MMA-062020-C3
6-22GHz, 0.1W Gain Block
Data Sheet
Features:
Frequency Range: 6 – 22 GHz
P1dB: 18.5 dBm @Vdd=5V
P3dB: 19.5 dBm @Vdd=5V
Gain: 14 dB
Vdd =3 to 6 V
Ids = 130 mA
Input and Output Fully Matched to 50 Ω
Applications:
Communication systems
Microwave instrumentations
ECM
Functional Block Diagram
Description:
The MMA-062020 is a broadband GaAs MMIC general purpose gain block for 19.5dBm saturated maximum output
power and high gain over full 6 to 22GHz frequency range. This amplifier was optimally designed for broadband
applications requiring flat gain with excellent input and output port matches.
Absolute Maximum Ratings:
SYMBOL PARAMETERS
(Ta= 25 C)*
UNITS
Vd1, Vd2 Drain-Supply Voltage
Min.
Max.
V
6.5
Id1
Drain Supply Current
mA
70
Id2
mA
84
Pin max
RF Input Power
dBm
Toper
Operating Temperature
ºC
-40 to +85
Tch
Channel Temperature
ºC
+150
Tstg
Storage Temperature
ºC
-55 to +165
Tmax
Max. Assembly Temp (60 sec max)
ºC
+300
*Operation of this device above any one of these parameters may cause permanent damage.
MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538
510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com
Data sheet is subject to change without notice. All rights reserved ©
Please visit MwT website www.mwtinc.com for information on other MwT MMIC
products. Page 1 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Electrical Specifications:
Vds=5V, Ids=130mA, Ta=25 C Z0=50 ohm
Parameter
Units
Typical Data
Frequency Range
Gain (Typ / Min)
Gain Flatness (Typ / Max)
Input RL(Typ/Max)
Output RL(Typ/Max)
Output P1dB(Typ/Min)
Output IP3 (1)
Output Psat(Typ/Min)
Operating Current at P1dB
(Typ/Max)
Thermal Resistance
GHz
dB
+/-dB
dB
dB
dBm
dBm
dBm
6 - 22
14 / 13.5
0.8 / 1
8/6
10/7
18.5/18
28
19.5/18.5
mA
130 / 132
C /W
65
(1) Output IP3 is measured with two tones at output power of 0 dBm/tone separated by 20 MHz.
Please visit MwT website www.mwtinc.com for information on other MwT MMIC products.
Page 2 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Typical RF Performance:
Vds=5V, Ids=130mA, Z0=50 ohm, Ta=25 ºC
S11, S21, S22 (dB)
10
DB(|S(1,1)|)
MEAS_PKG
5
DB(|S(2,1)|)
MEAS_PKG
DB(|S(2,2)|)
MEAS_PKG
-5
-10
-15
-20
2
4
6
8
10
12
14 16 18 20
Frequency (GHz)
22
24
26
28
30
S11[dB], S21[dB], and S22[dB] vs. Frequency
IM3 level [dBc] vs. Output power/tone [dBm]
P-1 and Psat vs. Frequency
Pout[dBm], Gain[dB], and Ids[mA] vs. Input power [dBm]
Page 3 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Typical Bias dependent RF Performance:
16
S21 (dB)
14
12
10
8
DB(|S(2,1)|)
sp_TRL_3V130mA
6
DB(|S(2,1)|)
sp_TRL_4V130mA
4
DB(|S(2,1)|)
sp_TRL_5V130mA
2
DB(|S(2,1)|)
sp_TRL_6V130mA
4
6
8
10
12
14 16 18 20
Frequency (GHz)
22
24
26
28
30
24
26
28
30
24
26
28
30
S21(dB) over voltage
Bias dependent P1 vs. Frequency
-4
S11 (dB)
-6
-8
-10
-12
DB(|S(1,1)|)
sp_TRL_3V130mA
-14
DB(|S(1,1)|)
sp_TRL_4V130mA
-16
DB(|S(1,1)|)
sp_TRL_5V130mA
-18
DB(|S(1,1)|)
sp_TRL_6V130mA
-20
2
4
6
8
10
12
14 16 18 20
Frequency (GHz)
22
S11(dB) over Voltage
DB(|S(2,2)|)
sp_TRL_3V130mA
-2
DB(|S(2,2)|)
sp_TRL_4V130mA
-4
S22 (dB)
Bias dependent P-3 vs. Frequency
-6
DB(|S(2,2)|)
sp_TRL_5V130mA
-8
DB(|S(2,2)|)
sp_TRL_6V130mA
-10
-12
-14
-16
-18
-20
2
4
6
8
10
12
14 16 18 20
Frequency (GHz)
22
S22(dB) over Voltage
Page 4 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Typical Over Temperature RF Performance: Vds=5V, Ids=130mA, Z0=50 ohm, Ta=25 ºC
P1 over temperature
S21(dB) over temperature
P-3 over temperature
S11(dB) over temperature
Page 5 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Applications
The MMA-062020-C3 is a GaAS PHEMT amplifier designed for Class-A condition, flat gain performance from
6GHz to 22GHz. It is applicable for cascadable gain stage for EW amplifiers, buffer stages, LO drivers, and
transmitter amplifiers used in commercial communication systems. This amplifier is provided as a 3x3mm QFN
package, and the packaged amplifier is fully compatible with industry standard high volume surface mount PCB
assembly processes.
Biasing and Operation
The MMA-062020-C3 is normally biased with a single positive supply voltage connected to both Vd1 and Vd2
pins. The recommended drain supply voltages are 3 to 6 volts. RF input and output ports are DC decoupled
internally. Typical DC supply connection with bi-passing capacitors for the MMA-062020-C3 is shown in
following pages.
Assembly Techniques
GaAs MMICs are ESD sensitive. ESD preventive measures must be employed in all aspects of storage,
handling, and assembly. MMIC ESD precautions, handling considerations, die attach and bonding methods are
critical factors in successful GaAs MMIC performance and reliability.
Page 6 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Package Pin-out:
3 +/- 0.13
Pin #1 Dot
0.3
12
10
1
Pin #1
9
0.5
3 +/- 0.13
3
7
4
6
2.1
1.5
SQUARE
0.8
Pin
2
8
12
10
1, 3, 7, 9, 13 (center pad)
4, 5, 6, 11
Description
RF Input
RF Output
Vd1
Vd2
Ground
N/C
Page 7 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Application Circuit:
Vdd1
Vdd2
3
GND PAD
13
4
GND
2
9
8
7
RF Output
GND
RF OUT
GND
6
RF IN
1
10
12
GND
5
RF Input
11
0.1uF
0.1uF
Page 8 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Recommended Application Board Design:
Board Material is 10mil (Dielectric) thickness Rogers 4350B with 0.5oz cupper clads. Board is soldered on a
gold plated solid cupper block and adequate heat-sinking is required for 0.7W total maximum power dissipation.
Vd1
C1
Vd2
C2
RF_OUT
RF_IN
Part
C1, C2
Description
0.1uF capacitor (0603)
Page 9 of 10, Updated June 2019
MMA-062020-C3
Data Sheet
Board Material is 10mil (Dielectric) thickness Rogers 4350B with 0.5oz cupper clads. The board material and
mounting pattern, as defined in the data sheet, optimizes RF performance and is strongly recommended. An
electronic drawing of the land pattern is available upon request from MwT Sales & Application Engineering.
GCWG layout Close-up
0.1
0.35
1.0
0.6
0.2
0.25
1.1
0.2
0.6
Plated Through Hole D=0.3
All units are in millimeters.
Underneath of the package must be
Cupper filled plated through holes.
D=0.3mm and Space=0.5mm
Total Via-holes = 3 x 3
Page 10 of 10, Updated June 2019
