NEW
Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height
X.FL Series
●Connector mated condition
Mated height comparison (compared to conventional company products)
0.89(0.95MAX)
1.2(1.3MAX)
0.94(1.0MAX)
X.FL-LP-040
X.FL-LP-032(09) X.FL-LP(P)-068
X.FL-PR-SMT1-2
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
X.FL-R-SMT-1 X.FL-R-SMT-1 X.FL-R-SMT-1
Fig. 1
■Features
4. High frequency transmission
1. A Low mated height of 0.94 or 1.2
mm (maximum of 1.0 or 1.3 mm)
This series offers the high performance needed to
meet the requirements of many different
miniature devices, featuring a DC to 6 GHz
capacity. X.FL-LP(P)-068 supports up to 12 GHz.
When connected this series delivers a world class
low mated height of 1.0 or 1.3 mm (see Figure 1).
2. Minimal mounting area required
5. Automatic board placement
The receptacle requires a footprint of only 3.4 mm2,
which is the same footprint as our W.FL and W.
FL2 series. In addition, the same land patterns can
be used. (Note: The X.FL series has no mating
compatibility with the W.FL2 and W.FL series.)
This product is available in embossed
packaging; this allows the plug and receptacles
to be automatically mounted.
6. T h e u s e o f u l t r a - f i n e c o a x i a l
(fluorinated resin insulated) cables
3. Ultra lightweight
The use of ultra-fine coaxial (fluorinated resin
insulated) cables on these connectors offer the
ability to complete connections in small,
confined spaces with a smooth, easy operation.
The world’s smallest and lightest class of coaxial
connectors
Receptacle: 3.2 mg
Right angle plug: 22.0 mg (068),14.4 mg (040), and 15.7 mg (032)
Plug receptacle: 5.5 mg
7. Simple connector mating / unmating
Dedicated tools are available to ensure that proper
mating/unmating of this connector takes place.
■Product Specifications
Nominal characteristic impedance
Frequency range
Ratings
50ø
DC~6GHz
Operating temperature range -40°C to +90°C (RH 90% or less)
Storage humidity range
-30°C to +70°C (RH 90% or less)
Specifications (for each plug type)
Item
X.FL-LP-040
X.FL-LP-032(09)
X.FL-LP(P)-068
X.FL-PR-SMT1-2
1. Contact
resistance
(Center) Maximum of 20 mø (Center) Maximum of 25 mø (Center) Maximum of 25 mø (Center) Maximum of 25 mø
(Outer) Maximum of 10 mø (Outer) Maximum of 25 mø (Outer) Maximum of 10 mø (Outer) Maximum of 15 mø
2. V.S.W.R. (*)
1.3 or less (DC to 3 GHz)
1.4 or less (3 to 6 GHz)
1.7 or less (6 to 12 GHz)
3. Insulation resistance
Minimum of 500 MΩ , 100 V DC
4. Withstanding voltage
200 V AC, 1 minute
1.5 or less (3 to 6 GHz)
*V.S.W.R. Measurement System (plug type)
The above V.S.W.R. specification values were measured using the measurement system shown below.
Network Analyzer
Test Set
Test Port
Test Port Cable
D.U.T
Termination
Note 1:Cable type connectors were measured with SMA
conversion adapters attached to both ends of the
harness product of a suitable 100 cm cable.
Note 2:Board type connectors were mounted to a 50
glass epoxy board and measurements were
conducted with SMA conversion adapters
attached.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2014.1
1
X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height
■Cable Assembly (Plug)
2
●X.FL-LP-040 (Applicable cable: outer diameter Ø0.81 or Ø0.64)
3.3
0.74
Ø0.81 or Ø0.64
Material / Finishes
Part
Shell
Insulator
Female contact
Material
Phosphor bronze
LCP resin
Phosphor bronze
Finish and remarks
Gold plated
Black, UL94V-0
Gold plated
2
●X.FL-LP-032 (09) (Applicable cable: outer diameterØ0.5)
0.74
3.5
Ø0.5
Material / Finishes
Part
Shell
Insulator
Female contact
Material
Phosphor bronze
LCP resin
Phosphor bronze
Finish and remarks
Partially gold plated
Black, UL94V-0
Gold plated
2
●X.FL-LP (P) -068 (Applicable cable: outer diameterØ1.13)
3.6
1
Ø1.13
Material / Finishes
Part
Shell
Insulator
Female contact
Material
Phosphor bronze
LCP resin
Phosphor bronze
Finish and remarks
Black, UL94V-0
Gold plated
●Cable Guide
Description
Ø0.81 mm Coaxial
Cable
Ø0.64 mm Coaxial
Cable
Ø0.5 mm Coaxial
Cable
Ø1.13 mm Coaxial
Cable
2
Cable
Type
04
044
032
068
Cable Specification
Dielectric
Jacket
Nominal Nominal attenuation
Center Conductor
Outer Conductor
Diameter
Diameter Impedance 3GHz
6GHz
7/0.05 (36 AWG)
Ø0.40 Single-layer braided wire Ø0.81
50
5.6dB/m 8.3dB/m
Tin plated
Silver plated annealed copper wire
FEP
FEP
Fiber or paper covered
7/0.05 (36 AWG)
Ø0.44
Ø0.64
copper winding wire
50
5.85dB/m 8.59dB/m
PFA
PFA
Tin plated
7/0.04 (38 AWG)
Ø0.32
Ø0.5
50
6.13dB/m 9.09dB/m
copper winding wire
Silver plated copper alloy wire
PFA
PFA
Tin plated
7/0.08 (32 AWG)
Ø0.68 Single-layer braided wire Ø1.13
50
3.7dB/m 5.3dB/m
FEP
Tin plated
FEP
How to Specify Plug Cable Assembly
The dimensions of a cable assembly of the X.FL series should be specified as follows:
[Double-Ended Cable Assembly]
[Single-Ended Cable Assembly]
L(mm)
L(mm)
Single ended assemblies come with a blunt cut on the
non-terminated end. Please contact us if special strip
requirements are needed.
■Product Number Structure
Refer to the charts below for determining specific part number characteristics.
Please select connectors listed in this catalog when placing orders and be sure to check the latest delivery specifications at
the time of ordering the product.
●Used Plug: X.FL-LP-040
◇Ø0.81 Coaxial Cable
Double-Ended
X.FL - 2LP - 04K「」TV - A - (L)
❶
Single-Ended
❷
❸
❹
❺
❻
X.FL - LP - 04K「」TV - A - (L)
❶
❷
❸
❹
❺
❻
❶ Series name: X.FL series
❹ Cable color
❷ Assembly type LP: Single-ended, 2LP: Double-ended
❺ Cable outer conductor TV: Tin plated braided wire
❸ Cable type
❻ Total length L (mm)
04K: Ø0.81 coaxial cable
1: White, 2: Black
L length in mm
◇Ø0.64 Coaxial Cable
Double-Ended
X.FL - 2LP - 044N「」TS - A - (L)
❶
Single-Ended
❷
❸
❹
❻
X.FL - LP - 044N「」TS - A - (L)
❶
❷
❸
❹
❺
❻
1: White, 2: Black
❹ Cable color
TS: Tin plated fiber or paper
covered copper winding wire
❸ Cable type
❺
044N: Ø0.64 coaxial cable
L length in mm
Plug: X.FL-LP-032 (09) Ø0.5 coaxial cable
Double-Ended
X.FL - 2LP9 - 032H「」TS - A - (L)
❶
Single-Ended
❷
❸
❺
❻
X.FL - LP9 - 032H「」TS - A - (L)
❶
❷
❸
❷ Assembly type LP9: Single-ended, 2LP9: Double-ended
❸ Cable type
❹
032H: Ø0.5 coaxial cable
❹
❺
❻
1: White, 2: Black
❹ Cable color
L length in mm
3
Plug: X.FL-LP (P)-068 Ø1.13 coaxial cable
X.FL - 2LP P - 068W「」TV - A - (L)
Double-Ended
❶
❷
❸
❹
❺
❻
❼
X.FL - LP P - 068W「」TV - A - (L)
Single-Ended
❶
❷
❸
❹
❺
❻
❼
❺ Cable color
❻ Cable outer conductor TV: Tin plated braided wire
❸ Connection type
Batch connection type
068W: Ø1.13 coaxial cable
❹ Cable type
1: Grey, 2: Black, 3: White
❼ Total length L (mm)
L length in mm
●Standard Tolerances for (L)
L (mm)
Standard Tolerances (mm)
35 ≦ L ≦ 200
±4
200 < L ≦ 500
±8
Note: Minimum available length (L) is 35 mm.
■Receptacles
L (mm)
500 < L ≦ 1000
1000 < L
±12
±1.5%
Recommended PCB Mounting Pattern (*1)
0.56
0.3
0.5
SIG
0.65
0.3
1.7
2
1.5
1.3
1.7
2
1.3 1.3
0.18
2.6
1.4
GND
SIG
No conductive
traces in this area
GND
*1) The pattern is the same as the W.FL and W.FL2 connectors.
Part No.
X.FL-R-SMT-1(80)
HRS No
CL331-0701-8-80
Packaging
Reel packaging 10,000 pieces per reel
φ
2 4
SIG
A
2
A
4
φ330
1.5
13.5
12
5.5
1.75
●Embossed Carrier Tape Dimensions (JIS-C-0806 compliant) ●Reel Dimensions
φ13
Unreeling direction
■Plug Receptacles
2.8
1.97
1.8
0.69
0.3
1.4
GND
HRS No
CL331-0713-7-80
0.65
0.3
1.94
2.28
Part No.
X.FL-PR-SMT1-2(80)
0.8
1.35
1.5
0.33
1.3
1.94
2.24
SIG
SIG
A
A
4
Unreeling direction
2
φ13
φ330
Ø1
.5
1.75
4
13.5
12
5.5
2
SIG
No conductive
traces in this area
Packaging
4
RoHS
GND
RoHS
■Conversion Adapters
●SMA Conversion Adapter (Mating portion - X.FL side: jack - SMA side: plug)
(9.98)
Note: The X.FL side mating portions has a lower lock
retention force than the regular product, so that
the adapter cannot be used for purposes other
than performance measurements.
Part No.
HRMP-X.FLJ
8HEX
HRS No
CL311-0435-1
RoHS
13.74
5.6
(4.05)
6
φ6.35
lock retention force than the regular product, so that
the adapter cannot be used for purposes other than
Part No
HRMJ-X.FLP
HRS No
CL311-0436-4
RoHS
●SMA Conversion Adapter (Mating portion - X.FL side: plug (w/o lock) - SMA side: jack)
(18.12)
6
(4.05)
5.5
φ6.35
Note: This connector is used by compressing the
mating portion of X.FL side onto the X.F L-R-S M T-1
portion.
Part No.
HRMJ-X.FLP-ST3
HRS No
CL311-0450-5
RoHS
BTool
●Plug Mating Tool (Space-Saving Type)
φ10
(100)
This tool is used for mating a plug.
JAPAN
8
●SMA Conversion Adapter (Mating portion - X.FL side: plug - SMA side: jack)
Part No.
W.FL-LP-IN ※
HRS No
CL331-0323-2
RoHS
*This tool can be also used for the X.FL series.
●Plug Mating and Unmating Tool
Mating side
Unmating side
X.FL
This is a combination tool that has both of
the mating and unmating tool at either end.
(60)
Part No.
X.FL-LP-IN.OUT1
HRS No
CL331-0715-2
RoHS
5
BUsage Precautions
1. Plugs
(1) Mating / un-mating
1.To un-mate a connector, use the unmating side of the plug mating and unmating tool
X.FL-LP-IN.OUT1 as shown in the following figure.
[How to un-mate a plug]
Insert the tool
from the direction
of the cable so that
it can hold the cable.
Tilt the tool to
pull the cable
side up.
Un-mating is completed.
Never un-mate the plug by pulling the cable. It may cause a failure of the connector.
2. To mate a connector, use the mating side of the plug mating and unmating tool X.FL-LPIN.OUT1 or the plug mating tool W.FL-LP-IN. Align the mating axes between both of the
connectors and check that the shell is properly aligned. The connector should be inserted
perpendicularly as much as possible. (See the following figure)
Do not attempt to insert the connector at an extreme angle. It may cause the connector to fail.
X.FL Plug Connector
(2) Allowable load to a
cable that is mated
X.FL-R-SMT-1 (Receptacle)
After the connector is mated, do not apply a load to the cable in excess of the values
indicated in the figure below.
2 N or less (X.FL-LP-040.X.FL-LP(P)-068)
1 N or less (X.FL-LP-032)
(while wiring after mating)
X.FL-R-SMT-1
When the cable is routed in such a direction that lifts the cable, it is recommended that
cushioning should be placed on the plug to prevent the connector from unmating (see the
example below).
1.05 ± 0.05
Cushioning
(3) Precautions
6
Do not mate or unmate a connector with an excessive prying force. It may cause a failure of
the connector.
2. Plug Receptacles
(1) Mating
This product should be mated by hand.
Do not apply an excessive load or over handle during the mating process. It may cause the connector
to fail.
[Mating procedure]
1. Before inserting the connector, bring the mating surface of the plug receptacle (X.F L-P R-S M T12) into gentle contact with that of the receptacle (X.F L-R-SMT-1) and slide them back and forth
and around so that the mating axes are aligned.
2. Also make sure the PCBs the parts are mounted on are not allowed to move relative to each other.
When the connector has been slightly mated with the receptacle, the connector will not move from
any side-to-side or front-to-back forces applied to it.
3. Push the connector down perpendicularly until you feel it click.
4. If the mating axes are not aligned, it will fail to make a complete connection. When there has
been a failure to make a connection due to misaligned mating axes, Please check that the female
terminal contacts on the plug receptacle have not been damaged
Mold surface
Female terminal
(2) Unmating
When unmating a connector, it is desirable to pull the connector in the direction perpendicular to the
surface on which the connector is mounted. However, unmating the FPC in a perpendicular direction
can be difficult when an FPC is detached from a thin printed circuit board.
When you find it difficult to unmate the connector, detach it to an oblique direction as shown in the left
figure below.
Avoid detaching the connector in a way as shown in the right figure.
SIG Terminal
SIG Terminal
(3) Precautions
GND Terminal
GND Terminal
GND Terminal
the connector.
7
(4) Notes for mounting
Avoid mounting multiple connectors of this type on the same circuit board.
(If it is unavoidable to mount multiple connectors, take necessary measures for use, such as
separating the circuit board between the connectors.)
When the connector is mounted on an FPC, insufficient stiffness may lead to land pattern
separation or solder separation. It is recommended that the FPC should be lined with a
stiffening film.
(5) Precautions
1. Do not mate or unmate a connector with an excessive prying force. It may cause a failure
of the connector.
2. The connector may become disconnected if it is dropped, or extreme stress is applied to
the FPC. To prevent this from happening, fix the connector in place by holding it with an
added portion of the case or some type of cushioning material.
3. Reflow conditions of receptacles and plug receptacles
Soldering profile for lead free solder (reference)
(1) Recommended reflow
temperature profile
[reference]
10 seconds or less
Temperature (ç)
250ç or lower
260
240
220
200
180
160
140
120
100
80
230℃
220℃
180℃
130℃
Time (second)
120 seconds or less
Preheat time
50 seconds or less
60 seconds or less
Soldering time
1. The temperatures indicated are the surface temperatures on the printed circuit board at
the points of contact with the terminals.
2. Reflow soldering should be performed at a peak temperature of 250°C or less at the
surface of the printed circuit board.
3. The temperature profile varies depending on conditions such as the size of the printed
circuit board, the solder paste type, and solder thickness.
(2) Recommended
metal mask thickness
(3) Reflow cycles
0.1mm~0.12mm
2 times
4. Operating Environment and Storage Conditions
(1) Operating environment
This product was designed under the assumption that it would be used in a normal operating
environment.
Use of this connector under adverse environmental conditions may lead to discoloration or other
kinds of degradation. Use of the connector in regions having exposure to excessive amounts of
fine particles and dust, high densities of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other
corrosive gasses (e.g., exhaust gas from automobiles or factories), is not advised
Environments having a large difference in temperature, such as a place near a heater.
(2) Storage conditions
Store the product in Hirose Electric's packaging or similar packaging conditions.
Temperature: -10 to +40°C, humidity: 85% or less (recommended storage conditions)
Use the product within six months from delivery.
Products for which the storage period has expired must be tested for solderability before the use.
8
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 1/2014. Contents are subject to change without notice for the purpose of improvements.
