Additional Resources:
Product Page
3D Model
PCB Footprint
date
12/15/2022
page 1 of 3
MODEL: PJ-031DH | DESCRIPTION: DC POWER JACK
FEATURES
• 1.3 mm center pin
• 3.5 A rating
• right angle orientation
• through hole mount
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
24
units
Vdc
rated input current
3.5
A
contact resistance
50
mΩ
insulation resistance
at 500 Vdc
100
MΩ
voltage withstand
insertion/withdrawal force
0.3
operating temperature
-25
life
500
Vac
2
kg
85
5,000
flammability rating
UL94V-0
RoHS
yes
°C
cycles
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
dipped in solder pot for 5 ±0.5 seconds
255
260
265
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: PJ-031DH | DESCRIPTION: DC POWER JACK
date 12/15/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
X. ±0.15 mm
X.X ±0.10 mm
X.XX ±0.05 mm
PCB: ±0.05 mm
unless otherwise specified
DESCRIPTION
MATERIAL
PLATING/COLOR
center pin
brass
silver
terminal 1
brass t=0.50
silver
terminal 2
MM alloy t=0.20
silver
terminal 3
brass t=0.50
silver
housing
PA10T (UL94V-0)
black
Recommended PCB Layout
Top View
1
3
2
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 7.0 mm
Model
PJ-031DH
Center Pin
Ø1.3 mm
cuidevices.com
Product Page
3D Model
PCB Footprint
date 12/15/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
07/30/2007
1.01
applied new spec template
06/29/2015
1.02
increased voltage rating
05/03/2016
1.03
brand update
10/24/2019
1.04
logo, datasheet style update
08/05/2022
1.05
product reengineered for improved manufacturability and production yield, see
PCN for details
12/15/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-031DH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+2.96743500+0.36031
- 1000+2.953571000+0.35863
- 2000+2.953502000+0.35862
- 2500+2.953432500+0.35861
- 7500+2.953377500+0.35860
- 国内价格
- 5+4.46546
- 10+4.24052
- 100+4.03016
- 250+3.83022
- 500+3.63443
