PT2041AT6
PT2041AT6
    PINTENG(品腾科技)
    SOT23-6
PT2041AT6 数据手册
PT2041A 规格书 目 录 1. 产品概述 .................................................................................................................................. 2 2. 主要特性 .................................................................................................................................. 2 3. 系统框图 .................................................................................................................................. 2 4. 封装及引脚说明 ........................................................................................................................ 3 5. 功能描述 .................................................................................................................................. 5 5.1 输出模式和选项脚位 .......................................................................................................... 5 5.2 按键最长输出时间 ............................................................................................................. 5 5.3 低功耗模式 ........................................................................................................................ 5 5.4 灵敏度调整 ........................................................................................................................ 5 6. 应用电路 .................................................................................................................................. 6 7. 电气特性 .................................................................................................................................. 7 7.1 电气特性极限参数 ............................................................................................................. 7 7.2 直流特性 ........................................................................................................................... 7 8. 封装信息 .................................................................................................................................. 8 8.1 SOT23-6封装 .................................................................................................................... 8 8.2 DFN2x2-6L封装尺寸 .......................................................................................................... 9 8.3 DFN2x2-6L编带信息 ........................................................................................................ 10 8.4 DFN1x1-4L封装尺寸 ........................................................................................................ 11 8.5 DFN1x1-4L编带信息 ........................................................................................................ 12 9. 历史记录 ................................................................................................................................ 12 www.pintengtech.com 版本号 V1.1 1 / 12 PT2041A 规格书 单触控单输出 IC 1. 文件编号:PT-DS21007 产品概述 PT2041A 是一款单通道触摸检测芯片。该芯片内建稳压电路,提供稳定电压给触摸感应电路使用, 同时内部集成高效完善的触摸检测算法,使得芯片具有稳定的触摸检测效果。该芯片专为取代传统 按键而设计,具有宽工作电压与低功耗的特性,可广泛地满足不同消费类应用的需求。 2. 主要特性 ⚫ 工作电压范围:2.4~5.5V ⚫ 工作温度范围:-40~85℃ ⚫ 抗干扰性能优良:内置稳压电路、上电复位、低压复位功能及环境自适应算法等多种措施 ⚫ 待机工作电流:典型值 2uA@V DD=3V/无负载 ⚫ 按键最长响应时间:低功耗模式下约 200ms@V DD=3V ⚫ 可接外部电容(1~50pF)调整触摸灵敏度 ⚫ 输出模式选择(TOG):同步输出或锁存(toggle)输出 ⚫ CMOS 输出(QC)有效电平选择(AHLB):高电平或低电平输出有效 ⚫ 按键最长输出时间:16 秒(±30%) ⚫ 上电约 0.4 秒的初始化时间,此期间内不要触摸检测点,且此时所有功能被禁止 ⚫ HBM ESD:大于 2KV ⚫ 封装形式:SOT23-6、DFN2*2-6L、DFN1*1-4L 3. 系统框图 TCH 传感器 震荡电路 时序计算器 & 功能选项控制电路 传感器 & 参考检测电路 QC 输出& 触摸检测电路 TOG 驱动电路 系统振荡电路 AHLB 稳压电路 按键有效 & 时序控制 图 1 系统框图 www.pintengtech.com 版本号 V1.1 2 / 12 PT2041A 规格书 4. 封装及引脚说明 1 VSS 2 TCH 3 PT2041AT6 QC 6 TOG 5 VDD 4 AHLB 图 2 PT2041A SOT23-6 管脚示意图 1 VSS 2 QC 3 PT2041AD6 TCH 6 AHLB 5 VDD 4 TOG 图 3 PT2041A DFN2x2-6L 管脚示意图 注:引脚布局与 SOT23-6 反向 1 TCH 2 PT2041 AD4 VDD 4 QC 3 VSS 图 4 PT2041A DFN1x1-4L 封装管脚示意图 注:固定为同步输出模式,输出高电平有效 www.pintengtech.com 版本号 V1.1 3 / 12 PT2041A 规格书 表 1 引脚说明表 序号 管脚 I/O 描述 SOT23-6 DFN2x2-6L DFN1x1-4L 名称 类型 1 3 4 QC O 输出脚,CMOS输出 2 2 3 VSS P 地 3 1 2 TCH I 触摸感应输入 4 6 / AHLB I-PL 5 5 1 VDD P 输出高电平有效或低电平有效选择 0(默认值):高电平有效;1:低电平有效 电源 输出模式选择 6 4 / TOG I-PL 0(默认值):同步输出; 1:锁存(toggle)输出 引脚类型: I: CMOS 输入 O: CMOS 输出 I/O: CMOS 输入/输出 P: 电源/接地 I-PH: CMOS 输入内置上拉电阻 I-PL: CMOS 输入内置下拉电阻 www.pintengtech.com 版本号 V1.1 4 / 12 PT2041A 规格书 5. 功能描述 5.1 输出模式和选项脚位 AHLB 和 TOG 选项脚位为锁存类型:上电默认状态为 0,若上电前管脚被接至 VDD,则上电后状态 变为 1,且不会有电流漏电。 TOG 脚位:选择同步输出或锁存(toggle)输出。 AHLB 脚位:选择 CMOS 输出高电平有效或低电平有效。 QC 脚(CMOS 输出)选项特性: 端口 QC 选项特性 TOG AHLB 0 0 同步模式、CMOS 高电平有效 0 1 同步模式、CMOS 低电平有效 1 0 锁存(toggle)输出,上电状态=0 1 1 锁存(toggle)输出,上电状态=1 5.2 按键最长输出时间 若有物体覆盖触摸盘或环境突然变化,可能导致触摸检测持续有效。IC 内部触控算法检测到输出有 效持续时间达到设定值 16S(±30%)时,系统会回到上电初始状态,且输出变为无效。 5.3 低功耗模式 PT2041A 在低功耗模式下运行,可节省功耗,在此模式下侦测到按键触摸后会切换至快速模式,直 到按键触摸释放,并保持约 10 秒快速模式,然后返回低功耗模式。 Fast mode timing Low Power mode timing Low Power mode timing Low Power mode timing Fast mode timing VDD TCH VSS -125ms -16ms POSSIBLE KEY TOUCH KEY RELEASE (NOT REALLY TOUCH) -125ms -16ms KEY TOUCH ABOUT 10 SEC -125ms KEY RELEASE VDD QC VSS 图 5 时序图 5.4 灵敏度调整 IC 触摸管脚上的等效电容大小会影响灵敏度,灵敏度调整必须符合 PCB 的实际应用,下面是一些调 整灵敏度的方法: 1) 调整触摸盘大小: 在其它条件不变的情况下,使用较大的触摸盘尺寸可增加灵敏度,反之则会降低灵敏度;但触摸 盘尺寸必须在有效范围内。 2) 调整介质面板厚度: 在其它条件不变的情况下,使用较薄的介质可增加灵敏度,反之则会降低灵敏度。 3) 调整 Cs 电容值 在其它条件不变的情况下,触摸盘上未接对地 Cs 电容时,灵敏度最高,反之 Cs 电容越大灵敏 度变低,Cs 电容可用范围:(1≦Cs≦50pF)。 www.pintengtech.com 版本号 V1.1 5 / 12 PT2041A 规格书 6. 应用电路 图 6 电路示意图 注: 1) 在 PCB 上从触摸盘到 TCH 脚的走线越短越好,且触摸走线与其它走线不得平行或交叉。 2) 电源供电必须稳定,若电源电压发生快速漂移或跳变,可能造成灵敏度异常或误检测。 3) 覆盖在 PCB 上的介质,不得含有金属或导电组件成份﹐表面涂料亦同样要求。 4) 必须在 VDD 和 GND 间使用 C1 电容(104 或更大容量);且应采取与 IC 的 VDD 和 GND 管脚 最短距离布线。 5) 可利用 Cs 电容调整灵敏度,Cs 电容值越小灵敏度越高,灵敏度调整必须根据实际应用的 PCB 来做调整,Cs 电容值的范围为 1~50pF。 6) 调整灵敏度的电容(Cs)必须选用较小的温度系数及较稳定的电容器,如 X7R、NPO。针对触 摸应用,建议选择 NPO 电容器,以降低因温度变化而影响灵敏度。 www.pintengtech.com 版本号 V1.1 6 / 12 PT2041A 规格书 7. 电气特性 7.1 电气特性极限参数 表 2 极限参数 参数 标号 条件 范围 单位 供电电压 V DD - -0 to +5.5 V 输入电压 VI 所有 I/O口 -0.3 to V DD +0.3 V 工作温度 TA - -40~ +85 ℃ 储藏温度 T STG - -50~ +125 ℃ 芯片抗静电强度HBM ESD 2 KV 7.2 直流特性 表 3 如无特殊说明 V DD=2.4V~5.5V,Temp=25ºC 参数 标号 工作电压 V DD 输入高电压 VIH 输入低电压 VIL 条件 最小值 典型值 最大值 单位 2.4 3 5.5 V V DD =5V,AHLB 0.75*VDD 1.0*VDD V DD =5V,TOG 0.4*VDD 1.0*VDD V DD =5V,AHLB 0 0.25*VDD V DD =5V,TOG 0 0.15*VDD V V 输出拉电流 I OH V DD =3V, VOH=2.1V 2 mA 输出灌电流 I OL V DD =3V, VOL=0.9V 15 mA 下拉电阻 RPL V DD =3V(TOG、AHLB) 输出响应时间 TR ISB 36 40 V DD =3V、低功耗模式 200 载) Kohm ms 2 2.5 uA V DD =3V,快速模式(无负载) www.pintengtech.com 30 V DD =3V、快速模式 V DD =3V,低功耗模式(无负 工作电流 24 版本号 V1.1 20 25 7 / 12 PT2041A 规格书 8. 封装信息 8.1 SOT23-6封装 图 7 SOT23-6 封装图 表 4 SOT23-6 封装尺寸 Unit: mm Symbol Min Typ Max Symbol Min Typ Max A - - 1.25 e 0.90 0.95 1.00 A1 0 - 0.15 e1 1.80 1.90 2.00 A2 1.00 1.10 1.20 L 0.35 0.45 0.60 A3 0.60 0.65 0.70 L1 0.59RET B 0.36 - 0.50 L2 0.25BSC b1 0.36 0.38 0.45 R 0.10 - - C 0.14 - 0.20 R1 0.10 - 0.20 c1 0.14 0.15 0.16 θ 0 - 8° D 2.826 2.926 3.026 θ1 3° 5° 7° E 2.60 2.80 3.00 θ2 6° - E1 1.526 1.626 1.726 www.pintengtech.com 版本号 V1.1 14° 8 / 12 PT2041A 规格书 8.2 DFN2x2-6L封装尺寸 图 8 DFN2x2-6L 封装图 表 5 DFN2x2-6L 封装尺寸 Unit: mm Symbol Min Typ Max Symbol Min Typ Max A 0.70 0.75 0.80 E2 0.75 0.80 0.85 A1 0.00 0.02 0.05 e 0.650BSC b 0.30 0.35 0.40 Nd 1.300BSC c 0.18 0.20 0.25 K 0.20 - - D 1.95 2.00 2.05 L 0.28 0.33 0.38 D2 1.25 1.30 1.35 h 0.15 0.20 0.25 E 1.95 2.00 2.05 www.pintengtech.com 版本号 V1.1 9 / 12 PT2041A 规格书 8.3 DFN2x2-6L编带信息 PIN1 D0 P1 P0 P2 E T F W θ B0 K0 进料方向 D1 PIN1 A0 θ DFN2*2-6L 印章示意 图 9 DFN2x2-6L 编带示意 表 6 DFN2x2-6L 编带尺寸 Unit: mm Symbol Min Typ Max Symbol Min Typ Max W 7.9 8.00 8.10 D1 - 1.00 1.10 A0 2.15 2.25 2.35 D0 - 1.50 1.60 B0 2.15 2.25 2.35 P0 3.90 4.00 4.10 K0 0.85 0.95 1.05 P1 3.90 4.00 4.10 E 1.65 1.75 1.85 P2 1.90 2.00 2.10 F 3.40 3.50 3.60 T 0.20 0.22 0.24 θ www.pintengtech.com 版本号 V1.1 10° 10 / 12 PT2041A 规格书 8.4 DFN1x1-4L封装尺寸 图 10 DFN1x1-4L 封装图 表 7 DFN1x1-4L 封装尺寸 Unit: mm Symbol Min Typ Max Symbol Min Typ Max A 0.32 0.37 0.40 E2 0.43 0.48 0.53 A1 0.00 0.02 0.05 e 0.650 BSC b 0.18 0.23 0.28 L1 0.205 REF c 0.102 REF D 0.95 1.00 1.05 D2 0.43 0.48 0.53 www.pintengtech.com 版本号 V1.1 E 0.95 1.00 1.05 L 0.20 0.25 0.30 11 / 12 PT2041A 规格书 8.5 DFN1x1-4L编带信息 PIN1 D0 P1 P0 P2 E T F W θ B0 K0 进料方向 D1 PIN1 A0 θ DFN1*1-4L 印章示意 图 11 DFN1x1-4L 编带示意 表 8 DFN1x1-4L 编带尺寸 Unit: Symbol Min Typ Max Symbol Min Typ Max W 7.9 8.00 8.10 D1 - 0.7 0.8 A0 1.15 1.25 1.35 D0 - 1.50 1.60 B0 1.15 1.25 1.35 P0 3.90 4.00 4.10 K0 0.47 0.57 0.67 P1 3.90 4.00 4.10 E 1.65 1.75 1.85 P2 1.90 2.00 2.10 F 3.40 3.50 3.60 T 0.18 0.23 0.28 θ 9. mm 6° 历史记录 版本号 修改记录 发布日期 V1.0 初版 2021-06-09 V1.1 更新DFN1*1-4L封装相关笔误 2021-09-23 www.pintengtech.com 版本号 V1.1 12 / 12
PT2041AT6
物料型号:PT2041A
器件简介:PT2041A 是一款单通道触摸检测芯片,具有内建稳压电路和触摸检测算法,专为取代传统按键设计,具有宽工作电压与低功耗特性。
引脚分配: - SOT23-6封装:QC(输出), VSS(地), TCH(触摸感应输入), AHLB(输出电平选择), VDD(电源), TOG(输出模式选择) - DFN2x2-6L封装:布局与SOT23-6相反 - DFN1x1-4L封装:固定为同步输出模式,输出高电平有效
参数特性: - 工作电压范围:2.4~5.5V - 工作温度范围:-40~85℃ - 待机工作电流:典型值2uA@VDD=3V/无负载 - 按键最长响应时间:低功耗模式下约200ms@VDD=3V - HBM ESD:大于2KV
功能详解: - 输出模式和选项脚位:可以选择同步输出或锁存(toggle)输出,以及CMOS输出高电平或低电平有效。 - 按键最长输出时间:设定值为16秒,超过该时间系统会回到初始状态。 - 低功耗模式:在该模式下,侦测到按键触摸后会切换至快速模式,释放后保持快速模式约10秒。 - 灵敏度调整:通过调整触摸盘大小、介质面板厚度或Cs电容值来调整。
应用信息: - 应用电路图提供了详细的元件布局和连接方式。 - 强调了PCB布局、电源稳定性、介质覆盖等对性能的影响。
封装信息: - 提供了SOT23-6、DFN2x2-6L和DFN1x1-4L三种封装的详细尺寸和编带信息。
PT2041AT6 价格&库存
很抱歉,暂时无法提供与“PT2041AT6”相匹配的价格&库存,您可以联系我们找货
PT2041AT6
    • 1+0.29115
    • 10+0.23487
    • 100+0.18474
    PT2041AT6
    • 10+0.38945
    • 100+0.31169
    • 300+0.27281
    • 3000+0.23426
    • 6000+0.21093
    • 9000+0.19926
    库存:32104
