BJ150FL
BJ150FL
    CINCH
BJ150FL 数据手册
PY O.140 u.008 GROUND LUG FL 14949 YY TRS INTERFACE PER SPC-09500-43-20 SOLDER POT ACCEPTS O.034 CONDUCTOR LL .90 ED 7/16-28 UNEF-2A 1/2 HEX C 1/2 HEX NUT O LOCKWASHER O O .600 .100 TR 4X 90° .818 N 1.05u.030 O NOTES: UNLESS OTHERWISE SPECIFIED. .190 .187 O .443 .439 U N C 1. MATERIAL & FINISH: 1.1 BODY & PANEL NUT: NICKEL PLATED BRASS 1.2 CENTER CONTACT AND INTERMEDIATE CONTACT: GOLD PLATED BERYLLIUM COPPER 1.3 DIELECTRIC: PTFE (TEFLON) 1.4 GASKET: SILICON RUBBER 1.5 GROUND LUG & LOCKWASHER: NICKEL PLATED COPPER ALLOY 3RD ANGLE PROJECTION 2. ELECTRICAL 2.1 FREQUENCY (MAX): 500 MHz 2.2 IMPEDENCE: NON-CONSTANT 3. PANEL NUT TORQUE (MAX): 35 INCH POUNDS 4. PANEL THICKNESS (MAX): .250 RoHS RECOMMENDED PANEL CUTOUT This PROPRIETARY Document is property of Emerson Network Power Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. Trompeter Title: TRS BULKHEAD SOLDER POT JACK 2002/95/EC UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX u.02 .XXX u.005 ANGLES u2v Model No. BJ150FL Size A DO NOT SCALE Date: 5/9/2014 DRAWING Sheet 1 of 1
BJ150FL 价格&库存
很抱歉,暂时无法提供与“BJ150FL”相匹配的价格&库存,您可以联系我们找货
