Ultra Low-profile Interface Connectors with 2.0mm Mounting Height
LX Series
■Overview
■ Features
Lower Profile
1. Low profile on the PCB
2. Strong Construction
Use of metal shell guarantees that fully mated
connectors will withstand 30N max. force applied
on the plug in any direction. (Fig.2)
3. High contact reliability
Bellows contact with long mating stroke provides
highly reliable mating as well as soft insertion
feeling.
Mating durability is up to 5,000 times long.
2
When mounted on the PCB surface the
receptacle height is 2.0mm. (Fig.1)
2.9
Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
LX Series is a super low profile interface
connector with sequential mating design and
friction lock, which has been developed for low
profile mobile terminals.
This connenctor features ESD problem
prevention in 0.5mm terminal pitch and 2.0mm
small and low profile design, which makes it
suitable to small mobile devices.
Existing 3200 Series
LX Series
Fig.1
Strong Construction
30N
4. Sequenced contact mating
The protection of the circuit is assured by having
the 2 contact at each end of the receptacle are
longer by 0.5mm, with electrical wipe of 1.45mm.
Location of the circuit protection contacts can be
changed as required.
Remaining contacts electrical wipe is 0.95mm.
30N
5. Incorrect Insertion Prevention
Connectors will not be damaged when angled or
reverse plug insertion is attempted. (Fig.3)
6. Safety plug release
Fig.2
Incorrect insertion prevention
Plug will release when an excessive pull force is
applied to the cable.
7. RoHS Compliant
All materials and substances used to produce
this product comply with RoHS standards.
■ Applications
DSC, Tablet device, thin electronic equipment,
mobile phones and other portable devices requiring
high durability interface connectors.
Angled insertion
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
Reversed insertion
Fig.3
2019.7r
1
LX Series●Ultra Low-profile Interface Connectors with 2.0mm Mounting Height
■Product specifications
Current rating
0.5A
(1A max. can be carried via 2 random contacts)
Ratings
Voltage rating
50V AC
Characteristic
Storage temperature range : – 55ç to +85ç
Specification
Conditions
1.Contact resistance 70mø max.
2.Insulation resistance
3.Withstanding voltage
100mA DC
1000Mø min. (dry)
100V DC
10Mø min. (high humidity)
No flashover or insulation breakdown.
250V AC / 1 minute
4.Mating/un-mating forces Mating : 10N max., un-mating : 4N min.
5. Durability
(mating/n-mating)
Operating temperature range : – 40ç to +70ç
6. Shock
7. Vibration
8. Temperature cycle
9. Salt spray
With corresponding connector.
Amount of change of contact resistance : 20mø max. 5,000 times
No electrical discontinuity of 1µ sec. Max.
Acceleration of 490 m/s2, 11 ms duration,
Contact resistance : 20mø max.
sine half-wave waveform, 3 cycles, 3 axis.
Frequency : 10 to 55 Hz, single amplitude of 0.75mm,
Insulation resistance : 10Mø min.
acceleration of 98 m/s2, 2 hours, 3 axis.
Temperature : – 55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç
Time
No heavy corrosions
5% water solution at 35°C for 48 hours
: 30
2 to 3
➝ 30
➝ 2 to 3 min
■Materials / Finish
●Receptacles
Component
Insulator
Material
Synthetic resin
Contacts
Copper alloy
Shell
Stainless steel
Component
Insulator
Material
Synthetic resin
Contacts
Copper alloy
Metal shield
Covers
Strain relief clamp
Self tapping screws
Stainless steel
Synthetic resin
Copper alloy
Steel
Finish/Color
Black
Contact area : Gold plated
Mounting area : Gold flash plated
Soldering area : Gold flash plated
Remarks
UL94V-0
Finish/Color
Black
Termination area : Gold flash plated
-------------Black
-------------Trivalent black chromate
Remarks
UL94V-0
●Plugs
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacles
1 Series number
LX 60 - 16 S
1
2
3
: LX
2 Termination type
40 : Solder type
4
60 : Right angle SMT
●Plugs
3 Number of contacts : 12, 16, 20
4 Contact type
LX 40 - 16 P
1
2
3
P : Male contact (Plug)
4
S : Female contact (Receptacle)
●Bushing
5 Bushing
LX 40 - 16 BS(4.5)
1
2
2
3
5
BS(4.0) : Dia. 4.0mm cable
BS(4.5) : Dia. 4.5mm cable
BS(5.0) : Dia. 5.0mm cable
--------------------------UL94V-0
-------------Screw size: M2
■Receptacles
●12 pos.
(5.5)
2.55
P=0.5
No.12
6.5
No.1
.5
2
R0
Ø1
0.8
4
10.6
3.6
245-0018-3
LX60-16S
245-0001-0
LX60-20S
245-0016-8
RoHS
2Ø1
.1
Ho
le
(5.5)
P=0.5
0.35
1.2
LX60-12S
Packaging
2,000 pcs/reel
5.7
HRS No.
PCB edge
0.3
3.8
2.8
1.5
Part No.
4
6.5
7.8
1.9
1.9
No conductive traces in this area
●16 pos.
2.55
(9.5)
P=0.5
2.55
P=0.5
6.5
No.1
.5
R0
(9.5)
Ø1
.1
P=0.5
le
Land area
5.7
PCB edge
1.9
7
10.5
11.8
0.3
0.3
1.9
3.8
2.8
1.5
5.7
1.9
5
8.5
9.8
0.35
Ho
le
PCB edge
Ø1
3.6
BRecommended PCB mounting pattern
2-
1.2
0.35
Ho
6.7
14.6
1.2
(7.5)
P=0.5
0.8
Ø1
3.6
2-Ø
.5
R0
2
0.8
5
12.6
6.5
No.1
No.20
2
No.16
1.1
Land area
●20 pos.
(7.5)
3.8
2.8
1.5
1.9
Land area
3
■Plugs
Ø5
.9
●12 pos.
8
14.8
(R
3.2
21.4
5.1
6.2
4
1.
Part No.
HRS No.
LX40-12P
245-0019-6
LX40-16P
245-0002-3
LX40-20P
245-0017-0
Packaging
RoHS
No.1
●20 pos.
Ø6
.4
.9
●16 pos.
8
16.8
(R
3.
No.12
1
Ø6
(R
18.8
3.
8.4
8)
21.4
21.4
8)
5.1
1.
No.1
4)
1.
(R
(R
5.5
No.16
No.1
6.2
4)
6.2
(R
No.20
■Bushing
Part No.
HRS No.
LX40-12BS(4.0)
245-0020-5
LX40-16BS(4.5)
245-0021-8
LX40-20BS(5.0)
245-0022-0
Packaging
RoHS
100 pcs/pack
4
Receptacle Packaging Specifications
●Embossed carrier tape dimensions
●Reel dimensions
Unreeling directions
C
JcgZZa^c\Y^gZXi^dch
B
.5
2
Ø1
1.75
4
A
9
>ch^YZY^bZch^dc
(mm)
Part No.
B
C
24
11.5
12
LX60-12S
LX60-16S
(mm)
Part No.
A
D
E
25.5
29.5
LX60-12S
LX60-16S
LX60-20S
LX60-20S
Receptacles Recommended Temperature Profile
This measurement is performed on the contact
lead section.
The temperature profile may vary due to external
conditions such as the type of cream solder,
manufacturer, and board size. Please contact the
solder manufacturer for their specifications.
E:6@/'*%
'(%b^c#
.%¤(%h
(%¤&%h
Applicable Plug Cable
(mm)
Part No.
Cable diameter
LX40-12P
Ø4 max.
LX40-16P
Ø4.5 max.
LX40-20P
Ø5 max.
Wire size
Ø0.6mm max. (AWG#30 to 32 or equivalent)
Note 1 : Applicable cable sizes are guidelines. (There may be slight differences depending on the cable outer insulation)
Note 2 : Cables must be attached using single piece overmolded bushings on the cable.
Note 3 : Please refer to applicable Cable Termination Procedures Manual for correct plug assembly and cable termination.
BMated Condition Dimensions
2
Receptacle
1.4
Plug
0.5
4
Djih^YZY^bZch^dc
2
(mm)
5
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 07/2019. Contents are subject to change without notice for the purpose of improvements.
