DF80-50P-0.5SD(51)
DF80-50P-0.5SD(51)
    HRS(广濑)
DF80-50P-0.5SD(51) 数据手册
0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable DF80 Series Superb mating operability ¤&bb ¤&bb Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. O ■Features N 1. Supports high speed connections M The single row alignment utilizes a 0.5mm pitch to support 2.7Gbps & 5.4Gbps speeds and produces excellent signal characteristics. Supports eDPTM 【Embedded DisplayPort TM 】version 1.3 Fig. 1 High contact reliability 2. Maximizes space Designed to be a space saving connector, this series features a 0.5mm pitch, a low-mated height, and a single row layout in a vertical mating style. 1.72 ±0.08 (mated height) 3. Excellent mating operation It features long mating guides and a generous lead in opening that makes it easy to visually check the connection. (Lead-in amount : ± 1mm)(Fig. 1) (0.5) Effective mating length 4. Reliable contact structure The DF80 series utilizes its effective contact length (0.5mm) and a 2 point type contact structure to ensure high contact reliability.(Fig. 2) 5. Shield performance enhancement Fig. 2 Shield performance enhancement By utilizing multiple contacts between the plug and receptacle shells, the shielding performance is enhanced and creates a more reliable contact. (Fig. 3) ① ② 6. Durable plug structure ③ The plug has two metal covers around it to form a rigid structure. 7. Secure locking system with a clear tactile click A tactile click ensures that the lock function has been completed and is properly secured. This system also produces excellent lock retention. ③ ① ③ ③ ② 8. Structure supports a pull tab The structure was designed to allow a pull tab to be utilized to aid in un-mating the connector. 9. Halogen-free and RoHS compliant All materials and substances used to produce these parts comply with the Halogen-free and RoHS free standards. * Defined according to IEC 61249-2-21. Br: 900 ppm or below, Cl : 900 ppm or below, Br+Cl: 1,500 ppm or below ② ③ ① Multiple ground springs/points (8 places) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.9③ Fig. 3 1 DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable ■Product Specifications 【Discreet Cable】 32 AWG : 0.5A 36 AWG : 0.35A 【Thin wire coaxial cable】 (Note 3) 40 AWG : 0.2A 42 AWG : 0.2A 44 AWG : 0.15A 46 AWG : 0.1A Rated Current Ratings –35~+85ç (Note 1) 20 to 80% Rated Voltage AC/DC 50V 1. Insulation Resistance Minimum of 50Mø Measured with DC 100V 2. Withstanding Voltage No flashover or breakdown Signal : Maximum of 80mø GND : Maximum of 80mø Apply AC 150V for 1 minute Items Storage Temperature Range −10~+60ç (Note 2) Storage Humidity Range 40~70% (Note 2) Specifications 3. Contact Resistance 4. Vibration Resistance Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating Temperature Range Operating Humidity Range Conditions 100mA (DC or 1,000Hz) measurement 10 cycles in each of three directions at frequency 10-55Hz, half amplitude 0.75mm No electrical discontinuity of 1µs or greater 7. Durability Contact resistance (difference from initial state) Maximum of 50mø Insulation resistance Minimum of 25mø Contact resistance (difference from initial state) 50mø or below, Insulation resistance 25mø or above Contact Resistance : Maximum of 50mø 8. Soldering Heat Resistance Should be no melting of resin parts that affects its performance 5. Humidity Resistance 6. Temperature Cycles Left at temperature 40±2ç, humidity 90 to 95%, 96 hours (−55ç : 30 minutes → 5~35ç : 2~3 minutes → 85ç : 30 minutes → 5~35ç : 2~3 minutes) 5 cycles 30 mating cycles Reflow : according to the Recommended Temperature Profile Hand solder : Soldering iron temperature 350ç, 3 seconds Note 1 : Includes the temperature rise caused by current flow. Note 2 : The term “storage” refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-energized condition of installed connectors in storage, shipment or during transportation after board mounting. Note 3 : With only the connector portion at an elevated temperature level, the rated current value is set. ■Materials / Finish Product Component Materials Finish Specifications Insulator Contact Metal fitting Insulator Contact Outer Shell Outer Shell LCP Phosphorous bronze Phosphorous bronze LCP Phosphorous bronze Stainless steel Stainless steel Black Gold plating Tin plating Black Gold plating Tin plating Tin plating UL94V-0 Receptacle Plug Shell ------------------UL94V-0 ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Connector DF 80 − * S − 0.5 V (* *) ❶ ❷ ❸ ❹ DF 80 − * P − ❶ ❷ ❸ ❶ Series Name : DF ❷ Series No. : 80/80 D ❸ No. of Contacts : 30, 40, 50 ❹ Connector Type S : Receptacle P : Plug ❺ Contact pitch : 0.5mm 2 ❹ ❺ ❻ ❼ SHL ❽ ❻ Termination method V : Vertical SMT SD : Thin wire coaxial plug ❼ Packaging Type (51) Embossed packaging ❽ Separately installed parts SHL : Outer shell ---------------------------- DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable ■Receptacle (SMT) A±0.1 B±0.1 C±0.1 D±0.1 Contact No.1 P=0.5±0.05 t=0.1±0.015 5±0.1 1.65±0.1 0.5±0.05 0.58±0.05 0.5±0.05 【Specification No.】- **, (**) (51) : Embossed packaging Unit : mm Part No. HRS No. No. of Contacts A B C D E DF80-30S-0.5V(**) 662-8004-0 ** 30 21.00 20.94 16.10 14.50 DF80-40S-0.5V(**) 662-8001-2 ** 40 26.00 25.94 21.10 19.50 DF80-50S-0.5V(**) 662-8007-9 ** 50 31.00 30.94 26.10 24.50 F G 4.40 7.10 15.88 9.40 12.10 20.88 14.40 17.10 25.88 Note 1 : This product is sold in full reel quantities of 5,000 pcs/reel. Please place orders by full reel quantities. Contact pad Connector outline GND pad (0.25) 0.135±0.02 P=0.5±0.02 0.25±0.02 1.08±0.02 A H±0.05 J±0.05 (K) Pattern prohibited area D±0.05 4.5±0.05 5.5±0.05 A(FREE) L ±0.05 Pattern prohibited area M±0.05 N±0.05 P±0.05 0.65±0.02 (0.55) Pattern prohibited area BRecommended PCB layout (1.45) Pattern prohibited area Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (1.86) Vacuum pick up area (E) Vacuum pick up area F±0.1 G±0.1 B±0.1 Unit : mm Part No. HRS No. No. of Contacts H J K D L M 5.00 7.60 N P DF80-30S-0.5V(**) 662-8004-0 ** 30 21.54 15.70 15.38 14.50 DF80-40S-0.5V(**) 662-8001-2 ** 40 26.54 20.70 20.38 19.50 10.00 12.60 20.48 26.54 DF80-50S-0.5V(**) 662-8007-9 ** 50 31.54 25.70 25.38 24.50 15.00 17.60 25.48 31.54 15.48 21.54 3 DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable ■Plug A±0.1(Contact area) P=0.5±0.05(Contact area pitch) A±0.1(Contact Termination area) P=0.5±0.05(Contact Termination area pitch) 5.1±0.1 1.69±0.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.05 C±0.1 【Specification No.】- **, (**) (51) : Embossed packaging Unit : mm Part No. HRS No. No. of Contacts A B C D DF80D-30P-0.5SD(**) 662-8018-5 ** 30 14.50 15.62 18.40 15.48 DF80D-40P-0.5SD(**) 662-8118-0 ** 40 19.50 20.62 23.40 20.48 DF80D-50P-0.5SD(**) 662-8020-7 ** 50 24.50 25.62 28.40 25.48 Note 1 : This product is sold in full reel quantities of 5,000 pcs/reel. Please place orders by full reel quantities. Note 2 : When terminating electric wire, the outer shell (DF80-*P-SHL) is required. BRecommended wire preparation diagram E(FREE) Center conductor (Pre-soldered) D±0.1 A±0.15 E 0.05±0.05 P=0.5±0.07 2.5±0.05 1.35±0.05 0.8±0.05 Dielectric Note 1 : Pre-soldering with lead free solder is required for the center conductor. 4 Outer shield (for individual conductor) 0.05 mm Max. Jacket 0.57 ±0.03 (Ground bar thickness) DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable 0.34±0.05 ■Outer shell 1.51±0.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3-1.2±0.1 0.6±0.03 3.59±0.05 4.74±0.05 A±0.05 B±0.03 C±0.03 D±0.03 Unit : mm Part No. HRS No. No. of Contacts A B C D DF80-30P-SHL 662-8006-6 30 18.40 DF80-40P-SHL 662-8003-8 40 23.40 4.50 6.50 11.07 8.00 10.00 16.07 DF80-50P-SHL 662-8009-4 50 28.40 10.00 12.00 21.07 Note 1 : This product is sold in full reel quantities of 10,000 pcs/reel. Please place orders by full reel quantities. 5 DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable BEmbossed tape and reel dimensions (JIS C 0806/IEC60286 compliant) ●Reel Dimensions 8±0.1 .1 +0 0 4±0.1 2±0.1 Product label Ø1 3± 0. 2 (2.25) Ø1.5 holes for feed mechanism on back edge of carrier tape R0 .75 0.2±0.05 +0 0 .1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2± 0.5 Ø2 1± 0 .8 B±0.1 C±0.1 (Ø79) A±0.1 .5 Ø1 Ø382MAX 1.75±0.1 ●Receptacle D +20 E MAX Unreeling Direction Unit : mm Part No. HRS No. No. of Contacts A B C D E DF80-30S-0.5V(51) 662-8004-0 51 30 20.2 40.4 44.0 44.4 50.4 DF80-40S-0.5V(51) 662-8001-2 51 40 20.2 40.4 44.0 44.4 50.4 DF80-50S-0.5V(51) 662-8007-9 51 50 20.2 40.4 44.0 44.4 50.4 BEmbossed tape and reel dimensions (JIS C 0806/IEC60286 compliant) ●Reel Dimensions 4±0.1 (2.5) + 0 0 .1 Product label Ø1 3± 0. 2 (2.09) Ø1.5 holes for feed mechanism on back edge of carrier tape 8 Ø2 2± 1± 0. B±0.1 C±0.3 D +20 E MAX R0 .1 +00 .75 0.2±0.05 0.5 A±0.3 .5 (Ø79) Ø1 Ø382MAX 8±0.1 1.75±0.1 ●Plug Unreeling Direction Unit : mm 6 Part No. HRS No. No. of Contacts A B C D E DF80D-30P-0.5SD(51) 662-8018-5 51 30 20.2 40.4 44.0 44.4 50.4 DF80D-40P-0.5SD(51) 662-8118-0 51 40 20.2 40.4 44.0 44.4 50.4 DF80D-50P-0.5SD(51) 662-8020-7 51 50 20.2 40.4 44.0 44.4 50.4 DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable BOperating Precautions 1. Recommended Soldering Profile MAX 250ç (Supports lead-free mounting) 250 220ç 220 Temperature (ç) 200 180ç 180 150 150ç Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 0 90 to 120 seconds Maximum of 60 seconds Preheating time Soldering time Time (sec) [Applicable Conditions] 1. Peak temperature : 250ç MAX 2. Heating parts : 220ç or above, within 60 seconds 3. Preheating parts : 150 to 180ç, 90 to 120 seconds 4. Number of times : No more than 2 times *Solder composition : Sn- 3 Ag- 0.5 Cu Note 1 : This temperature profile is recommended values. 2. Recommended hand solder conditions The maximum temperature of the soldering iron should be 350ç with a maximum contact time of three seconds. 3. Recommended screen thickness : Opening ratio (pattern area ratio) Thickness : 0.1mm, opening ratio : lead 100%, ground 100% 4. Leaning of PCB Maximum of 0.02mm at the center of connector (using both edges of connector as criteria) 5. Washing conditions IPA washing OK. (Washing is not recommended as it may alter the tactile click feel upon mating. Please contact your local rep if you plan on using another cleaning agent.) 7 DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable BOperating Precautions Operating Precautions ■Connector mating procedure Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. • When inserting the plug, press straight down on the entire surface of the plug until it is completely inserted. • Do not press down on the wires when mating. Inserting the plug while pressing down on the wires may cause an angled insertion to occur and may result in damage to the connector. ■Connector unmating procedure • Un-mating the connector can be done in two different methods : unmating with fingers or with the pull tab. • Do not pull/hold on the terminal wires during extraction. Doing so can lead to damaged or disconnected wires. 【Unmating with fingers】 Pull up on the extension hook that is part of the connectors plug. Extension hook • The extension hook is made of metal, so please use caution when manipulating it as it may cause damage to your nail or finger. 【Unmating with pull tab】 Pull up on the tab in the arrowed direction (vertically) to extract the plug. ■Do not mate and unmate this connector if it has not been mounted on a PCB, doing this can damage and deform the contacts. ■Using excessive force while mating or unmating will damage the contacts or connector. ■When hand soldering, do not apply excessive amounts of flux. Doing so may promote solder wicking. ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 09/2017. Contents are subject to change without notice for the purpose of improvements.
DF80-50P-0.5SD(51)
物料型号:DF80系列
器件简介: - 支持高速连接,单排0.5mm间距,支持2.7Gbps和5.4Gbps速度。 - 采用嵌入式DisplayPort™版本1.3。 - 设计为节省空间的连接器,具有低配对高度和垂直连接方式的单排布局。
引脚分配:文档中提供了详细的引脚分配图和尺寸,包括接触点、拾取区域、绝缘体和外壳的尺寸。
参数特性: - 额定电流:32AWG 0.5A,36 AWG 0.35A,40AWG至46AWG 0.2A至0.1A。 - 工作温度范围:-35~+85°C。 - 额定电压:AC/DC 50V。 - 绝缘电阻:最小50MΩ。 - 耐电压:施加AC 150V 1分钟,无闪络或击穿。 - 接触电阻:信号最大80mΩ,地最大80mΩ。
功能详解: - 优秀的配对操作性,±1mm的引导量。 - 高接触可靠性,有效接触长度0.5mm,2点接触结构。 - 提升屏蔽性能,通过插头和插座壳体之间的多点接触。 - 耐用的插头结构,有两个金属盖形成坚固结构。 - 安全的锁定系统,具有清晰的触觉点击感。
应用信息: - 适用于需要高可靠性的应用,如汽车领域。
封装信息: - 提供了详细的材料和表面处理信息,包括绝缘体、接触点、金属配件和外壳的材料和镀层。 - 产品编号结构,用于确定产品规格。
操作注意事项: - 推荐焊接温度曲线,支持无铅焊接。 - 推荐手工焊接条件。 - 推荐网板厚度和开口比率。 - 清洗条件,建议使用IPA清洗。
DF80-50P-0.5SD(51) 价格&库存
很抱歉,暂时无法提供与“DF80-50P-0.5SD(51)”相匹配的价格&库存,您可以联系我们找货
