HSCP-HRFCJ-1AS(60)
HSCP-HRFCJ-1AS(60)
    HRS(广濑)
HSCP-HRFCJ-1AS(60) 数据手册
SC Type Fiber Optic Connectors Environment MU Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC SC HSC Series ■Features 1. IEC, JIS standard compliant and intermateability test certified. Comply with IEC 61754-4 and JIS C 5973(F04). SC intermate test by NTT certified connector. 2. Flame resistant Satisfies flammability rating UL94V-0. Attenuators 3. Three types of Duplex SC connector Available in following types; Flexible F type – Floating mechanism and comply with ANSI standards. Rigid F type – 12.7mm spacing between the fibers, low profile and compatibility with the flexible F-type. Rigid H type – 8.5mm spacing between the fibers and for high density applications. 4. Simplified plugs and receptacles POF / PCF Terminators Small size (23.8 mm plug length). SC simplified plug is designed for equipments inside connection.Comply with IEC 61754-4-1. 6 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. HSC Series●SC Type Fiber Optic Connectors ■Product Specifications Ratings Operating temperature range -25°C to +70°C Storage temperature range -25°C to +70°C SC Optical Characteristics Item Insertion Loss Return Loss Test Method (IEC 61300) Specifications (SM) Wavelength 1310nm (LD) 0.5dB max. (PC, AdPC, APC) (GI) Wavelength 1310nm (LED) 0.3dB max. (PC) Wavelength 1310nm (LD) 22dB min. (PC) 40dB min. (AdPC) 60dB min. (APC) (SM) (GI) 22dB min. (PC) Mechanical Characteristics Ferrule withdrawal force Extract zirconia gauge 2.499 ±0.0005 mm dia from split sleeve. Copper alloy split sleeve Zirconia split sleeve Cable retention (Straight pull) 89N tensile load for one minute. 1) Insertion loss fluctuation after test: 0.2dB max. 2) No visible damage, dislocation of clamp or cable. Durability (cycles, mating/un-mating) 1000 times Duplex plug 2N to 5.9N 2N to 3.9N Vibration Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 axis. Shock Acceleration of 981 m/s2, 6 ms duration, half sine shock pulse, 10 cycles in each of the 3 axis. Humidity (Temperature/ humidity- cycles) -10°C to +65°C, humidity: 90% to 96% 10 cycles Change of temperature -40°C to +75°C 42 cycles (Complies with Telcordia standard GR-326-CORE) Dry heat 240 hours at 85°C Cold 240 hours at -25°C Salt mist 48 hours in a 5% concentration of salt mist 1) Insertion loss fluctuation after test: 0.2dB max. 2) No visible damage, cracks or part dislocation. Harsh Environment Environmental Characteristics Measured with corresponding connector. MU No significant corrosion. Attenuators ■Materials Part Material Simplex plug housing Synthetic resin Spring Stainless steel Ferrule Zirconia Simplex adapter housing Synthetic resin or Zinc alloy 4-position adapter housing Synthetic resin 5-position adapter housing Synthetic resin Receptacle housing Zinc alloy Split sleeve Zirconia or Phosphor Bronze Dust cap Synthetic resin Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Engagement force: 19.6 N max. Separation force: 19.6 N max. Engagement force: 39 N max. Separation force: 39 N max. FC Simplex plug Engagement and Separation force POF / PCF 7 HSC Series●SC Type Fiber Optic Connectors ■Function diagram SC Plugs Ferrules Pre-dome APC FC Flat Manual coupling/ decoupling type Simplex MU Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh Plug housings Duplex F-type Duplex Flexibility type Environment Tool decoupling type Simplex Adapters Attenuators Manual coupling/ decoupling type Simplex Duplex F-type Terminators Tool decoupling type 4-position 5-position * * Conversion adapters POF / PCF SC - FC SC - FC SC - FC Note *Please refer to the section HRFC. Receptacle 8 Duplex H-type HSC Series●SC Type Fiber Optic Connectors SC Simplified plugs & receptacles Plugs FC Manual coupling/ decoupling type Simplex MU Duplex H-type Duplex F-type 4-position 8-position Duplex F-type (built-in shutter only one port) Tool decoupling type Harsh Environment Split sleeve Attenuators Caps For plug Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacles For adapter POF / PCF 9 HSC Series●SC Type Fiber Optic Connectors 1. Ferrules SC ① It is not possible to connect it with a ferrule alone. Please use it with the plug housing. Ø1 (Hole diameter) 16 7.95 +00.05 1.8 Part Number CL No. A dimension HSC-F321-A125(10) 704-0070-9-10 0.125 HSC-F321-A1255(10) 704-0200-2-10 0.1255 HSC-F321-A126(10) 704-0071-1-10 0.126 Ø4.6 (Hole diameter) A dimension 0.125 704-0571-4-00 0.1255 HSC-F3E2-A126 704-0591-1-00 0.126 %#%* &#- Terminators POF / PCF 10 Applicable Fiber cable SM-9.5/125 GI-50/125 ¢)#+ ¢6 %#%%& % &+#&* -#%.* % ( &#* =daZY^VbZiZg 704-0590-9-00 HSC-F3E2-A1255 ¢'#)..¤%#%%%* HSC-F3E2-A125 ●For APC Attenuators 16 7.95 +00.05 1.8 CL No. SM-9.5/125 GI-50/125 ¢&=daZY^VbZiZg Part Number ¢& Environment 3 Ø2.499±0.0005 1.5 ØA+0.001 0 R20 Applicable Fiber cable Ø1(Hole diameter) ●For PC, AdPC and UPC(Pre-dome) MU Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC 3 Ø2.499±0.0005 1.5 Ø4.6 ●For PC, AdPC and UPC(Flat) (Hole diameter) ØA+0.001 0 ② The angle of the fiber entrance (cone) is 60 degrees or 90 degrees. Part Number CL No. A dimension HSC-F391-A125(40) 704-3101-7-40 0.125 HSC-F391-A1255(40) 704-3130-5-40 0.1255 HSC-F391-A126(40) 704-3102-0-40 0.126 Applicable Fiber cable SM-9.5/125 HSC Series●SC Type Fiber Optic Connectors 2. Plug Housings Please use them with the ferrule. SC ■Manual coupling / decoupling type 33 ●Light weight type (For 0.9mm fiber) 9 1.8 25 0.9 Part Number CL No. Boot color HSC-PH0.9-E1(26) 704-0339-2-26 Blue HSC-PH0.9-E2(51) 704-0354-6-51 Light purple HSC-PH0.9-E5(51) 704-3104-5-51 Green ●Strain relief type Slider color Polishing type PC Blue AdPC Green APC MU 55 9 1.8 25 7.4 0.9 CL No. HSC-PH2-E1(64) 704-0327-3-64 HSC-PH2-E2(75) 704-0328-6-75 HSC-PH2-E5(62) 704-3108-6-62 HSC-PH3-B1(68) 704-0222-5-68 HSC-PH3-B2(68) 704-0223-8-68 HSC-PH3-B5(62) 704-3020-7-62 Fiber cable type Slider color Boot color Polishing type Outer jacket fixing Ø2mm Blue Blue PC Light purple AdPC Green APC Green Ø3mm Blue Blue PC Light purple AdPC Green APC Green Crimp Attenuators Part Number Harsh Environment Crimp ●Short length type (For 2mm Cable) 36.5 25 9 1.8 Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FC 7.4 7.4 0.9 Slider color CL No. 704-0464-4-62 HSC-PH2-E2-A(62) 704-0480-0-62 HSC-PH2-E5-A(60) 704-3124-2-60 Green Blue Boot color Polishing type Blue PC Light purple AdPC Green APC Outer jacket fixing POF / PCF Part Number HSC-PH2-E1-A(62) Glue 11 HSC Series●SC Type Fiber Optic Connectors 22.1 12.7 SC ●Duplex F-type 7.8 25 Part Number HSCF-2PH2-E1(P)(62) HSCF-2PH2-E2(P)(62) HSCF-2PH3-B1(P)(63) HSCF-2PH3-B2(P)(65) MU CL No. Applicable Fiber cable 704-2109-3-62 Guide key Slider color Ø2mm 704-2120-6-62 Blue P 704-2032-0-63 Ø3mm 704-2036-1-65 Boot Color Polishing type Blue PC Light purple AdPC Blue PC Light purple AdPC ●Duplex Flexibility type (Comply with ANSI), for single Mode 8.99 1 Environment 23 12.7 1.8 9.9 14.1 36.7 Attenuators 61.5 Slider color Part Number CL No. Applicable Fiber cable HSCM-2SPH2-B1(60) 704-2100-9-60 Simplex-2mm dia. cable or dual fiber zip cable HSCM-2SPH3-B1(60) 704-2102-4-60 Simplex-3mm dia. cable or dual fiber zip cable HSCM-2SPH2-B2(60) 704-2133-8-60 Simplex-2mm dia. cable or dual fiber zip cable Black Boot Color Polishing type Blue PC Light purple AdPC The pitch size between plugs is flexible. It is possible to connect it with duplex F-type adapter. Terminators ●Duplex Flexibility type (Comply with ANSI), for Multi-mode 8.99 23 12.7 1.8 9.9 1.8 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC 55 14.1 36.7 POF / PCF 61.5 Part Number CL No. Applicable Fiber cable HSCM-2GPH2-B1(60) 704-2104-0-60 Simplex-2mm dia. cable or dual fiber zip cable HSCM-2GPH3-B1(60) 704-2106-5-60 Simplex-3mm dia. cable or dual fiber zip cable The pitch size between plugs is flexible. It is possible to connect it with duplex F-type adapter. 12 Slider color Black Boot Color Polishing type Blue PC HSC Series●SC Type Fiber Optic Connectors ■Tool decoupling type SC ●Light weight type (For 0.9mm fiber) 7.2 33 6 FC CL No. Boot Color Polishing type HSC2-PH0.9-E1(51) 704-0421-1-51 Blue PC HSC2-PH0.9-E2(51) 704-0422-4-51 Light purple AdPC ●Strain relief type MU 7.2 55 6 Part Number CL No. HSC2-PH2-E1(69) 704-0329-9-69 HSC2-PH2-E2(68) 704-0330-8-68 HSC2-PH3-B1(63) 704-0226-6-63 HSC2-PH3-B2(63) 704-0227-9-63 Harsh Environment Fiber cable type Boot color Polishing type Outer jacket fixing Ø2mm Ø3mm Blue PC Light purple AdPC Blue PC Light purple AdPC Glue Crimp Attenuators Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Number POF / PCF 13 HSC Series●SC Type Fiber Optic Connectors 3.Adapters & Receptacles BPanel cutout 9.4 1.8 18 22 12.8 27.4 3 18±0.1 ●SC/SC Plastic Housing 13 +0.5 -0.5 SC ■Manual coupling / decoupling type Ø2.3 Part Number 0.5 0.5 2-M2×0.4 or 2-Ø2.4 Panel thickness: 1.6mm CL No. Split sleeve HSC-A3(51) 704-0092-1-51 Phosphor Bronze HSC-A3-D1(02) 704-0217-5-02 Zirconia HSC-A3-D2(06) 704-3007-9-06 Zirconia +0.2 0.5 Remarks PC,AdPC(Blue) APC(Green) BPanel cutout ●SC/SC Die Cast Metal Housing 9.4 13 +0.5 -0.5 1.8 Environment 18 22 12.8 27.4 3 18±0.1 MU 9.5 0.5 0.5 2-M2×0.4 or 2-Ø2.4 Ø2.3 +0.2 0.5 Panel thickness: 1.6mm Part Number Attenuators CL No. Split sleeve HSC-A2(50) 704-0020-0-50 Phosphor Bronze HSC-A2-D1(01) 704-0258-2-01 Zirconia BPanel cutout ●SC/SC Plastic Housing (Short flange) ',#) .#) Terminators .#* &( &#- &'#- ( &)#- Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC 9.5 EVcZai]^X`cZhh/&#+bb CL No. Split sleeve Snap in latch for panel mount HSC-AFR-D1(01) 704-0572-7-01 Zirconia without latch HSC-AFR-D2(01) 704-0573-0-01 Zirconia with latch Part Number Remarks PC,AdPC(Blue) POF / PCF Note: When applying excessive force to the plug or inserting in an odd angle, the adapter housing might be damaged. 14 HSC Series●SC Type Fiber Optic Connectors ●SC/SC Plastic Housing (With shutter) ',#) && SC H]jiiZg"aZhhh^YZ CL No. Split sleeve Remarks HSC-AFL1-S1-D1 704-0593-7-00 Zirconia PC, AdPC(Blue) HSC-AFL1-S1-D2 704-3141-1-00 Zirconia APC(Green) Features With built-in automatic shutter. MU 6[iZgbVi^c\ 7Z[dgZbVi^c\ Harsh Environment BdkZbZcid[i]Zh]jiiZg Attenuators Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. H]jiiZgh^YZ FC Part Number &)#- &'#- ( POF / PCF 15 HSC Series●SC Type Fiber Optic Connectors ●F type Snap-in and/or Screw Mounting BPanel cutout #( ¢' .#* '*#. . &'#, ()#, (%#, SC '"B'%#)dg '"¢'#) %%#' '+#' %%#( (%#,¤%#& ( &#',#) .#) CL No. Split sleeve HSCF-2A(P)(51) 704-2008-6-51 Phosphor Bronze HSCF-2A-D(P)(06) 704-2040-9-06 HSCF-2A-D2(P)(06) 704-2112-8-06 APC(Green) 27.4 15.5 12.8 18 +00.5 +0.3 0 Panel thickness: 1.6mm Part Number CL No. Split sleeve HSCH-2A1(P)(51) 704-2066-2-51 HSCH-2A1-D2(P) 704-2137-9-00 Remarks Phosphor Bronze PC, AdPC(Blue) Zirconia ●H type Snap-in and/or Screw Mounting APC(Green) BPanel cutout 2-M2∞0.4 or 2-Ø2.4 +00.2 17.9 (8.5) 3 1.8 18 12.8 18 +0.5 0 Ø2.3 23 13 1.8 3 (8.5) Environment PC, AdPC(Blue) BPanel cutout 20.5 17.9 Attenuators Remarks Zirconia ●H type Snap-in MU Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC Part Number Panel thickness: 1.6mm 13 +0.3 0 18±0.1 27.4 Terminators Panel thickness: 1.6mm POF / PCF Part Number 16 CL No. Split sleeve HSCH-2A(P)(51) 704-2020-1-51 Phosphor Bronze HSCH-2A-D(P)(02) 704-2062-1-02 HSCH-2A-D2(P)(03) 704-2108-0-03 Zirconia Remarks PC, AdPC(Blue) APC(Green) HSC Series●SC Type Fiber Optic Connectors ■Tool decoupling type +0.2 28.5 -0.5 1.8 28.2 15 12.8 24 3 SC BPanel cutout ●SC2/SC2 4-way adapter 13 +0.5 0.5 Panel thickness: 1.6mm Split sleeve 704-0024-1-51 Phosphor Bronze Remarks HSC2-4A-D1(01) 704-0290-5-01 Zirconia PC,AdPC(Blue) Note: When applying excessive force to the plug or inserting in an odd angle, the zirconia sleeve within the adapter might be damaged. BPanel cutout ●SC2/SC2 5-way adapter(for Multi-mode fiber) 35 15 MU 35.3 +0.5 +0.5 1.8 12.8 24 3 +0.5 13 +0.5 Panel thickness: 1.6mm HSC2-5A(51) CL No. Split sleeve Remarks 704-0025-4-51 Phosphor Bronze PC,AdPC(Blue) Harsh Environment Part Number Note: When applying excessive force to the plug or inserting in an odd angle, the zirconia sleeve within the adapter might be damaged. ■Conversion adapters ●FC / SC Screw Mounting BPanel cutout Ø9 +0.5 0.5 2-M2×0.4 or 2-Ø2.4 Attenuators 13.4 9 21.2 5.5 3.5 12.2 +0.2 +0.5 Ø19 12.8 M8 × 0.75 13.4±0.1 15 Part Number HSCJ-HRFCJ-B(43) CL No. Split sleeve 704-0021-3-43 Phosphor Bronze Terminators Note: The type of SC plug that can be mated is manual coupling/decoupling type. BPanel cutout ●FC / SC Snap-in and/or Screw Mounting 9.4 Part Number HSCJ-HRFCJ-C(43) 2-M2×0.4 +0.2 or 2-Ø2.4 +0.5 POF / PCF M8 × 0.75 +0.5 0.5 18 22 Ø9 12.8 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Number FC CL No. HSC2-4A(51) 18±0.1 1.8 21.2 Ø2.3 Panel thickness: 1.6mm CL No. Split sleeve 704-0206-9-43 Phosphor Bronze Note: The type of SC plug that can be mated is manual coupling/decoupling type. 17 HSC Series●SC Type Fiber Optic Connectors SC ■Receptacles 15 12.8 13.4 9 Ø19 Ø7 Ø3 15.2 12.2 2-Ø2.3 CL No. Remarks HSC-R1-B(41) 704-0022-6-41 For MM HSC-R2-B(41) 704-0023-9-41 For SM Note: The type of SC plug that can be mated is manual coupling/decoupling type. POF / PCF Terminators Attenuators Environment MU Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC Note: Designed for power meter sensors Part Number 18 HSC Series●SC Type Fiber Optic Connectors 4. Simplified plugs & receptacles SC ■Features 1.This product greatly reduced the number of parts compared with the SC connector, and achieved cost-saving. SC plug Simplified receptacle SC adapter MU Harsh Environment Attenuators Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FC Simplified plug 2.It achieved space-saving by using this product inside of the system. POF / PCF 3.Please use a special tool when you decouple the plug. 19 HSC Series●SC Type Fiber Optic Connectors ■Simplified plug &+#' &%#( )#* * * ¢'#).. ●Simplified plug(Flat) ¢6=daZY^VbZiZg SC Please use the special decoupling tool when you unmate the simplified plug. ¢'#).. &%#( )#* l^i]Wddih Part Number CL No. 704-0267-3-56 0.125 HSC2-FK-A1255(56) 704-0269-9-56 0.1255 HSC2-FK-A126(56) 704-0268-6-56 0.126 HSC2-FK-A125(51) 704-0267-3-51 0.125 HSC2-FK-A1255(51) 704-0269-9-51 0.1255 HSC2-FK-A126(51) 704-0268-6-51 0.126 Remarks without boots with boots &+#' &%#( )#* * * ¢'#).. ●Simplified plug(Pre-dome) Environment A dimension HSC2-FK-A125(56) ¢6=daZY^VbZiZg MU (l^i]djiWddih) '(#&%#( )#* * * ¢'#).. Attenuators G'% ¢6=daZY^VbZiZg Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh * * '(#- ¢6=daZY^VbZiZg FC l^i]djiWddih G'% POF / PCF Terminators Part Number 20 (l^i]Wddih) CL No. A dimension HSC2-FK2-A125(56) 704-0407-0-56 0.125 HSC2-FK2-A1255(56) 704-0408-3-56 0.1255 HSC2-FK2-A126(56) 704-0409-6-56 0.126 HSC2-FK2-A125(51) 704-0407-0-51 0.125 HSC2-FK2-A1255(51) 704-0408-3-51 0.1255 HSC2-FK2-A126(51) 704-0409-6-51 0.126 Remarks without boots with boots HSC Series●SC Type Fiber Optic Connectors ■Simplified receptacle to SC '" ¢' #( ●Simplex / Shrouded &*#' SC BPanel cutout '"B'×%#)dg'"¢'#) %%#' %#* % &( &- ¤%#& &'#- '' &&'#. H8 HG ?6E6C ( .#) '+ CL No. Split sleeve HSC-SR-1(51) 704-0320-4-51 Phosphor Bronze HSC-SR-D1(02) 704-0321-7-02 Zirconia HSC-SR-1(03) 704-0320-4-03 None %#* % #( Note. The type of SC plug that can be mated is manual coupling/decoupling type. ¢' '" MU BPanel cutout SC ●Simplex / Unshrouded SR &'#, %%#* &-¤%#& &'#* +#( '' &&'#* . '"B'×%#)dg'"¢'#) %%#' JAPAN ( ,#) .#) .#(* &+#' ,#- Part Number Harsh Environment CL No. Split sleeve HSC-SR-2(51) 704-0291-8-51 Phosphor Bronze HSC-SR-D2(06) 704-0292-0-06 Zirconia HSC-SR-2(03) 704-0291-8-03 None %#* % Note. The type of SC plug that can be mated is manual coupling/decoupling type. &,#. &*#. -#* BPanel cutout '+ &*#* &#- ( '"B'×%#)dg'"¢'#) %%#' &( %%#* &-¤%#& ¢' '" ,#) Panel thickness: 1.6mm #( Part Number Terminators &'#- &- '( &&'#. %#* % ●Duplex H type / Shrouded Attenuators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Number .#* FC ,#) CL No. Split sleeve HSCH-2SR-1(R)(51) 704-0293-3-51 Phosphor Bronze HSCH-2SR-D1(R)(01) 704-0294-6-01 Zirconia Note. The type of SC plug that can be mated is manual coupling/decoupling type. POF / PCF 21 '" ¢' #( HSC Series●SC Type Fiber Optic Connectors '*#* +#( %#' % '"B'%#)dg'" ¢'#) - . %#* % &. ()#, '*#* '&#, &'#, SC 'HG BPanel cutout H8G ●Duplex F type / Unshrouded &+#' ( .#) Part Number '*#, %%#* (%#,¤%#& ,#- CL No. Split sleeve HSCF-2SR-2(P)(51) 704-0295-9-51 Phosphor Bronze HSCF-2SR-2(P)(03) 704-0295-9-03 None Note. The type of SC plug that can be mated is manual coupling/decoupling type. ●Duplex F type / Shrouded, built-in shutter type Environment BPanel cutout 37 26 34.7 .1 +0 0 13±0.05 13 12.7 25.5 2.5 9 30.7 MU 2- .4 Ø2 30.7±0.1 2-Ø 6 2.3 Part Number HSCF-2SR-S2 CL No. Split sleeve 704-0516-6-00 None #( ●4-Position / Shrouded '" BPanel cutout ')#( &%#,( #) or 4SR JAPAN JAPAN -%%#* (,#) ((#) '-#' 4SR £% '"B' &'#) Terminators '-#+%%#* Attenuators π The type of SC plug that can be mated is manual coupling/decoupling type. Note. The shutter is built into only one of ports. ¢' Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC ,#) .#) Part Number &'#,%%#* CL No. Split sleeve HSC2-4SR-1(51) 704-0311-3-51 Phosphor Bronze HSC2-4SR-D1(01) 704-0312-6-01 Zirconia HSC2-4SR-1(03) 704-0311-3-03 None POF / PCF Note: When applying excessive force to the plug or inserting in an odd angle, the zirconia sleeve within the adapter might be damaged. π The type of SC plug that can be mated is tool decoupling type. 22 %#' % '"¢'#) HSC Series●SC Type Fiber Optic Connectors ●8-Position / Shrouded %#' &%#, ( #)% *+ % %#* **#) + +%#+ +)#+ £%# '"B' -HG 8SR '"¢' )dg +%#+¤%#& ¢ SC BPanel cutout ')#( ( '# FC &'#) %#* &'#,% CL No. Split sleeve HSC2-8SR-D1(01) 704-0270-8-01 Zirconia HSC2-8SR-1(03) 704-0266-0-03 None Note: When applying excessive force to the plug or inserting in an odd angle, the zirconia sleeve within the adapter might be damaged. π The type of SC plug that can be mated is tool decoupling type. MU BPanel cutout ●8-Position / Unshrouded #( ¢' ¢'#) &)#* &&#* ( g'" %#)d %#' % £ '"B' Harsh Environment +)#+ +%#+ **#) *+%%#* +%#+¤%#& 8SR &'#,%%#* &'#) Part Number CL No. Split sleeve HSC2-8SR-2(51) 704-0318-2-51 Phosphor Bronze HSC2-8SR-D2(01) 704-0403-0-01 Zirconia HSC2-8SR-2(03) 704-0318-2-03 None Attenuators Note: When applying excessive force to the plug or inserting in an odd angle, the zirconia sleeve within the adapter might be damaged. π The type of SC plug that can be mated is tool decoupling type. Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Number ■Split sleeve Zirconia &&#) Copper alloy CL No. Split sleeve HSC-SLIT-SLEEVE(51) 704-0275-1-51 Phosphor Bronze HSC-D 704-0264-5-00 Zirconia POF / PCF Part Number 23 HSC Series●SC Type Fiber Optic Connectors 5. Caps SC ■For plug ●Ferrule cap &%#* #* ) ¢*#* ¢' Part Number FC 704-0420-9-20 ●Press fit to plug frame inner type cap 4-0.15 π HRS standard cap for plugs. π Press fit to ferrule outer. .6 Ø4 Ø6.5 10 MU Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh CL No. HSC-C7(20) Part Number CL No. HSC-C1 704-0484-1-00 π Press fit to plug frame inner.The cap will not touch the outiside ferrule. Environment ●Cap for SC plug housing 15 9.6 Part Number CL No. Attenuators HSC-C8 704-0542-6-00 π Press fit to outside of SC slider. ■For adapter 7.4 ●Simplex plastic cap HSC-C5 CL No. 12.5 Part Number 8.3 9 Terminators 16 12.7 704-0363-7-00 POF / PCF 7.6 π HRS standard cap for SC adapters. π The cap is inserted in the lock part of the adapter. 8.8 HSC-C9 CL No. 704-0588-7-00 π Press fit to adapter innner. 24 12.7 Part Number 9 5.8 12 HSC Series●SC Type Fiber Optic Connectors ●Simplex plastic cap Ø5.5 SC 25 Part Number CL No. HSC2-C2 704-0487-0-00 π The cap is inserted in the lock part of the adapter. FC 8.3 22.1 20 MU (75) 12.7 Part Number CL No. Remarks HSCF-C2(40) 704-2126-2-40 without cahin HSCF-C3(40) 704-2135-3-40 with cahin Harsh Environment ●Duplex H-type plastic cap 12.7 16.8 19.8 Attenuators (75) Part Number HSCH-C1(40) CL No. Remarks 704-2122-1-40 with cahin Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Duplex F-type plastic cap POF / PCF 25 HSC Series●SC Type Fiber Optic Connectors 6. Tools SC ●HSC2 Insertion/Extraction Tool FC Part Number 704-0286-8-00 HSC2 Series Note. Handle with care because slim tips breaks easily. 1.Open the tip of tool by compressing levers as shown below. MU Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh HSC-T1-L Applicable Products CL No. Environment ② 2.Insert the tool (with opening the tips) into adapter. ① 3.Release the levers (then the tool catch HSC2 plug) and you can release the connector. ● Extraction tool for Simplified plug (without boots) 7 Attenuators 6 30 6 20 Terminators 5 20 POF / PCF Part Number 26 CL No. Shape HSC-T13 704-0449-0-00 Straight HSC-T8 704-0447-5-00 L type HSC Series●SC Type Fiber Optic Connectors ● Extraction tool for Simplified plug (with boots) , SC + (% + '% Part Number CL No. Shape HSC-T10 704-0350-5-00 Straight HSC-T12 704-0448-8-00 L type MU ●Crimp Tool Harsh Environment This is used in crimping of Kevlar or jacket at time of the plug (for cable diameter 2mm & 3mm) termination. 18 12 228 Attenuators Part Number CL No. HT501/HSC-T20 CL902-6064-2 (1) 2mm Jacket crimping: Please select section"2mm". 3mm Jacket crimping: Please select section"3mm". (2) KevlarTM crimping: Please select section center round groove. Terminators Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. '% FC * ●Plug assemble tool POF / PCF Part Number HSC2-PH2/CVMD CL No. 902-6029-1 27
HSCP-HRFCJ-1AS(60) 价格&库存
很抱歉,暂时无法提供与“HSCP-HRFCJ-1AS(60)”相匹配的价格&库存,您可以联系我们找货
