FX4C-20P-1.27DSA(71) 数据手册
Stacking Height 5 to 11mm Half Pitch Connector
FX4 Series
Stacking Height Flexible
5 to 11mm
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DIP type
The mounting area 70% reduced, compared with
conventional product (FX2 series)
FX2 series
FX4 series
(Compared with 60 contacts)
■Features
The FX4 series is a miniature board to board connectors, where the stacking height can be set at the 1mm interval.
●Through hole Type
1. Small and Light
The mounting space and weight is reduced about 30%, compared to the conventional product (HRS FX2 series),
respectively, and the mounting area about 70% reduced, compared to the conventional one.
2. Stacking Height 5 to 11mm
The board to board stacking height can be set per 1mm from 5mm up to 11mm.
3. Flux Swell Prevention
When solder is dipped, the flux swell from the board rear side is completely prevented.
4. Mis-insertion Prevention and Low Insertion/Extraction Force Mechanism
The connection area is designed to completely prevent the mis-insertion.
Moreover, the low insertion/extraction mechanism is adopted.
■Applications
Computers, peripheral equipments, business equipments, etc.
A119
FX4 Series●Stacking Height 5 to 11mm Half Pitch Connector
■Product Specifications
Rating
Current rating 0.5A
Operating Temperature Range -55ç to +85ç (Note 1)
Storage Temperature Range -10ç to +60ç (Note 2)
Voltage rating 125V AC
Operating Humidity Range 40% to 80%
Storage Humidity Range 40% to 70%
Item
Specification
Condition
1. Insulation Resistance
100M ohms min.
Measured at 250V PC
2. Withstanding Voltage
No flashover or insulation breakdown.
300V AC for 1 minute
3. Resistance
45m ohms max.
100mA
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Contact resistance: 55m ohms max. Insulation resistance: 100M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95%
6. Temperature Cycle
Contact resistance : 55m ohms max.
(-55ç: 30 minutes 15 to 35ç: 2 to 3 minutes
Insulation resistance : 100M ohms min.
(-85ç: 30 minutes 15 to 35ç: 2 to 3minutes) 5 cycles
7. Durability (Mating/un-mating) Contact resistance : 55m ohms max.
300 cycles
8. Resistance to Soldering heat No deformation of components affecting performance. Solder bath: 260ç for 10 seconds
Manual soldering: 360ç for 5 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Part
Material
Finish
Remarks
Insulator
Polyamide
Beige
Selective gold plated
UL94V-0
________
________
Receptacle Contact
Phosphor bronze
Header Contact
Note : The black dots on the insulater will not affect performance.
■Ordering Information
●Dip Type
FX4C 1 - 80 P - 1.27 DSA L
q
w
e
q Series Name : FX4C
r
t
y
r Connector Type
w Product Height Variable:None: Standard 1: +1mm
2: +2mm
3: +3mm
e Number of Contacts: 20, 32, 40, 52, 60, 68, 80
u
P : Header
S : Receptacle
t Contact Pitch : 1.27mm
y Contact type DSA : Straight
u L: Board prefixed pin
BApplication Pattern and Stacking Height Combination
●Through hole Type
Unit: mm
Receptacle
Header
A120
FX4C -*S
FX4C2-*S
FX4C3-*S
(Catalog page A124) (Catalog page A125) (Catalog page A126)
FX4C -*P
(Catalog page A121)
5
7
8
FX4C1-*P
(Catalog page A122)
6
8
9
FX4C3-*P
(Catalog page A123)
8
10
11
■Header (Through hole Type)-Stacking Height: Standard type
BPCB mounting pattern
Unit: mm
Part Number
CL No.
574-0001-0-71
FX4C-20P-1.27DSAL(71)
574-0051-9-71
FX4C-32P-1.27DSA(71)
574-0002-3-71
FX4C-32P-1.27DSAL(71)
574-0052-1-71
FX4C-40P-1.27DSA(71)
574-0003-6-71
FX4C-40P-1.27DSAL(71)
574-0053-4-71
FX4C-52P-1.27DSA(71)
574-0004-9-71
FX4C-52P-1.27DSAL(71)
574-0054-7-71
FX4C-60P-1.27DSA(71)
574-0005-1-71
FX4C-60P-1.27DSAL(71)
574-0055-0-71
FX4C-68P-1.27DSA(71)
574-0006-4-71
FX4C-68P-1.27DSAL(71)
574-0056-2-71
FX4C-80P-1.27DSA(71)
574-0007-7-71
FX4C-80P-1.27DSAL(71)
574-0057-5-71
Number of Contacts
A
B
C
14.58
11.43
32
29.49
22.2
19.05
40
34.57
27.28
24.13
52
42.19
34.9
31.75
60
47.27
39.98
36.83
68
52.35
45.06
41.91
80
59.97
52.68
49.53
D
________
RoHS
20.32
________
27.94
________
33.02
________
40.64
________
YES
45.72
________
50.8
________
58.42
A121
■Header (Through hole Type)-Stacking Height: Standard+1mm type
A122
Unit: mm
Part Number
CL No.
FX4C1-20P-1.27DSA(71)
574-0011-4-71
FX4C1-20P-1.27DSAL(71)
574-0061-2-71
FX4C1-32P-1.27DSA(71)
574-0012-7-71
FX4C1-32P-1.27DSAL(71)
574-0062-5-71
FX4C1-40P-1.27DSA(71)
574-0013-0-71
FX4C1-40P-1.27DSAL(71)
574-0063-8-71
FX4C1-52P-1.27DSA(71)
574-0014-2-71
FX4C1-52P-1.27DSAL(71)
574-0064-0-71
FX4C1-60P-1.27DSA(71)
574-0015-5-71
FX4C1-60P-1.27DSAL(71)
574-0065-3-71
FX4C1-68P-1.27DSA(71)
574-0016-8-71
FX4C1-68P-1.27DSAL(71)
574-0066-6-71
FX4C1-80P-1.27DSA(71)
574-0017-0-71
FX4C1-80P-1.27DSAL(71)
574-0067-9-71
Number of Contacts
A
B
C
14.58
11.43
32
29.49
22.2
19.05
40
34.57
27.28
24.13
52
42.19
34.9
31.75
60
47.27
39.98
36.83
68
52.35
45.06
41.91
80
59.97
52.68
49.53
D
________
RoHS
20.32
________
27.94
________
33.02
________
40.64
________
45.72
________
50.8
________
58.42
YES
■Header (Through hole Type)-Stacking Height: Standard+3mm type
Unit: mm
Part Number
CL No.
FX4C3-20P-1.27DSA(71)
574-0031-1-71
FX4C3-20P-1.27DSAL(71)
574-0081-0-71
FX4C3-32P-1.27DSA(71)
574-0032-4-71
FX4C3-32P-1.27DSAL(71)
574-0082-2-71
FX4C3-40P-1.27DSA(71)
574-0033-7-71
FX4C3-40P-1.27DSAL(71)
574-0083-5-71
FX4C3-52P-1.27DSA(71)
574-0034-0-71
FX4C3-52P-1.27DSAL(71)
574-0084-8-71
FX4C3-60P-1.27DSA(71)
574-0035-2-71
FX4C3-60P-1.27DSAL(71)
574-0085-0-71
FX4C3-68P-1.27DSA(71)
574-0036-5-71
FX4C3-68P-1.27DSAL(71)
574-0086-3-71
FX4C3-80P-1.27DSA(71)
574-0037-8-71
FX4C3-80P-1.27DSAL(71)
574-0087-6-71
Number of Contacts
A
B
C
14.58
11.43
32
29.49
22.2
19.05
40
34.57
27.28
24.13
52
42.19
34.9
31.75
60
47.27
39.98
36.83
68
52.35
45.06
41.91
80
59.97
52.68
49.53
D
________
RoHS
20.32
________
27.94
________
33.02
________
40.64
________
YES
45.72
________
50.8
________
58.42
A123
■Receptacle (Through hole Type)-Stacking Height: Standard type
A124
Unit: mm
Part Number
CL No.
FX4C-20S-1.27DSA(71)
574-0101-5-71
FX4C-20S-1.27DSAL(71)
574-0151-3-71
FX4C-32S-1.27DSA(71)
574-0102-8-71
FX4C-32S-1.27DSAL(71)
574-0152-6-71
FX4C-40S-1.27DSA(71)
574-0103-0-71
FX4C-40S-1.27DSAL(71)
574-0153-9-71
FX4C-52S-1.27DSA(71)
574-0104-3-71
FX4C-52S-1.27DSAL(71)
574-0154-1-71
FX4C-60S-1.27DSA(71)
574-0105-6-71
FX4C-60S-1.27DSAL(71)
574-0155-4-71
FX4C-68S-1.27DSA(71)
574-0106-9-71
FX4C-68S-1.27DSAL(71)
574-0156-7-71
FX4C-80S-1.27DSA(71)
574-0107-1-71
FX4C-80S-1.27DSAL(71)
574-0157-0-71
Number of Contacts
A
B
C
11.43
18.48
32
29.49
19.05
26.1
40
34.57
24.13
31.18
52
42.19
31.75
38.8
60
47.27
36.83
43.88
68
52.35
41.91
48.96
80
59.97
49.53
56.58
D
________
RoHS
20.32
________
27.94
________
33.02
________
40.64
________
45.72
________
50.8
________
58.42
YES
■Receptacle (Through hole Type)-Stacking Height: Standard+2mm type
Unit: mm
Part Number
CL No.
FX4C2-20S-1.27DSA(71)
574-0121-2-71
FX4C2-20S-1.27DSAL(71)
574-0171-0-71
FX4C2-32S-1.27DSA(71)
574-0122-5-71
FX4C2-32S-1.27DSAL(71)
574-0172-3-71
FX4C2-40S-1.27DSA(71)
574-0123-8-71
FX4C2-40S-1.27DSAL(71)
574-0173-6-71
FX4C2-52S-1.27DSA(71)
574-0124-0-71
FX4C2-52S-1.27DSAL(71)
574-0174-9-71
FX4C2-60S-1.27DSA(71)
574-0125-3-71
FX4C2-60S-1.27DSAL(71)
574-0175-1-71
FX4C2-68S-1.27DSA(71)
574-0126-6-71
FX4C2-68S-1.27DSAL(71)
574-0176-4-71
FX4C2-80S-1.27DSA(71)
574-0127-9-71
FX4C2-80S-1.27DSAL(71)
574-0177-7-71
Number of Contacts
A
B
C
11.43
18.48
32
29.49
19.05
26.1
40
34.57
24.13
31.18
52
42.19
31.75
38.8
60
47.27
36.83
43.88
68
52.35
41.91
48.96
80
59.97
49.53
56.58
D
________
RoHS
20.32
________
27.94
________
33.02
________
40.64
________
YES
45.72
________
50.8
________
58.42
A125
■Receptacle (Through hole Type)-Stacking Height: Standard+3mm type
A126
Unit: mm
Part Number
CL No.
FX4C3-20S-1.27DSA(71)
574-0131-6-71
FX4C3-20S-1.27DSAL(71)
574-0181-4-71
FX4C3-32S-1.27DSA(71)
574-0132-9-71
FX4C3-32S-1.27DSAL(71)
574-0182-7-71
FX4C3-40S-1.27DSA(71)
574-0133-1-71
FX4C3-40S-1.27DSAL(71)
574-0183-0-71
FX4C3-52S-1.27DSA(71)
574-0134-4-71
FX4C3-52S-1.27DSAL(71)
574-0184-2-71
FX4C3-60S-1.27DSA(71)
574-0135-7-71
FX4C3-60S-1.27DSAL(71)
574-0185-5-71
FX4C3-68S-1.27DSA(71)
574-0136-0-71
FX4C3-68S-1.27DSAL(71)
574-0186-8-71
FX4C3-80S-1.27DSA(71)
574-0137-2-71
FX4C3-80S-1.27DSAL(71)
574-0187-0-71
Number of Contacts
A
B
C
11.43
18.48
32
29.49
19.05
26.1
40
34.57
24.13
31.18
52
42.19
31.75
38.8
60
47.27
36.83
43.88
68
52.35
41.91
48.96
80
59.97
49.53
56.58
D
________
RoHS
20.32
________
27.94
________
33.02
________
40.64
________
45.72
________
50.8
________
58.42
YES
BConnector Precautions
1. Tolerance Clearance on Mating Side
The effective connecting length of the product is set to
1.5mm. Please use the product to specify the clearance
between the header and the receptacle in the connection
process within 1mm.
2. Prefixed Process to Board (Through hole Type)
If the prefixed work is required for
mounting on the board, please use
the prefixed pin type. (Applicable
board thickness t = 1.6±0.1)
Cautions:When the connector is installed in the
board, the dip post is guided into the board
through-hole in order to prevent the dip
post breakage, and then insert the board in
parallel to the connector so as to push in
the prefixed pin.
A127
FX4C-20P-1.27DSA(71) 价格&库存
很抱歉,暂时无法提供与“FX4C-20P-1.27DSA(71)”相匹配的价格&库存,您可以联系我们找货
