SFPC020GM1EC2TO-I-5E-51P-STD
    SWISSBIT
SFPC020GM1EC2TO-I-5E-51P-STD 数据手册
Product Fact Sheet Industrial PCIe NVMe M.2 N-26m2 Series PCIe Gen 3.1, 3D pSLC Industrial Temperature Grade Date : Re vi si o n: Se pte mbe r 03 , 2 0 20 1 .0 1 Product Fact Sheet N-26m2 Series Product Summary                 1 2 3 Capacities: 5 GBytes, 10 GBytes, 20 GBytes, 40 GBytes, 80 GBytes, 160 GBytes Form Factor: PCI Express® M.2 (2230/2242/2280, S4) (30/42/80 mm x 22 mm x 2.63 mm) Compliance1: PCI Express (PCIe) Specification Revision 3.1 Interface: Gen3 x 4 Lanes o Drive operates in x1 mode in x1 M.2 PCIe slots o Drive operates in x2 mode in x2 M.2 PCIe slots o Drive operates in x4 mode in x4 M.2 PCIe slots Command Sets: Supports NVMe 1.3 Performance: o Read Performance: Sequential Read up to 1,773 MBytes/s, Random Read 4K up to 140,000 IOPS o Write Performance: Sequential Write up to 718 MBytes/s, Random Write 4K up to 100,000 IOPS Host Memory Buffer (HMB): Support for increased random performance Operating Temperature Range2: o Industrial: -40 °C to 85 °C Storage Temperature Range: -40 °C to 85 °C Operating Voltage: 3.3, 1.8 and 0.9V supply voltages Low Power Consumption Power: o Power States PS0, PS1, PS2, PS3 and PS4 o Thermal Throttling supported Data Retention3: 10 Years @ Life Begin; 1 Year @ Life End, @40°C Shock/Vibration: 1,500 g / 50 g High-Performance Processor with Integrated, Parallel Flash Interface Engines: o Triple-Level Cell (TLC) 3D NAND Flash in pSLC mode o LDPC Code ECC with up to 120 bit correction per 1 KByte page High Reliability: o Mean Time Between Failure (MTBF): > 2,000,000 hours o Data Reliability: < 1 non-recoverable error per 1016 bits read To check the compatibility of the customer system and the storage device is part of the customer’s responsibility. Swissbit can provide guidance and support on request. Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 125°C (industrial temperature drive) and 110°C (commercial temperature drive) respectively. NAND Flash suppliers refer to JEDEC JESD47 and JESD22 for Data Retention testing. Based on the information provided by the NAND Flash suppliers, Data Retention is targeted as shown in the table for reference. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland www.swissbit.com industrial@swissbit.com Revision: 1.01 Doc-3581 File: N-26m2_fact_sheet_Rev101 Page 2 of 3 Product Fact Sheet N-26m2 Series Product Features                 Dynamic and Static Wear Leveling Subpage Mode Flash Translation Layer (FTL) Data Care Management o Active: Adaptive Read Refresh o Passive: Background Media Scan Lifetime Enhancements o Dynamic Bad Block Remapping o Write Amplification Reduction Power Fail Data Loss Protection Data set management support (TRIM) Active State Power Management (ASPM) Support In-Field Firmware Update4 Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.) 30 µinch Gold-Plated Connector (IPC-6012B Class 2 Compliant) End-to-End (E2E) Data Protection AES256 Encryption (on request) Life Cycle Management Controlled “Locked” BOM RoHS / REACH Compliant Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addressees the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. 4 The support of In-Field FW update capabilities on host systems is recommended. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland www.swissbit.com industrial@swissbit.com Revision: 1.01 Doc-3581 File: N-26m2_fact_sheet_Rev101 Page 3 of 3
SFPC020GM1EC2TO-I-5E-51P-STD 价格&库存
很抱歉,暂时无法提供与“SFPC020GM1EC2TO-I-5E-51P-STD”相匹配的价格&库存,您可以联系我们找货
