SiT8008BI-71-33S-6.000000 数据手册
SiT8008B
Low Power Programmable Oscillator
Features
ow Power, Standard Frequency Oscillator
Applications
Any frequency between 1 MHz and 110 MHz accurate to
6 decimal places
100% pin-to-pin drop-in replacement to quartz-based XO
Excellent total frequency stability as low as ±20 ppm
Operating temperature from -40°C to 85°C. For 125°C
and/or -55°C options, refer to SiT1618, SiT8918, SiT8920
Low power consumption of 3.5 mA typical at 1.8 V
Qualify just one device with 1.62 V to 3.63 V continuous
supply voltage option
Standby mode for longer battery life
Fast startup time of 5 ms
LVCMOS/HCMOS compatible output
Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5,
5.0 x 3.2, 7.0 x 5.0 mm x mm
Instant samples with Time Machine II and Field
Programmable Oscillators
RoHS and REACH compliant, Pb-free, Halogen-free and
Antimony-free
For AEC-Q100 oscillators, refer to SiT8924 and SiT8925
Ideal for DSC, DVC, DVR, IP CAM, Tablets, e-Books,
SSD, GPON, EPON, etc
Ideal for high-speed serial protocols such as: USB,
SATA, SAS, Firewire, 100M / 1G / 10G Ethernet, etc.
Electrical Characteristics
All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise
stated. Typical values are at 25°C and nominal supply voltage.
Table 1. Electrical Characteristics
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Range
Output Frequency Range
f
1
110
MHz
Frequency Stability and Aging
Frequency Stability
F_stab
-20
+20
ppm
-25
+25
ppm
-50
+50
ppm
Inclusive of initial tolerance at 25°C, 1st year aging at 25°C, and
variations over operating temperature, rated power supply voltage
and load.
Operating Temperature Range
Range
T_use
-20
+70
°C
Extended Commercial
-40
+85
°C
Industrial
Supply Voltage and Current Consumption
Supply Voltage Options
Current Consumption
Vdd_1.8
1.62
1.8
1.98
V
Vdd_2.5
2.25
2.5
2.75
V
Vdd_2.8
2.52
2.8
3.08
V
Vdd_3.0
2.7
3.0
3.3
V
Vdd_3.3
2.97
3.3
3.63
V
Vdd_XX
2.25
3.63
V
Vdd_YY
1.62
3.63
V
Idd
3.8
4.5
mA
No load condition, f = 20 MHz, Vdd_2.8, Vdd_3.0, Vdd_3.3,
Vdd_XX, Vdd_YY
3.7
4.2
mA
No load condition, f = 20 MHz, Vdd_2.5
3.5
4.1
mA
No load condition, f = 20 MHz, Vdd_1.8
4.2
mA
Vdd_2.5, Vdd_2.8, Vdd_3.0, Vdd_3.3, Vdd_XX, Vdd_YY.
OE = GND, Output in high-Z state
4.0
mA
Vdd_1.8. OE = GND, Output in high-Z state
2.1
4.3
A
ST = GND, Vdd_2.8, Vdd_3.0, Vdd_3.3, Vdd_XX, Vdd_YY.
Output is weakly pulled down
1.1
2.5
A
ST = GND, Vdd_2.5, Output is weakly pulled down
0.2
1.3
A
ST = GND, Vdd_1.8, Output is weakly pulled down
OE Disable Current
I_OD
Standby Current
I_std
1.06
27 January 2021
Contact SiTime for 1.5 V support
www.sitime.com
SiT8008B Low Power Programmable Oscillator
Table 1. Electrical Characteristics (continued)
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
LVCMOS Output Characteristics
DC
45
55
All Vdds. See Duty Cycle definition in Figure 3 and Footnote 6
Tr, Tf
1
2
ns
20% - 80% Vdd_2.5, Vdd_2.8, Vdd_3.0, Vdd_3.3
1.3
2.5
ns
20% - 80% Vdd_1.8
2
ns
20% - 80% Vdd_XX
2.7
ns
20% - 80% Vdd_YY
Duty Cycle
Rise/Fall Time
Output High Voltage
VOH
90%
Vdd
Output Low Voltage
VOL
10%
Vdd
Input High Voltage
VIH
70%
Vdd
Pin 1, OE or ST
Input Low Voltage
VIL
30%
Vdd
Pin 1, OE or ST
Input Pull-up Impedance
Z_in
50
87
150
k
Pin 1, OE logic high or logic low, or ST logic high
2
M
Pin 1, ST logic low
IOH = -4 mA (Vdd_3.0 and
IOH = -3 mA (Vdd_2.8 and
IOH = -2 mA (Vdd _1.8)
Vdd_3.3)
Vdd_ 2.5)
Vdd_3.3)
Vdd_ 2.5)
Input Characteristics
Startup and Resume Timing
Startup Time
T_start
5
ms
Measured from the time Vdd reaches its rated minimum value
T_oe
130
ns
f = 110 MHz. For other frequencies, T_oe = 100 ns + 3 * cycles
T_resume
5
ms
Measured from the time ST pin crosses 50% threshold
Enable/Disable Time
Resume Time
Jitter
RMS Period Jitter
T_jitt
Peak-to-peak Period Jitter
T_pk
RMS Phase Jitter (random)
T_phj
1.8
3
ps
3.3
ps
f = 75 MHz, Vdd_1.8, Vdd_2.5, Vdd_2.8, Vdd_3.0, Vdd_3.3,
Vdd_XX,
f = 75 MHz, Vdd_YY
12
25
ps
f = 75 MHz, Vdd_2.5, Vdd_2.8, Vdd_3.0, Vdd_3.3, Vdd_XX, Vdd_YY
14
30
ps
f = 75 MHz, Vdd_1.8
0.5
0.9
ps
1.3
2
ps
1.4
ps
f = 75 MHz, Integration bandwidth = 900 kHz to 7.5 MHz. Vdd_1.8,
f = 75 MHz, Integration bandwidth = 12 kHz to 20 MHz. Vdd_1.8,
f = 75 MHz, Integration bandwidth = 900 kHz to 7.5 MHz. Vdd_YY
2.3
ps
f = 75 MHz, Integration bandwidth = 12 kHz to 20 MHz. Vdd_YY
Table 2. Pin Description
Pin
1
Symbol
OE/ST
̅ ̅ ̅ /NC
Top View
Functionality
Output Enable
H[1]: specified frequency output
L: output is high impedance. Only output driver is disabled.
Standby
L: output is low (weak pull down). Device goes to sleep mode.
Supply current reduces to I_std.
No Connect
OE/ST
̅ ̅ ̅ /NC
Any voltage between 0 and Vdd or Open [1]: Specified frequency
output. Pin 1 has no function.
2
GND
Power
Electrical ground
3
OUT
Output
Oscillator output
4
VDD
Power
Power supply voltage [2]
Figure 1. Pin Assignments
Notes:
1. In OE or ST
̅ ̅ ̅ mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option.
2. A capacitor of value 0.1 µF or higher between Vdd and GND is required.
1.06
Page 2 of 17
www.sitime.com
Table 3. Absolute Maximum Limits
Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance
of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Min.
Max.
Unit
Storage Temperature
Parameter
-65
150
°C
Vdd
-0.5
4
V
Electrostatic Discharge
2000
V
Soldering Temperature (follow standard Pb free soldering guidelines)
260
°C
Junction Temperature[3]
150
°C
Note:
3. Exceeding this temperature for extended period of time may damage the device.
Table 4. Thermal Consideration[4]
JA, 4 Layer Board
JA, 2 Layer Board
JC, Bottom
(°C/W)
142
(°C/W)
273
(°C/W)
30
5032
97
199
24
3225
109
212
27
2520
117
222
26
2016
152
252
36
Package
7050
Note:
4. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table.
Table 5. Maximum Operating Junction Temperature[5]
Max Operating Temperature (ambient)
70°C
80°C
85°C
95°C
Note:
5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 6. Environmental Compliance
Parameter
Condition/Test Method
Mechanical Shock
MIL-STD-883F, Method 2002
Mechanical Vibration
MIL-STD-883F, Method 2007
Temperature Cycle
JESD22, Method A104
Solderability
MIL-STD-883F, Method 2003
Moisture Sensitivity Level
MSL1 @ 260°C
1.06
Page 3 of 17
www.sitime.com
Test Circuit and Waveform[6]
Vdd
Vout
Test Point
tr
4
Power
Supply
3
80% Vdd
15pF
(including probe
and fixture
capacitance)
0.1 uF
2
1
tf
50%
20% Vdd
High Pulse
(TH)
Vdd
OE/ST Function
Low Pulse
(TL)
Period
1 kΩ
Figure 2. Waveform
Figure 1. Test Circuit
Note:
6. Duty Cycle is computed as Duty Cycle = TH/Period.
Timing Diagrams
90% Vdd
Vdd
Vdd
50% Vdd
Pin 4 Voltage
T_start
[7]
No Glitch
during start up
T_resume
ST Voltage
CLK Output
CLK Output
HZ
HZ
T_start: Time to start from power-off
T_resume: Time to resume from ST
Figure 3. Startup Timing (OE/ ST
̅ ̅ ̅ Mode)
Figure 4. Standby Resume Timing ( ST
̅ ̅ ̅ Mode Only)
Vdd
Vdd
50% Vdd
OE Voltage
OE Voltage
T_oe
50% Vdd
T_oe
CLK Output
CLK Output
HZ
HZ
T_oe: Time to re-enable the clock output
T_oe: Time to put the output in High Z mode
Figure 5. OE Enable Timing (OE Mode Only)
Figure 6. OE Disable Timing (OE Mode Only)
Note:
7. SiT8008 has “no runt” pulses and “no glitch” output during startup or resume.
1.06
Page 4 of 17
www.sitime.com
Performance Plots[8]
1.8
2.5
2.8
3.0
3.3
6.0
DUT2
DUT3
DUT4
DUT5
DUT6
DUT7
DUT8
DUT9
DUT10
Frequency (ppm)
5.5
5.0
Idd (mA)
DUT1
4.5
4.0
3.5
10
5
-10
-15
-20
3.0
40
50
60
70
80
90
100
-40
110
-30
-20
-10
Figure 8. Idd vs Frequency
2.5 V
2.8 V
3.0 V
40
50
60
70
80
Temperature (°C)
Frequency (MHz)
1.8 V
10
Figure 9. Frequency vs Temperature
3.3 V
1.8 V
2.5 V
2.8 V
3.0 V
3.3 V
55
RMS period jitter (ps)
54
53
ty cyc
52
51
50
49
48
47
46
45
Frequency (MHz)
40
50
60
70
80
90
100
110
Frequency (MHz)
Figure 10. RMS Period Jitter vs Frequency
Figure 11. Duty Cycle vs Frequency
Temperature (°C)
Temperature (°C)
Figure 12. 20%-80% Rise Time vs Temperature
1.06
10
Page 5 of 17
Figure 13. 20%-80% Fall Time vs Temperature
www.sitime.com
1.8 V
2.5 V
2.8 V
3.0 V
3.3 V
0.9
0.8
IPJ (ps)
0.7
0.6
0.5
0.4
10
30
50
70
90
10
110
30
50
70
90
110
Frequency (MHz)
Frequency (MHz)
Figure 15. RMS Integrated Phase Jitter Random
(900 kHz to 20 MHz) vs Frequency[9]
Figure 14. RMS Integrated Phase Jitter Random
(12 kHz to 20 MHz) vs Frequency[9]
Notes:
8. All plots are measured with 15 pF load at room temperature, unless otherwise stated.
9. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is up to 5 MHz for carrier frequencies below 40 MHz.
1.06
Page 6 of 17
www.sitime.com
Programmable Drive Strength
The SiT8008 includes a programmable drive strength
feature to provide a simple, flexible tool to optimize the
clock rise/fall time for specific applications. Benefits from
the programmable drive strength feature are:
Improves system radiated electromagnetic interference
(EMI) by slowing down the clock rise/fall time.
Improves the downstream clock receiver’s (RX) jitter by
decreasing (speeding up) the clock rise/fall time.
Ability to drive large capacitive loads while maintaining
full swing with sharp edge rates.
For more detailed information about rise/fall time control and
drive strength selection, see the SiTime Application Notes
section.
EMI Reduction by Slowing Rise/Fall Time
Figure 16 shows the harmonic power reduction as the
rise/fall times are increased (slowed down). The rise/fall
times are expressed as a ratio of the clock period. For the
ratio of 0.05, the signal is very close to a square wave. For
the ratio of 0.45, the rise/fall times are very close to neartriangular waveform. These results, for example, show that
the 11th clock harmonic can be reduced by 35 dB if the
rise/fall edge is increased from 5% of the period to 45% of
the period.
trise=0.05
trise=0.1
trise=0.15
trise=0.2
trise=0.25
trise=0.3
trise=0.35
trise=0.4
trise=0.45
10
Harmonic amplitude (dB)
-20
The SiT8008 can support up to 60 pF or higher in
maximum capacitive loads with drive strength settings.
Refer to the Rise/Fall Time Tables (Table 7 to 11) to
determine the proper drive strength for the desired
combination of output load vs. rise/fall time.
SiT8008 Drive Strength Selection
Tables 7 through 11 define the rise/fall time for a given
capacitive load and supply voltage.
1. Select the table that matches the SiT8008 nominal
supply voltage (1.8 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V)
2. Select the capacitive load column that matches the
application requirement (5 pF to 60 pF)
3. Under the capacitive load column, select the
desired rise/fall times.
4. The left-most column represents the part number
code for the corresponding drive strength.
5. Add the drive strength code to the part number for
ordering purposes.
Calculating Maximum Frequency
Any given rise/fall time in Table 7 through 11 dictates the
maximum frequency under which the oscillator can operate
with guaranteed full output swing over the entire operating
temperature range. This max frequency can be calculated as
the following:
Max Frequency =
1
5 x Trf_20/80
-30
where Trf_20/80 is the typical value for 20%-80% rise/fall time.
-40
-50
Example 1
-60
Calculate fMAX for the following condition:
-70
-80
1
3
5
7
9
11
Harmonic number
Figure 16. Harmonic EMI reduction as a Function
of Slower Rise/Fall Time
Jitter Reduction with Faster Rise/Fall Time
Power supply noise can be a source of jitter for the
downstream chipset. One way to reduce this jitter is to
speed up the rise/fall time of the input clock. Some chipsets
may also require faster rise/fall time in order to reduce their
sensitivity to this type of jitter. Refer to the Rise/Fall Time
Tables (Table 7 to Table 11) to determine the proper drive
strength.
Vdd = 1.8 V (Table 7)
Capacitive Load: 30 pF
Desired Tr/f time = 3 ns
(rise/fall time part number code = E)
fMAX = 66.666660
Part number for the above example:
SiT8008BIE12-18E-66.666660
Drive strength code is inserted here. Default setting is “-”.
High Output Load Capability
The rise/fall time of the input clock varies as a function of
the actual capacitive load the clock drives. At any given
drive strength, the rise/fall time becomes slower as the
output load increases. As an example, for a 3.3 V SiT8008
device with default drive strength setting, the typical rise/fall
time is 1 ns for 15 pF output load. The typical rise/fall time slows
down to 2.6 ns when the output load increases to 45 pF. One
can choose to speed up the rise/fall time to 1.83 ns by then
increasing the drive strength setting on the SiT8008.
1.06
Page 7 of 17
www.sitime.com
Rise/Fall Time (20% to 80%) vs CLOAD Tables
Table 7. Vdd = 1.8 V (Vdd_1.8) Rise/Fall Times
for Specific CLOAD
Table 8. Vdd = 2.5 V (Vdd_2.5) Rise/Fall Times
for Specific CLOAD
Rise/Fall Time Typ (ns)
Drive Strength \ CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
5 pF
15 pF
30 pF
45 pF
60 pF
L
A
R
B
T
E
U
F or "‐": default
6.16
3.19
2.11
1.65
0.93
0.78
0.70
0.65
11.61
6.35
4.31
3.23
1.91
1.66
1.48
1.30
22.00
11.00
7.65
5.79
3.32
2.94
2.64
2.40
31.27
16.01
10.77
8.18
4.66
4.09
3.68
3.35
39.91
21.52
14.47
11.08
6.48
5.74
5.09
4.56
L
A
R
B
T
4.13
2.11
1.45
1.09
0.62
8.25
4.27
2.81
2.20
1.28
12.82
7.64
5.16
3.88
2.27
21.45
11.20
7.65
5.86
3.51
27.79
14.49
9.88
7.57
4.45
E or "‐": default
U
F
0.54
0.43
0.34
1.00
0.96
0.88
2.01
1.81
1.64
3.10
2.79
2.54
4.01
3.65
3.32
Table 10. Vdd = 3.0 V (Vdd_3.0) Rise/Fall Times
for Specific CLOAD
Table 9. Vdd = 2.8 V (Vdd_2.8) Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
L
A
R
B
T
3.77
1.94
1.29
0.97
0.55
7.54
3.90
2.57
2.00
1.12
12.28
7.03
4.72
3.54
2.08
19.57
10.24
7.01
5.43
3.22
25.27
13.34
9.06
6.93
4.08
E or "‐": default
U
F
0.44
0.34
0.29
1.00
0.88
0.81
1.83
1.64
1.48
2.82
2.52
2.29
3.67
3.30
2.99
L
A
R
B
T or "‐": default
E
U
F
5 pF
15 pF
30 pF
45 pF
60 pF
3.60
1.84
1.22
0.89
0.51
0.38
0.30
0.27
7.21
3.71
2.46
1.92
1.00
0.92
0.83
0.76
11.97
6.72
4.54
3.39
1.97
1.72
1.55
1.39
18.74
9.86
6.76
5.20
3.07
2.71
2.40
2.16
24.30
12.68
8.62
6.64
3.90
3.51
3.13
2.85
Table 11. Vdd = 3.3 V (Vdd_3.3) Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
L
A
R
B
3.39
1.74
1.16
0.81
6.88
3.50
2.33
1.82
11.63
6.38
4.29
3.22
17.56
8.98
6.04
4.52
23.59
12.19
8.34
6.33
T or “‐”: default
E
U
F
0.46
0.33
0.28
0.25
1.00
0.87
0.79
0.72
1.86
1.64
1.46
1.31
2.60
2.30
2.05
1.83
3.84
3.35
2.93
2.61
1.06
Page 8 of 17
www.sitime.com
Pin 1 Configuration Options
(OE, ST
̅ ̅ ̅ , or NC)
Pin 1 of the SiT8008 can be factory-programmed to support
three modes: Output Enable (OE), standby ( ST
̅ ̅ ̅ ) or
No Connect (NC). These modes can also be programmed
with the Time Machine using field programmable devices.
Output Enable (OE) Mode
In the OE mode, applying logic Low to the OE pin only
disables the output driver and puts it in Hi-Z mode. The core
of the device continues to operate normally. Power
consumption is reduced due to the inactivity of the output.
When the OE pin is pulled High, the output is typically
enabled in
