S-24C02DI-T8T1U5
S-24C02DI-T8T1U5
    ABLIC(艾普凌科)
    TSSOP-8
    低功耗宽温范围2线串行EEPROM
S-24C02DI-T8T1U5 数据手册
S-24C02D/04D/08D/16D www.ablic.com www.ablicinc.com 2-WIRE SERIAL E2PROM © ABLIC Inc., 2012 Rev.3.0_02_U This IC is a 2-wire, low current consumption and wide range operation serial E2PROM. This IC has the capacity of 2 K-bit, 4 K-bit, 8-K bit and 16 K-bit, and the organization is 256 words  8-bit, 512 words  8-bit, 1024 words  8-bit and 2048 words  8-bit, respectively. Page write and sequential read are available. Caution This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, contact to ABLIC Inc. is indispensable.  Features  Operation voltage range Read: 1.7 V to 5.5 V Write: 1.7 V to 5.5 V  Operation frequency: 1.0 MHz max. (VCC = 2.5 V to 5.5 V) 400 kHz max. (VCC = 1.7 V to 5.5 V)  Write time: 5.0 ms max.  Page write S-24C02D: 8 bytes / page S-24C04D: 16 bytes / page S-24C08D: 16 bytes / page S-24C16D: 16 bytes / page  Sequential read  Noise suppression: Schmitt trigger and noise filter on input pins (SCL, SDA)  Write protect function during low power supply voltage  Endurance: 106 cycle / word*1 (Ta = 25C)  Data retention: 100 years (Ta = 25C)  Memory capacity S-24C02D: 2 K-bit S-24C04D: 4 K-bit S-24C08D: 8 K-bit S-24C16D: 16 K-bit  Write protect: 100%  Initial delivery state: FFh  Operation temperature range: Ta = 40°C to 85°C  Lead-free (Sn 100%), halogen-free *1. For each address (Word: 8-bit)  Packages  8-Pin SOP (JEDEC)  SOT-23-5 5 4 8 4 5 3 1 1 (5.0  6.0  t1.75 mm) (2.8  2.9  t1.3 mm)  8-Pin TSSOP  DFN-8(2030) 8 5 5 8 1 4 1 4 (3.0  6.4  t1.1 mm) (3.0  2.0  t0.5 mm)  TMSOP-8  SNT-8A 8 5 4 5 8 4 1 1 (2.9  4.0  t0.8 mm) (2.5  2.0  t0.5 mm) 1 2-WIRE SERIAL E2PROM S-24C02D/04D/08D/16D Rev.3.0_02_U  Block Diagram VCC WP SCL GND Start / Stop Detector SDA Voltage Detector Serial Clock Controller High-Voltage Generator LOAD Device Address Comparator COMP Data Register LOAD INC A0*1 R/W A1*2 A2*3 Address Counter X Decoder Memory Cell Array Y Decoder Data Output ACK Output Controller DIN DOUT *1. *2. *3. This pin is not available for the S-24C04D/08D/16D. This pin is not available for the S-24C08D/16D. This pin is not available for the S-24C16D. Remark 2 Selector The A0 pin, the A1 pin and the A2 pin are no connection in the product with SOT-23-5 package. 2-WIRE SERIAL E2PROM S-24C02D/04D/08D/16D Rev.3.0_02_U  Product Name Structure 1. Product name S-24CxxD I - xxxx U 5 Environmental code U: Lead-free (Sn 100%), halogen-free Package name (abbreviation) and IC packing specification*1 J8T1: 8-Pin SOP (JEDEC), Tape T8T1: 8-Pin TSSOP, Tape K8T3: TMSOP-8, Tape M5T1: SOT-23-5, Tape A8T1: DFN-8(2030), Tape I8T1: SNT-8A, Tape Operation temperature I: Ta = 40°C to 85°C Product name S-24C02D: 2 K-bit S-24C04D: 4 K-bit S-24C08D: 8 K-bit S-24C16D: 16 K-bit *1. 2. Refer to the tape drawing. Packages Package Name 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 SOT-23-5 DFN-8(2030) SNT-8A Dimension FJ008-Z-P-SD FT008-Z-P-SD FM008-A-P-SD MP005-A-P-SD PP008-A-P-S1 PH008-A-P-SD Tape FJ008-Z-C-SD FT008-Z-C-SD FM008-A-C-SD MP005-B-C-SD PP008-A-C-SD PH008-A-C-SD Reel FJ008-Z-R-SD FT008-Z-R-SD FM008-A-R-SD MP005-B-R-SD PP008-A-R-SD PH008-A-R-SD Land     PP008-A-L-SD PH008-A-L-SD 3 2-WIRE SERIAL E2PROM S-24C02D/04D/08D/16D 3. Product name list Product Name S-24C02DI-J8T1U5 S-24C02DI-T8T1U5 S-24C02DI-K8T3U5 S-24C02DI-M5T1U5 S-24C02DI-A8T1U5 S-24C02DI-I8T1U5 S-24C04DI-J8T1U5 S-24C04DI-T8T1U5 S-24C04DI-K8T3U5 S-24C04DI-M5T1U5 S-24C04DI-A8T1U5 S-24C04DI-I8T1U5 S-24C08DI-J8T1U5 S-24C08DI-T8T1U5 S-24C08DI-K8T3U5 S-24C08DI-M5T1U5 S-24C08DI-A8T1U5 S-24C08DI-I8T1U5 S-24C16DI-J8T1U5 S-24C16DI-T8T1U5 S-24C16DI-K8T3U5 S-24C16DI-M5T1U5 S-24C16DI-A8T1U5 S-24C16DI-I8T1U5 4 Rev.3.0_02_U Capacity 2 K-bit 2 K-bit 2 K-bit 2 K-bit 2 K-bit 2 K-bit 4 K-bit 4 K-bit 4 K-bit 4 K-bit 4 K-bit 4 K-bit 8 K-bit 8 K-bit 8 K-bit 8 K-bit 8 K-bit 8 K-bit 16 K-bit 16 K-bit 16 K-bit 16 K-bit 16 K-bit 16 K-bit Package Name 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 SOT-23-5 DFN-8(2030) SNT-8A 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 SOT-23-5 DFN-8(2030) SNT-8A 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 SOT-23-5 DFN-8(2030) SNT-8A 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 SOT-23-5 DFN-8(2030) SNT-8A 2-WIRE SERIAL E2PROM S-24C02D/04D/08D/16D Rev.3.0_02_U  Pin Configurations 1. 8-Pin SOP (JEDEC), 8-Pin TSSOP, TMSOP-8, DFN-8(2030), SNT-8A Top view 1 8 2 7 3 6 4 5 2. Symbol S-24C04D S-24C08D NC*2 NC*2 NC*2 A1 A2 A2 GND GND SDA*1 SDA*1 *1 SCL SCL*1 S-24C16D NC*2 NC*2 NC*2 GND SDA*1 SCL*1 7 WP WP WP WP 8 VCC VCC VCC VCC Description Slave address input Slave address input Slave address input Ground Serial data I/O Serial clock input Write protect input Connected to VCC: Protection valid Open or connected to GND: Protection invalid Power supply SOT-23-5 Top view 5 4 1 2 3 *1. *2. 1 2 3 4 5 6 S-24C02D A0 A1 A2 GND SDA*1 SCL*1 Pin No. Pin No. Symbol *1 1 2 3 4 SCL GND SDA*1 VCC 5 WP Description Serial clock input Ground Serial data I/O Power supply Write protect input Connected to VCC: Open or connected to GND: Protection valid Protection invalid Do not use it in "High-Z". The NC is no connection. Remark For DFN-8(2030) package, connect the heatsink of back side to the board, and set electric potential open or GND. However, do not use it as the function of electrode. 5 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U  Absolute Maximum Ratings Table 1 Item Power supply voltage Input voltage Output voltage Operation ambient temperature Storage temperature Symbol VCC VIN VOUT Topr Tstg Absolute Maximum Rating 0.3 to 6.5 0.3 to 6.5 0.3 to 6.5 40 to 85 65 to 150 Unit V V V °C °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Recommended Operating Conditions Table 2 Item Symbol Power supply voltage VCC High level input voltage Low level input voltage VIH VIL Condition Read Write VCC = 1.7 V to 5.5 V VCC = 1.7 V to 5.5 V Ta = 40°C to 85°C Min. Max. Unit 1.7 1.7 5.5 5.5 0.7  VCC 0.3 5.5 0.3  VCC V V V V  Pin Capacitance Table 3 Item Symbol Input capacitance CIN I/O capacitance CI/O Condition (Ta = 25°C, f = 1.0 MHz, VCC = 5.0 V) Min. Max. Unit VIN = 0 V (S-24C02D: SCL, A0, A1, A2, WP) VIN = 0 V (S-24C04D: SCL, A1, A2, WP) VIN = 0 V (S-24C08D: SCL, A2, WP) VIN = 0 V (S-24C16D: SCL, WP) VI/O = 0 V (SDA)      8 8 8 8 8 pF pF pF pF pF  Endurance Table 4 Item Symbol Operation Ambient Temperature Endurance NW Ta = 25°C *1. For each address (Word: 8-bit) Min. 106 Max.  Unit cycle / word*1 Min. 100 Max.  Unit year  Data Retention Table 5 Item Data retention 6 Symbol  Operation Ambient Temperature Ta = 25°C 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U  DC Electrical Characteristics Table 6 Item Current consumption (READ) Symbol Ta = 40°C to 85°C VCC = 2.5 V to 5.5 V VCC = 1.7 V to 5.5 V fSCL = 1.0 MHz fSCL = 400 kHz Min. Max. Min. Max. Condition  ICC1   1.0 0.8 Unit mA Table 7 Item Current consumption (WRITE) Symbol Ta = 40°C to 85°C VCC = 2.5 V to 5.5 V VCC = 1.7 V to 5.5 V fSCL = 1.0 MHz fSCL = 400 kHz Min. Max. Min. Max. Condition  ICC2   2.0 2.0 Unit mA Table 8 Ta = 40°C to 85°C Item Symbol Standby current consumption ISB Input leakage current 1 ILI1 Input leakage current 2 ILI2 Output leakage current ILO Input current 1 IIL Input current 2 IIH Input Impedance 1 ZIL Input Impedance 2 ZIH Low level output voltage VOL Condition VIN = VCC or GND SCL, SDA VIN = GND to VCC A0, A1, A2 VIN > 0.7  VCC SDA VOUT = GND to VCC WP VIN < 0.3  VCC WP VIN > 0.7  VCC WP VIN = 0.3  VCC WP VIN = 0.7  VCC IOL = 3.2 mA IOL = 1.5 mA IOL = 0.7 mA VCC = 2.5 V to 5.5 V VCC = 1.7 V to 2.5 V Unit Min. Max. Min. Max.  1.0  1.0 A  1.0  1.0 A  1.0  1.0 A  1.0  1.0 A  50.0  50.0 A  2.0  2.0 A 30  30  k 500  500  k    0.4 0.3 0.2     0.3 0.2 V V V 7 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U  AC Electrical Characteristics Table 9 Measurement Conditions Input pulse voltage Input pulse rising / falling time Output reference voltage Output load Input pulse voltage 0.2  VCC to 0.8  VCC 20 ns or less 0.3  VCC to 0.7  VCC 100 pF Output reference voltage 0.8  VCC 0.7  VCC 0.3  VCC 0.2  VCC Figure 1 Input / Output Waveform during AC Measurement Table 10 Item SCL clock frequency SCL clock time "L" SCL clock time "H" SDA output delay time SDA output hold time Start condition setup time Start condition hold time Data input setup time Data input hold time Stop condition setup time SCL, SDA rising time SCL, SDA falling time WP setup time WP hold time WP release setup time WP release hold time Bus release time Noise suppression time Write time 8 Symbol fSCL tLOW tHIGH tAA tDH tSU.STA tHD.STA tSU.DAT tHD.DAT tSU.STO tR tF tWS1 tWH1 tWS2 tWH2 tBUF tI tWR Ta = 40°C to 85°C VCC = 2.5 V to 5.5 V VCC = 1.7 V to 5.5 V Min. Max. Min. Max. 0 1000 0 400 0.4  1.3  0.3  0.6  0.1 0.5 0.1 0.9 50  50  0.25  0.6  0.25  0.6  80  100  0  0  0.25  0.6   0.3  0.3  0.3  0.3 0  0  0  0  0  0  0  0  0.5  1.3   50  50  5.0  5.0 Unit kHz s s s ns s s ns ns s s s s s s s s ns ms 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U tHIGH tF tLOW tR SCL tHD.STA tHD.DAT tSU.STA tSU.DAT tSU.STO SDA input tAA tDH tBUF SDA output Figure 2 Bus Timing Start Condition Acknowledge Write Data Stop Condition tWR Start Condition SCL D0 SDA tWS1 tWH1 tWS2 tWH2 WP (valid) WP (invalid) Figure 3 Write Cycle Timing 9 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U  Pin Functions 1. VCC (Power supply) pin The VCC pin is used to apply positive supply voltage. Regarding the applied voltage value, refer to " Recommended Operating Conditions". Set a bypass capacitor of about 0.1 F between the VCC pin and the GND pin to make the power supply voltage stable. 2. A0, A1 and A2 (Slave address input) pins In the S-24C02D, to set the slave address, connect each of A0 pin, A1 pin and A2 pin to the GND pin or the VCC pin. Therefore the users can set 8 types of slave address by a combination of A0, A1, A2 pins. In the S-24C04D, to set the slave address, connect each of A1 pin and A2 pin to the GND pin or the VCC pin. Therefore the users can set 4 types of slave address by a combination of A1, A2 pins. In the S-24C08D, to set the slave address, connect A2 pin to the GND pin or the VCC pin. Therefore the users can set 2 types of slave address. In the S-24C16D, the slave address can not be assigned. Comparing the slave address transmitted from the master device and one that you set, makes possible to select one slave address from other devices connected onto the bus. Each of A0 pin, A1 pin and A2 pin has a built-in pull-down resistor. In open, the pin is set to the same status as it connected to the GND pin. In the case of the products with SOT-23-5, set the slave address transmitting from the master device to "0". 3. SDA (Serial data I/O) pin The SDA pin is used for the bi-directional transmission of serial data. This pin is a signal input pin, and an Nch opendrain output pin. In use, generally, connect the SDA line to any other device which has the open-drain or open-collector output with Wired-OR connection by pulling up to VCC by a resistor. Figure 4 shows the relation with an output load. 4. SCL (Serial clock input) pin The SCL pin is used for the serial clock input. Since the signals are processed at a rising or falling edge of the SCL clock, pay attention to the rising and falling time and comply with the specification. 5. WP (Write protect input) pin The write protect is enabled by connecting the WP pin to VCC. When not using the write protect, connect this pin to the GND pin or set in open. Maximum value of pull-up resistor [k] 20 18 16 14 12 10 8 6 4 2 0 fSCL= 400 kHz fSCL= 1000 kHz 10 100 Value of load capacity [pF] Figure 4 Output Load 10 200 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U  Initial Delivery State Initial delivery state of all addresses is "FFh".  Operation 1. Initialization operation after power-on By a power-on-clear circuit, this IC initializes the internal circuit at the time of power-on. Perform the beginning (start condition) of the instruction transmission to this IC after the initialization by the power-on-clear circuit. Regarding the datails of power-on-clear, refer to "5. Power-on-clear circuit" in " Usage". 2. Start condition Start is identified by a "H" to "L" transition of the SDA line while the SCL line is stable at "H". Every operation begins from a start condition. 3. Stop condition Stop is identified by a "L" to "H" transition of the SDA line while the SCL line is stable at "H". When a device receives a stop condition during a read sequence, the read operation is interrupted, and the device enters standby mode. When a device receives a stop condition during a write sequence, the reception of the write data is halted, and this IC initiates a write cycle. tINIT VCC tSU.STA tHD.STA tSU.STO SCL SDA Start condition Stop condition Figure 5 Start / Stop Conditions after Power-on 11 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 4. Data transmission Changing the SDA line while the SCL line is "L", data is transmitted. Changing the SDA line while the SCL line is "H", a start or stop condition is recognized. tSU.DAT tHD.DAT SCL SDA Figure 6 Data Transmission Timing 5. Acknowledge The unit of data transmission is 8 bits. During the 9th clock cycle period the receiver on the bus pulls down the SDA line to acknowledge the receipt of the 8-bit data. When an internal write cycle is in progress, the device does not generate an acknowledge. SCL (E2PROM input) 1 8 9 SDA (Master output) Acknowledge output SDA (E PROM output) 2 Start condition tAA Figure 7 Acknowledge Output Timing 12 tDH 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 6. Device addressing To start communication, the master device on the system generates a start condition to the bus line. Next, the master device sends 7-bit device address and a 1-bit read / write instruction code on to the SDA bus. The higher 4 bits of the device address are the "Device Code", and are fixed to "1010". In the S-24C02D, successive 3 bits are the "Slave Address". These 3 bits are used to identify a device on the system bus and are compared with the predetermined value which is defined by the address input pins (A2, A1, A0). When the comparison result matches, the slave device responds with an acknowledge during the 9th clock cycle. In the S-24C04D, successive 2 bits are the "Slave Address". These 2 bits are used to identify a device on the system bus and are compared with the predetermined value which is defined by the address input pins (A2, A1). When the comparison result matches, the slave device responds with an acknowledge during the 9th clock cycle. The successive 1 bit (P0) is used to define a page address and choose the two 256-byte memory blocks (Address 000h to 0FFh, 100h to 1FFh). In the S-24C08D, successive 1 bit is called the "Slave Addrdess". This 1 bit is used to identify a device on the system bus and is compared with the predetermined value which is defined by the address input pin (A2). When the comparison result matches, the slave device responds with an acknowledge during the 9th clocks cycle. The successive 2 bits (P1, P0) are used to define a page address and choose the four 256-byte memory blocks (Address 000h to 0FFh, 100h to 1FFh, 200h to 2FFh , 300h to 3FFh). In the S-24C16D, successive 3 bits (P2, P1, P0) are "Page Address". Choose the 8 memory blocks of 256-byte (Adress 000h to 0FFh, 100h to 1FFh, 200h to 2FFh, 300h to 3FFh, 400h to 4FFh, 500h to 5FFh, 600h to 6FFh, 700h to 7FFh). In the case of the product with SOT-23-5, set the slave address transmitting from the master device to "0". Slave / Page Address Device Code S-24C02D 1 0 1 0 A2 A1 A0 R/W S-24C04D 1 0 1 0 A2 A1 P0 R/W S-24C08D 1 0 1 0 A2 P1 P0 R/W S-24C16D 1 0 1 0 P2 P1 P0 R/W MSB LSB Figure 8 Device Address 13 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 7. Write 7. 1 Byte write When the master sends a 7-bit device address and a 1-bit read / write instruction code set to "0", following a start condition, this IC acknowledges it. This IC then receives an 8-bit word address and responds with an acknowledge. After this IC receives 8-bit write data and responds with an acknowledge, it receives a stop condition and that initiates the write cycle at the addressed memory. During the write cycle all operations are forbidden and no acknowledge is generated. S T A R T SDA LINE DEVICE ADDRESS 1 M S B W R I T E 0 1 0 A2 A1 A0 0 WORD ADDRESS DATA W7 W6 W5 W4 W3 W2 W1 W0 D7 D6 D5 D4 D3 D2 D1 D0 L R A S / C B W K Remark A0 is P0 in the S-24C04D/08D/16D. A1 is P1 in the S-24C08D/16D. A2 is P2 in the S-24C16D. Set A0, A1, A2 to "0" in the product with SOT-23-5 package. Figure 9 Byte Write 14 A A C C K K S T O P A C K 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 7. 2 Page write The page write mode allows up to 8 bytes to be written in a single write operation in the S-24C02D. The page write mode allows up to 16 bytes to be written in a single write operation in the S-24C04D/08D/16D. Its basic process to transmit data is as same as byte write, but it operates page write by sequentially receiving 8-bit write data as much data as the page size has. When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "0", following a start condition, it generates an acknowledge. Then this IC receives an 8-bit word address, and responds with an acknowledge. After this IC receives 8-bit write data and responds with an acknowledge, it receives 8-bit write data corresponding to the next word address, and generates an acknowledge. This IC repeats reception of 8-bit write data and generation of acknowledge in succession. This IC can receive as many write data as the maximum page size. Receiving a stop condition initiates a write cycle of the area starting from the designated memory address and having the page size equal to the received write data. S T A R T SDA LINE W R I T E WORD ADDRESS (n) DATA (n) 1 0 1 0 A2 A1 A0 0 W7W6 W5W4 W3 W2 W1W0 D7 D6 D5 D4 D3 D2 D1 D0 DEVICE ADDRESS M S B L R A S / C BWK A C K DATA (n  1) D7 A C K S T O P DATA (n x) D0 D7 A C K D0 A C K Remark A0 is P0 in the S-24C04D/08D/16D. A1 is P1 in the S-24C08D/16D. A2 is P2 in the S-24C16D. Set A0, A1, A2 to "0" in the product with SOT-23-5 package. Figure 10 Page Write In the S-24C02D, the lower 3 bits of the word address are automatically incremented every time when the S-24C02D receives 8-bit write data. If the size of the write data exceeds 8 bytes, the higher 5 bits (W7 to W3) of the word address remain unchanged, and the lower 3 bits are rolled over and the last 8-byte data that the S-24C02D received will be overwritten. In the S-24C04D, the lower 4 bits of the word address are automatically incremented every time when the S-24C04D receives 8-bit write data. If the size of the write data exceeds 16 bytes, the higher 4 bits (W7 to W4) of the word address and page address (P0) remain unchanged, and the lower 4 bits are rolled over and the last 16byte data that the S-24C04D received will be overwritten. In the S-24C08D, the lower 4 bits of the word address are automatically incremented every time when the S-24C08D receives 8-bit write data. If the size of the write data exceeds 16 bytes, the higher 4 bits (W7 to W4) of the word address and page address (P1, P0) remain unchanged, and the lower 4 bits are rolled over and the last 16-byte data that the S-24C08D received will be overwritten. In the S-24C16D, the lower 4 bits of the word address are automatically incremented every time when the S-24C16D receives 8-bit write data. If the size of the write data exceeds 16 bytes, the higher 4 bits (W7 to W4) of the word address and page address (P2, P1, P0) remain unchanged, and the lower 4 bits are rolled over and the last 16-byte data that the S-24C16D received will be overwritten. 15 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 7. 3 Write protect Write protect is available in this IC. When the WP pin is connected to the VCC pin, write operation to memory area is forbidden at all. When the WP pin is connected to the GND pin or set in open, the write protect is invalid, and write operation in all memory area is available. Fix the level of the WP pin from start condition in the write operation (byte write, page write) until stop condition. If the WP pin changes during this time, the address data being written at this time is not guaranteed. Regarding the timing of write protect, refer to "Figure 3 Write Cycle Timing". When not using the write protect, connect the WP pin to the GND pin or set in open. The write protect is valid in the range of operation power supply voltage. As seen in Figure 11 when the write protect is valid, this IC does not generate an acknowledgel after data input. S T A R T SDA LINE DEVICE ADDRESS 1 M S B W R I T E 0 1 0 A2 A1 A0 0 WORD ADDRESS DATA W7 W6 W5 W4 W3 W2 W1 W0 D7 D6 D5 D4 D3 D2 D1 D0 L R A S / C B W K A A C C K K WP Remark A0 is P0 in the S-24C04D/08D/16D. A1 is P1 in the S-24C08D/16D. A2 is P2 in the S-24C16D. Set A0, A1, A2 to "0" in the product with SOT-23-5 package. Figure 11 Write Protect 16 S T O P N A C K 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 7. 4 Acknowledge polling Acknowledge polling is used to know the completion of the write cycle in this IC. After this IC receives a stop condition and once starts the write cycle, all operations are forbidden and no response is made to the signal transmitted by the master device. Accordingly the master device can recognize the completion of the write cycle in this IC by detecting a response from the slave device after transmitting the start condition, the device address and the read / write instruction code to this IC, namely to the slave devices. That is, if this IC does not generate an acknowledge, the write cycle is in progress and if this IC generates an acknowledge, the write cycle has been completed. It is recommended to use the read instruction "1" as the read / write instruction code transmitted by the master device. Acknowledge polling during read DATA SDA LINE S T O P S T A R T R E A D S T A R T DEVICE ADDRESS 1 DEVICE ADDRESS 1 D2 D1 D0 NO ACK from R Master Device E A D R N / A W C K S T O P S T A R T DEVICE ADDRESS DATA R A / C WK R A / C WK tWR Acknowledge polling during write DATA SDA LINE D2 D1 D0 S T O P W R I T E S T A R T DEVICE ADDRESS 0 R N / A W C K S T A R T W R I T E DEVICE ADDRESS 0 WORD ADDRESS R A / C WK A C K tWR Remark Users are able to read data after acknowledge output in acknowledge polling during read. Users are able to input word address and data after acknowledge output in acknowledge polling during write. However, after that users input the write instruction, a start condition may not be input during data output. Input a stop condition and the next instruction after data output and acknowledge output. Figure 12 Usage Example of Acknowledge Polling 17 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 8. Read 8. 1 Current address read Either in writing or in reading this IC holds the last accessed memory address. The memory address is maintained when the instruction transmission is not interrupted, and the memory address is maintained as long as the power voltage does not decrease less than the operating voltage. The master device can read the data at the memory address of the current address pointer without assigning the word address as a result, when it recognizes the position of the address pointer in this IC. This is called "Current Address Read". In the following the address counter in this IC is assumed to be "n". When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "1" following a start condition, it responds with an acknowledge. Next an 8-bit data at the address "n" is sent from this IC synchronous to the SCL clock. The address counter is incremented and the content of the address counter becomes n  1. The master device outputs stop condition not an acknowledge, the reading of this IC is ended. S T A R T SDA LINE DEVICE ADDRESS 1 M S B 0 1 NO ACK from Master Device R E A D S T O P DATA 0 A2 A1 A0 1 L R S / B W D7 D6 D5 D4 D3 D2 D1 D0 A C K Remark In the S-24C04D/08D/16D, A0 = Don't care. In the S-24C08D/16D, A1 = Don't care. In the S-24C16D, A2 = Don't care. Set A0, A1, A2 to "0" in the product with SOT-23-5 package. Figure 13 Current Address Read Attention should be paid to the following point on the recognition of the address pointer in this IC. In Read, the memory address counter in this IC is automatically incremented after output of the 8th bit of the data. In Write, on the other hand, the higher bits of the memory address (the higher bits of the word address and the page address*1) are left unchanged and are not incremented.  18 1. In the S-24C02D, the higher 5 bits (W7 to W3) of the word address. In the S-24C04D, the higher 4 bits (W7 to W4) of the word address and the page address (P0). In the S-24C08D, the higher 4 bits (W7 to W4) of the word address and the page address (P1, P0). In the S-24C16D, the higher 4bits (W7 to W4) of the word address and the page address (P2, P1, P0). 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 8. 2 Random read Random read is used to read the data at an arbitrary memory address. A dummy write is performed to load the memory address into the address counter. When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "0" following a start condition, it responds with an acknowledge. This IC then receives an 8-bit word address and responds with an acknowledge. The memory address is loaded to the address counter in this IC by these operations. Reception of write data does not follow in a dummy write whereas reception of write data follows in byte write and in page write. Since the memory address is loaded into the memory address counter by dummy write, the master device can read the data starting from the arbitrary memory address by transmitting a new start condition and performing the same operation in the current address read. That is, when this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "1", following a start condition signal, it responds with an acknowledge. Next, 8-bit data is transmitted from this IC in synchronous to the SCL clock. The master device outputs stop condition not an acknowledge, the reading of this IC is ended. S-24C02D SDA LINE S T A R T DEVICE ADDRESS W R I T E S T A R T WORD ADDRESS (n) DEVICE ADDRESS R E A D NO ACK from Master Device S T O P DATA 1 0 1 0 A2 A1 A0 0 W7 W6 W5 W4 W3 W2 W1 W0 1 0 1 0 A2 A1 A0 1 D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 0 A2 A1 P0 0 W7 W6 W5 W4 W3 W2 W1 W0 1 0 1 0 A2 A1 X 1 D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 0 A2 P1 P0 0 W7 W6 W5 W4 W3 W2 W1 W0 1 0 1 0 A2 X X 1 D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 0 P2 P1 P0 0 W7 W6 W5 W4 W3 W2 W1 W0 1 0 1 0 X X X 1 D7 D6 D5 D4 D3 D2 D1 D0 S-24C04D SDA LINE S-24C08D SDA LINE S-24C16D SDA LINE M S B L R A S / C B W K A C K M S B L R A S / C B W K DUMMY WRITE Remark 1. X = Don't care 2. Set A0, A1, A2 to "0" in the product with SOT-23-5 package. Figure 14 Random Read 19 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 8. 3 Sequential read When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "1" following a start condition both in current address read and random read, it responds with an acknowledge. When an 8-bit data is output from this IC synchronous to the SCL clock, the address counter is automatically incremented. When the master device responds with an acknowledge, the data at the next memory address is transmitted. Response with an acknowledge by the master device has the memory address counter in this IC incremented and makes it possible to read data in succession. This is called sequential read. The master device outputs stop condition not an acknowledge, the reading of this IC is ended. Data can be read in succession in the sequential read mode. When the memory address counter reaches the last word address, it rolls over to the first word address. NO ACK from Master Device R E DEVICE A ADDRESS D SDA LINE 1 R A / C W K A C K D7 D0 DATA (n) A C K D7 D0 DATA (n 1) D7 D0 DATA (n 2) Figure 15 Sequential Read 20 S T O P A C K D7 D0 DATA (n x) 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U  Usage 1. A pull-up resistor to SDA I/O pin and SCL input pin In consideration of I2C-bus protocol function, the SDA I/O pin should be connected with a pull-up resistor. This IC cannot transmit normally without using a pull-up resistor. In case that the SCL input pin of this IC is connected to the Nch open-drain output pin of the master device, connect the SCL pin with a pull-up resistor. As well, in case the SCL input pin of this IC is connected to the tri-state output pin of the master device, connect the SCL pin with a pull-up resistor in order not to set it in "High-Z". This prevents this IC from error caused by an uncertain output (High-Z) from the tri-state pin when resetting the master device during the voltage drop. 2. Equivalent circuits of input pin and I/O pin The SCL pin and the SDA pin of this IC does not have a built-in pull-down or pull-up resistor. Each of A0 pin, A1 pin, A2 pin and WP pin has a built-in pull-down resistor. The SDA pin is an open-drain output. The followings are equivalent circuits of the pins. SDA SCL Figure 16 SCL Pin Figure 17 SDA Pin A0, A1, A2 WP Figure 18 WP Pin Figure 19 A0, A1, A2 Pin Remark In the S-24C04D/08D/16D, A0 pin is not available. In the S-24C08D/16D, A1 pin is not available. In the S-24C16D, A2 pin is not available. The A0 pin, the A1 pin and the A2 pin are no connection in the product with SOT-23-5 package. 21 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 3. Phase adjustment of the I2C-bus product The I2C-bus product does not have a pin to reset (the internal circuit). The users cannot forcibly reset it externally. If the communication interrupted, the users need to handle it as you do for software. In this IC, users are able to reset the internal circuit by inputting a start condition and a stop condition. Although the reset signal is input to the master device, this IC’s internal circuit does not go in reset, but it does by inputting a stop condition to this IC. This IC keeps the same status thus cannot do the next operation. Especially, this case corresponds to that only the master device is reset when the power supply voltage drops. If the power supply voltage restored in this status, input the instruction after resetting (adjusting the phase with the master device) this IC. How to reset is shown below. [How to reset this IC] This IC is able to be reset by a start and stop instructions. When this IC is reading data "0" or is outputting the acknowledgment signal, outputs "0" to the SDA line. In this status, the master device cannot output an instruction to the SDA line. In this case, terminate the acknowledgment output operation or the Read operation, and then input a start condition. Figure 20 shows this procedure. First, input a start condition. Then transmit 9 clocks (dummy clock) of SCL. During this time, the master device sets the SDA line to "H". By this operation, this IC interrupts the acknowledgment output operation or data output, so input a start condition*1. When a start condition is input, this IC is reset. To make doubly sure, input the stop condition to this IC. The normal operation is then possible. Start Condition Start Condition Dummy Clock 1 2 8 Stop Condition 9 SCL SDA Figure 20 Resetting Method *1. After 9 clocks (dummy clock), if the SCL clock continues to being output without inputting a start condition, this IC may go in the write operation when it receives a stop condition. To prevent this, input a start condition after 9 clocks (dummy clock). Remark 22 Regarding this reset procedure with dummy clock, it is recommended to perform at the system initialization after applying the power supply voltage. 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 4. Acknowledge check The I2C-bus protocol includes an acknowledge check function as a handshake function to prevent a communication error. This function allows detection of a communication failure during data communication between the master device and this IC. This function is effective to prevent malfunction, so it is recommended to perform an acknowledge check with the master device. 5. Power-on-clear circuit By power-on-clear circuit, this IC initializes at the same time when the power supply voltage is raised. After the initialization by the power-on-clear circuit is completed, this IC becomes standby state. In order to use this IC safely, raise the power supply voltage depending on the following conditions. 5. 1 Initialization time This IC initializes at the same time when the power supply voltage is raised. Input instructions to this IC after initialization. This IC does not accept any instruction during initialization. Figure 21 shows the initialization time of this IC. 100 m 10 m Initialization time (tINIT) max. [s] 1.0 m 100  10  1.0  1.0  10  100  1.0 m 10 m 100 m Rise time (tRISE) [s] Figure 21 Initialization Time 23 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 5. 2 Caution when raising the power supply voltage The internal circuit of this IC is reset by the power-on-clear circuit. In order for the power-on-clear circuit to operate normally, the condition showed in Table 11 must be obeyed for raising the power supply voltage. Due to the voltage drop, this IC may not perform normal communication if the power-on-clear operation condition is not fulfilled, even when the master device is reset. However, the interface of this IC is reset normally and the master device can make normal communication if phase adjustment is performed, even when the power-on-clear operation condition of this IC is not fulfilled. Table 11 Item Power-off time Power-off voltage Symbol tOFF VBOT Min. Max. Unit 100   0.6 s V VCC min. Power supply voltage 0V VBOT *1 tINIT *2 tOFF tINIT *2 *1. 0 V means that there is no potential difference between the VCC pin and the GND pin of this IC. *2. tINIT is the time to initialize the internal IC. This IC does not accept any instruction during the initialization time. Figure 22 Caution When Raising the Power Supply Voltage 6. Write protect function during the low power supply voltage This IC has a built-in detection circuit which operates with the low power supply voltage, cancels Write when the power supply voltage drops and power-on. Its detection and release voltages are 1.3 V typ. (refer to Figure 23). This IC cancels Write by detecting a low power supply voltage when it receives a stop condition. In the data trasmission and the Write operation, data in the address written during the low power supply voltage is not assurable. Power supply voltage Detection voltage (VDET) 1.3 V typ. Release voltage (VDET) 1.3 V typ. Write instruction cancel Figure 23 Operation during Low Power Supply Voltage 24 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 7. Data hold time (tHD.DAT = 0 ns) If SCL and SDA of this IC are changed at the same time, it is necessary to prevent a start / stop condition from being mistakenly recognized due to the effect of noise. This IC may error if it does not recognize a start / stop condition correctly during transmission. In this IC, it is recommended to set the delay time of 0.3 s minimum from a falling edge of SCL for the SDA. This is to prevent this IC from going in a start / stop condition due to the time lag caused by the load of the bus line. tHD.DAT = 0.3 s min. SCL SDA Figure 24 Data Hold Time 8. SDA pin and SCL pin noise suppression time This IC includes a built-in low-pass filter at the SDA pin and the SCL pin to suppress noise. If the power supply voltage is 5.0 V, this suppression time can be suppressed noise with a pulse width of approx. 80 ns. For details of the assurable value, refer to noise suppression time (tl) in Table 10 in " AC Electrical Characteristics". 300 Noise suppression time (tI) max. 200 [ns] 100 2 3 4 5 Power supply voltage (VCC) [V] Figure 25 Noise Suppression Time for SDA Pin and SCL Pin 25 2-WIRE SERIAL E2PROM S-24C02D/04D/08D16D Rev.3.0_02_U 9. Operation when input stop condition during input write data This IC does the write operation only when it receives data of 1 byte or more and receives a stop condition immediately after acknowledge output. Refer to Figure 26 regarding details. Write valid by stop condition Write invalid by stop condition S T A R T SDA LINE Write invalid by stop condition W R I T E WORD ADDRESS (n) DATA (n) 1 0 1 0 A2 A1 A0 0 W7W6 W5W4 W3 W2 W1W0 D7 D6 D5 D4 D3 D2 D1 D0 DEVICE ADDRESS M S B L R A S / C BWK A C K Write valid by stop condition Write invalid by stop condition DATA (n 1) D7 A C K Write valid by stop condition S T O P DATA (n x) D0 D7 A C K D0 A C K Remark A0 is P0 in the S-24C04D/08D/16D. A1 is P1 in the S-24C08D/16D. A2 is P2 in the S-24C16D. Set A0, A1, A2 to "0" in the product with SOT-23-5 package. Figure 26 Write Operation by Inputting Stop Condition during Write 10. Command cancel by start condition By a start condition, users are able to cancel command which is being input. However, adjust the phase while this IC is outputting "L" because users are not able to input a start condition. When users cancel the command, there may be a case that the address will not be identified. Use random read for the read operation, not current address read.  Precautions  Do not operate these ICs in excess of the absolute maximum ratings. Attention should be paid to the power supply voltage, especially. The surge voltage which exceeds the absolute maximum ratings can cause latch-up and malfunction. Perform operations after confirming the detailed operation condition in the data sheet.  Operations with moisture on this IC's pins may occur malfunction by short-circuit between pins. Especially, in occasions like picking this IC up from low temperature tank during the evaluation. Be sure that not remain frost on this IC's pin to prevent malfunction by short-circuit. Also attention should be paid in using on environment, which is easy to dew for the same reason.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 26 +0.20 5.02 -0.35 8 5 1 4 1.27 0.20±0.05 +0.11 0.4 -0.07 No. FJ008-Z-P-SD-2.1 TITLE SOP8J-Z-PKG Dimensions FJ008-Z-P-SD-2.1 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.55±0.05 0.3±0.05 ø1.5 min. 8.0±0.1 2.1±0.1 +0.30 6.5 -0.25 1 8 4 5 Feed direction No. FJ008-Z-C-SD-1.0 TITLE SOP8J-Z-Carrier Tape No. FJ008-Z-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 17.5±1.5 13.4±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FJ008-Z-R-SD-1.0 TITLE SOP8J-Z-Reel No. FJ008-Z-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 +0.3 3.00 -0.2 8 5 1 4 0.15±0.07 0.2±0.1 0.65 No. FT008-Z-P-SD-1.2 TITLE TSSOP8-Z-PKG Dimensions FT008-Z-P-SD-1.2 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 0.3±0.05 ø1.55±0.05 +0.2 8.0±0.1 ø1.55 -0.05 +0.4 6.6 -0.2 1 8 4 5 Feed direction No. FT008-Z-C-SD-1.0 TITLE TSSOP8-Z-Carrier Tape No. FT008-Z-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 13.4±1.0 17.5±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FT008-Z-R-SD-1.0 TSSOP8-Z-Reel TITLE FT008-Z-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 4,000 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-B-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.25 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-B-C-SD-1.0 TITLE SOT235-B-Carrier Tape No. MP005-B-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.2±0.5 Enlarged drawing in the central part ø13±0.2 No. MP005-B-R-SD-1.0 TITLE SOT235-B-Reel No. MP005-B-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 2.0±0.1 (1.70) +0.05 0.08 -0.02 0.5 0.23±0.1 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PP008-A-P-S1-2.0 TITLE DFN-8/HSNT-8-A-PKG Dimensions No. PP008-A-P-S1-2.0 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.0±0.05 4.0±0.1 0.25±0.05 +0.1 ø1.0 -0 0.60±0.05 4.0±0.1 2.3±0.05 4 321 5 6 78 Feed direction No. PP008-A-C-SD-1.0 TITLE DFN-8/HSNT-8-A-Carrier Tape No. PP008-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PP008-A-R-SD-1.0 TITLE DFN-8/HSNT-8-A-Reel No. PP008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 1.6 0.30 0.50 No. PP008-A-L-SD-1.0 TITLE No. DFN-8/HSNT-8-A -Land Recommendation PP008-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 2.01 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) TITLE No. PH008-A-L-SD-4.1 SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-24C02DI-T8T1U5
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,常用于遥控器等设备。
3. 引脚分配:EL817有2个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V-1.9V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817通过电流控制发光强度,常用于红外线信号传输。
6. 应用信息:广泛应用于遥控器、红外线通信等领域。
7. 封装信息:EL817采用黑色环氧树脂封装,尺寸为3.8mm1.5mm。
S-24C02DI-T8T1U5 价格&库存
很抱歉,暂时无法提供与“S-24C02DI-T8T1U5”相匹配的价格&库存,您可以联系我们找货
