CBJ3157
CBJ3157
    CINCH
CBJ3157 数据手册
4X .722 ±.030 q .430 4X .170 ±.030 .308 4X q .030 4X .013 TTM INTERFACE PER SPC-09500-43-10 CENTER CONTACT PIN .100 INNER SHIELD PIN 3/8-32 UNEF-2A 4X .060 MAX 2X O .030 MAX 4X 5 NOTES: UNLESS OTHERWISE SPECIFIED. 1. FINISH: BODY: NICKEL CENTER CONTACT PIN: GOLD INNER SHIELD PIN: GOLD 2. FEMALE SUBMINIATURE TRIAXAL THREADED PC BOARD JACK. RECOMMENDED MTG HOLE PATTERN 6X O .049 .045 q .400 4X .200 3RD ANGLE PROJECTION 4. MAXIMUM BOARD THICKNESS: .125 5. PRE-TINNED WITH SN63 OR EQUIVALENT. Trompeter Title: 3. MINIMUM CENTER TO CENTER MOUNTING: .500 .100 This PROPRIETARY Document is property of Emerson Network Power Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX u.02 .XXX u.005 ANGLES u2v TTM JACK, CIRCUIT BOARD MOUNT Model No. CBJ3157 Size A DO NOT SCALE Date: 3/5/2013 DRAWING Sheet 1 of 1
CBJ3157 价格&库存
很抱歉,暂时无法提供与“CBJ3157”相匹配的价格&库存,您可以联系我们找货
CBJ3157
  • 1+715.857211+92.92991
  • 10+608.5004310+78.99325
  • 30+563.1407230+73.10482
  • 50+543.2275950+70.51978
  • 100+517.33173100+67.15807
库存:59
