APPLICABLE STANDARD
Operating
temperature range
Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
Storage
temperature range
Operating or storage
humidity range
-55C to 85C
Voltage
30V AC/DC
Current
0.20A
-10C TO 50C (packed condition)
Relative humidity 90% MAX (not dewed)
Applicable cable
t=0.2±0.02mm, gold plating
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
According to drawing.
(note 1,2)
① Contact resistance: 300m MAX.
② No damage, crack and loose parts.
Direction of insertion: (0.14×n)+1N MIN(note 3)
(n: Number of contacts)
Exposed at 35±2C, 5% salt water spray for 96h.
③ No evidence of corrosion which affects
connector’s operation.
Temperature-55 → +15TO+35 →+85→+15TO+35C
Time
30 →
2 TO 3 → 30→ 2 TO 3 min
Under 5 cycles.
Exposed at 40±2C,
relative humidity 90 to 95%, 96h.
② Insulation resistance: 50M MIN.
③ No damage, crack and loose parts.
Damp heat,cyclic
Exposed at -10 to +65C,
relative humidity 90 to 96%,
10 cycles, total 240h.
② Insulation resistance: 1M MIN.
(at high humidity)
③ Insulation resistance: 50M MIN.
(at dry)
④ No damage, crack and loose parts.
Dry heat
Exposed at 85±2C, 96h.
Cold
Exposed at -55±3C, 96h.
CONSTRUCTION
General examination
Visually and by measuring instrument.
Marking
Confirmed visually.
ELECTRICAL CHARACTERISTICS
Voltage proof
90V AC for 1 min.
No flashover or breakdown.
100V DC.
50M MIN.
Contact resistance
20mV AC MAX, 1mA.
300m MAX.
Including FPC, FFC bulk resistance (L=8mm)
MECHANICAL CHARACTERISTICS
Vibration
Frequency 10 to 55 Hz, half amplitude 0.75 mm,
for 10 cycles in 3 axial directions.
Shock
981 m/s , duration of pulse 6 ms at 3 times
in 3 both axial directions.
Mechanical operation
10 times insertions and extractions.
① No electrical discontinuity of 1s.
② Contact resistance: 300m MAX.
2
Measured by applicable FPC.
FPC retention force
(thickness of FPC shall be t=0.20mm at initial ondition)
ENVIRONMENTAL CHARACTERISTICS
Corrosion salt mist
Rapid change of
temperature
Damp heat
(steady state)
Sulphur dioxide
[JIS C 60068-2-42]
Hydrogen sulphide
[JIS C 60068-2-43]
COUNT
REMARK
Exposed at 40±2C,
relative humidity 80±5%,
25±5ppm for 96h.
Exposed at 40±2C,
10 to 15ppm for 96h.
DESCRIPTION OF REVISIONS
DESIGNED
Unless otherwise specified, refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
CHECKED
APPROVED
NF.MIYAZAKI
16.06.07
CHECKED
YH.MICHIDA
16.06.07
DESIGNED
SI.MIZUSAWA
16.06.07
DRAWN
OTNIEL RINALDO
16.06.06
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
DATE
ELC-370587-00-00
FH58-**S-0.2SHW
CL580
1/2
SPECIFICATIONS
ITEM
TEST METHOD
Solderability
Soldered at solder temperature 245±3C,
for immersion duration 3±0.3 sec.
Resistance to
soldering heat
1) Reflow soldering:
peak tmp. 250C MAX.
reflow tmp. over 230C within 60 sec.
2) Soldering irons:
tmp. 350±10C for 5±1 sec.
REQUIREMENTS
A new uniform coating of solder
shall cover a minimum of 95% of
the surface being immersed.
QT
AT
No case-deformation and loose contacts.
(note 4)
(note1)
This connector is back flip lock type, and top/bottom both contact points are available.
(note2)
Do not close the actuator before inserting FPC even after the connector is mounted onto a PCB.
Closing the actuator without FPC could make the contact gap smaller, which increases the FPC insertion force.
(note3)
If pull-up or pull-down force is exepected to be applied to the FPC, stabilize the FPC into PCB or other fixed components.
(note4)
Blisters which may be generated on the housing do not affect product performance.
Note
FORM HD0011-2-2
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO
ELC-370587-00-00
FH58-**S-0.2SHW
CL580
2/2
很抱歉,暂时无法提供与“FH58-35S-0.2SHW”相匹配的价格&库存,您可以联系我们找货
