MMA-020624-P3EV
MMA-020624-P3EV
    MWT
MMA-020624-P3EV 数据手册
MMA-020624-P3 2000-6000 MHz Fully Matched High Dynamic Range Amplifier Data Sheet Nov 2011 Features: • • • • • • • P1dB: +25 dBm OIP3: +40 dBm Pave: +18.5 dBm @ 2.5% EVM 802.16 / 64QAM Gain: 17 dB Single +8V Supply MTTF > 100 years @ 85ºC ambient temperature RoHS Compliant Surface-Mount QFN 3X3mm Package Applications: • • • WiMax Instrumentation Point-to-Point Microwave Radio Description: The MMA-020624-P3 is a high linearity GaAs MESFET MMIC amplifier utilizing MwT’s proprietary linear device technology. Applications include the driver amplifiers in 3G cellular and WiMax/WLAN infrastructure base stations, access points and gain-block amplifiers in 2-6 Ghz range. The third order intercept performance of the MMA-020624-P3 is excellent, typically 15 dB above the Output power at 1 dB gain compression point. It provides +25 dBm P1dB, +40 dBm OIP3, +18.5 dBm Pave @ 2.5% EVM under 802.16/64 QAM input signal and 17 dB gain. Typical RF Performance: Vds=8.0V, Ids=250mA, Ta=25 ºC Z0=50 ohm Parameter Units Frequency Range Gain (Typ / Min) Gain Flatness (Typ / Max) Input Return Loss Output Return Loss Output P1dB Output IP3 (1) Pout @ 2.0% EVM Noise Figure Operating Current Range (Typ / Max) Thermal Resistance MHz dB +/-dB dB dB dBm dBm dBm dB Typical Data 2000-4000 17 / 15 1.0 / 1.5 12 12 25 40 4000-6000 13 / 11.5 1.3 / 1.5 12 10 24 40 18 3.5 mA 250 / 300 °C /W 30 (1) Output IP3 is measured with two tones at output power of 13 dBm/tone separated by 10 MHz. MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-651-2208 WEB www.mwtinc.com email info@mwtinc.com Data contained herein is subject to change without notice. All rights reserved © 2007 Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 1 of 4, Updated Nov 2011 MMA-020624-P3 2000-6000 MHz Fully Matched High Dynamic Range Amplifier Data Sheet Nov 2011 Typical RF Performance: Vds=8V, Ids=250mA, Z0=50 ohm, Ta=25 ºC MMA-020624 Return Loss vs Frequency 20 0 15 -5 Gain(dB) Gain(dB) MMA-020624 Gain vs Frequency 10 -10 -15 5 -20 0 0 1 2 3 4 5 6 7 0 8 1 2 3 Gain Freq(GHz) 4 5 6 7 8 Input RL Output RL Freq(GHz) MMA-020624 Output IP3 vs Frequency MMA-020624 Output Power vs Frequency 28 44 27 42 OIP3(dBm) Power(dBm) 26 25 24 23 22 40 38 36 21 20 34 1 2 3 4 5 6 7 1 Freq(GHz) 3 4 5 6 7 Output IP3 Freq(GHz) MMA-020624 EVM vs Channel Power 3.5GHz (64QAM Modulation) MMA-020624 EVM vs Channel Power 2.5GHz (64QAM Modulation) 8 8 7 7 6 6 5 5 EVM(%) EVM(%) 2 Output P-1 4 3 4 3 2 2 1 1 0 0 11 12 13 14 15 Freq(GHz) 16 17 18 19 20 2.4GHz EVM 21 11 12 13 14 15 16 17 Freq(GHz) MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-651-2208 WEB www.mwtinc.com email info@mwtinc.com Data contained herein is subject to change without notice. All rights reserved © 2007 Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 2 of 4, Updated Nov 2011 18 19 20 3.5GHz EVM 21 MMA-020624-P3 2000-6000 MHz Fully Matched High Dynamic Range Amplifier Data Sheet Nov 2011 Absolute Maximum Ratings: SYMBOL Vds Ids Pdiss Pin max (Ta= 25 °C)* PARAMETERS Drain-Source Voltage Drain Current DC Power Dissipation RF Input Power UNITS V mA W dBm ABSOLUTE MAXIMUM 9.0 300.0 2.7 +24.0 Tch Channel Temperature C 150.0 Tstg Storage Temperature C -60.0 to 150.0 *Operation of this device above any one of these parameters may cause permanent damage. Typical Scattering Parameters: Freq (GHz) Vds=8.0V, Ids=250mA, Z0=50 ohm, Ta=25 ºC S11 S21 S12 S22 Mag - Ang Mag - Ang Mag - Ang Mag - Ang 2.0 0.842 17.6 0.775 39.5 0.0179 -40.5 0.747 -1.97 2.2 0.805 -13.8 0.918 14.7 0.0198 -68.5 0.654 -38.9 2.4 0.758 -45.4 1.07 -6.5 0.0216 -94.2 0.542 -78.8 2.6 0.675 -76.6 1.38 -26.2 0.0241 -117 0.384 -122 2.8 0.579 -105 2.04 -53.7 0.0303 -139 0.202 -176 3.0 0.483 -127 2.82 -91.9 0.0407 -168 0.0817 65.2 3.2 0.459 -145 3.39 -135 0.0506 154 0.179 -29.5 3.4 0.471 -169 3.61 -175 0.0567 116 0.248 -70.2 3.6 0.467 163 3.71 147 0.0596 79.4 0.286 -99.8 3.8 0.442 131 3.8 111 0.0619 43.7 0.319 -127 4.0 0.396 96.8 3.88 75.8 0.0633 8.36 0.345 -156 4.2 0.328 56.9 3.9 40.4 0.0659 -25.8 0.354 173 4.4 0.25 5.93 3.81 5.06 0.0694 -61.5 0.342 142 4.6 0.206 -66.2 3.76 -30.6 0.0719 -98.3 0.294 111 4.8 0.26 -144 3.6 -67.5 0.0683 -136 0.21 81.2 5.0 0.384 160 3.35 -105 0.0657 -173 0.114 53 5.2 0.499 114 2.98 -142 0.0628 152 0.0246 62.6 5.4 0.584 72.7 2.59 -177 0.0593 118 0.0718 140 5.6 0.646 33.8 2.22 150 0.0559 85.3 0.132 116 5.8 0.69 -3.61 1.89 118 0.0507 53.1 0.177 85.3 6.0 0.732 -39.7 1.61 85.3 0.0458 22.7 0.213 52.4 MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-651-2208 WEB www.mwtinc.com email info@mwtinc.com Data contained herein is subject to change without notice. All rights reserved © 2007 Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 3 of 4, Updated Nov 2011 MMA-020624-P3 2000-6000 MHz Fully Matched High Dynamic Range Amplifier Data Sheet Nov 2011 Mechanical Information: QFN 16 LEAD , 3 X 3 mm This Package is RoHS compliant All dimensions are in mm Pin Assignment Pin # Function Pin # Function 1 2 3 4 5 6 7 8 n/c RF in RF in n/c n/c n/c n/c n/c 9 10 11 12 13 14 15 16 n/c RF out RF out n/c n/c Vdd Vdd n/c MicroWave Technology, Inc. an IXYS Company, 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-651-2208 WEB www.mwtinc.com email info@mwtinc.com Data contained herein is subject to change without notice. All rights reserved © 2007 Please visit MwT website www.mwtinc.com for information on other MwT MMIC products. Page 4 of 4, Updated Nov 2011
MMA-020624-P3EV 价格&库存
很抱歉,暂时无法提供与“MMA-020624-P3EV”相匹配的价格&库存,您可以联系我们找货
