BZT52C2V0S THRU BZT52C75S
Zener Voltage - 2 to 75 Volts
Peak Pulse Power - 0.2 W
SURFACE MOUNT ZENER DIODE
Features
Total power dissipation: Max. 200mW.
Wide zener reverse voltage range 2.0V to 75V.
Small plastic package suitable for surface mounted design.
Tolerance approximately±5%
PINNING
PIN
DESCRIPTION
1
Cathode
2
Anode
Mechanical Data
2
Case : JEDEC SOD-323 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.00019 ounce, 0.00548 grams
1
Top View
Simplified outline SOD-323 and symbol
Ordering Information
Marking
Type No.
See table 2
BZT52C2V0S-BZT52C75S
MAXIMUM RATING
SOD-323
@ Ta=25℃ unless otherwise specified
Parameter
Forward Voltage
Package Code
@ IF=10mA
Power Dissipation
Typical thermal resistance juncting to ambient
(1)
Symbol
Value
Unit
VF
0.9
V
Pd
200
mW
RθJA
417
℃/W
Junction temperature
Tj
-55-150
Storage temperature range
Tstg
-55-150
Fig.1 Maximum Continuous Power Derating
0.35
Power Dissipation ( W )
0.3
0.25
0.2
0.15
0.1
0.05
0.0
25
50
75
100
125
150
T c ,Case Temperature (°C)
175
Transient Thermal Impedance( °C /W)
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper areas pads.
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
DN:T19819A0
https://www.microdiode.com
Rev:2019A0
Page :1
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
BZT52C2V0S
WY
V ZT(at I ZT)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Min(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
Max(μA)
(V)
1.8
2
2.15
5
100
120
0.5
BZT52C2V2S
WZ
2.08
2.2
2.33
5
100
120
0.7
BZT52C2V4S
WX
2.28
2.4
2.56
5
100
120
1
BZT52C2V7S
W1
2.5
2.7
2.9
5
110
120
1
BZT52C3V0S
W2
2.8
3
3.2
5
120
50
1
BZT52C3V3S
W3
3.1
3.3
3.5
5
130
BZT52C3V6S
W4
3.4
3.6
3.8
5
130
10
1
BZT52C3V9S
W5
3.7
3.9
4.1
5
130
5
1
BZT52C4V3S
W6
4
4.3
4.6
5
130
5
1
BZT52C4V7S
W7
4.4
4.7
5
5
130
2
1
BZT52C5V1S
W8
4.8
5.1
5.4
5
130
2
1.5
BZT52C5V6S
W9
5.2
5.6
6
5
80
1
2.5
BZT52C6V2S
WA
5.8
6.2
6.6
5
50
1
3
5
30
0.5
3.5
30
0.5
4
5
BZT52C6V8S
WB
6.4
6.8
7.2
BZT52C7V5S
WC
7
7.5
7.9
5
BZT52C8V2S
WD
7.7
8.2
8.7
5
30
0.5
BZT52C9V1S
WE
8.5
9.1
9.6
5
30
0.5
6
BZT52C10S
WF
9.4
10
10.6
5
30
0.1
7
BZT52C11S
WG
10.4
11
11.6
5
30
0.1
8
BZT52C12S
WH
11.4
12
12.7
5
35
0.1
9
BZT52C13S
WI
12.4
13
14.1
5
35
0.1
10
BZT52C15S
WJ
13.8
15
15.6
5
40
0.1
11
BZT52C16S
WK
15.3
16
17.1
5
40
0.1
12
BZT52C18S
WL
16.8
18
19.1
5
45
0.1
13
BZT52C20S
WM
18.8
5
50
0.1
15
BZT52C22S
WN
20.8
22
23.3
5
55
0.1
17
BZT52C24S
WO
22.8
24
25.6
5
60
0.1
19
BZT52C27S
WP
25.1
27
28.9
2
70
0.1
21
BZT52C30S
WQ
28
30
32
2
80
0.1
23
BZT52C33S
WR
31
33
35
2
80
0.1
25
BZT52C36S
WS
34
36
38
2
90
0.1
27
BZT52C39S
WT
37
39
41
2
100
0.1
30
BZT52C43S
WU
40
43
46
2
130
0.1
33
BZT52C47S
WV
44
47
50
2
150
0.1
36
BZT52C51S
WW
48
51
54
2
180
0.1
39
BZT52C56S
XW
52
56
60
2
200
0.1
43
BZT52C62S
6E
58
62
66
2
215
0.1
47
BZT52C68S
6F
64
68
72
2
240
0.1
52
BZT52C75S
6H
70
75
79
2
265
0.1
56
(1) V ZT is tested with pulses (20 ms)
Rev:2019A0
Page :2
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
S O D - 3 2 3 me
m e c h a n i c a l da
data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
( mil)
Rev:2019A0
Page :3
很抱歉,暂时无法提供与“BZT52C3V0S-W2”相匹配的价格&库存,您可以联系我们找货
