HNC1-2.5S-12
HNC1-2.5S-12
    HRS(广濑)
HNC1-2.5S-12 数据手册
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HNC Series 2.5mm Pitch Connector for Discrete Wire Connection Feb. 2021 ① HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Features 1. Positive Lock Postive lock design does not unlock without releasing the lock on both sides for effective prevention against cable disconnection when the cable gets caught, etc. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Mis-insertion Prevention Design Positive Lock 2. Low Profile Mounted height when the connector is used at a right angle : 4. 8mm 3. Mechanism to Prevent Misinsertion This thin type connector is equipped with a misinsertion prevention design. 4. Tin and Gold Plating Variations Available Two plating types, tin and gold, are available and can be chosen based on your application needs. Additionally, the tin plating type has a light operating feel. Applications Various business equipment, financial terminals 2 HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Product Specifications Rated Current (Note 1) Rated Voltage 22 AWG 24AWG 26 AWG 28 AWG 30 AWG Operating Temperature (Note 2) -55 to +85℃ 3A/pin 3A/pin 2A/pin 1A/pin 0.5A/pin Storage Temperature Range -10 to +60℃ Operating Humidity Range (Note 3) 20 to 80% Storage Humidity Range 40 to 70% 250V AC/DC Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Condition Insulation Resistance 1000M Ω Min. 500V DC Withstanding Voltage No flashover or insulation breakdown. 1000V AC for 1 min. Contact Resistance 10m Ω Max. Measured at a maximum of 20mV, 1mA (DC or 1000Hz) Insertion/Extraction Force Insertion force : 4.4N Max. Extraction force : 0.4N Min. Measure at the square steel pin of 0.635 ± 0.002mm Vibration No electrical discontinuity of 10μ s or more 10 cycles in each of three axis at frequency 10-55Hz, half amplitude 0.75mm Humidity (Steady State) Contact resistance : 10m Ω Max. Insulation resistance : 1000M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95% Temperature Cycle Contact resistance : 10m Ω Max. Insulation resistance : 1000M Ω Min. (-55℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes -85℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes) 5 cycles Mating Durability Tin plating : Contact resistance : 30m Ω Max. Gold plating : Contact resistance : 20m Ω Max. Tin plating : 30 cycles Gold plating : 50 cycles Resistance to Soldering Heat No deformation of components affecting performance. Flow : 250℃ for 5 seconds Note 1 : Note 2 : Note 3 : Note 4 :      Manual soldering : 300℃ for 2 seconds The rated current varies based on the cable size for use. The rated current of the header only is 3A. Includes temperature rise caused by current flow. The connector should be completely dry (no condensation present). Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. Materials / Finish Product Part Material Finish Remarks Crimp Socket Insulator Polyamide Black UL94V-2 Socket Crimp Contact Contact Phosphor Bronze Tin Plated or Gold Plated - Insulator Polyamide Black UL94V-2 Contact Brass Tin Plated or Gold Plated - Pin Header 3 RoHS 〇 HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Connector HNC2 - 2.5 P - # DSL Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❶ Series Name HNC2, 1 ❹ Number of Contacts 2 to 5, 7, 8, 10, 12, 15 ❷ Contact Pitch 2.5mm ❺ Contact Type ❸ Connector Type S : Socket P : Pin Header None : Crimp Socket DS : Straight DSL : Right Angle ❸ Applicable Cable Size A : 22-26 AWG B : 26-30 AWG ■ Contact HNC - 2.5S - C - A ❶ ❷ ❸ ❶ Type 2.5mm Pitch Socket ❷ Packaging Type C : Reel D : Bag 4 HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Crimp Socket [Fig.1]                  [Fig.2] Contact No.1 Contact No.1 Unit : mm Part No. HRS No. No. of Pos. A B C Dimensions HNC2-2.5S-2 CL0218-0011-1-00 2 12.4 6.0 2.5 HNC2-2.5S-3 CL0218-0022-8-00 3 14.9 8.5 5.0 HNC2-2.5S-4 CL0218-0039-0-00 4 17.4 11.0 7.5 HNC2-2.5S-5 CL0218-0027-1-00 5 19.9 13.5 10.0 HNC2-2.5S-7 CL0218-0030-6-00 7 24.9 18.5 15.0 HNC2-2.5S-8 CL0218-0014-0-00 8 27.4 21.0 17.5 HNC2-2.5S-10 CL0218-0017-8-00 10 32.4 26.0 22.5 HNC1-2.5S-12 CL0218-0008-7-00 12 37.0 31.0 27.5 Fig.2 HNC2-2.5S-15 CL0218-0045-3-00 15 44.9 38.5 35.0 Fig.1 Note : The series name for the 12 position connector is HNC1 and varies slightly in design. 5 Purchase Unit Fig.1 100pcs per bag HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Pin Header [Fig.3]                  [Fig.4] Contact No.1 Contact No.1 0.1 Note : Board Through-hole Diameter : φ 1.1 +  0 Unit : mm Specific No. Part No. HRS No. No. of Pos. A B C HNC2-2.5P-2DS(##) CL0218-0012-4-## 2 12.5 7.8 2.5 55 02 HNC2-2.5P-3DS(##) CL0218-0023-0-## 3 15.0 10.4 5.0 55 02 HNC2-2.5P-4DS(##) CL0218-0040-0-## 4 17.5 12.9 7.5 55 01 HNC2-2.5P-5DS(##) CL0218-0028-4-## 5 20.0 15.4 10.0 55 02 HNC2-2.5P-7DS(##) CL0218-0031-9-## 7 25.0 20.4 15.0 55 02 HNC2-2.5P-8DS(##) CL0218-0015-2-## 8 27.5 22.8 17.5 55 02 HNC2-2.5P-10DS(##) CL0218-0018-0-## 10 32.5 27.8 22.5 55 02 HNC1-2.5P-12DS(##) CL0218-0009-0-## 12 35.5 32.8 27.5 55 02 Fig.4 HNC2-2.5P-15DS(##) CL0218-0046-6-## 15 45.0 40.4 35.0 55 01 Fig.3 Note : The series name for the 12 position connector is HNC1 and varies slightly in design. 6 Tin Gold Dimensions Purchase Unit Plating Plating Fig.3 100pcs per bag HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right Angle Pin Header [Fig.5]                  [Fig.6] Contact No.1 Contact No.1 0.1 Note : Board Through-hole Diameter : φ 1.1 +  0 Unit : mm Specific No. Part No. HRS No. No. of Pos. A B C Tin Plating HNC2-2.5P-2DSL(##) CL0218-0013-7-## 2 12.5 7.8 2.5 55 02 HNC2-2.5P-3DSL(##) CL0218-0024-3-## 3 15.0 10.4 5.0 55 02 HNC2-2.5P-4DSL(##) CL0218-0041-2-## 4 17.5 12.9 7.5 55 01 HNC2-2.5P-5DSL(##) CL0218-0029-7-## 5 20.0 15.4 10.0 55 02 HNC2-2.5P-7DSL(##) CL0218-0032-1-## 7 25.0 20.4 15.0 55 02 HNC2-2.5P-8DSL(##) CL0218-0016-5-## 8 27.5 22.8 17.5 55 02 HNC2-2.5P-10DSL(##) CL0218-0019-3-## 10 32.5 27.8 22.5 55 02 HNC1-2.5P-12DSL(##) CL0218-0010-9-## 12 35.5 32.8 27.5 55 02 Fig.6 HNC2-2.5P-15DSL(##) CL0218-0047-9-## 15 45.0 40.4 35.0 55 01 Fig.5 Note : The series name for the 12 position connector is HNC1 and varies slightly in design. 7 Gold Dimensions Plating Purchase Unit Fig.5 100pcs per bag HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Socket Crimp Contact Unit : mm Part No. A B 1.8 2.6 1.5 1.7 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HNC-2.5S-C-A(15) HNC-2.5S-C-A(02) HNC-2.5S-D-A(15) HNC-2.5S-D-A(02) HNC-2.5S-C-B(15) HNC-2.5S-C-B(02) HNC-2.5S-D-B(15) HNC-2.5S-D-B(02) ● Reel Contact (Applicable Tool : Applicator) Part No. HRS No. Finish HNC-2.5S-C-A(15) HNC-2.5S-C-A(02) CL0218-0021-5-15 CL0218-0021-5-02 Tin Plated Gold Plated HNC-2.5S-C-B(15) HNC-2.5S-C-B(02) ● Loose CL0218-0020-2-15 CL0218-0020-2-02 Tin Plated Gold Plated Applicable Wire(Tin Plated Annealing Copper Wire) (Note 2) UL AWG Wire Construction Sectional Area Jacket Diameter 1007 22 24 26 17/0.16mm 11/0.16mm 7/0.16mm 0.342mm2 0.221mm2 0.141mm2 1.35 to 1.7mm 1061,1007 26 28 30 7/0.16mm 7/0.127mm 7/0.1mm 0.141mm2 0.089mm2 0.055mm2 1.0 to 1.35mm Purchase Unit 10,000pcs per reel Contact (Applicable Tool : Manual Crimping Tool) Part No. HRS No. Finish HNC-2.5S-D-A(15) HNC-2.5S-D-A(02) CL0218-0037-5-15 CL0218-0037-5-02 Tin Plated Gold Plated HNC-2.5S-D-B(15) HNC-2.5S-D-B(02) CL0218-0038-8-15 CL0218-0038-8-02 Tin Plated Gold Plated Applicable Wire(Tin Plated Annealing Copper Wire) (Note 2) UL AWG Wire Construction Sectional Area Jacket Diameter 1007 22 24 26 17/0.16mm 11/0.16mm 7/0.16mm 0.342mm2 0.221mm2 0.141mm2 1.6mm 1.5mm 1.3mm 1007 26 28 30 7/0.16mm 7/0.127mm 7/0.1mm 0.141mm2 0.089mm2 0.055mm2 1.3mm 1.2mm 1.1mm Note : Please consult with a Hirose representative when using wires other than those specified. Mated Diagram 8 Purchase Unit 100pcs per bag HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Applicable Crimping Tool Type Part No. HRS No. Applicable Contact Applicator AP105-HNC CL0901-4502-0-00 HNC-2.5S-C-A(15)、 HNC-2.5S-C-A(02) HNC-2.5S-C-B(15)、 HNC-2.5S-C-B(02) Press Main Unit CM-105C CL0901-0001-0-00 - TC-HNC-B CL0250-0005-7-00 HNC-2.5S-D-B(15)、 HNC-2.5S-D-B(02) TC-HNC-A CL0250-0006-0-00 HNC-2.5S-D-A(15)、 HNC-2.5S-D-A(02) Manual Crimping Tool Extraction Tool Flat-blade screwdriver (thickness < 0.75mm) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note 1 : Please conduct crimping work according to the "Crimping Quality Standard" (ETAD-H0980-00)" and "Crimping Condition Table". Note 2 : Issues with non-Hirose specified tools are outside the scope of warranty. Note 3 : When non-authorized tools are used, please consult with Hirose sales representative about provision of the drawing of the crimping tool. 9 HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Crimping ■Items Required Prior to Starting The work- related documents listed below are required before starting harness assembly. The ● mark indicates a required document. When the documents shown below are not available, ask a Hirose sales personnel to provide them. Description Automatic Crimping Machine Hand Crimping Tool 1. Crimping Machine Main Unit Instruction Manual Explanation of main press machine unit ● - 2. Applicator Instruction Manual Crimp Method ● - 3. Applicator Spare Parts List Explanation for Applicator Installation ● - 4. Crimp Conditions Standard crimp height and tensile strength values ● - 5. Crimp Quality Standards Various standards for crimping conditions ● - 6. Operating Instructions for Hand Tool Crimping method, standard crimp height and tensile strength values - ● Bundled with purchase of hand tool. 7 .Cable Assembly Procedure Cable Assembly Procedure ● ● Ask a Hirose sales personnel to provide them. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Document Title Remarks Bundled with purchase of main press machine unit. Bundled with purchase of applicator. ■Tools The tools specified by Hirose should be used for crimping work. Crimping work by tools other than those specified must not be done because it may result in contact failure, disconnection of cable, etc. * The operating instructions manual is available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual before implementing the work. ■Applicable Electric Wires Check that the electric wire to be used is within the applicable range. If you intend to use an electric wire other than those recommended, ask a HRS sales personnel. [ Precautions] ・Electric wires that are suitable for crimping connectors are tin- plated stranded softcopper wire. ・Avoid crimping solid wires, wires with polyester threads or tin- coated wires. ・Avoid crimping two electric wires together. ・The crimp height setting value ( Note) may vary between tin- plated and gold- plated contacts even if the same electric wires are used. ・The crimp height setting value ( Note) may vary depending on the difference in the core wire configuration even if the computed cross- sectional area is the same. Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 10 HNC Series/2.5mm Pitch Connector for Discrete Wire Connection Handling Precautions 1. Cleaning Conditions Please refer to the " Wire- to- Board Connector Guide" . 2. Handling Instructions Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Please refer to the following documents. ■ Crimp Quality Standard ( ETAD- H0980- 00) ■ Wire- to- Board Connector Guide While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 2/ 2021. Contents are subject to change without notice for the purpose of improvements. 11
HNC1-2.5S-12 价格&库存
很抱歉,暂时无法提供与“HNC1-2.5S-12”相匹配的价格&库存,您可以联系我们找货
HNC1-2.5S-12
  • 1+4.473191+0.55950
  • 10+3.7778310+0.47252
  • 25+3.5446425+0.44336
  • 50+3.3748250+0.42212
  • 100+3.21264100+0.40183
  • 300+2.97269300+0.37182
  • 500+2.86740500+0.35865
  • 1000+2.730401000+0.34151
  • 2500+2.559392500+0.32012
