Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
PCN10 Series
IEC603-2 / DIN41612 Standard Compliant Products
Jul.2022
PCN10 Series/IEC603-2 / DIN41612 Standard Compliant Products
Features
1. Complies with DIN Standard
Complies with IEC603- 2/ DIN41612 standard.
2. Number of Positions
14 pin variations available : 16, 20, 24, 30,
32, 44, 48, 50, 64, 90, 96, 100, 128, and 144
3. Two- point Contact Design
Double-sided Two-point Contact System
Highly reliable double- sided two point contacts.
4. Wide Applications
DIN standard types of B, C, R, and Q are available.
The easy lock pin type for temporary board
installation is available.
5. Stacking Height Variation
The PCN10H Series includes 5 stacking height
variations : 25, 30, 35, 40 and 45mm.
Stacking Connector
2
6. Circuit Protection
The PCN10MC Series has a sequence design for
circuit protection.
7. Cable Connector
IDC connectors for ribbon cable are available.
Crimp connectors compatible with 26- 30 AWG are
also available.
Applications
Computers, Control Equipment, Switches, Measuring Devices, etc.
3
Product Specifications
Rated Current
2A
Operating Temperature (Note 1)
-55 to +85℃
Rated Voltage
300V AC
Operating Humidity Range
85% Max.
Storage Temperature (Note 2)
-10 to +60℃
Storage Humidity Range (Note 2)
40 to 70%
Item
Specification
Condition
Insulation
Resistance
106M Ω Min.
Measured at 100V DC
Withstanding
Voltage
No flashover or insulation breakdown.
1000V AC for 1 min. (IDC, Crimp Type : 650V AC)
Contact Resistance
20m Ω Max.
Measured at 0.1A
Vibration
Resistance
No electrical discontinuity of 10μ s Min.
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in
each of the 3 directions.
Humidity
(Steady State)
Insulation resistance : 106M Ω Min.
96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95%
Temperature Cycle
No damage, cracks, or parts looseness.
(-65℃ : 30 minutes → 15 to 35℃ : 5 minutes Max. →
125℃ : 30 minutes → 15 to 35℃ : 5 minutes Max.) 5 times
Mating Durability
Contact resistance : 20m Ω Max.
500 times
Soldering Heat
Resistance
No deformation of components affecting
performance.
Manual soldering : 350℃ for 3 seconds
Note 1 : Includes the temperature rise due to current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. The operating temperature and humidity range applies to
the non-energized state after board mounting and temporary storage during transportation.
Material / Finish
Component
Material
Insulator
Contact
Color/Finish
Remarks
PBT
Gray
UL94V-0
Pin Header
Brass
Receptacle
Copper Alloy
Contact Area: Nickel Underplated+Gold Plated
Remaining Areas: Nickel Underplated+Tin Plated
4
Product Number Structure
■ PCN10 Series
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
PCN10 A - # P - 2.54 DS
❶
❷
❸ ❹
❺
❻
❶
Series Name
PCN10
❷
Configuration
Blank : Mold Type (as listed below)
A : Mold Type (as listed below)
B : Mold Type (as listed below)
C : 2-row Type
EA : 2-row Type (With Lock Pin for
Temporary Board Installation)
H : 35mm Stacking Height
HA : 30mm Stacking Height
HB : 25mm Stacking Height
HC : 45mm Stacking Height
HD : 40mm Stacking Height
MC : With Circuit Protection
PCN10 (Note)
PCN10B
❸
No. of Pos.
2-row : 16,20,24,32,44,50,64,90,100
3-row : 48,96,144
4-row : 128
❹
Connector Type
P : Pin Header
S : Receptacle
❺
Contact Pitch
2.54mm
❻
Contact Type
DS : Right Angle Through Hole Type
DSA : Straight Through Hole Type
WA : Wrapping Type (0.5tx0.7W)
WB : Wrapping Type (0.5tx0.5W)
C : Crimp Type
PCN10A
PCN10EA
PCB
Note : However the right angle 2-row receptacle type is PCN10A.
5
Combination
Pin Header
Receptacle
●Straight Through Hole Type
PCN10-##P-2.54DSA
PCN10-##S-2.54DSA
PCN10C-##S-2.54DSA
PCN10EA-##S-2.54DSA
PCN12-##S-2.54DSA
PCN12E-##S-2.54DSA
PCN13-##S-2.54DSA
●Stacking Through Hole Type
PCN10H#-##P-2.54DSA
●Wrapping Type
PCN10-##S-2.54W#
*Does not mate with PCN10EA-##S-2.54DSA.
●Right Angle Through Hole Type
(Mounted on Board Edge)
(Mounted On The Board Edge)
PCN10-##P-2.54DS
PCN12-##P-2.54DS
PCN12E-##P-2.54DS
PCN10B-##S-2.54DS
(Board Mounted)
(Mounted On The Board)
PCN10A-##P-2.54DS
PCN10EA-##P-2.54DS
PCN12A-##P-2.54DS
PCN12EA-##P-2.54DS
PCN10A-##S-2.54DS
PCN10C-##S-2.54DS
PCN13-##S-2.54DS
●Cable Type
PCN10-##S-2.54C + PCN10-####SC#
PCN10-##S-2.54R
6
■Circuit Protection Type
Pin Header
Receptacle
PCN10MC#-##S-2.54DSA
PCN10MC#-##P-2.54DS
●Wrapping Type
PCN10MC#-##S-2.54W#
7
Contact Numbers
For the mating of DIN Standard type C (Type B) and Type R (Type Q),
the contact numbers are No.1-32 and the rows are a, b, and c.
●DIN standard type C and type R represent the 3-row 96 contacts type, including 32 contacts in single-row.
●DIN standard type B and type Q represent the 2-row 64 contacts type, including 32 contacts in single-row.
1. Receptacle Straight Type
2. Pin Header Right Angle Type
Type C (Type B)
Type C (Type B)
Row c
Row b
Row a
n←
2・1
Row c
Row b
Row a
n←
2・1
Contact No.
Matching
Contact No.
Inverted
Contact No.
Inverted
Row c
Row b
Row a
n←
2・1
Row c
Row b
Row a
n←
2・1
Contact No.
Matching
3. Pin Header Straight Type
4. Receptacle Right Angle Type
Type R (Type Q)
Type R (Type Q)
Note : DIN connectors are standardized based on a combination of straight and right angle types. In the above figure,
the contact no. of combination 1-2, 3-4 match, but the contact no. of combination 1-3, 2-4 are inverted.
8
Pin Header : 2-row Right Angle Type (DIN Standard Type B)
A
B
C
2.54
2.54
10.1
6.4
5.6 7.1
5.5
1.5
2-φ2.6
0.5×0.5
D
1.65
2.9
6.0
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
a
5.3±0.1 2.54±0.1
PCB Mounting Pattern
b
8.6
2.54
2.54±0.1
C±0.1
D±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10-16P-2.54DS(72)
CL0583-0230-9-72
16
33.04
24.39
17.78
27.94
PCN10-20P-2.54DS(72)
CL0583-0077-3-72
29.47
22.86
33.02
PCN10-32P-2.54DS(72)
CL0583-0015-6-72
32
53.36
44.71
38.10
48.26
PCN10-44P-2.54DS(72)
CL0583-0038-1-72
44
68.60
59.95
53.34
63.50
PCN10-50P-2.54DS(72)
CL0583-0016-9-72
50
76.22
67.57
60.96
71.12
PCN10-64P-2.54DS(72)
CL0583-0017-1-72
64
94.00
85.35
78.74
88.90
PCN10-90P-2.54DS(72)
CL0583-0018-4-72
90
127.02
118.37
111.76
121.92
PCN10-100P-2.54DS(72)
CL0583-0113-5-72
100
139.72
131.07
124.46
134.62
9
RoHS
Purchase Unit
40pcs per tray
Yes
20pcs per tray
10pcs per tray
A
B
C
2.54
2.54
10.1
6.4
1.5
2-φ2.6
0.5×0.5
D
2.9
(A Type)
7.65
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
a
12.6±0.1 2.54±0.1
b
5.6 7.1
5.5
8.6
2.54
2.54±0.1
C±0.1
D±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10A-16P-2.54DS(72)
CL0583-0231-1-72
16
33.04
24.39
17.78
27.94
PCN10A-20P-2.54DS(72)
CL0583-0078-6-72
29.47
22.86
33.02
PCN10A-32P-2.54DS(72)
CL0583-0011-5-72
32
53.36
44.71
38.10
48.26
PCN10A-44P-2.54DS(72)
CL0583-0039-4-72
44
68.60
59.95
53.34
63.50
PCN10A-50P-2.54DS(72)
CL0583-0012-8-72
50
76.22
67.57
60.96
71.12
PCN10A-64P-2.54DS(72)
CL0583-0013-0-72
64
94.00
85.35
78.74
88.90
PCN10A-90P-2.54DS(72)
CL0583-0014-3-72
90
127.02
118.37
111.76
121.92
PCN10A-100P-2.54DS(72)
CL0583-0114-8-72
100
139.72
131.07
124.46
134.62
10
RoHS
Purchase Unit
40pcs per tray
Yes
20pcs per tray
10pcs per tray
● With
Lock Pin for Temporary Board Installation
A
B
C
2.0
2.54
2.54
10.1
6.4
6.2
5.5
7.1
6.1
8.6
2.54
2.54
3.0
0.5×0.5
D
2.9
●The PCB mounting pattern is equivalent to PCN10A-#P-2.54DS(72).
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10EA-16P-2.54DS(72)
CL0583-0256-2-72
16
33.04
24.39
17.78
27.94
PCN10EA-20P-2.54DS(72)
CL0583-0181-5-72
29.47
22.86
33.02
PCN10EA-32P-2.54DS(72)
CL0583-0182-8-72
32
53.36
44.71
38.10
48.26
PCN10EA-44P-2.54DS(72)
CL0583-0183-0-72
44
68.60
59.95
53.34
63.50
PCN10EA-50P-2.54DS(72)
CL0583-0184-3-72
50
76.22
67.57
60.96
71.12
PCN10EA-64P-2.54DS(72)
CL0583-0185-6-72
64
94.00
85.35
78.74
88.90
PCN10EA-90P-2.54DS(72)
CL0583-0186-9-72
90
127.02
118.37
111.76
121.92
PCN10EA-100P-2.54DS(72)
CL0583-0187-1-72
100
139.72
131.07
124.46
134.62
11
RoHS
Purchase Unit
40pcs per tray
Yes
20pcs per tray
10pcs per tray
Pin Header : 2-row Straight Type
A
B
C
D
8.6
2.54
6.4
5.2 6.4
3.2 11.6
2.54
0.5×0.5
*Type Q differs in the outer dimensions and PCB mounting pattern.
φ2.8 +0.1
2.54±0.1
φ0.8 +0.1
b a
2-φ2.6
2.54±0.1
D±0.1
B±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
RoHS
Purchase Unit
PCN10-20P-2.54DSA(72)
CL0583-0139-9-72
38.10
29.47
22.86
45pcs per tray
PCN10-32P-2.54DSA(72)
CL0583-0007-8-72
32
58.54
53.34
44.71
38.10
30pcs per tray
PCN10-44P-2.54DSA(72)
CL0583-0488-8-72
44
73.78
68.58
59.95
53.54
PCN10-50P-2.54DSA(72)
CL0583-0008-0-72
50
81.40
76.20
67.57
60.96
PCN10-64P-2.54DSA(72)
CL0583-0009-3-72
64
99.18
93.98
85.35
78.74
PCN10-90P-2.54DSA(72)
CL0583-0010-2-72
90
132.20
127.00
118.37
111.76
PCN10-100P-2.54DSA(72)
CL0583-0251-9-72
100
144.90
139.70
131.07
124.46
12
Yes
15pcs per tray
Receptacle : 2-row Right Angle Type
A
B
C
2.54
R1.3
0.3t×0.7w
2.9
*Type Q differs in the external size and PCB mounting pattern.
6.3±0.1 2.54±0.1
D±0.1
C±0.1
φ0.8 +0.1
2.54±0.1
2-φ2.8 +0.1
2.54±0.1
D
2.54
3.88
3.82
8.9 6.3
8.1
6.0
2.9
2.54
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10C-20S-2.54DS(72)
CL0583-0201-0-72
29.12
22.86
38.10
PCN10C-32S-2.54DS(72)
CL0583-0202-3-72
32
58.34
44.36
38.10
53.34
PCN10C-44S-2.54DS(72)
CL0583-0052-2-72
44
73.58
59.60
53.34
68.58
PCN10C-50S-2.54DS(72)
CL0583-0168-7-72
50
81.20
67.22
60.96
76.20
PCN10C-64S-2.54DS(72)
CL0583-0203-6-72
64
98.98
85.00
78.74
93.98
PCN10C-90S-2.54DS(72)
CL0583-0204-9-72
90
132.00
118.02
111.76
127.00
PCN10C-100S-2.54DS(72)
CL0583-0178-0-72
100
144.70
130.72
124.46
139.70
Note : DIN standard type Q (Reverse type of type B) is PCN10B-64S-2.54DS(72).
13
RoHS
Purchase Unit
33pcs per tray
22pcs per tray
Yes
11pcs per tray
Receptacle : 2-row Straight Type (DIN Standard Type B)
C
D
2-φ2.8
8.1
0.3
2.54
3.2
5.2 6.3
3.9 11.5
0.25t×0.7w
2.54
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
2.54±0.1
D±0.1
B±0.1
a b
B
A
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10-32S-2.54DSA(72)
CL0583-0019-7-72
32
54.36
49.36
44.36
38.10
PCN10-50S-2.54DSA(72)
CL0583-0020-6-72
50
77.22
72.22
67.22
60.96
PCN10-64S-2.54DSA(72)
CL0583-0021-9-72
64
95.00
90.00
85.00
78.74
14
RoHS
Purchase Unit
50pcs per tray
Yes
30pcs per tray
Receptacle : 2-row Wrapping Type (DIN Standard Type B)
C
D
2-φ2.8
8.1
0.3
2.54
3.2
13.0
WA : 0.5t×0.7w
WB : 0.5t×0.5w
2.54
(Note)
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
2.54±0.1
D±0.1
B±0.1
a b
11.5
5.2 6.3
B
A
Note : WA type is φ1.0 +0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10-32S-2.54WA(72)
CL0583-0107-2-72
32
54.36
49.36
44.36
38.10
PCN10-50S-2.54WB(72)
CL0583-0068-2-72
50
77.22
72.22
67.22
60.96
PCN10-64S-2.54WA(72)
CL0583-0109-8-72
64
95.00
90.00
85.00
78.74
15
RoHS
Purchase Unit
Yes
26pcs per tray
C
D
2-φ2.8
8.1
0.3
2.54
3.2
3.9 11.5
5.2 6.3
0.25t×0.7w
2.54
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
a b
B
A
2.54±0.1
D±0.1
B±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10C-16S-2.54DSA(52)
CL0583-0226-1-52
16
34.04
29.04
24.04
17.78
80pcs per tray
PCN10C-20S-2.54DSA(52)
CL0583-0079-9-52
34.12
29.12
22.86
70pcs per tray
PCN10C-32S-2.54DSA(52)
CL0583-0033-8-52
32
54.36
49.36
44.36
38.10
50pcs per tray
PCN10C-44S-2.54DSA(52)
CL0583-0034-0-52
44
69.60
64.60
59.60
53.34
PCN10C-50S-2.54DSA(52)
CL0583-0035-3-52
50
77.22
72.22
67.22
60.96
PCN10C-64S-2.54DSA(52)
CL0583-0036-6-52
64
95.00
90.00
85.00
78.74
PCN10C-90S-2.54DSA(52)
CL0583-0037-9-52
90
128.02
123.02
118.02
111.76
PCN10C-100S-2.54DSA(52)
CL0583-0112-2-52
100
140.72
135.72
130.72
124.46
16
RoHS
Yes
Purchase Unit
40pcs per tray
30pcs per tray
20pcs per tray
● With
A
B
C
0.3
5.2
3.0 5.2 6.3
6.0
11.5
3.9
8.1
2.54
D
2.54
0.25t×0.7w
2.54
PCN10-#S-2.54DSA(72) and PCN10C-#S-2.54DSA(52).
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10EA-20S-2.54DSA(52)
CL0583-0188-4-52
34.12
29.12
22.86
70pcs per tray
PCN10EA-32S-2.54DSA(52)
CL0583-0189-7-52
32
54.36
49.36
44.36
38.10
50pcs per tray
PCN10EA-44S-2.54DSA(52)
CL0583-0190-6-52
44
69.60
64.60
59.60
53.34
40pcs per tray
PCN10EA-50S-2.54DSA(52)
CL0583-0191-9-52
50
77.22
72.22
67.22
60.96
PCN10EA-64S-2.54DSA(52)
CL0583-0192-1-52
64
95.00
90.00
85.00
78.74
PCN10EA-90S-2.54DSA(52)
CL0583-0193-4-52
90
128.02
123.02
118.02
111.76
PCN10EA-100S-2.54DSA(52)
CL0583-0194-7-52
100
140.72
135.72
130.72
124.46
17
RoHS
Yes
Purchase Unit
30pcs per tray
20pcs per tray
Pin Header : 3-row Right Angle Type (DIN Standard Type C)
A
B
C
D
11.0
2.54
□0.5
1.5
E
2.54 2.54 2.54
6.4
3.7
12.7
5.6 7.1
5.5
2-φ2.6
6.0
2.9
The 48pos. variation has guide key grooves in 8 locations.
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
D±0.1
E±0.1
2.54±0.1
12.6±0.1 5.08±0.1
c b a
1.65
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
E
PCN10-48P-2.54DS(72)
CL0583-0063-9-72
48
53.36
47.36
44.61
38.10
48.26
PCN10-96P-2.54DS(72)
CL0583-0001-1-72
96
94.00
88.00
85.25
78.74
88.90
18
RoHS
Yes
Purchase Unit
48pcs per tray
24pcs per tray
A
B
C
D
11.0
2.54
□0.5
6.0
3.35
2.54
2.54 2.54
6.4
3.7
5.5
12.7
1.5
2-φ2.6
2.9
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
D±0.1
E±0.1
2.54±0.1
12.6±0.1 5.08±0.1
c b a
1.65
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
E
PCN10A-48P-2.54DS(72)
CL0583-0064-1-72
48
53.36
47.36
44.61
38.10
48.26
PCN10A-96P-2.54DS(72)
CL0583-0006-5-72
96
94.00
88.00
85.25
78.74
88.90
19
RoHS
Yes
Purchase Unit
48pcs per tray
24pcs per tray
Pin Header : Right Angle Type
94
88
85.25
78.74
11.0
2.54
□0.5
2.54
3.35
5.08
3.7 6.4
1.5
2-φ2.6
88.9
6.0
2.9
φ0.8 +0.1
a
φ2.8 +0.1
2.54±0.1
2.54±0.1
5.3±0.1 5.08±0.1
c
12.7
4.9
5.6 7.1
5.5
1.65
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN10-64ACP-2.54DS(72)
HRS No.
CL0583-0046-0-72
No. of Pos.
RoHS
Purchase Unit
64
Yes
24pcs per tray
94
88
85.25
78.74
11.0
2.54
□0.5
5.08 2.54
3.7 6.4
1.5
2-φ2.6
3.35
2.9
88.9
φ0.8 +0.1
a
φ2.8 +0.1
2.54±0.1
2.54±0.1
12.6±0.1 5.08±0.1
c
12.7
4.9
5.6 7.1
5.5
1.65 6.0
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN10A-64ACP-2.54DS(72)
HRS No.
CL0583-0032-5-72
21
No. of Pos.
RoHS
Purchase Unit
64
Yes
24pcs per tray
Pin Header : 3-row Straight Type (DIN Standard Type R)
95
90±0.2
88
85.25
78.74±0.15
2-φ2.8
2.9
6.4
3.2 11.6
5.2 6.4
□0.5
2.54
2.54
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
78.74±0.1
5.08±0.1
c b a
8.7
0.3
2.54±0.1
90±0.1
Unit : mm
Part No.
PCN10-96P-2.54DSA(72)
HRS No.
CL0583-0002-4-72
22
No. of Pos.
RoHS
Purchase Unit
96
Yes
24pcs per tray
58.54
53.34±0.2
8.7
11.0
0.3
47.36
44.61
38.1±0.15
2.54±0.1
6.4
3.9 7.2 5.5
□0.5
2.54
2.54
0.3±0.05
φ0.8 +0.1
5.08±0.1
φ2.8 +0.1
2.54±0.1
c ba
2-φ2.6
2.54±0.1
38.1±0.1
53.34±0.1
Unit : mm
Part No.
PCN10-48P-2.54DSA(72)
HRS No.
CL0583-0104-4-72
23
No. of Pos.
RoHS
Purchase Unit
48
Yes
40pcs per tray
Receptacle : 3-row Right Angle Type
3.18
2.54±0.1
φ0.8 +0.1
2.54±0.1
5.3±0.15 5.08±0.1
c b a
2-φ2.5
88.9±0.2
2.54
2.54
2.54
12.5
10.15
6.3
10.26
8.5
2.54±0.1
94
85
78.74±0.15
φ2.8 +0.1
2.54±0.1
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN10A-96S-2.54DS(72)
HRS No.
CL0583-0027-5-72
24
No. of Pos.
RoHS
Purchase Unit
96
Yes
24pcs per tray
Receptacle : 3-row Right Angle Type (DIN Standard Type R)
94
85
78.74±0.15
2.54±0.1
2.54
2.54
10.15
6.3
2-φ2.5
5.56
3.18±0.5
1.25
2.54
88.9±0.2
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
2.54±0.1
5.3±0.15 5.08±0.1
c b a
12.5
10.26
8.5
0.3t×0.7w
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN10B-96S-2.54DS(72)
HRS No.
CL0583-0004-0-72
25
No. of Pos.
RoHS
Purchase Unit
96
Yes
24pcs per tray
Receptacle : 3-row Straight Type (DIN Standard Type C)
A
B
C
D
5.2 6.3
2.9
8.5
0.3
2.54±0.1
2.54
2.54
2.54
2.54
WA、WB
13.0
11.5
5.2 6.3
2.9
0.25t×0.7w
WA:0.5t×0.7w
WB:0.5t×0.5w
φ0.8 +0.1
φ2.8 +0.1
0 (Note)
2.54±0.1
D±0.1
B±0.1
5.08±0.1
2.54±0.1
a b c
DSA
3.9 11.5
10.5
2-φ2.8
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10-48S-2.54DSA(72)
CL0583-0065-4-72
48
54.36
50.00
44.36
38.10
PCN10-96S-2.54DSA(72)
CL0583-0003-7-72
96
95.00
90.00
85.00
78.74
PCN10-96S-2.54WA(72)
CL0583-0085-1-72
96
95.00
90.00
85.00
78.74
PCN10-96S-2.54WB(72)
CL0583-0071-7-72
96
95.00
90.00
85.00
78.74
26
RoHS
Purchase Unit
20pcs per tray
Yes
15pcs per tray
● With
3.9 11.5
3.0 5.2 6.3
10.5
8.5
0.3
2.54±0.1
A
B±0.2
C
D±0.15
0.25t×0.7w
2.54
2.54
PCN10-#S-2.54DSA(72).
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10EA-48S-2.54DSA(72)
CL0583-0195-0-72
48
54.36
50.00
44.36
38.10
PCN10EA-96S-2.54DSA(72)
CL0583-0180-2-72
96
95.00
90.00
85.00
78.74
27
RoHS
Yes
Purchase Unit
30pcs per tray
15pcs per tray
Receptacle : Straight Type
2.54±0.1
5.2 6.3
3.9 11.5
0.25t×0.7w
5.08
φ0.8 +0.1
c
2.54±0.1
78.74±0.1
90±0.1
5.08±0.1
φ2.8 +0.1
2.54±0.1
a
0.3
10.5
8.5
2-φ2.8
95
90±0.2
85
78.74±0.15
Unit : mm
Part No.
PCN10-64ACS-2.54DSA(72)
HRS No.
CL0583-0044-4-72
28
No. of Pos.
RoHS
Purchase Unit
64
Yes
15pcs per tray
Pin Header : 3-row Right Angle Type 144pos.
● With
11.6
2.54
11.1
0.5×0.5
2.54
2.54
129.54±0.2
3.78
2.54±0.1
φ0.9 +0.1
2.54±0.1
13.6±0.1 5.08±0.1
cba
1.5
5.5 3.0
15.0
9.7
2.54±0.1
137
130.64
125.94 +0.3
119.38±0.15
φ3.3 +0.1
2.54±0.1
119.38±0.1
129.38±0.1
Unit : mm
Part No.
PCN10MA-144P-2.54DS(72)
HRS No.
CL0583-0131-7-72
29
No. of Pos.
RoHS
Purchase Unit
144
Yes
20pcs per tray
Receptacle : 3-row Straight Type 144pos.
● With
3.4 12.74
3.0 5.24 7.5
126
2.54
1.79
2.54
0.75
Sequential contacts in rows a, b and c are located at 27 points between contact no.30-38.
φ0.9 +0.1
φ3.3 +0.1
2.54±0.1
2.54±0.1
5.08±0.1
0.75±0.05
14.5
9.5
2.54±0.1
140
134.8±0.15
131.4
125.64
119.38±0.15
119.38±0.1
134.8±0.1
Unit : mm
Part No.
PCN10MA-144S-2.54DSA(72)
HRS No.
CL0583-0130-4-72
30
No. of Pos.
RoHS
Purchase Unit
144
Yes
20pcs per tray
Pin Header : 4-row Right Angle Type
13.54
11.24
2.54±0.1
93.6
88
85.25
78.74±0.15
2.54
1.5
88.9±0.2
2.54 2.54 2.54
3.7 6.4
PCN10
2-φ2.6
1.65
4.55 6.0 5.89
φ0.8 +0.1
d c b a
φ2.8 +0.1
5.3±0.1
5.6 7.1
5.5
0.5×0.5
2.54±0.1
2.54±0.1
2.54±0.1
2.54±0.1
2.54±0.05
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN10-128P-2.54DS(72)
HRS No.
CL0583-0087-7-72
31
No. of Pos.
RoHS
Purchase Unit
128
Yes
12pcs per tray
93.6
88
85.25
78.74
11.24
13.54
2.54±0.1
0.5×0.5
2.9
2.9 5.89
1.65
φ0.8 +0.1
d c b a
φ2.8 +0.1
12.6±0.1
1.5
2-φ2.6
88.9±0.2
2.54 2.54 2.54
5.6 7.1
3.7 6.4
5.5
PCN10A
2.54±0.1
2.54±0.1
2.54±0.1
2.54±0.1
2.54±0.05
78.74±0.05
88.9±0.1
Unit : mm
Part No.
PCN10A-128P-2.54DS(72)
HRS No.
CL0583-0088-0-72
32
No. of Pos.
RoHS
Purchase Unit
128
Yes
12pcs per tray
Pin Header : 4-row Straight Type
95
90±0.2
85.25
78.74±0.15
11.24
0.3
2.54±0.1
2.9
6.4
3.2
0.5×0.5
2.54
2.54
2.54
2.54±0.1
2.54±0.1
φ0.8 +0.1
2.54±0.1
φ2.8 +0.1
78.74±0.1
90.0±0.1
2.54±0.1
0.3±0.05
11.6
5.2 6.4
13.54
2-φ2.8
Unit : mm
Part No.
PCN10-128P-2.54DSA(72)
HRS No.
CL0583-0215-5-72
33
No. of Pos.
RoHS
Purchase Unit
128
Yes
15pcs per tray
Receptacle : 4-row Straight Type
93.6
90±0.2
85
R1.4
78.74±0.15
11.04
13.04
2.54±0.1
13.0
WA、
WB
DSA
0.25t×0.7w
WA
0.5t×0.7w
2.54
2.54
WB
□0.5×0.5
2.54
2.54
3.9 11.5
5.2 6.3
DSA
2.54
2.54
φ2.8 +0.1
φ0.8 +0.1
0 (Note)
2.54±0.05
78.74±0.1
90±0.1
Note : WA is φ1 +0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
PCN10-128S-2.54DSA(72)
CL0583-0089-2-72
128
PCN10-128S-2.54WA(72)
CL0583-0090-1-72
128
PCN10-128S-2.54WB(72)
CL0583-0091-4-72
128
34
RoHS
Purchase Unit
12pcs per tray
Yes
16pcs per tray
Receptacle : 4-row Right Angle Type
94
85
2.54
2.54
2.54
4.5
5.56
88.9±0.2
4
1.25
3.18
2.54
22.26
12.5
7.62 10.15
.6
2-φ2
.6
2
2-φ
0.3t×0.7w
2.54±0.05
2.54±0.05
2.54±0.05
φ
2.54±0.05
5.3±0.1
2.54±0.05
.1
+0 0
8
0.
dcba
6.3
12.8
11.04
2.54±0.1
78.74±0.15
+0.1
4-φ2.8
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN10B-128S-2.54DS(72)
HRS No.
CL0583-0333-1-72
35
No. of Pos.
RoHS
Purchase Unit
128
Yes
12pcs per tray
Polarity Key
Use of the polarity key prevents connector misinsertion.
Insert the polarity key into both the receptacle side and pin header side.
Insert the polarity key far enough so that it makes contact with the bottom of
the mold.
PCN10-GK(A)
28.4
0.7
4.5
4.2
3.7
Part No.
PCN10-GK(A)
HRS No.
CL0583-0269-4-00
Material
Color
RoHS
Purchase Unit
PBT
Black
Yes
100pcs per bag
(The above diagram
include 4 polarity keys.)
Crimping Connector Compliant with DIN Standard
Ratings
Rated Current
Crimping
IDC
26 AWG
28, 30 AWG
2A
1A
Rated Voltage
300V AC
36
1A
200V AC
● 3-row
Type
2-φ2.8
95
90
85
78.74
2.9
Unit : mm
Part No.
PCN10-96S-2.54C
● 2-row
HRS No.
No. of Pos.
RoHS
Purchase Unit
96
Yes
10pcs per bag
CL0583-0100-3-00
Type
A
B±0.2
C
D±0.15
8.1
6.0
0.3
2.54±0.1
2-φ2.8
15.2
5.2 6.3
15.2
5.2 6.3
10.5
8.5
0.3
P=2.54
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10-20S-2.54C
CL0583-0241-5-00
34.12
29.12
22.86
PCN10-64S-2.54C
CL0583-0243-0-00
64
95.00
90.00
85.00
78.74
37
RoHS
Purchase Unit
Yes
10pcs per bag
Applicable Crimping Tool
● Manual
Crimping Tool
Crimp Contact
Crimping Tool
●PCN10-2630SC
(Fully Gold Plated)
●PCN10-TA2630HC
(PCN10-2630SC)
CL0583-0102-9-00(RoHS Compliant)
CL0550-0163-2-00
【Purchase Unit】100pcs per bag
●PCN10-TA2226HC
(PCN10-2226SC)
●PCN10-2226SC
(Partially Gold Plated)
CL0550-0218-2-00
CL0583-0216-8-00(RoHS Compliant)
13.2
2.8
(4.9)
1.85
5.5
1.85
Applicable Cable
●PCN10-2630SC : 26-30 AWG
●PCN10-2226SC : 22-26 AWG
● Automatic
Crimping Tool
Item
Part Number
Crimping Machine Body
Applicator
● Contact
HRS.No.
Applicable Contact
CM-105C
CL0901-0001-0-00
AP105-PCN10-2226S
CL0901-3506-6-00
PCN10-2226SCF
AP105-PCN10-2630S
CL0901-3508-1-00
PCN10-2630SCF
Extraction Tool
Part No.
HRS.No.
PCN10-PO
CL0550-0282-1-00
38
● Features
2. The exterior is black to distinguish
it from the other PCN10 Series.
( PCN10MC cannot be mated with other
series. )
● Pin
94
88
85.25
78.74±0.15
11
8.7
2.54±0.1
8.1
2.54
3.35
3
2.54
5.9
7.4
11.1
6.5
13.7
0.5×0.5
2-φ2.6
2.54
88.9±0.2
3.5
1.65
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
78.74±0.1
88.9±0.1
2.54±0.1
5.3±0.1 5.08±0.1
c b a
1. When mated, first the power supply
( ground) is contacted followed by
signal. When removed, the signal is
disconnected followed by power supply
( ground) . This prevents the circuit from
being affected if the board is removed or
inserted when the power is on.
Unit : mm
Part No.
PCN10MC-96P-2.54DS(72)
HRS No.
CL0583-0120-0-72
39
No. of Pos.
RoHS
Purchase Unit
96
Yes
24pcs per tray
● Receptacle
95
2-φ2.8
Sequence
3.9
1.2
0.25t×0.7w
2.54
2.54
The sequential contacts are No.1 and No.32 in row a.
5.08±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
a b c
12.5
5.2 7.3
1.7
2.9
10.5
8.5
0.3
2.54±0.1
Sequence
90±0.2
85
78.74±0.15
2.54±0.1
78.74±0.1
90±0.1
Unit : mm
Part No.
PCN10MC-96S-2.54DSA(72)
HRS No.
CL0583-0169-0-72
40
No. of Pos.
RoHS
Purchase Unit
96
Yes
15pcs per tray
2.54±0.1
0.6
2.54
11.1
5.9
7.4
6.5
1.8
D±0.2
0.5×0.5
3.9
3
2.54±0.1
2.54±0.1
D±0.1
C±0.1
φ0.8 +0.1
φ2.8 +0.1
13.6±0.1
2.54±0.1
ba
5.6 8.1
8.6
6.2
0.97
2.54±0.1
A
B
C±0.15
2.54
● Pin
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10MC-64P-2.54DS(72)
CL0583-0211-4-72
64
94.00
85.35
78.74
88.90
PCN10MC-100P-2.54DS(72)
CL0583-0212-7-72
100
139.72
131.07
124.46
134.62
41
RoHS
Purchase Unit
Yes
10pcs per tray
● Receptacle
A
B=0.2
0.3
C
2-φ2.8
3.9
1.2
0.25t×0.7w
2.54
樹脂塗布
Note
(64 contacts) : The sequential contacts are located at 22 points from contact No.1-4 and 26-32.
(100 contacts) : The sequential contacts are located at 22 points from contact No.1-4 and 44-50.
2.54±0.1
0.3±0.05
2.54±0.1
φ0.8 +0.1
B±0.1
D±0.1
φ2.8 +0.1
a b
2.9
3.2
12.5
5.2 7.3
1.7
8.1
6.0
2.54±0.1
D=0.15
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10MC-64S-2.54DSA(72)
CL0583-0213-0-72
64
95.00
90.00
85.00
78.74
PCN10MC-100S-2.54DSA(72)
CL0583-0214-2-72
100
140.72
135.72
130.72
124.46
42
RoHS
Yes
Purchase Unit
30pcs per tray
20pcs per tray
Stacking Pin Header
A
2.54±0.1
B=0.2
F
3 6.5
□0.5
B±0.1
D±0.1
2.54±0.1
2.54±0.1
φ0.8 +0.1
φ3.3 +0.1
Application Pattern
0.3
2.54
G
E
6.4
9.6
6.2
2.54±0.1
C
D=0.15
PCN10H#-#P-2.54DSA(72)
43
2.54
2.54
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN10H-16P-2.54DSA(72)
CL0583-0227-4-72
16
37.92
33.02
24.39
17.78
PCN10H-20P-2.54DSA(72)
CL0583-0157-0-72
38.10
29.47
22.86
PCN10H-24P-2.54DSA(72)
CL0583-0425-8-72
24
48.08
43.18
34.55
27.94
PCN10H-32P-2.54DSA(72)
CL0583-0161-8-72
32
58.24
53.34
44.71
38.10
PCN10H-44P-2.54DSA(72)
CL0583-0164-6-72
44
73.48
68.58
59.95
53.34
PCN10H-50P-2.54DSA(72)
CL0583-0401-0-72
50
81.10
76.20
67.57
60.96
PCN10HA-16P-2.54DSA(72)
CL0583-0228-7-72
16
37.92
33.02
24.39
17.78
PCN10HA-20P-2.54DSA(72)
CL0583-0158-3-72
38.10
29.47
22.86
PCN10HA-24P-2.54DSA(72)
CL0583-0426-0-72
24
48.08
43.18
34.55
27.94
PCN10HA-32P-2.54DSA(72)
CL0583-0162-0-72
32
58.24
53.34
44.71
38.10
PCN10HA-44P-2.54DSA(72)
CL0583-0165-9-72
44
73.48
68.58
59.95
53.34
PCN10HA-50P-2.54DSA(72)
CL0583-0402-2-72
50
81.10
76.20
67.57
60.96
PCN10HB-16P-2.54DSA(72)
CL0583-0229-0-72
16
37.92
33.02
24.39
17.78
PCN10HB-20P-2.54DSA(72)
CL0583-0159-6-72
38.10
29.47
22.86
PCN10HB-32P-2.54DSA(72)
CL0583-0163-3-72
32
58.24
53.34
44.71
38.10
PCN10HB-44P-2.54DSA(72)
CL0583-0166-1-72
44
73.48
68.58
59.95
53.34
PCN10HB-50P-2.54DSA(72)
CL0583-0403-5-72
50
81.10
76.20
67.57
60.96
PCN10HC-16P-2.54DSA(72)
CL0583-0397-4-72
16
37.92
33.02
24.39
17.78
PCN10HC-44P-2.54DSA(72)
CL0583-0399-0-72
44
73.48
68.58
59.95
53.34
PCN10HC-50P-2.54DSA(72)
CL0583-0404-8-72
50
81.10
76.20
67.57
60.96
PCN10HD-16P-2.54DSA(72)
CL0583-0398-7-72
16
37.92
33.02
24.39
17.78
PCN10HD-24P-2.54DSA(72)
CL0583-0429-9-72
24
48.08
43.18
34.55
27.94
PCN10HD-44P-2.54DSA(72)
CL0583-0400-7-72
44
73.48
68.58
59.95
53.34
PCN10HD-50P-2.54DSA(72)
CL0583-0405-0-72
50
81.10
76.20
67.57
60.96
Note: Please note that the above series cannot mate with PCN10EA Series
44
E
F
G
29.80
3.44
35.00
24.80
3.36
30.00
RoHS Purchase Unit
20pcs per tray
Yes
19.80
3.28
25.00
16pcs per tray
39.80
3.30
45.00
20pcs per tray
16pcs per tray
34.80
4.42
40.00
20pcs per tray
Precautions
● DIN Connector Mating Conditions
Use Hirose DIN connectors within the following range.
The contacts of the PCN10 Series receptacle rattle slightly in order to stabilize the contact installation but this does not
represent a performance issue.
±4°
1mm
±2°
1mm
While Taking in Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com
※ The contents of this catalog are current as of date of 7/ 2022. Contents are subject to change without notice for the purpose of improvements.
45
PCN12 Series
Jul.2022
PCN12 Series/IEC603-2 / DIN41612 Standard Compliant Products
Features
12 pin variations available : 10, 16, 20, 24, 28,
32, 44, 50, 64, 90, 96 and 100.
4. Wide applications
DIN standard types of C is available.
Applications
2
Rated Current
2A
-55 to +85℃
Rated Voltage
300V AC
85% Max.
Storage Temperature Range (Note 2)
-10 to +60℃
40 to 70%
Item
Specification
Condition
Insulation
Resistance
106M Ω Min.
Measured at 100V DC
Withstanding
Voltage
Contact Resistance
20m Ω Max.
Measured at 0.1A
Vibration
Humidity(Steady
State)
Temperature Cycle
Mating Durability
500 times
Soldering Heat
Resistance
performance.
Note 1 : Includes temperature rise due to current flow.
Material / Finish
Component
Material
Insulator
Contact
Color/Finish
Remarks
PBT
Beige
UL94V-0
Pin Header
Brass
Receptacle
Copper Alloy
3
■ PCN12 Series (Pin Header)
PCN12 A - # P - 2.54 DS
❶
❷
❸ ❹
❺
❻
❶
Series Name
PCN12
❸
No. of Pos.
❷
Configuration
Blank : DIN Standard Type C (96pos.)
A : Original Type
E・EA : With Lock Pin for Temporary Board
Installation
2 row : 10,16,20,24,28,32,44,50,64,90,100
3 row : 96
❹
Connector Type
P : Pin Header
❺
Contact Pitch
2.54mm
❻
Contact Type
■ PCN12 Series (Receptacle)
PCN12 E - # S - 2.54 DSA
❶
❷
❸ ❹
❺
❻
❶
Series Name
PCN12
❸
No. of Pos.
❷
Configuration
Blank : Standard Type
E : With Lock Pin for Temporary Board
Installation
3 row : 96
❹
Connector Type
S : Receptacle
❺
Contact Pitch
2.54mm
❻
Contact Type
DSA : Straight Through Hhole Type
4
2.54
4.9
B
C
2.54
2.54
D
0.5×0.5
1.65
2.9
Lot No. Mark
2.54±0.1
12.6±0.1 2.54±0.1
10.1
6.4
1.5
5.6 7.1
8.6
6.2
2.54
5.5
A
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
C±0.1
D±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
RoHS
Purchase Unit
PCN12A-10P-2.54DS(71)
CL0583-2010-3-71
10
25.42
16.77
10.16
20.32
60pcs per tray
PCN12A-20P-2.54DS(71)
CL0583-2012-9-71
29.47
22.86
33.02
40pcs per tray
PCN12A-28P-2.54DS(71)
CL0583-2085-2-71
28
48.26
39.63
33.02
43.18
30pcs per tray
PCN12A-32P-2.54DS(71)
CL0583-2013-1-71
32
53.36
44.71
38.10
48.26
PCN12A-44P-2.54DS(71)
CL0583-2014-4-71
44
68.60
59.95
53.34
63.50
PCN12A-50P-2.54DS(81)
CL0583-2015-7-81
50
76.22
67.57
60.96
71.12
PCN12A-64P-2.54DS(71)
CL0583-2016-0-71
64
94.00
85.35
78.74
88.90
5
20pcs per tray
10pcs per tray
● With
A
B
C
2.54
2.54
6.4
10.1
4.9
5.6 7.1
5.5
1.5
D
0.5×0.5
1.65
2.9
Lot No. Mark
2.54±0.1
12.6±0.1 2.54±0.1
8.6
6.2
2.54
2.54
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
C±0.1
D±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN12EA-10P-2.54DS(71)
CL0583-2028-9-71
10
25.42
16.77
10.16
20.32
PCN12EA-16P-2.54DS(71)
CL0583-2029-1-71
16
33.04
24.39
17.78
27.94
PCN12EA-20P-2.54DS(71)
CL0583-2030-0-71
29.47
22.86
33.02
PCN12EA-32P-2.54DS(71)
CL0583-2031-3-71
32
53.36
44.71
38.10
48.26
PCN12EA-44P-2.54DS(71)
CL0583-2032-6-71
44
68.60
59.95
53.34
63.50
PCN12EA-50P-2.54DS(71)
CL0583-2033-9-71
50
76.22
67.57
60.96
71.12
PCN12EA-64P-2.54DS(71)
CL0583-2034-1-71
64
94.00
85.35
78.74
88.90
PCN12EA-90P-2.54DS(71)
CL0583-2035-4-71
90
127.02
118.37
111.76
121.92
6
RoHS
Purchase Unit
60pcs per tray
40pcs per tray
20pcs per tray
10pcs per tray
A
0.3
2.54
D
8.1
2.54
B
C
3.9
3.2
11.5
5.2 6.3
6.0
2.54
φ2.8 +0.1
φ0.8 +0.1
2.54±0.1
2.54±0.1
0.25t×0.7w
D±0.1
B±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN12-10S-2.54DSA(71)
CL0583-2055-1-71
10
26.42
21.42
16.42
10.16
110pcs per tray
PCN12-16S-2.54DSA(71)
CL0583-2056-4-71
16
34.04
29.04
24.04
17.78
80pcs per tray
PCN12-20S-2.54DSA(71)
CL0583-2057-7-71
34.12
29.12
22.86
70pcs per tray
PCN12-24S-2.54DSA(71)
CL0583-2106-0-71
24
44.20
39.20
34.20
27.94
PCN12-28S-2.54DSA(71)
CL0583-2088-0-71
28
49.28
44.28
39.28
33.02
PCN12-32S-2.54DSA(71)
CL0583-2058-0-71
32
54.36
49.36
44.36
38.10
PCN12-44S-2.54DSA(71)
CL0583-2059-2-71
44
69.60
64.60
59.60
53.34
PCN12-50S-2.54DSA(71)
CL0583-2060-1-71
50
77.22
72.22
67.22
60.96
PCN12-64S-2.54DSA(71)
CL0583-2061-4-71
64
95.00
90.00
85.00
78.74
PCN12-100S-2.54DSA(71)
CL0583-2063-0-71
100
140.72
135.72
130.72
124.46
7
RoHS
Purchase Unit
60pcs per tray
50pcs per tray
40pcs per tray
30pcs per tray
20pcs per tray
● With
A
0.3
2.54
D
8.1
2.54
B
C
11.5
2.9 5.2 6.3
3.9
3.2
2.54
0.25t×0.7w
φ2.8 +0.1
φ0.8 +0.1
2.54±0.1
2.54±0.1
6.0
D±0.1
B±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN12E-10S-2.54DSA(71)
CL0583-2064-2-71
10
26.42
21.42
16.42
10.16
110pcs per tray
PCN12E-20S-2.54DSA(71)
CL0583-2066-8-71
34.12
29.12
22.86
70pcs per tray
PCN12E-32S-2.54DSA(71)
CL0583-2067-0-71
32
54.36
49.36
44.36
38.10
50pcs per tray
PCN12E-44S-2.54DSA(71)
CL0583-2068-3-71
44
69.60
64.60
59.60
53.34
PCN12E-50S-2.54DSA(71)
CL0583-2069-6-71
50
77.22
72.22
67.22
60.96
PCN12E-64S-2.54DSA(71)
CL0583-2070-5-71
64
95.00
90.00
85.00
78.74
PCN12E-90S-2.54DSA(71)
CL0583-2071-8-71
90
128.02
123.02
118.02
111.76
PCN12E-100S-2.54DSA(71)
CL0583-2072-0-71
100
140.72
135.72
130.72
124.46
8
RoHS
Purchase Unit
40pcs per tray
30pcs per tray
20pcs per tray
94
88
85.25
78.74
2.54
2.54 2.54 2.54
6.4
10.1
4.9
1.5
2-φ2.6
88.9
1.65
2.9
3.35
6
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
5.08±0.1
5.3±0.1
12.7
5.5
0.5×0.5
2.54
8.7
11
2.54
2.54±0.1
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN12-96P-2.54DS(71)
HRS No.
CL0583-2090-2-71
9
No. of Pos.
RoHS
Purchase Unit
96
24pcs per tray
94
88
85.25
78.74
2.54
2.54 2.54 2.54
6.4
10.1
2-φ2.6
88.9
2.9
1.65
6
3.35
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
2.54±0.1
5.08±0.1
12.6±0.1
1.5
4.9
12.7
5.5
0.5×0.5
2.54
8.7
11
2.54
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN12A-96P-2.54DS(71)
HRS No.
CL0583-2091-5-71
10
No. of Pos.
RoHS
Purchase Unit
96
24pcs per tray
Pin Header: 3-row Right Angle Type (Type C)
● With
94
88
85.25
78.74
2.54
2.54 2.54 2.54
6.4
88.9
10.1
4.9
12.7
5.5
1.5
1.65
2.9
6
3.35
2.54±0.1
2.54±0.1
5.08±0.1
5.3±0.1
0.5×0.5
2.54
8.7
11
2.54
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN12E-96P-2.54DS(71)
HRS No.
CL0583-2092-8-71
11
No. of Pos.
RoHS
Purchase Unit
96
24pcs per tray
● With
94
88
85.25
78.74
2.54
2.54 2.54 2.54
6.4
88.9
10.1
4.9
12.7
5.5
1.5
2.9
3.35
6
1.65
5.08±0.1
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
12.6±0.1
0.5×0.5
2.54
8.7
11
2.54
2.54±0.1
78.74±0.1
88.9±0.1
Unit : mm
Part No.
PCN12EA-96P-2.54DS(71)
HRS No.
CL0583-2093-0-71
12
No. of Pos.
RoHS
Purchase Unit
96
24pcs per tray
95
90
85
78.74
2-φ2.6
0.25t×0.7w
2.54
2.54
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
2.54±0.1
78.74±0.1
90±0.1
5.08±0.1
0.3
3.9 11.5
5.2 6.3
8.5
0.3
2.54
Unit : mm
Part No.
PCN12-96S-2.54DSA(71)
HRS No.
CL0583-2096-9-71
13
No. of Pos.
RoHS
Purchase Unit
96
15pcs per tray
Receptacle: 3-row Straight Type
● With
95
90
85
78.74
8.5
0.3
3.9 11.5
2.9 5.2 6.3
0.25t×0.7w
2.54
2.54
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
2.54±0.1
78.74±0.1
90±0.1
5.08±0.1
0.3
10.5
2.54
Unit : mm
Part No.
PCN12E-96S-2.54DSA(71)
HRS No.
CL0583-2097-1-71
14
No. of Pos.
RoHS
Purchase Unit
96
15pcs per tray
Precautions
±4°
1mm
±2°
1mm
15
PCN13 Series
Jul.2022
PCN13 Series/IEC603-2 / DIN41612 Standard Compliant Products
Features
12 pin variations available : 10, 16, 20, 30,
32, 44, 48, 50, 64, 90, 96 and 100.
Single-sided Two-point Contact System
High cost performance with the single- sided two
point contact design.
Applications
2
Rated Current
2A
-55 to +85℃
Rated Voltage
300V AC
85% Max.
-10 to +60℃
40 to 70%
Item
Specification
Condition
Insulation
Resistance
106M Ω Min.
Measured at 100V DC
Withstanding
Voltage
Contact Resistance
20m Ω Max.
Measured at 0.1A
Vibration
Humidity(Steady
State)
Temperature Cycle
Mating Durability
500 times
Soldering Heat
Resistance
performance.
Material / Finish
Component
Material
Insulator
Contact
Receptacle
Color/Finish
Remarks
PBT
Beige
UL94V-0
Copper Alloy
3
■ PCN13 Series (Receptacle)
PCN13 E - # S - 2.54 DSA
❶
❷
❶
Series Name
❷
❸
❸ ❹
❺
❻
❹
Connector Type S : Receptacle
Configuration Blank : Standard Type
E : With Lock Pin for Temporary Board Installation
❺
Contact Pitch
2.54mm
No. of Pos.
❺
Contact Pitch
PCN13
2 row : 10,16,20,30,32,44,50,64,90,100
3 row : 48,96
*PCN13 Series only includes socket connectors that mate with the PCN10 and PCN12 Series plugs.
4
A
B
C
D
8.1
6.0
0.3
2.54
11.5
5.2 6.3
3.2
2-φ2.6
0.25t×0.6w
2.54
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
2.54±0.1
0.3
3.9
C1
Lot No. Mark
D±0.1
B±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
RoHS
Purchase Unit
PCN13-16S-2.54DSA(71)
CL0583-3001-8-71
16
34.04
29.04
24.04
17.78
80pcs per tray
PCN13-20S-2.54DSA(71)
CL0583-3002-0-71
34.12
29.12
22.86
70pcs per tray
PCN13-32S-2.54DSA(71)
CL0583-3004-6-71
32
54.36
49.36
44.36
38.10
50pcs per tray
PCN13-44S-2.54DSA(71)
CL0583-3005-9-71
44
69.60
64.60
59.60
53.34
PCN13-50S-2.54DSA(71)
CL0583-3006-1-71
50
77.22
72.22
67.22
60.96
PCN13-64S-2.54DSA(71)
CL0583-3007-4-71
64
95.00
90.00
85.00
78.74
PCN13-90S-2.54DSA(71)
CL0583-3008-7-71
90
128.02
123.02
118.02
111.76
PCN13-100S-2.54DSA(71)
CL0583-3009-0-71
100
140.72
135.72
130.72
124.46
5
40pcs per tray
30pcs per tray
20pcs per tray
A
B
C
2.54
8.9
6.3
3.82
8.1
6.0
3.2
2.54
3.1
0.3t×0.7w
6.3±0.1
2.54±0.1
C
2.54±0.1
2.54±0.1
D
2.54
2-φ2.6
Lot No. Mark
φ0.8 +0.1
2-φ2.8 +0.1
D
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
RoHS
Purchase Unit
PCN13-16S-2.54DS(71)
CL0583-3031-9-71
16
38.02
24.04
17.78
33.02
44pcs per box
PCN13-20S-2.54DS(71)
CL0583-3032-1-71
29.12
22.86
38.10
33pcs per tray
PCN13-30S-2.54DS(71)
CL0583-3033-4-71
30
55.80
41.82
35.56
50.80
PCN13-32S-2.54DS(71)
CL0583-3034-7-71
32
58.34
44.36
38.10
53.34
PCN13-44S-2.54DS(71)
CL0583-3035-0-71
44
73.58
59.60
53.34
68.58
PCN13-50S-2.54DS(81)
CL0583-3036-2-81
50
81.20
67.22
60.96
76.20
PCN13-64S-2.54DS(71)
CL0583-3037-5-71
64
98.98
85.00
78.74
93.98
PCN13-90S-2.54DS(81)
CL0583-3038-8-81
90
132.00
118.02
111.76
127.00
PCN13-100S-2.54DS(71)
CL0583-3039-0-71
100
144.70
130.72
124.46
139.70
6
22pcs per tray
11pcs per tray
2.54
2.9
3.9
C1
0.25t×0.6w
2.54
2.54
2.54±0.1
φ0.8 +0.1
φ2.8 +0.1
2.54±0.1
D±0.1
B±0.1
5.08±0.1
a b c
11.5
5.2 6.3
8.5
0.3
2-φ2.6
10.5
A
B
C
D
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN13-48S-2.54DSA(71)
CL0583-3010-9-71
48
54.36
50.00
44.36
38.10
PCN13-96S-2.54DSA(71)
CL0583-3011-1-71
96
95.00
90.00
85.00
78.74
7
RoHS
Purchase Unit
20pcs per tray
15pcs per tray
A
B
C
8.5
2.54
2.54
10.15
6.3
2.54
2-φ2.6
D
Lot No. Mark
6.81
3.18
0.3t×0.7w
2.54±0.1
φ0.8 +0.1
2.54±0.1
5.3±0.1 5.08±0.1
c b a
12.5
10.26
2.54
φ2.8 +0.1
2.54±0.1
C±0.1
D±0.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
PCN13-48S-2.54DS(71)
CL0583-3040-0-71
48
53.36
44.36
38.10
48.26
PCN13-96S-2.54DS(71)
CL0583-3041-2-71
96
94.00
85.00
78.74
88.90
8
RoHS
Purchase Unit
48pcs per tray
24pcs per tray
Application Pattern
● Right
Angle Connection
●2-row Type
Mounting Hole Center
C.L. Center Line
C.L.
5.3
2.54
3.62
17.84
17.96
2.54
6.3
PCN10-#P-2.54DSA(72)
2.54
PCN10EA-#S-2.54DSA(52)
2.54
0.3
C.L.
2.54
0.3
PCN12A-#P-2.54DS(##)
5.27
C.L.
9
17.84
2.54
0.3
C.L.
12.6
17.96
2.54
2.54
PCN13-#S-2.54DSA(71)
2.54
2.54
2.78
17.84
PCN12(E)-#S-2.54DSA(71)
17.84
5.3
2.54
17.84
0.3
2.54
2.54
PCN13-#S-2.54DS(##)
12.6
C.L.
3.62
2.54
0.3
5.27
12.6
2.54
2.54
C.L.
2.54
PCN12A(EA)-#P-2.54DS(71)
PCN10-#P-2.54DS(72)
2.54
C.L.
5.27
6.3
PCN10EA-#P-2.54DS(72)
2.54
2.54
PCN10C-#S-2.54DS(72)
PCN10-#P-2.54DS(72)
2.54
2.78
●3-row Type
C.L. Center Line
2.54
0.3
17.84
0.3
2.54
2.54
0.3
C.L.
2.54
2.54
C.L.
0.3
2.54
2.54
C.L.
17.99
0.3
2.54
2.54
C.L.
5.2
2.54
PCN12A-#P-2.54DS(71)
0.3
2.54
0.3
2.54
2.54
C.L.
2.54
C.L.
10
17.84
12.6
17.84
2.54
5.3
PCN10-#P-2.54DS(72)
PCN12-#P-2.54DS(71)
2.54
2.54
3.55
48pos. : 19.09
5.3
2.54
17.99
48pos. : 19.09
2.54
2.54
2.54
5.3
PCN10B-#S-2.54DS(72)
4.83
PCN10A-#S-2.54DS(72)
2.54
2.54
3.58
2.54
2.54
48pos. : 17.9
16.8
12.6
2.54
2.54
5.2
C.L. Center Line
3.55
2.54
PCN12(E)-#P-2.54DS(71)
2.54
2.54
5.2
0.3
2.54
C.L.
17.84
12.6
2.54
C.L.
●3-row 144pos. Type
2.54
9.0
2.54
2.54
2.54
1.79
C.L.
0.75
C.L.
●4-row Type
6.77
2.54
2.54
5.3
17.84
2.54
12.6
17.84
2.54
2.54
2.54
5.12
2.54
2.54
2.54
C.L.
2.54
C.L. 4.85
17.99
5.3
2.54
2.54
0.3
2.54
2.54
C.L.
2.54
2.54
11
18.88
2.54
17.99
0.3
2.54
13.64
5.3
48pos. : 19.09
2.54
2.54
2.54
4.83
PCN13-#S-2.54DS(71)
0.3
2.54
2.54
2.54
2.54
2.54
17.84
5.3
Connection
●2-row Type
C.L. Center Line
19.0
2.54
2.65
4.3
2.54
6.3
5.3
2.54
2.54
19.0
19.0
2.54
PCN13-#S-2.54DS(##)
PCN10-#P-2.54DS(72)
6.3
2.54
4.05
2.54
C.L.
4.05
C.L.
PCN13-#S-2.54DS(##)
12.6
2.54
2.54
5.3
PCN12A-#P-2.54DS(72)
2.54
PCN10-#P-2.54DS(72)
2.54
2.54
19.0
2.54
6.3
2.54
6.3
2.54
4.05
2.54
C.L.
4.05
C.L.
2.65
4.3
12
12.6
● Coplanar
●3-row Type
C.L. Center Line
3.88
5.3
5.3
2.54
19.03
2.54
19.03
12.6
2.54
5.3
2.54
2.54
2.54
2.54
2.54
3.88
3.85
2.54
5.5
2.54
2.54
2.54
PCN10-#P-2.54DS(72)
C.L.
C.L.
2.54
2.54
2.54
5.13
5.3
5.3
2.54
19.03
2.54
19.03
2.54
2.54
5.3
12.6
C.L. 5.13
2.54
C.L.
2.54
3.85
2.54
PCN10-#P-2.54DS(72)
2.54
5.5
2.54
2.54
19.03
2.54
19.03
13
2.54
2.54
5.5
2.54
2.54
2.54
5.3
PCN10-#P-2.54DS(72)
PCN12-#P-2.54DS(71)
PCN10-#P-2.54DS(72)
PCN12-#P-2.54DS(71)
3.85
5.3
2.54
2.54
PCN13-#S-2.54DS(71)
5.3
2.54
C.L. 5.13
12.6
5.13
PCN13-#S-2.54DS(71)
2.54
C.L.
2.54
●4-row Type
C.L.
5.15
2.54
7.62
5.12
14
2.54
6.77
2.54
2.54
2.54
5.3
2.54
19.03
2.54
5.3
2.54
12.6
2.54
7.62
2.54
2.54
2.54
19.03
5.15
5.3
C.L.
● Parallel
Connection
●2-row Type
C.L. Center Line
0.3
0.3
2.54
2.54
16.8
2.54
2.54
C.L.
●3-row Type
2.54
2.54
0.3
16.8
0.3
2.54
2.54
C.L.
●4-row Type
C.L.
2.54
2.54
2.54
16.8
0.3
2.54
2.54
C.L.
0.3
48pos. : 17.9
2.54
2.54
2.54
2.54
0.3
15
48pos. : 17.9
2.54
16.8
16.8
● Circuit
Protection Type
C.L. Center Line
●3-row Type
5.27
PCN10MC-#P-2.54DS(72)
C.L.
2.54
●2-row Type
2.54
18.84
13.6
PCN10MC-#S-2.54DSA(72)
0.3
64pos. : The sequential contacts are indicated at 22 points from contact
No.1 to 4 and 26 to 32 in both rows a and b.
100pos. : The sequential contact is indicated at 22 points from contact
No.1 to 4 and 44 to 50 in both rows a and b.
● Stacking
2 points: a1 and a32.
Connector
C.L. Center Line
0.3
2.54
G
2.54
2.54
16
*G…35、30、25、45、40
Precautions
±4°
1mm
±2°
1mm
17
