USB1040-GF-L-B
USB1040-GF-L-B
    GCT
    插件
    USB连接器 Type-A 4P 直插 端口数:1 额定电流:1.5A 额定电压:30V 工作温度:-40℃~+85℃
USB1040-GF-L-B 数据手册
7.00 2.00 12.50 H Ø0 Ø2 5.12 1 3 1 2 3 .30 4 4 2.40 G 2 .90 13.14 Recommended P.C.B Layout Thickness: 1.6mm General Tolerance: ±0.05 as viewed from component side Solder Area F 14.50 Component Outline 7.12 Specifications Material Plastic Housing: LCP, UL94V-0, Black Contact Terminal: Brass Metallic Shell: Brass C Electrical: Voltage Rating: 30V Current Rating: 1.5A Operating Temperature: -40°C to +85°C Contact Resistance: 30 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 500V AC 3.00 3.50 D Plating Underplating: Nickel all over Contact Area: Gold Flash or 15µ" Gold Solder Tails: Tin Metallic Shell: Nickel 17.20 13.70 E 2.00 0.25 1.86 7.00 1.65 2.50 0.60 0 0.3 2.40 15.60+0.40 -0.00 B Mechanical & Environmental Mating Force: 35N (3.57Kgf) max. Unmating Force: 10N (1.02Kgf) min. Durability: 1,500 Cycles Ordering Grid USB1040 XX L B Packing Options B = Tray Contact Plating GF = Gold Flash (Standard) 15 = 15u" Gold (100 per tray) Insulator Material L = LCP A Request Samples and Quotation Part Number Product Description USB1040 USB Receptacle, Type A, 4 Pin, Through Hole, Vertical, With Kinked Shell Stakes Drawing Date 14th February 2011 By Detail 1 2 3 4 Revision Date 5 CC USB1040 C PCN C2 17/01/20 Tolerances (Except as Noted) Length Angle X.X ± 0.35 X.XX ± 0.25 X.° ± 3.0° X.X° ± 1.5° 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By SA 8 Sheet No. 1/2 H 1 3 USB G Base 240 F E 2 Cover 29 0 0 23 Carton D Packing Rules﹕ 1.USB's placed into the tray base. 2.Tray cover and base taped together to keep USB's in place. 3.25 trays put into carton. 4.Boxed taped and label stuck on the outer carton. Base 4 Tape C Products P/N USB1040 Label PCS/Tray Trays/Carton PCS/Carton 100 25 2500 B Tray RoHS Label Part Number Product Description USB1040 USB Receptacle, Type A, 4 Pin, Through Hole, Vertical, With Kinked Shell Stakes Drawing Date 14th February 2011 A By Detail Revision Date 1 2 3 4 5 CC USB1040 C PCN C2 17/01/20 Tolerances (Except as Noted) Length Angle Units: Metric (mm) - - C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By SA 8 Sheet No. 1/2
USB1040-GF-L-B 价格&库存
很抱歉,暂时无法提供与“USB1040-GF-L-B”相匹配的价格&库存,您可以联系我们找货
USB1040-GF-L-B
  • 1+3.95034
  • 10+3.39097
  • 25+3.17896
  • 50+3.03642
  • 100+2.88790
  • 500+2.58964
  • 1000+2.47825
  • 2000+2.38482
  • 3000+2.32014
  • 5000+2.25426
库存:2000
USB1040-GF-L-B
  • 1+5.33520
  • 10+4.34160
  • 30+3.83400
库存:23
USB1040-GF-L-B
    库存:28500
