA 20 ℃/W TJ,TSTG -55 to +150 ℃ Resistance Junction to Lead. www.doeshare.net nS 50.0 Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal 500 CJ Typical thermal resistance (NOTE 3) Operating junction and storage temperature range 250 RS2A THUR RS2M Rating And Characteristic Curves www.doeshare.net RS2A THUR RS2M Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
很抱歉,暂时无法提供与“RS2M”相匹配的价格&库存,您可以联系我们找货
