U.FL-2LP-066J1-A-(300)
    HRS(广濑)
U.FL-2LP-066J1-A-(300) 数据手册
Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height U.FL Series Plug U.FL(A) : Up to 18GHz Plug U.FL : Up to 8GHz (2.5Max) ●Space Factor of Mated Connector U.FL-LP-040HF 4 1.5 2.4 Ø0.81 U.FL-LP-066HF U.FL-LP-068HF 4 1 2.4 Ø1.32 Ø1.13 3.4 U.FL-LP(V)-040HF Ø0.81 1 The maximum height from the board surface when the plug and Receptacle are mated is 2.0 to 2.0mm Max. depending on the plug for a low profile. (Refer to diagram on right) (2Max) 1. Mated Height (1.9mm to 2.4mm NOM) U.FL-R-SMT-1 1.9 ■Features 2. Receptacle 4. Plug compatible with ultra-fine coaxial (fluorinated resin insulated) cable (2.4Max) Ø0.95 1.3 Plug U.FL(A) : Up to 18GHz Plug U.FL : Up to 8GHz Receptacle can be used with both U.FL(A) and U.FL. U.FL-LP-062HF 4 2.3 3. Frequency U.FL-R-SMT-1 U.FL-R-SMT-1 (2.4Max) Small and light weight with a mass of 15.7mg and occupied mounting space of 7.7mm2. Compatible with board mounting. (Embossed packaging) U.FL-LP-088HF 5 Ø1.37, Ø1.32, Ø1.13, Ø0.95, Ø0.81 0.9 2.3 U.FL(A)-LP(P)-068 Ø1.13 1 Tactile click sensation confirms fully mated condition, assuring complete electrical and mechanical connection. 5.9 7. Environmental Compatibility U.FL-R-SMT-K(800) U.FL-R-SMT-1 (2.2Max) ◆Halogen Free Chlorine and bromine above the standard values are not used for receptacle and plug harnesses. *As defined by IEC61249-2-21 Br-900 ppm maximum, Cl-900 ppm maximum, Cl+Br combined-1,500 ppm maximum ◆ROHS2 Compatible 5.9 U.FL(A)-LP(P)-088 Ø1.37 ■Applications Wireless LAN Devices (Wi-Fi 6), Bluetooth devices, Car navigation, drone, PDA, GPS, wireless transmission devices, electronic measuring devices, etc. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. U.FL-R-SMT-K(800) U.FL-R-SMT-1 0.65 6. Tactile Mating U.FL-R-SMT-1 (2.2Max) Plug insertion/extraction tools, adapter for inspection and internal wiring, and SMA, MMCX, and TNC connectors for U.FL back end connection are available. Ø1.37 2.1 5. Various Accessories 2.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (2.5Max) U.FL-R-SMT-1 2021.8⑧ 1 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Product Specifications Nominal characteristic impedance Frequency range Ratings Item 1. Contact resistance 2. Insulation resistance 3. Withstanding voltage Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. V.S.W.R.* 5. Female Contact Retention Force 6. Durability (mating / un-mating, with corresponding plug) 7. Vibration 50ø DC to 8GHz Operating temperature range -40˚C to +105˚C Storage temperature range Operating humidity 90%RH max. Storage humidity Specification Center : 20mø max. (50mø max.) Outer : 10mø max. (20mø max.) (U.FL(A)) 500Mømin. No flashover or insulation breakdown. Cable Type U.FL-LP-040HF Ø0.81 U.FL-LP(V)-040HF Ø0.81 U.FL-LP-068HF Ø1.13 U.FL-LP-066HF Ø1.32 Ø0.95 U.FL-LP-062HF U.FL-LP-088HF Ø1.37 U.FL(A)-LP(P)-068 Ø1.13 U.FL(A)-LP(P)-088 Ø1.37 10. Temperature cycle 11. Salt spray Conditions 10mA max. 100V DC 200V AC / 1 minute DC∼3GHz 3∼6GHz 6∼8GHz 1.3 Max 1.35 Max 1.4 Max 1.3 Max 1.3 Max 1.4 Max 1.6 Max 1.3 Max 1.5 Max 1.7 Max 1.3 Max 1.4 Max 1.3 Max 1.4 Max 1.6 Max 6-9GHz : 1.5 Max 9-12GHz : 1.6 Max 1.3 Max 1.4 Max 12-15GHz : 1.7 Max 15-18GHz : 2.0 Max 0.15N Min./0.1N Min. (062 Plug, U.FL(A)) Measured with Ø0.475 pin gauge Contact resistance Initial Value+5mø 30 cycles No electrical discontinuity of 1µs min. No damage, cracks or parts dislocation. Frequency : 10 to 100Hz, single amplitude of 1.5mm, acceleration of 59m/s2, for 5 cycles in the direction of each of the 3 axis. Acceleration of 735m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of 3 axes. 8. Shock 9. Humidity (Steady state) -30˚C to +70˚C 90%RH max. Insulation Resistance 10Mø min. (High Temperature) 500Mø min. (When Dry) No damage, cracks or parts dislocation. Contact resistance : 25mø max. (Center) 15mø max. (Outer) V.S.W.R. Satisfies initial value 96 hours at temperature of 40ç and humidity of 95%. Temperature : -40˚C/+5 to +35˚C/+105˚C/+5 to +35˚C Time : 30min. / 3min. / 30min. / 3min. 5 cycles 5% salt water solution, 48 hours *V.S.W.R. Measurement System The above V.S.W.R. standard values were measured using the measurement connection shown below. Note 1 : Cable type connectors were measured with SMA conversion adapters attached to both ends of the harness product of a suitable 100cm cable. Note 2 : Board type connectors were mounted to a 50ø glass epoxy board and measurements were conducted with SMA conversion adapters attached. ■Material / Finish ●Plug-right angle Part Shell Insulator Female center contact Material Phosphor bronze PBT, Color : Gray LCP, Color : Milky-white LCP (Black) Phosphor bronze Finish/Remarks Silver plated / Nickel plated (Contact gold plated) (U.FL(A)) UL94HB (LP(V)-040HF) UL94V-0 (040HF,066HF, 068HF, 062HF, 088HF) UL94V-0 (U.FL(A)) Gold plated Material Phosphor bronze LCP, Color : Milky-white LCP (Black) Brass Finish/Remarks Silver plated (U.FL-R-SMT-1) / Gold Plated (U.FL-R-SMT-K) UL94V-0 (U.FL-R-SMT-1) UL94V-0 (U.FL-R-SMT-K) Gold plated ●Receptacle Part Shell Insulator Male center contact 2 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Receptacle GND No conductive traces in this area 3.9±0.05 1±0.05 2.2±0.05 GND GND SIG 1±0.05 (3.1) 2.6 1.8 1.05±0.05 3 2.6 0.6 2.1±0.05 2±0.05 1.2Max(Note) 1.25 4±0.05 1.9±0.05 1.1±0.05 SIG Ø2 0.35 BRecommended Metal Mask Dimensions 0.85±0.05 GND BRecommended PCB Mounting Pattern 0.8±0.03 (Note 1) The sales unit of the (01) specification receptacle is one pack (100 units per pack). Please order based on the number of packs. (Note 2) The sales unit of the (60) specification receptacle is 1 reel (4,000 pcs per reel) so please order based on the number of reels. (Note 3) The sales unit of the (80) specification receptacle is 1 reel (10,000 pcs per reel), so please order based on number of reels. (Note 4) Tolerance value of mold resin applied to center contact. (3.1) 2.6 1.8 GND Part No. HRS No. Packaging U.FL-R-SMT-K(800) 480-0761-0 00 10,000 pcs per reel Mass 15.7/pc .5 Center contact 0.85±0.05 0.8±0.03 (Note 5) The sales unit of the receptacle is 1 reel (10,000 pcs per reel), so please order based on the number of reels. BReel Dimensions Material: PS(Black) U.FL-R-SMT-1 PS(White) U.FL-R-SMT-K 13.5 Ø330 12 5.5 1.75 Ø1 4 3.9±0.05 2.1±0.05 Mask Thickness : 0.1mm/0.12mm Embossed Carrier Tape Dimensions(IEC 60286-3 compliant) Embossed Carrier Tape Dimensions 2 No conductive traces in this area GND SIG  1±0.05 U.FL-R-SMT-K Shell : Gold plated BRecommended Metal Mask Dimensions 2.2±0.05 1.2Max(注4) 0.35 1.25 Ø2 2±0.05 SIG 3 2.6 0.6 4±0.05 1.9±0.05 GND 1±0.05 GND 1±0.05 GND BRecommended PCB Mounting Pattern 0.85±0.05 GND 2±0.05 Part No. HRS No. Packaging Weight / EA U.FL-R-SMT-1(01) 331-0472-2 01 100 pcs/pack 15.7/mg U.FL-R-SMT-1(60) 331-0472-2 60 4,000 pcs/reel U.FL-R-SMT-1(80) 331-0472-2 80 10,000 pcs/reel 2.2±0.05 Shell : Silver plated 8 4 .5 2 Ø1 1.75 U.FL-R-SMT-1(60) : 8mm pitch A Center contact 5.5 A(SCALE FREE) 2 Ø13 12 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Mask Thickness : 0.1mm/0.12mm U.FL-R-SMT-1 4 Unreeling direction Ø2 1 U.FL-R-SMT-1(80) / U.FL-R-SMT-K(800) : 4mm pitch 3 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Plug (Center Solder Type) ◆U.FL Plug U.FL-LP-088HF 4 1.8 1.5 5 1.85 3.4 4 1.93 1.93 4 Mated Height U.FL-LP-062HF 3 3 3 Part No. Size U.FL-LP(V)-040HF 2.8 U.FL-LP-066HF U.FL-LP-068HF U.FL-LP-040HF 2.8 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ・The center contact is gold plated and the outer contact is silver plated. 2.5mm Max. 2.5mm Max. 2.0mm Max. 2.4mm Max. 2.4mm Max. (2.4mm Nom.) (2.4mm Nom.) (1.9mm Nom.) (2.3mm Nom.) (2.3mm Nom.) Dia. 0.81mm Dia. 0.95mm Dia. 1.37mm 35 45.5 72 Applicable cable Dia. 0.81mm Weight (mg) 54 Dia. 1.13mm and Dia. 1.32mm 59 ●Cable Guide Description Dia.0.81mm Coaxial Cable Dia.1.13mm Coaxial Cable Dia.1.32mm Coaxial Cable Dia.0.95mm Coaxial Cable Dia.1.37mm Coaxial Cable Dia.1.37mm Coaxial Cable (Low Loss) Cable Specification Cable Type 04 068 066 062 088 088 Inner Conductor* Dielectric Diameter Outer Conductor* 7/0.05 SA Dia.0.4mm Single (AWG#36) FEP Shield TA 7/0.08 SA Dia.0.68mm Single (AWG#32) FEP Shield TA 7/0.08 SA Dia.0.66mm Double (AWG#32) FEP Shield TA 7/0.071 SA Dia.0.62mm Tape, single (AWG#33) FEP Shield TA 7/0.102 SA Dia.0.88mm Single (AWG#30) FEP Shield TA 7/0.102 SA Dia.0.88mm Tape, Single (AWG#30) FEP/PTFE Shield TA Jacket FEP (Attenuation is a reference value.) * SA : Silver plated annealed copper wire, TA : Tin plated annealed copper wire [Plugs can be ordered only as terminated cable assemblies.] 4 Flame Retardant Nominal attenuation (dB/m) Grade At 3GHz At 6GHz At 8GHz 5.4 8.0 10.2 3.73 5.44 6.5 3.8 5.6 7.1 3.1 4.4 5.3 2.8 4.3 5.0 2.5 3.4 3.8 VW-1 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Plug (No Solder Type) ◆U.FL(A) Plug ・Harness product guarantees frequency up to 18GHz and impedance matching. ・The inner and outer contact portion are gold plated (the main body is nickel plated) ・The receptacle can be mated with U.FL-R-SMT-1 (shell : silver plated) and U.FL-R-SMT-K (shell : gold plated). ・The SMA inspection adapter and extraction tool are only for the U.FL(A) Plug. ・Controls variation and improves extraction force by 50% compared to conventional products and competing products (Approx. 30N). It is difficult to remove the connector even when bending the cable. Part No. Size 2.66 2.66 U.FL(A)-LP(P)-088 5.9 1.73 5.9 1.73 Mated Height 2.2mm Max. (2.1mm Nom.) Applicable cable Ø1.13 Ø1.37 Weight (mg) 56 58 4 HRS V.S.W.R. Company A V.S.W.R. 3.5 m m 00 1 Measuring Adapter HRMP-U.FLAJ V.S.W.R. ※Cable Length = 100mm 3 2.5 2 Reference Plane APC 3.5 1.5 1 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Frequency (GHz) ■U.FL(A) Inspection SMA Conversion Adapter  (Mated Portion: U.FLA Jack- SMA Plug) 8HEX 10.7 Part No. HRS No. HRMP-U.FLAJ 311-2400-0 (Note) Since the U.FL side mated portion has a weaker lock than standard products, it cannot be used for purposes other than performance measurement. ■U.FL(A) Insertion/Extraction Tool 12 3.7 10  For removing from the mated condition 12 38 10 2 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. U.FL(A)-LP(P)-068 Part No. HRS No. U.FL(A)-LP-IN.OUT 331-2401-0 5 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■The Procedure for ordering patch cord Please select the specifications in 3 steps. No need product name for ordering patch cords. STEP 1 : Single end or both ends [Single ended cable assembly] [Double ended cable assembly] L L Ordering information STEP 2 : Cable and mating height Cable color Mating height (Max) Plug 0 Gray / Black 2.3mm (2.4mm) U.FL-LP-088HF Gray / Black Gray / Black Gray / Black Gray / Black Gray / Black White / Black White / Black 2.1mm (2.2mm) 2.4mm (2.5mm) 2.4mm (2.5mm) 2.1mm (2.2mm) 2.3mm (2.4mm) 2.4mm (2.5mm) 2.0mm (1.9mm) -1 U.FL(A)-LP(P)-088 U.FL-LP-066HF U.FL-LP-068HF U.FL(A)-LP(P)-068 U.FL-LP-062HF U.FL-LP-040HF U.FL-LP(V)-040HF INSERTION LOSS (dB) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No. Jacket diameter 1 Ø1.37 2 Ø1.37 Low Loss 3 Ø1.37 4 Ø1.32 5 Ø1.13 6 Ø1.13 7 Ø0.95 8 Ø0.81 9 Ø0.81 Insertion Loss comparison between each cable size【dB/m】 STEP 3 : Cable length (mm) -3 -4 -5 -6 -7 -8 -9 ●Standard tolerances for (L) (L)(mm) *L=35 to 200 L=201 to 500 L=501 to 1000 L=Longer than 1000 -2 -10 Standard tolera(mm) ±4 ±8 ±12 ±1.5% of (L) 0 1 2 3 4 5 6 7 Frequency (GHz) Note : Minimum available length(L) is 35mm. (U.FL(A) is from 80 to 1200mm) ■Patch cord name example Characters that are not red are for Hirose internal identification. ●Plug (Center Solder Type) ●Plug (No Solder Type)  U.FL-2LPHF6-04N1TV-A-300   UFL-2LPA-068Y2T-A-300 Cable length : STEP 3 Cable type : STEP 2 Double ended or single ended : STEP 1 Series name Cable length : STEP 3 Cable type : STEP 2 Double ended or single ended : STEP 1 Series name STEP 1 Example Notation [Double ended] U.FL-2LPHF6-04N1TV-A-300 [Single ended] U.FL-LPHF6-04N1TV-A-300 STEP 2 Example Notation 1 Cable-mating height [Dia. 1.37 cable (088 cable)] 088 is listed in the third block representing the cable type. U.FL-2LPHF6-088N1T-A-300 (Plug : U.FL) U F L-2LPA-088Y1T-A-300 (Plug : U.FL(A)) [Dia. 1.37 Cable (088) Low Loss] Block 3 that shows the cable times says 088. U F L-2LPHF6-088N1PD-A-300 (Plug : U.FL) [Dia. 1.32 cable (066 cable)] 066 is listed in the third block representing the cable type. U.FL-2LPHF6-066N1-A-300 (Plug : U.FL) [Dia. 1.13 cable (068 cable)] 068 is listed in the third block representing the cable type. U.FL-2LPHF6-068N1T-A-300 (Plug : U.FL) U F L-2LPA-068Y1T-A-300 (Plug : U.FL(A)) [Dia. 0.95 cable (062 cable)] 062 is listed in the third block representing the cable type. U.FL-2LPHF6-062N1D-A-300 (Plug : U.FL) [Dia. 0.81 cable (040 cable)] 04 is listed in the third block representing the cable type. When the height is 1.9mm, V enters affer LP. Dot does not needed for U.FL series name. U.FL-2LPHF6-04N1TV-A-300 : Mating height 2.4mm U F L-2LPVHF6-04N1TV-A-300 : Mating height 1.9mm STEP 3 Example Notation Cable length is written in millimeters at the end. EX : 300mm U.FL-2LPHF6-088N1T-A-300 6 2 Cable color ∼Except Dia. 0.81 cable∼ [Gray] 1 is listed in the third block representing the cable type. U.FL-2LPHF6-062N1D-A-300 (Plug : U.FL) [Black] 2 is listed in the third block representing the cable type. U.FL-2LPHF6-062N2D-A-300 (Plug : U.FL) ∼Dia. 0.81 cable∼ [White] 1 is listed in the third block representing the cable type. U.FL-2LPHF6-04N1TV-A-300 (Plug : U.FL) [Black] 2 is listed in the third block representing the cable type. U.FL-2LPHF6-04N2TV-A-300 (Plug : U.FL) 8 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Conversion Adapter ●SMA Conversion Adapter (Mated Portion : UFL Jack - SMA Plug) (10.7) Part No. HRS No. HRMP-U.FLJ(40) 311-0300-2 40 8HEX ●SMA Conversion Adapter (Mated Portion : U.FL Plug - SMA Jack) 14.05 (4.05) 5.6 Ø6.35 6 1/4-36UNS-2A Part No. HRS No. HRMJ-U.FLP(40) 311-0301-5 40 (Note) Since the U.FL side mating portion has a weaker lock than standard products, it cannot be used for purposes other than performance measurement. ●SMA Conversion Adapter (Mated Portion : U.FL Plug - SMA Jack) (18.6) (4) 6 5.5 1/4-36UNS-2A Part No. HRS No. HRMJ-U.FLP-ST1(40) 311-0385-5 40 This connector is used by pressing the mating portion of the U.FL side with the mating portion of U.FL-R-SMT. ●SMA Conversion Adapter (Mated Portion: SMA Jack (Measuring Device Connection Side) -SMA Plug) 2× Ø2 Ø10.86 .3 20 16 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Note) Since the U.FL side mating portion has a weaker lock than standard products, it cannot be used for purposes other than performance measurement. Part No. HRS No. HRM-PA-PJ(F)-1(40) 323-0805-9 40 8 11.6 4.4 18.84 31.3 (Note) HRMJ-U.FLP-ST1 aborbs misalignment when mated with the plug (coupling side) and connecting the jack with the measuring device. (Refer to next page) 7 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ●Probe for Inspect of Multiple Narrow Pitch Receptacles (Mated Portion : U.FL Plug (No lock) - ML51 Jack) 2× Ø2 Ø3.8 12 8.5 Ø4 .4 4.2 1.75 15.5 22.8 Part No. HRS No. U.FLP-ML51.J-PA(F)-ST 311-0446-8 (Note) Hirose's ML51 is used for the measuring device interface. It is ideal for simultaneous inspection of multiple narrow pitch mounted receptacles. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Harness for Narrow Pitch Probe Connection (Mated Portion : SMA Plug (Measuring Device Connection Side) - ML55 Plug 350±8 Part No. HRS No. HRMP-ML51LP-DTR178-350RS 321-4926-2 01 (Note) Used to connect U.FLP-ML51J-PA(F)-ST and the measuring device. It is recommended to provide slack to the cable length so that it can absorb misalignment smoothly. ■Inspection Probe ●HRMJ-U.FLP-ST1 and HRM-PA-PJ(F)1 Combination and Usage (A) 12mm min Shortest Pitch for Adjacency Flange to Board Surface (A) Recommendation for Measurement 32.5±0.2 Starting Load 33.2 ●U.FLP-ML51.J-PA(F)-ST and HRMP-ML51LP-DTR178-350RS Combination and Usage (A) 4.5mm min Shortest Pitch for Adjacency Flange to Board Surface (A) Recommendation for Measurement 15.1±0.2 Beginning Load 16 *For the inspection probe do not tilt the tip contact from the tensile load of the connecting cable. 8 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Inspection Receptacle Receptacle for inspecting the conduction and withstanding voltage of harness products. 12.9 (7.9) (4.4) 7HEX 5 1 M5∞0.5 Part No. HRS No. U.FL-R-1 331-0466-0 ■Inspection Assistance Device ●SMA Mating Push On Conversion Adapter Ø7.8 Ø9 Push On Mating Portion (Mates with SMA-J) 8 Part No. HRS No. HRMP(PO)-HRMJ 323-0741-8 6 3 10.6 Coverts SMA plug mating portion to push on type, reducing the number of steps required for repeated SMA mating. -IN -LP h) W.FL g ou from hr (T hing 2 Ø guis n isti le d Ho ■Insertion Tool 8 Ø10 Tool for plug insertion. 100 Part No. HRS No. U.FL-LP-IN 331-0334-9 BExtraction Tool (90) Tool for unmating. 5 Ø15 50 U.FL Marking U.FL U.FL/V 2.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Note 1) Product cannot be used for purposes other than conduction or withstanding voltage inspection because there is no lock on the mating portion. (Note) U.FL-LP-N is also used with E.FL Series. Part No. HRS No. Applicable Plug U.FL-LP-N-2(V) 331-0494-5 U.FL-LP-040HF, 066HF, 088HF, 068HF U.FL-LP(V)-N-2 331-0493-2 U.FL-LP-062HF, U.FL-LP(V)-040HF 9 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height Usage Precautions 1. Plugs (1) Mating / unmating 1) To disconnect connectors, insert the end portion of U.FL-LP-N-2 and U.FL-LP(V)-N-2 under the connector flanges and pull off vertically, in the direction of the connector mating axis. However for U.FL(A) (Solderless connection type, use U.FL(A)-LP-IN.OUT and Extraction Tool pull out vertically. When removing the connector directly, hold the connector lid and pull out vertically in relation to the connector mating U.FL Cable Assembly axis. (Be careful not to damage the connector with fingers or nails.) 2) To mate the connectors, the mating axes of both connectors must be aligned and the connectors can be mated. The "click" will confirm fully mated connection.Do not attempt to insert on an extreme angle. U.FL-R-SMT-1 After the connectors are mating, do not apply a load to the cable in excess of the values indicated in the diagram below. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. U.FL-LP Cable Assembly (2) Pull forces on the cable after connectors are mated. 1N max (U.FL-LP(V)-040HF, U.FL-LP-062HF) 2N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF, U.FL(A)-LP(P)-068, U.FL(A)-LP(P)-088) U.FL-R-SMT-1 3N max (U.FL-LP(V)-040HF, U.FL-LP-062HF) 4N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF, U.FL(A)-LP(P)-068, U.FL(A)-LP(P)-088) 1N max (U.FL-LP(V)-040HF, U.FL-LP-062HF) 2N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF, U.FL(A)-LP(P)-068, U.FL(A)-LP(P)-088) (3) Precautions Do NOT forcefully twist or deform wires. 2. Receptacles 250 ç max. for 10 seconds [ç] (1) Recommended reflow temperature profile 260 240 220 200 180 160 140 120 100 80 Preheat (130 to 180ç) 120 seconds max. 230ç 220ç 50 seconds max. 60 seconds max. Time q The temperature of the printed circuit board surface temperature at the points of contact with the terminals. w Reflow soldering should be performed at a printed circuit surface temperature of 250°C max. e In individual applications the actual temperature may vary, depending on the solder paste type, volume / thickness and board size / thickness. Consuly your solder paste and equipment manufacturer for specific recommendations. (2) Recommended manual Manual soldering : 350˚C for 5 seconds soldering (3) Recommended metal mask thickness 0.1 to 0.12mm (4) Reflow cycles 2 times 3. Operating environment and storage conditions (1) Operating environment (2) Storage conditions Receptacle (3) Silver Plating Discoloration 10 The connectors are not designed to operate in the following environments : • Exposed to a excessive amounts of fine particles and dust • Regions and places having a high density of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other corrosive gasses. • Environments having large rapid variations in temperature. Store in the Hirose Electric packaging. Temperature : -10 to +40ç, Humidity : 85% max. Use within 6 months of delivery. Receptacles for which the storage period has elapsed must be tested for solderability to the PC board mounting surface. Discoloration occurs only on the plating surface. Since the contact portion is wiped, there is no effect on the electrical contact. U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Standard Connectors that Connect with U.FL SMA Cable Type Straight Plug HRS No. 8HEX Applicable cable HRM-200-040PBN (40) 323-0790-3 40 Dia. 0.81 type HRM-200-066PBN (40) 323-0791-6 40 Dia. 1.13, Dia.1.32 type HRM-200-088PBN (40) 323-0800-5 40 Dia. 1.37 type Notes SMA (Male Contact) Straight Jack 17 4.5 Part No. 1/4-36UNS-2A 8 8HEX HRS No. Applicable cable HRM-200-040JBN (40) 323-0792-9 40 Dia. 0.81 type HRM-200-066JBN (40) 323-0793-1 40 Dia. 1.13, Dia.1.32 type HRM-200-088JBN (40) 323-0801-8 40 Dia. 1.37 type ●Panel mount Jack (Four Screws) 17 9.55 1.7 1/4-36UNS-2A 4-Ø2.6 Notes SMA (Female Contact) 12.7 8.64 Ø6.4 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. 1/4-36UNS-2B 15 Part No. HRS No. Applicable cable HRM-200-040PJ4BN(40) 323-0795-7 40 Dia. 0.81 type HRM-200-066PJ4BN(40) 323-0796-0 40 Dia. 1.13, Dia.1.32 type HRM-200-088PJ4BN(40) 323-0803-3 40 Dia. 1.37 type Notes SMA (Female Contact) 11 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height 17 9.55 1.7 8 1/4-36UNS-2A ●Panel mount Jack (Two Screws) Ø6.4 2∞Ø2.6 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. Applicable cable HRM-200-040PJ2BN(40) 323-0794-4 40 Dia. 0.81 type HRM-200-066PJ2BN(40) 323-0788-1 40 Dia. 1.13, Dia.1.32 type HRM-200-088PJ2BN(40) 323-0802-0 40 Dia. 1.37 type 17 1.5 11 8HEX 5.85 5.9+0.1 0 Ø6.4+0.1 0 Part No. HRS No. Applicable cable HRM-200-040BPJBN(40) 323-0797-2 40 Dia. 0.81 type HRM-200-066BPJBN(40) 323-0798-5 40 Dia. 1.13, Dia.1.32 type HRM-200-088BPJBN(40) 323-0804-6 40 Dia. 1.37 type 2 16.98 11 1/4-36UNS-2A 8HEX 5.85 SMA (Female Contact) Ø6.4+0.1 0 Part No. 12 Notes 5.9+0.1 0 Ø12 ●Panel mount Jack   (Bulkhead, Waterproof Mounting Surface Type) SMA (Female Contact) BPanel Cutouts Ø10 ●Panel mount Jack (Bulkhead) 1/4-36UNS-2A Notes HRS No. Applicable cable HRM-200-040WBPJBN 323-0945-8 Dia. 0.81 type HRM-200-066WBPJBN 323-0946-0 Dia. 1.13, Dia.1.32 type HRM-200-088WBPJBN 323-0920-7 Dia. 1.37 type Notes SMA (Female Contact) U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■SMA-U.FL Cable Assembly Representative Product SMA Straight Plug-U.FL Plug L Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. Cable (Color) HRMP-UFLHF6-04N2TV-A200RS 321-0753-0-04 Ø0.81(Black) HRMP-UFLHF6-068N2T-A200RS 321-0854-0-02 Ø1.13(Black) HRMP-UFLHF6-066N2-A200RS 321-0862-0-05 Ø1.32(Black) HRMP-UFLHF6-088N2T-A200RS 321-0755-0-07 Ø1.37(Black) Lmm Notes 200±4 SMA (Female Contact) Lmm Notes 200±4 SMA (Male Contact) Lmm Notes 200±4 SMA (Female Contact) SMA Straight Jack-U.FL Plug L HRS No. Cable (Color) HRMJ-UFLHF6-04N2TV-A200RS Part No. 321-0881-0-02 Ø0.81(Black) HRMJ-UFLHF6-068N2T-A200RS 321-0869-0-03 Ø1.13(Black) HRMJ-UFLHF6-066N2-A200RS 321-0868-0-02 Ø1.32(Black) HRMJ-UFLHF6-088N2T-A200RS 321-0904-0-04 Ø1.37(Black) SMA Panel Mount Jack (Four Screws)-U.FL Plug L Part No. HRS No. Cable (Color) HPJ-UFLHF6-04N2TV-A200RS 321-0965-0-02 Ø0.81(Black) HPJ-UFLHF6-068N2T-A200RS 321-3660-0-02 Ø1.13(Black) HPJ-UFLHF6-066N2-A200RS 321-0905-0-01 Ø1.32(Black) HPJ-UFLHF6-088N2T-A200RS 321-0911-0-03 Ø1.37(Black) ◆For cable lengths, cable colors and connector combinations other than those listed above, please contact a Hirose representative. 13 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height SMA Panel Mount Jack (Two Screws)-U.FL Plug L Part No. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. Cable (Color) HPJ2-UFLHF6-04N2TV-A200RS 321-0969-0-03 Ø0.81(Black) HPJ2-UFLHF6-068N2T-A200RS 321-1083-0-03 Ø1.13(Black) HPJ2-UFLHF6-066N2-A200RS 321-1084-0-03 Ø1.32(Black) HPJ2-UFLHF6-088N2T-A200RS 321-0812-0-04 Ø1.37(Black) Lmm Notes 200±4 SMA (Female Contact) SMA Panel Mount Jack (Bulkhead)-U.FL Plug L 5.9+0.1 0 Ø6.4+0.1 0 L 5.9+0.1 0 Ø6.4+0.1 0 SMA Side: Die Cast Product 11.5 1.5 17 HRS No. Cable (Color) HBPJ-UFLHF6-04N2TV-A200RS Part No. 321-0964-0-02 Ø0.81(Black) HBPJD-UHF6-068N2T-A200(Note) 321-5463-0-02 Ø1.13(Black) HBPJD-UHF6-066N2-A200(Note) 321-5464-0-02 Ø1.32(Black) HBPJD-UHF6-088N2T-A200(Note) 321-5600-0-02 Ø1.37(Black) Lmm Notes 200±4 SMA (Female Contact) (Note) Die Cast Body on SMA Side (Different product than those listed on the SMA Cable Type Page) SMA Panel Mount Jack (Bulkhead, Waterproof Mounting Surface)-U.FL Plug L 5.9+0.1 0 Ø6.4+0.1 0 Part No. HRS No. Cable (Color) HWBPJ-UHF6-068N2T-A-200 321-1235-0-03 Ø1.13(Black) HWBPJ-UFLHF6-088N2T-A200 321-0760-0-04 Ø1.37(Black) Lmm Notes 200±4 SMA (Female Contact) ◆For cable lengths, cable colors and connector combinations other than those listed above, please contact a Hirose representative. 14 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Standard Connectors that Connect with U.FL SMA/R Cable Type /R : Reverse Polarity SMA Connector 15 8HEX Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1/4-36UNS-2B Straight Plug Part No. HRS No. SMA(R)-200-040PBN 323-0925-0 Applicable cable Dia. 0.81 type SMA(R)-200-066PBN 323-0930-0 Dia. 1.13, Dia.1.32 type SMA(R)-200-088PBN 323-0905-3 Dia. 1.37 type Notes SMA Reverse (Female Contact) 17 Straight Jack 4.5 8 8 HEX 1/4-36UNS-2A Part No. HRS No. Applicable cable SMA(R)-200-040JBN 323-0926-3 Dia. 0.81 type SMA(R)-200-066JBN 323-0931-3 Dia. 1.13, Dia.1.32 type SMA(R)-200-088JBN 323-0904-0 Dia. 1.37 type 17 Panel Mount Jack (Four Screws) SMA Reverse (Male Contact) 12.7 9.55 1.7 Notes 8.64 1/4-36UNS-2A .6 Ø2 4∞ Part No. HRS No. Applicable cable SMA(R)-200-040PJ4BN 323-0928-9 SMA(R)-200-066PJ4BN 323-0932-6 Dia. 1.13, Dia.1.32 type SMA(R)-200-088PJ4BN 323-0934-1 Dia. 1.37 type Dia. 0.81 type Notes SMA Reverse (Male Contact) 15 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height 17 1.7 9.55 8 1/4-36UNS-2A 12.2 Panel Mount Jack (Two Screws) 6 Ø2. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2∞ Part No. HRS No. SMA(R)-200-040PJ2BN 323-0929-1 Dia. 0.81 type SMA(R)-200-066PJ2BN 323-0933-9 Dia. 1.13, Dia.1.32 type SMA(R)-200-088PJ2BN 323-0935-4 Dia. 1.37 type 17 8HEX 11 1.5 Applicable cable Panel Mount Jack (Bulkhead) Notes SMA Reverse (Male Contact) BPanel Cutouts 5.85 5.9+0.1 0 Ø6 .4 + 0 0 .1 Ø10 1/4-36UNS-2A Part No. HRS No. Applicable cable Notes SMA(R)-200-040BPJBN 323-0927-6 SMA(R)-200-066BPJBN 323-0902-5 Dia. 1.13, Dia.1.32 type SMA(R)-200-088BPJBN 323-0901-2 Dia. 1.37 type Panel Mount Jack  (Bulkhead, Waterproof Mounting Surface Type) 2 17 Dia. 0.81 type 8HEX 5.85 11 SMA Reverse (Male Contact) 5.9+0.1 0 Ø6 .4 + 0 0 .1 Ø12 1/4-36UNS-2A Part No. 16 HRS No. Applicable cable SMA(R)-200-040WBPJBN 323-0947-3 Dia. 0.81 type SMA(R)-200-066WBPJBN 323-0948-6 Dia. 1.13, Dia.1.32 type SMA(R)-200-088WBPJBN 323-0949-9 Dia. 1.37 type Notes SMA Reverse (Male Contact) U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height ■Standard Connectors that Connect with U.FL TNC Cable Type Panel Jack (Bulkhead, Waterproof Panel Mounting Surface Type) 28.31 18.14 15.9 7/16-28UNEF-2A BPanel Cutouts .15 +0 0 3 2.8 Ø1 +0.2 Part No. HRS No. Applicable cable TNC-WBPJ-088-1 313-0004-0 Ø1.37 cable *Please order the product after designating the harness specifications including product length, etc. TNC/R Cable Type /R : Reverse Polarity SMA Connector Panel Jack (Bulkhead, Waterproof Panel Mounting Surface Type) 28.31 18.14 15.9 7/16-28UNEF-2A BPanel Cutouts5 .1 +0 0 3 2.8 Ø1 +0.2 12.01−0.05 Part No. HRS No. Applicable cable TNC(R)-WBPJ-088 313-0003-0 Ø1.37 cable *Please order the product after designating the harness specifications including product length, etc. /R : Reverse Polarity SMA Connector Panel Mount Adapter (Two Screws) 8 (22.25) 14.25 (2.25) 12.7 7/16-28UNEF-2A U.FL TNC(R)-J 18 TNC/R Conversion Adapter Ø6.9 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.01−0.05 . No 2∞ Part No. HRS No. TNC(R)J-U.FLJ-PA-2 311-0416-7 2B F- UN 6 3-5 Notes TNC Reverse (Male Contact) 17 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height SMA Conversion Adapter Note : Please avoid mating with the U.FL(A) plug. 17.9 Panel Mount Adapter (Four Screws) 12.7 9.55 1.7 8.64 1/4-36UNS-2A .6 Ø2 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4∞ Part No. HRS No. HRMJ-U.FLJ-PA4 311-0465-2 Notes SMA (Female Contact) 17.9 9.55 8 1.7 Panel Mount Adapter (Two Screws) 12.2 1/4-36UNS-2A 2∞ Ø2. Part No. HRS No. HRMJ-U.FLJ-PA2 311-0467-8 6 Notes SMA (Female Contact) Panel Mount Adapter (Bulkhead) 17.9 1.5 11.5 1/4-36UNS-2A 8HEX 5.85 5.9+0.1 0 Ø6 .4 +0 PCB Mount Adapter Part No. HRS No. HRMJ-U.FLJ-BPAD-5 311-1004-0 6 Notes SMA (Female Contact) Body : Die Cast Type 16 BPanel Cutouts 1/4-36UNS-2A 5.08±0.05 12.7 9.7 6.4 5.08±0.05 0.1 + .5 0 4∞Ø1 5.08 Part No. HRMJ-U.FLJ-PC 18 0 .1 HRS No. Notes 311-0411-3 Nickel Exterior U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height SMA/R Conversion Adapter R : Reverse Polarity SMA Connector 17.9 Note : Please avoid mating with the U.FL(A) plug. 12.7 9.55 Panel Mount Adapter (Four Screws) 1.7 8.64 1/4-36UNS-2A Ø2. 6 Part No. HRS No. Notes SMA(R)J-U.FLJ-PA4 311-0466-5 Reverse Polarity SMA (Male Contact) 17.9 8 9.55 1.7 1/4-36UNS-2A 12.2 Panel Mount Adapter (Two Screws) 2∞ Part No. HRS No. SMA(R)J-U.FLJ-PA2 311-0468-0 1.5 6 Notes Reverse Polarity SMA (Male Contact) 8HEX 17.9 Panel Mount Adapter (Bulkhead) Ø2. BPanel Cutouts 5.85 11 5.9 +0.1 0 1/4-36UNS-2A Ø6 . 4 + 0 0 .1 Ø10 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4∞ Part No. HRS No. SMA(R)J-U.FLJ-BPA-4 311-0464-0 Notes Reverse Polarity SMA (Male Contact) 19 U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 20 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2021. Contents are subject to change without notice for the purpose of improvements.
U.FL-2LP-066J1-A-(300) 价格&库存
很抱歉,暂时无法提供与“U.FL-2LP-066J1-A-(300)”相匹配的价格&库存,您可以联系我们找货
