31157104
31157104
    METZCONNECT
    接线端子
31157104 数据手册
Page 1/6 Data sheet P/N 311571xx xx=number of poles RP095xxRBWC Type 157 with clip system 2022/12/20 Version: AH Illustrations Dimensional drawing See enlarged drawings at the end of document Product specification • screw type terminal block, pluggable • centerline 5.00 mm, direction of connection 90° • wire protector, fittable without loss of poles • color black • pluggable, top side pin insertion, snap-in technique for mounting into a housing Data sheet Page 2/6 RP095xxRBWC Type 157 with clip system P/N 311571xx xx=number of poles 2022/12/20 Version: AH Technical Data General Data Tightening torque SEV Tightening torque UL 0.5 Nm min. number of poles 2 max. number of poles 24 Insulating material class CTI 600 clearance/creepage dist. 4.15 mm Protection category IP20 Min. insul. strip length 6 mm Rated current 13.5 A Overvoltage category III III II Pollution degree 3 2 2 Rated voltage 63 V 320 V 320 V Rated test voltage 2.5 kV 2.5 kV 2.5 kV 4.4 lb-in Terminal data rat.wiring solid AWGmax 0.08 mm² - 2.5 mm² / AWG 28 - AWG 14 rat.wiring strand.AWGmax 0.08 mm² - 2.5 mm² / AWG 28 - AWG 14 Approvals V / A / AWG approval UL - File No. 2.5 mm² 300 / 5 / 28 - 14 E121004 250 V / 4 kV / 13.5 A Material insulating material PA66 flammability class V0 contact material CuSn Contact surface Sn terminal body thread M3 terminal body material CuZnPb terminal body surface Ni screw thread M3 screw material 8,8 screw surface Zn Cr(VI)-frei/free wire protector material CuSn Data sheet Page 3/6 RP095xxRBWC Type 157 with clip system P/N 311571xx xx=number of poles 2022/12/20 Version: AH Technical Data wire protector surface Sn Glow-Wire Flammability GWFI 850 °C acc. to IEC 60695-2-12 Glow-Wire Flammability GWIT 775 °C acc. to IEC 60695-2-13 REACH compliant REACH - substance (SVHC) Lead / 7439-92-1 Climatic Data upper limit temperature 105 °C lower limit temperature -40 °C general Tolerance ISO 2768 -mH Data sheet Page 4/6 RP095xxRBWC Type 157 with clip system P/N 311571xx xx=number of poles 2022/12/20 Version: AH Counterpart P/N Designation 310461 PR035xxVBHC Type 046 313171 PM015xxVBHC Type 317 313181 PM025xxVBHC Type 318 Data sheet RP095xxRBWC Type 157 with clip system Page 5/6 P/N 311571xx xx=number of poles 2022/12/20 Version: AH Illustrations Dimensional drawing L=(pole size - 1) x centerline + 5 mm [0.197] Data sheet RP095xxRBWC Type 157 with clip system Page 6/6 P/N 311571xx xx=number of poles 2022/12/20 Version: AH Illustrations Application example Powered by TCPDF (www.tcpdf.org)
31157104 价格&库存
很抱歉,暂时无法提供与“31157104”相匹配的价格&库存,您可以联系我们找货
