Page 1/6
Data sheet
P/N
311571xx
xx=number of poles
RP095xxRBWC Type 157 with clip system
2022/12/20
Version: AH
Illustrations
Dimensional drawing
See enlarged drawings at the end of document
Product specification
• screw type terminal block, pluggable
• centerline 5.00 mm, direction of connection 90°
• wire protector, fittable without loss of poles
• color black
• pluggable, top side pin insertion, snap-in technique for mounting into a housing
Data sheet
Page 2/6
P/N
311571xx
xx=number of poles
2022/12/20
Version: AH
Technical Data
General Data
Tightening torque SEV
Tightening torque UL
0.5 Nm
min. number of poles
2
max. number of poles
24
Insulating material class
CTI 600
clearance/creepage dist.
4.15 mm
Protection category
IP20
Min. insul. strip length
6 mm
Rated current
13.5 A
Overvoltage category
III
III
II
Pollution degree
3
2
2
Rated voltage
63 V
320 V
320 V
Rated test voltage
2.5 kV
2.5 kV
2.5 kV
4.4 lb-in
Terminal data
rat.wiring solid AWGmax
0.08 mm² - 2.5 mm² / AWG 28 - AWG 14
rat.wiring strand.AWGmax
Approvals
V / A / AWG
approval UL - File No.
2.5 mm²
300 / 5 / 28 - 14
E121004
250 V / 4 kV / 13.5 A
Material
insulating material
PA66
flammability class
V0
contact material
CuSn
Contact surface
Sn
terminal body thread
M3
terminal body material
CuZnPb
terminal body surface
Ni
screw thread
M3
screw material
8,8
screw surface
Zn Cr(VI)-frei/free
wire protector material
CuSn
Data sheet
Page 3/6
P/N
311571xx
xx=number of poles
2022/12/20
Version: AH
Technical Data
wire protector surface
Sn
Glow-Wire Flammability GWFI
850 °C acc. to IEC 60695-2-12
Glow-Wire Flammability GWIT
775 °C acc. to IEC 60695-2-13
REACH
compliant
REACH - substance (SVHC)
Lead / 7439-92-1
Climatic Data
upper limit temperature
105 °C
lower limit temperature
-40 °C
general
Tolerance
ISO 2768 -mH
Data sheet
Page 4/6
P/N
311571xx
xx=number of poles
2022/12/20
Version: AH
Counterpart
P/N
Designation
310461
PR035xxVBHC Type 046
313171
PM015xxVBHC Type 317
313181
PM025xxVBHC Type 318
Data sheet
Page 5/6
P/N
311571xx
xx=number of poles
2022/12/20
Version: AH
Illustrations
Dimensional drawing
L=(pole size - 1) x centerline + 5 mm [0.197]
Data sheet
Page 6/6
P/N
311571xx
xx=number of poles
2022/12/20
Version: AH
Illustrations
Application example
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“31157102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.038031+1.04121
- 10+5.8966910+0.76383
- 25+5.1340925+0.66505
- 50+4.6274750+0.59942
- 100+4.18864100+0.54258
- 250+3.71180250+0.48081
- 500+3.42474500+0.44363
- 1000+3.192751000+0.41358
- 5000+2.822545000+0.36562
