M100-006-HD
M100-006-HD
    TRIPPLITE
    M100-006-HD
M100-006-HD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Heavy-Duty USB-A to Lightning Sync/Charge Cable, MFi Certified - M/M, USB 2.0, 6 ft. (1.83 m) MODEL NUMBER: M100-006-HD Highlights ● Constructed using bulletproof Aramid fiber, this cable stands up to rigorous and frequent use ● Connects to USB-A port on computer or wall charger ● MFi-certified for broad compatibility with your Apple iPhone, iPad or iPod ● Nylon braiding maintains top performance and long life ● Reversible Lightning plug connects in either direction Applications ● Charge and sync your Apple iPhone, iPad or iPod using the USB-A port on your computer or a wall charger up to 6 ft. away ● Transfer photos and other important files between an external hard drive and your Apple device Heavy-duty Lightning cable charges and synchronizes your latest-generation Apple iPhone, iPad or iPod using the USB port on your computer. System Requirements Features The M100-006-HD Heavy-Duty USB Sync/Charge Cable connects your latest-generation iPhone, iPad or iPod to the USB-A port on a computer or USB wall charger, so you can charge your Apple device and transfer data. The reversible 8-pin Lightning plug connects in either direction to ensure fast, easy connection every time. Constructed using bulletproof Aramid fiber to reinforce the conductors inside the cable, this heavy-duty Lightning cable features enhanced protection to stand up to the most rigorous use. The double braided nylon jacket and integral strain relief provide additional strength and flexibility to endure the stress and abuse of frequent use. The six-foot (1.8-meter) heavy-duty Lightning cable is MFicertified for use with the latest generation of iPhone, iPad and iPod devices. Specifications OVERVIEW UPC Code 037332207319 Technology Lightning; USB; USB 2.0 (High Speed) USB Cable Type Passive INPUT Maximum Input Amps 2 POWER USB Power Delivery (PD) Charging Support No 1/3 ● Computer, laptop or charger with USB-A port ● Most current iPhone, iPad and iPod devices Package Includes ● M100-006-HD Heavy-Duty USB Sync/Charge Cable with Lightning Connector, 6 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States CHARGING Total Charging Watts 12 PHYSICAL Material of Construction TPE, PVC, Nylon, Aramid Fiber Cable Jacket Color Black; White Cable Jacket Material TPE Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.2mm Wire Gauge (AWG) 28/21 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 0.91 x 2.40 x 5.40 Shipping Dimensions (hwd / cm) 2.31 x 6.10 x 13.72 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range -4 to 140 F (-20 to 60 C) Storage Temperature Range -4 to 176 F (-20 to 80 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 12W (5V/2.4A) CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 LIGHTNING (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS Data Transfer Rate 480 Mbps USB Specification USB 2.0 (up to 480 Mbps) Angled Plug No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications MFi Product Compliance RoHS; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
M100-006-HD 价格&库存
很抱歉,暂时无法提供与“M100-006-HD”相匹配的价格&库存,您可以联系我们找货
M100-006-HD
  • 6+81.34260
库存:10
