Small I/O connectors for AC adapters
RP34 Series
Features
1. Superior mating operability
A snap-and-lock style allows easy mating/
unmating.
2. Cable direction is variable
The three-position, right-angled plug makes it
possible to arrange the cable to the left or right,
offering flexible wiring options depending on your
requirement.
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3. Sequential contact mating
Designed with sequential contact mating, one pin
makes contact with its counterpart sooner than
the others and establishes a securely grounded
connection.
4. Easy plug assembly
A snap-together case eliminates the need for
screws to fasten the case and helps provide for a
quick plug assembly.
5. Variations
Items
Number of contacts
3 or, 4
Plug : Straight, right angle
Connector type
Receptacle : Right angle
Plug termination version
Crimp
Receptacle termination version PCB dip
Receptacle mounting method PCB dip
Product Specifications
Rated current
Rated voltage
Ratings
Items
1. Contact resistance
2. Insulation
resistance
3. Withstanding
voltage
4. Vibration
resistance
3A
AC30V, DC42V
Operating temperature range
Storage temperature range
Specifications
Conditions
30mø max
Measured at DC 1A
1,000Mø min
Measured at DC 100V
No flashover or dielectric breakdown.
AC 150V for 1 minute
No electrical discontinuity for 10µs or longer.
5. Shock resistance
6. Mating Cycles
Contact resistance : 60mø max.
7. Temperature cycle Insulation resistance : 100Mø min.
8. Moisture
resistance
-10 to +60℃
-10 to +60℃
Insulation resistance:
10Mø min (at high humidities).
100Mø min (when dry).
10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions,
2 hours each
Acceleration : 490m/s2, duration : 11ms, 3 axis directions,
3 cycles each
3 contacts : 5,000 times, 4 contacts : 1,000 times
-55ç : 30 minutes ➝ Normal temperature : 10 to 15
minutes ➝ 85ç : 30 minutes➝ Normal Temperature :
10 to 15 minutes, left for 5 cycles
Temperature : 40ç, relative humidity : 90 to 95%, left for
96 hours
Materials / Finish
Plug
Receptacle
Crimped female
contact
Items
Exterior, insulator
Clamp
Bushing
Male contact
Material
Polycarbonate resin
Brass
Vinyl chloride resin
PBT resin
Steel
Brass
Finish
Tin plating
Silver plating
Remarks
UL94V-0
UL94V-0
Female contact
Phosphor bronze
Silver plating
Exterior, insulator
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.11③
1
RP34 Series●Small plastic connectors for AC adapters
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Connector
RP34 - 8 SP - 3 S C (71)
Model name : RP34 Series
Shell size : The shell size is the outer diameter of the mating end of the plug.
Shell type
SP : Straight plug
P : Right-angled plug
R : Receptacle
Number of contacts :
Contact form
P : Male contact
S : Female contact
Contact termination method :
C : Crimp contact termination
DL : Right-angled dip method
Other specifications : A two-digit character is added to indicate other specifications.
Crimp contact
RP34 - SC - 2 1 2
Contact type : SC = Crimped female contact
Contact packaging types :
1 : Loose piece contacts
2 : Reel contacts
Applicable wire :
1 : For 18 to 22 AWG
2 : For 24 to 28 AWG
Identification of plating : 2 : Silver plating
2
Straight plug
37.5
10
Ø4.4
30.5
7.5
A
3
1
2
RP34-8SP-3SC(71)
HRS No.
113-5049-1 71
RP34-8SP-3SCD(71)
113-5061-7 71
RP34-8SP-4SC(71)
113-5097-4 71
No. of contacts
A
3
9.6
4
11
Remarks
Mating key dependent type
Note : Cable clamping force, cable rotation force, and other aspects may differ depending on the cable construction.
We reccomend that you verify the suitability of the cable assembly before use or production.
Right-angled plug
25
7.5
2
18
Ø4.4
18
10
RP34-8P-3SC(71)
10
Part No.
RP34-8SP-3SC(71)
(This figure is a representative example.)
3
1
2
Part No.
RP34-8P-3SC(71)
HRS No.
113-5041-0 71
We recommend that you verify the suitability of the cable assembly before use or production.
3
Receptacle
11.3
A
10
1
3
3
2
B
RP34-8R-3PDL
Part No.
HRS No.
No. of contacts
RP34-8R-3PDL
113-5042-2
RP34-8R-3PDLD
113-5066-0
RP34-8R-4PDL
113-5098-7
A
B
3
10
11
4
11
12
Remarks
Contact (female contact)
Part No.
HRS No.
B
A_A
RP34-SC-212
113-5043-5
1.6
Applicable wire
size
2.1 18 to 22 AWG
B
RP34-SC-112
113-5076-4
1.6
2.1 18 to 22 AWG
RP34-SC-222
113-5100-7
1.2 1.35 24 to 28 AWG
RP34-SC-122
113-5102-2
1.48
C
A
A
C
Remarks
Reel contacts
Loose piece
contacts
Reel contacts
Loose piece
contacts
Note : Loose piece contacts are packaged 100 pcs/pack and reel contacts are
available on 10,000 piece reel. Please order in full quantity packs or
reels.
8.7
Dip post arrangement for PCB layout
5.25
5.9
2
2.1
.1
+0 0
.5
Ø1
1
.7
3
0.8
0.8
1.
Ø1
4-
1 +0
.1
+0 0
1.9
0 .1
4
4Ø
+0
0 .1
1.7
4-Ø
1.9
5.25
10.5
4 position
2.1
5 +0.1
Ø1.
7.4
1
+0.
3-Ø
Positioning hole
(1 location)
4.25
4.75
2.75
4.75
Positioning hole
(1 location)
10.5
3 position
2.4 2.4
Remarks 1. The applicable PCB thickness is between 0.8 and 1.6mm.
2. A machining tolerance of ±0.05 is recommended for the PCB layout.
3. The above figure shows the PCB side of the rack into which contact dip
posts will be inserted.
"▼" mark indicates the plug interface mating side.
4
Termination procedure
Straight plug
Operation procedure̶straight plug
1. First, pass the prepared cable through the bushing, and then crimp
and terminate the contacts.
2. Assemble the crimped and terminated contacts into the contact holes
of the S-insulation P case.
At this time, please make sure that the crimped contacts are
securely engaged onto the contact holes of the S-insulation P case
by lightly pulling on the cable.
3. Crimp and fix the metal fitting for clamping with the applicable tool
(RP34-TC-01).
4. Assemble the S-insulation P case, metal fitting for clamping, and
bushing onto the cord tube (A). The S-insulation P case can be
assembled in two ways, at 180° opposing angles. Please make sure
to select the orientation that is suitable for your purpose.
5. Finally, assemble the remaining cord tube (B). The assembly has
been completed.
Metal fitting for
clamping
Cord tube
(A) or (B)
2 0
S-insulation
P case
+0.5
2mm or more
Bushing
1.3
Cable
Rightangle plug
Operation procedure̶right-angled plug
1. The right-angled plugs can be assembled in the same manner as
the straight plugs, and the S-insulation P case can be assembled
to the cord tube in one of two positions. 180° opposite each other.
Please make sure to select the orientation that is suitable for your
purpose.
Cover
S-insulation
P case
Cord tube
Applicable tools
Type
Machine
crimping
Items
Part No.
HRS No.
Applicable contact
Applicable wire size
Automatic crimping press
CM-105C
901-0001-0
AP105-RP34-1
901-2025-2
RP34-SC-212
18 to 22 AWG
AP105-RP34-2
901-2034-3
RP34-SC-222
24 to 28 AWG
Applicator
Cable crimping tool
RP34-TC-01
150-0074-1
Extraction tool
RP34-SC-TP
150-0072-6
Cable crimping tool (RP34-TC-01)
(The handle shape shown above is a representative example.)
(Type CM-105C)
5
RP34L Series●Small plastic connectors for AC adapters
Type RP34L
Ratings
Rated current
5A (when using 18 AWG)
−25℃ to +85℃
Rated voltage
AC30V, DC42V
−10℃ to +60℃
Items
Specifications
Conditions
1. Contact resistance 30mø max.
2. Insulation
1,000Mø min.
resistance
3. Withstanding
voltage
4. Vibration proof
No electrical discontinuity 10µs or longer.
5. Temperature cycle Insulation resistance : 100Mø min
6. Corrosion
resistance
7. Mating Cycles
Measured at DC 1A
Measured at DC 100V
10 to 55Hz, half amplitude : 0.75mm, 3 axis directions,
2 hours each
minutes ➝ +85ç : 30 minutes ➝
Normal Temperature : 10 to 15 minutes, 5 cycles
No corrosion that affects performance.
Left in 5% salt water solution for 48 hours
5,000 times
Materials / Finish
Items
Receptacle̶
(2position)
Plug̶
(2 position)
Receptacle̶
(3 position)
Metal fitting
Material
Phosphor bronze
Insulator
Polyamide resin
Black
UL94HB
Contact
Brass
Palladium plating
Exterior
Insulator
Polyamide resin
Black
UL94V-0
UL94HB
Contact
Phosphor bronze
Silver plating
Phosphor bronze
Solder plating
Insulator
PPS resin
Black
UL94V-0
Brass
Palladium plating
Black
UL94V-0
Palladium plating
Exterior
Polycarbonate resin
Insulator
PPS resin
Contact
Phosphor bronze
■Product Number Structure
RP34L - 5 PA - 2 SC (****)
Series name : RP34L
Shell : Indicates the shell form.
Type
Receptacle : R
Straight plug : PA
Right-angled plug : LP
Number of contacts : Shows the number.
2 or 3 contacts.
6
Remarks
Metal fitting
Contact
Plug̶
(3 position)
Finish
Solder plating
Contact type
PD : Male contact (dip)
SC : Female contact (crimped)
Cable length : (****) may vary depending on
the cable.
Receptacle
2 position
3 position
2 position
7
9.1
7
2.5
2.5
6.1
5
7.4
RP34L-5R-2PD(71)
Recommended panel opening dimensions (reference)
7.5
+0.1
1.3
7.4
+0.1
3−
Ø1 +
.1 0
0 1
1.35±0.05
1.35±0.05
3
4±0.05
4−
Ø1
.1
2.35±0.05
+0
0 .1
4±0.05
.1
2− Ø1.5 +0
2− Ø1.5 +0.1
RP34L-5R-3PD(71) 113-5157-4 71
4.3±0.05
2.35±0.05
4.5±0.05
4.3±0.05
3.45±0.05
(Mating interface side) (Mating interface side)
1.15±0.05
PCB layout mounting dimensions
PCB layout dimension
3.45±0.05
(1.2)
PCB
Plug Panel
0.2±0.05
Part No.
HRS No.
RP34L-5R-2PD(71) 113-5154-6 71
1.3 -0.1
3.9
6.2
(1.2)
RP34L-5R-3PD(71)
PCB
Plug
1857 A
22.4
4.8
5.5
2.5
7.6
A
Bushing
Single-contact shielded cable
(Center conductor wires: 18 AWG, shielded cable: 18AWG or equivalent)
Ø9
6
A_A
21.5
Board-in
crimping
contact
1.5
9.7
7
6.1
1800
Ø3.5
7.8
R3
6
RP34L-5PA-2SC(1857)(71)
29.7
23.1
6.2
10.45
7.2
4.8
Ø4.4
7.8
3.7
(External shell)
RP34L-5PA-3SC(71)
Ø4.4
RP34L-5LP-3SC(71)
11.625
4.8
7.2
10.9
11.85
2.65
6.2
5.925 11.4
17.6
11
7.8
+0.1
Panel
2.12±0.05
3 position
3.7
Part No.
HRS No.
RP34L-5PA-2SC(1857)(71) 113-5153-3 71
RP34L-5PA-3SC(71)
113-5178-4 71
RP34L-5LP-3SC(71)
113-5161-1 71
7
Crimp contact
1.6
0.3
2.2
A
A
12.7
Section A_A
RP34L-SC1-212(01)
Part No.
RP34L-SC1-212(01)
HRS No.
113-5151-8 01
Applicable tools
Type
Manual crimping tools
Automatic
Machine
crimping press
crimping
Applicator
Part No.
HT-102/RP34L-SC1-212
HRS No.
150-0210-8
Applicable contact
RP34L-SC1-112(01)
Applicable cables
18 to 22 AWG
CM-105C
901-0001-0
AP105-RP34L-SC1-212
901-2043-4
RP34L-SC1-212(01)
18 to 22 AWG
Cable crimping tool
RP34-TC-01
150-0074-1
Ø4
Extraction tool
RP6-SC-TP
150-0039-0
Assembly procedure (3 position plug)
Straight plug
Cable
Bushing
2
1
Metal fitting for
clamping
8
2 +0.5
(Mating section)
(Round hole)
Cord tube (A)
Cord tube (B)
Cord tube (A)
(Tab)
S-insulation P case
Cord tube (B)
Right angle
1. Right-angled plugs can be assembled in the same manner as the
straight plugs.
13.7
2
+0.5
S-insulation P case
Metal fitting for clamping
2
11
2
Bushing
Cable
S-insulation P case
8
1
1. First pass the prepared cable through the bushing, and then crimp
holes of the S-insulation P case. At this time, please make sure that
the crimped contacts are securely engaged onto the contact holes
of the S-insulation P case by lightly pulling the cable. If you find an
erroneous wiring, insert the extractor (RP6-SC-TP) from the mating
side to pull out the contact from the termination side, and then reassemble.
3. Crimp the metal fitting for clamping with the applicable tool (RP34TC-01).
4. Align and assemble the protrusion of the S-insulation P case to the
round hole of the cord tube (B).
5. Attach the mating section of the metal fitting for clamping to the
recess of the cord tube (B), and then assemble the bushing and
metal fitting for clamping onto the cord tube (B).
6. Assemble the cord tube (A) onto the cord tube (B). At this time,
please make sure that the four tabs of the cord tube (B) rest on the
angled hole of the cord tube (A).
Cord tube
Precautions
1. To prevent damage to the connector after mounting, make sure that it is supported with a panel or another substrate. This
will prevent any type of excessive load or force on the connector. For 2 position type, please support the external shell of the
receptacle. For 3 position type, please support the external shell of the plug.
See page 3 for details on recommended panel dimensions.
Receptacle
Panel
(External shell)
Receptacle
Plug
Panel
2. When mated together, do not apply a load of 30 N or more on the cable in the direction indicated by the arrows.
Please note that an excessive tensile stress may break the connectors.
3. This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may
cause tarnishing.
・Dusty environments
・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on.
Example; In close proximity to factory exhaust, automotive emissions, etc.
・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.
・Close to rubber products includes rubber adhesives.
The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins.
Storage
Packing state; Packed in original packing or equivalent container
Temperature -10 to +60ç
Humidity
85% Max
(It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any
temperature fluctuation)
Please use this products within 6 months of delivery.
(After 6 month, please check the solderbility before use)
“Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB.
9
MEMO :
10
MEMO :
11
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
12
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 11/2018. Contents are subject to change without notice for the purpose of improvements.
