DATA SHEET
THICK FILM CHIP RESISTORS
AUTOMOTIVE GRADE
AC series
±5%, ±1%, ±0.5%, ±0.1% (LOW TCR)
Sizes 0201/0402/0603/0805/1206/
1210/1218/2010/2512
Product specification – November 17, 2023 V.11
RoHS compliant & Halogen free
Chip Resistor Surface Mount
AC
0201 to 2512
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes AC0201
to AC2512 chip resistors with leadfree terminations made by thick film
process.
Part number is identified by the series name, size, tolerance, packaging
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
All general purpose applications
Car electronics, industrial
application
FEATURES
AEC-Q200 qualified
Moisture sensitivity level: MSL 1
AC series soldering is compliant
with J-STD-020D
Halogen free epoxy
RoHS compliant
- Products with lead-free
terminations meet RoHS
requirements
- Pb-glass contained in electrodes,
resistor element and glass are
exempted by RoHS
Reduce environmentally
hazardous waste
High component and equipment
reliability
The resistors are 100% performed
by automatic optical inspection
prior to taping.
GLOBAL PART NUMBER
AC XXXX X X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0201/ 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512
(2) TOLERANCE
B = ± 0.1% for low TCR
F = ± 1%
D = ± 0.5%
J = ± 5% (for Jumper ordering, use code of J)
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
= Base on spec
E = ± 50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel & Standard power
7W = 7 inch dia. Reel & 2 x standard power
13 = 13 inch dia. Reel
3W = 13 inch dia. Reel & 2 x standard power
(6) RESISTANCE VALUE
1Ω to 22 MΩ
There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no
need to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed coding rules of resistance are shown in the table of “Resistance rule of
global part number”.
(7) DEFAULT CODE
Letter B is for bulk AOI ordering only. (Note)
Resistance rule of global part
number
Resistance coding
Example
rule
XRXX
(1 to 9.76Ω)
1R = 1Ω
1R5 = 1.5Ω
9R76 = 9.76Ω
XXRX
(10 to 97.6Ω)
10R = 10Ω
97R6 = 97.6Ω
XXXR
(100 to 976Ω)
100R = 100Ω
976R = 976Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000Ω
9K76 = 9760Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000Ω
9M76= 9,760,000Ω
XXMX
(10 MΩ)
10M = 10,000,000Ω
O RDERING EXAMPLE
The ordering code for an AC0402
chip resistor, value 100 KΩ with
± 1% tolerance, supplied in 7-inch
tape reel is: AC0402FR-07100KL.
NOTE
1. All our R-Chip products are RoHS
compliant and Halogen free. "LFP" of the
internal 2D reel label states "Lead-Free
Process".
2. On customized label, "LFP" or specific
symbol can be printed.
3. AC series with 0.5% tolerance is also
available. For further information, please
contact sales.
www.yageo.com
Nov. 17, 2023 V.11
AC
SERIES
0201 to 2512
MARKING
AC0201 / AC0402
No marking
Fig. 1
AC0603 / AC0805 / AC1206 / AC1210 / AC2010 / AC2512
E-24 series: 3 digits, ± 5%
First two digits for significant figure and 3rd digit for number of zeros
Fig. 2
Value=10 KΩ
AC0603
YNSC037
Fig. 3
E-24 series: 3 digits, ± 1% & ± 0.5%
One short bar under marking letter
Value = 24 Ω
E-96 series: 3 digits, ± 1% & ± 0.5%
First two digits for E-96 marking rule and 3rd letter for number of zeros
Fig. 4
Value = 12.4 KΩ
Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5%
First three digits for significant figure and 4th digit for number of zeros
Fig. 5 Value = 10 KΩ
AC1218
Fig. 6 Value = 10 KΩ
YNSC103
Fig. 7 Value = 10 KΩ
NOTE
For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AC series is the same as RC series.
www.yageo.com
Nov. 17, 2023 V.11
AC
SERIES
0201 to 2512
CONSTRUCTION
The resistors are constructed on top of an automotive grade ceramic body. Internal metal electrodes are added at
each end and connected by a resistive glaze. The resistive glaze is covered by a protective glass.
The composition of the glaze is adjusted to give the approximately required resistance value and laser trimming of this
resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and
bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added, as
shown in Fig.8.
OUTLINES
Fig. 8_1
Fig. 8_2
Chip resistor outlines
AC2010/ 2512 double power chip resistor outlines
DIMENSIONS
Table 1 For outlines, please refer to Fig. 9
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
AC0201
0.60 ± 0.03
0.30 ± 0.03
0.23 ± 0.03
0.12 ± 0.05
0.15 ± 0.05
AC0402
1.00 ± 0.05
0.50 ± 0.05
0.32 ± 0.05
0.20 ± 0.10
0.25 ± 0.10
AC0603
1.60 ± 0.10
0.80 ± 0.10
0.45 ± 0.10
0.25 ± 0.15
0.25 ± 0.15
AC0805
2.00 ± 0.10
1.25 ± 0.10
0.50 ± 0.10
0.35 ± 0.20
0.35 ± 0.20
AC1206
3.10 ± 0.10
1.60 ± 0.10
0.55 ± 0.10
0.45 ± 0.20
0.45 ± 0.20
AC1210
3.10 ± 0.10
2.60 ± 0.15
0.55 ± 0.10
0.45 ± 0.15
0.50 ± 0.20
AC1218
3.10 ± 0.10
4.60 ± 0.10
0.55 ± 0.10
0.45 ± 0.20
0.40 ± 0.20
AC2010
5.00 ± 0.10
2.50 ± 0.15
0.55 ± 0.10
0.55 ± 0.15
0.55 ± 0.20
AC2512
6.35 ± 0.10
3.10 ± 0.15
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
For dimension, please refer to Table 1
AC0201/0402
0603/0805/1206/1210/
2010/2512
I1
AC1218
Side view for all type
I1
I1
W
W
Fig. 9 Chip resistor dimensions
H
W
I2
L
L
L
YNSC096
www.yageo.com
Nov. 17, 2023 V.11
AC
SERIES
0201 to 2512
ELECTRICAL CHARACTERISTICS
Table 2
CHARACTERISTICS
TYPE
AC0201
POWER
1/20 W
Operating
Max.
Temperature Working
Range Voltage
-55°C to 155°C
25V
Max.
Dielectric
Overload Withstanding
Voltage
Voltage
50V
50V
Resistance
Range
Temperature
Coefficient
Jumper
Criteria
5% (E24)
1Ω ≤ R ≤ 10Ω
Rated Current
1Ω ≤ R ≤ 10MΩ
-100/+350 ppm°C
0.5A
1% (E24/E96)
10Ω < R ≤ 10M
Maximum
1Ω ≤ R ≤ 10MΩ
± 200 ppm°C
Current
0.5% (E24/E96)
1.0A
10Ω ≤ R ≤ 1MΩ
Jumper
很抱歉,暂时无法提供与“AC0603CRNPO9BN9R0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05429
- 500+0.04936
- 5000+0.04278
- 30000+0.04113
- 90000+0.03949
- 国内价格
- 460+0.51990
- 1000+0.35840
- 2000+0.25090
- 4000+0.17860
- 国内价格 香港价格
- 1+1.154531+0.14936
- 10+0.6360610+0.08229
- 50+0.4402250+0.05695
- 100+0.38100100+0.04929
- 500+0.28291500+0.03660
- 1000+0.252751000+0.03270
- 国内价格 香港价格
- 4000+0.197704000+0.02558
- 8000+0.181768000+0.02352
- 12000+0.1737712000+0.02248
- 20000+0.1649320000+0.02134
- 28000+0.1597728000+0.02067
- 40000+0.1548040000+0.02003
