DF37NB-16DS-0.4V(53) 数据手册
DF37 Series
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
0.4mm Pitch, 0.98/1.5mm Stacking Height,
FPC-to-Board Connectors
Feb. 2022
DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors
Features
1. Contributes to End Product
Size Reduction
4.56mm
DF37
10.22mm
PCB Mounting Space Comparison( 40pos. , 0. 4mm Pitch,
0. 98mm Height)
2. High Contact Reliability
DF37 has an effective mating length of 0. 25mm,
one of the longest for connectors with a 1. 0mm
mated height. The clear tactile click prevents
incomplete mating and the 2- point contact design
provides a high mating force.
3. Wide Mating Self- Alignment
Range
The guide ribs effectively utilize dead space,
enabling a self alignment range of 0. 3mm.
4. Robust Design with Shock
Absorbing Contacts
Header
Locks on both sides of the 2- point contact
absorb stress on impact.
0.98
Space- saving design with minimal connector
depth and an automatic placement area that does
not interfere with mounting( tested) .
Depth:When mated 2. 98mm
Header 1. 98mm
2.98mm
DF30
Receptacle
5. Solder Wicking Prevention
The receptacle with nickel barrier and the insert
molder header prevent solder wicking.
2
Lock
6. Contamination Protection
Contact Area
Insulator walls protect the contact areas against
flux splatter or other physical particle
contamination.
The contact area is not exposed to the outside,
preventing penetration of flux or other particles.
Contact Area
3
Product Specifications
Rated Current
0.3A
Operating Temperature (Note 1)
-35 to +85℃
Rated Voltage
30V AC/DC
Storage Temperature (Note 2)
-10 to +60℃
Operating Humidity Range
20-80%
Storage Humidity Range (Note 2)
40-70%
Item
Specification
Conditions
Insulation
Resistance
50M Ω Min.
100V DC
Withstanding Voltage
No flashover or insulation breakdown
100V AC / 1minute
Contact Resistance
100m Ω Max.
20mV AC, 1kHz, 1mA
Vibration
No electrical discontinuity of 1μ s or
longer
Frequency : 10 to 55 Hz, single amplitude of 0.75mm,
2 hours, 3 axis
Humidity
Contact resistance : 100m Ω Max.,
Insulation resistance : 25M Ω Min.
96 hours at 40 ± 2℃ and humidity of 90 to 95%
No damage or parts dislocation
Temperature Cycle
Insulation resistance : 50M Ω Min.
-55℃ → +5 to +35℃ → +85℃ → +5 to +35℃
Time: 30 min. → 10 min. → 30 min. → 10 min.
5 cycles
Mating
Durability
10 cycles
Solder Heat
Resistance
No deformation of components affecting
performance
Reflow : At the recommended temperature profile
Hand solder : Solder iron temperature of 350℃ for 3 seconds
Max.
Note 1 : Includes temperature rise caused by current flow.
Note 2 : Storage refers to long-term storage of unused items before they are mounted on the PCB.
Operating temperature and humidity range apply when the product is not powered after PCB mounting and when temporarily stored during transportation.
Materials / Finish
Product
Part
Material
Finish
Remarks
Receptacle
Header
Insulator
LCP
Color: Black
UL94V-0
Contacts
Phosphor Bronze
Gold Plated
4
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Receptacle
DF37 # (##) - # DS - 0.4 V (##)
❶
❷
❸
❹
❺
❻
❼
❽
❶
Series Name
DF37
❹
No. of Pos.
❷
Configuration
NB : With Retention Tabs
NC : Without Retention Tabs
❺
Connector Type
DS : Receptacle
❻
Contact Pitch
0.4mm
❼
Termination Type
V : SMT Vertical Mount
❽
Packaging
(51) Stacking Height 0.98mm : Embossed
Tape Packaging (8,000pcs per reel)
(51) Stacking Height 1.5mm : Embossed
Tape Packaging (5,000pcs per reel)
(53) : Embossed Tape Packaging
(1,000pcs per reel)
❸
Stacking Height
Blank : 0.98mm
1.5
: 1.5mm
■ Header
DF37 # - # DP - 0.4 V (##)
❶
❷
❸
❹
❺
❻
❼
❶
Series Name
DF37
❺
Contact Pitch
0.4mm
❷
Configuration
❻
Termination Type
❸
No. of Pos.
❼
Packaging
❹
Connector Type
(51) : Embossed Tape Packaging
(8,000pcs per reel)
(1,000pcs per reel)
DP : Double Row Header
5
Receptacle (Stacking Height=0.98mm)
2.98
2.32
P=0.4
A
B
Vacuum pick-up area : C
0.08
0.98
0.15
■ Recommended PCB Layout
DF37NC
P=0.4±0.02
B±0.02
3.28+0.05
3.28 +0.05
P=0.4±0.02
E+0.05
D -0.05
B±0.02
1.1+0.05
DF37NB
With Retention Tabs
0.23±0.02
0.23±0.02
■ Recommended Metal Mask Dimensions
1.1+0.05
P=0.4±0.02
D -00.05
B±0.02
P=0.4±0.02
0.23±0.01
2.28±0.01
DF37NC
E +0.05
3.28±0.01
DF37NB
With Retention Tabs
3.28±0.01
2.28±0.01
0.96
(With Retention Tabs only)
0.23±0.01
6
B±0.02
With Retention Tabs
Unit : mm
Part No.
HRS No.
No. of
Pos.
A
B
C
D
E
DF37NB-10DS-0.4V(##)
CL0684-3301-6-##
10
4.22
1.6
0.8
3.7
4.46
DF37NB-16DS-0.4V(##)
CL0684-3302-9-##
16
5.42
2.8
1.2
4.9
5.66
DF37NB-20DS-0.4V(##)
CL0684-3303-1-##
3.6
1.6
5.7
6.46
DF37NB-24DS-0.4V(##)
CL0684-3304-4-##
24
7.02
4.4
6.5
7.26
DF37NB-30DS-0.4V(##)
CL0684-3305-7-##
30
8.22
5.6
7.7
8.46
DF37NB-34DS-0.4V(##)
CL0684-3082-4-##
34
9.02
6.4
8.5
9.26
DF37NB-40DS-0.4V(##)
CL0684-3306-0-##
40
10.22
7.6
9.7
10.46
DF37NB-44DS-0.4V(##)
CL0684-3407-7-##
44
11.02
8.4
10.5
11.26
DF37NB-50DS-0.4V(##)
CL0684-3307-2-##
50
12.22
9.6
11.7
12.46
DF37NB-60DS-0.4V(##)
CL0684-3308-5-##
60
14.22
11.6
3.2
13.7
14.46
DF37NB-70DS-0.4V(##)
CL0684-3409-2-##
70
16.22
13.6
3.6
15.7
16.46
2
2.4
2.8
Purchase Unit Purchase Unit
(##) : (51)
(##) : (53)
8,000pcs
per reel
Unit : mm
HRS No.
No. of
Pos.
A
B
C
DF37NC-10DS-0.4V(##)
CL0684-3309-8-##
10
4.22
1.6
0.8
DF37NC-16DS-0.4V(##)
CL0684-3310-7-##
16
5.42
2.8
1.2
DF37NC-20DS-0.4V(##)
CL0684-3311-0-##
3.6
1.6
DF37NC-24DS-0.4V(##)
CL0684-3312-2-##
24
7.02
4.4
DF37NC-30DS-0.4V(##)
CL0684-3313-5-##
30
8.22
5.6
DF37NC-34DS-0.4V(##)
CL0684-3083-7-##
34
9.02
6.4
DF37NC-40DS-0.4V(##)
CL0684-3314-8-##
40
10.22
7.6
DF37NC-44DS-0.4V(##)
CL0684-3324-1-##
44
11.02
8.4
DF37NC-50DS-0.4V(##)
CL0684-3315-0-##
50
12.22
9.6
DF37NC-60DS-0.4V(##)
CL0684-3316-3-##
60
14.22
11.6
3.2
DF37NC-70DS-0.4V(##)
CL0684-3084-0-##
70
16.22
13.6
3.6
Part No.
1,000pcs
per reel
Note 1 : The position of the HRS and CAV marks may differ from the diagram.
Note 2 : This connector is NOT polarized.
7
Purchase Unit
(##) : (51)
Purchase Unit
(##) : (53)
8,000pcs
per reel
1,000pcs.
per reel
2
2.4
2.8
Receptacle (Stacking Height=1.5mm)
2.98
2.32
P=0.4
A
B
1.5
0.08
0.15
P=0.4±0.02
B±0.02
2.02-00.05
2.02-00.05
DF37NC
3.28 +0.05
P=0.4±0.02
E+0.05
D -0.05
B±0.02
1.1+0.05
DF37NB
With Retention Tabs
3.28 +0.05
0.23±0.02
0.23±0.02
DF37NC
3.28±0.01
P=0.4±0.02
0.23±0.01
2.28±0.01
P=0.4±0.02
E+0.05
D -0.05
B±0.02
1.1+0.05
DF37NB
With Retention Tabs
3.28±0.01
2.28±0.01
0.96
(With Retention Tabs Only)
0.23±0.01
8
B±0.02
With Retention Tabs
Part No.
HRS No.
No. of
Pos.
A
B
C
D
E
Purchase Unit
(##) : (51)
Purchase Unit
(##) : (53)
DF37NB(1.5)-24DS-0.4V(##)
CL0684-3602-2-##
24
7.02
4.4
2
6.5
7.26
5,000pcs
per reel
1,000pcs
per reel
Unit : mm
HRS No.
No. of
Pos.
A
B
DF37NC(1.5)-24DS-0.4V(##)
CL0684-3603-5-##
24
7.02
4.4
DF37NC(1.5)-30DS-0.4V(##)
CL0684-3604-8-##
30
8.22
5.6
DF37NC(1.5)-34DS-0.4V(##)
CL0684-3618-0-##
34
9.02
6.4
DF37NC(1.5)-40DS-0.4V(##)
CL0684-3606-3-##
40
10.22
7.6
DF37NC(1.5)-50DS-0.4V(##)
CL0684-3610-0-##
50
12.22
9.6
2.8
DF37NC(1.5)-60DS-0.4V(##)
CL0684-3613-9-##
60
14.22
11.6
3.2
DF37NC(1.5)-70DS-0.4V(##)
CL0684-3614-1-##
70
16.22
13.6
3.6
Part No.
Unit : mm
9
C
Purchase Unit
(##) : (51)
Purchase Unit
(##) : (53)
5,000pcs
per reel
1,000pcs
per reel
2
2.4
Header
1.98
1.46
P=0.4
A
B
0.08
E+0.05
D -0.05
B±0.02
P=0.4±0.02
2.28 +0.05
2.28 +0.05
B±0.02
P=0.4±0.02
0.68 +0.05
With Retention Tabs
0.23±0.02
0.23±0.02
E+0.05
D -0.05
B±0.02
P=0.4±0.02
2.28±0.01
1.26±0.01
B±0.02
P=0.4±0.02
0.68+0.05
With Retention Tabs
2.28±0.01
1.26±0.01
0.76
0.15
0.23±0.02
0.23±0.02
10
0.58
With Retention Tabs
Unit : mm
Part No.
HRS No.
No. of
Pos.
A
B
C
D
E
DF37B-10DP-0.4V(##)
CL0684-3037-0-##
10
3.14
1.6
0.8
2.62
3.38
DF37B-16DP-0.4V(##)
CL0684-3057-7-##
16
4.34
2.8
1.2
3.82
4.58
DF37B-20DP-0.4V(##)
CL0684-3008-1-##
3.6
1.6
4.62
5.38
DF37B-24DP-0.4V(##)
CL0684-3009-4-##
24
5.94
4.4
5.42
6.18
DF37B-30DP-0.4V(##)
CL0684-3010-3-##
30
7.14
5.6
6.62
7.38
DF37B-34DP-0.4V(##)
CL0684-3064-2-##
34
7.94
6.4
7.42
8.18
DF37B-40DP-0.4V(##)
CL0684-3011-6-##
40
9.14
7.6
8.62
9.38
DF37B-44DP-0.4V(##)
CL0684-3408-0-##
44
9.94
8.4
9.42
10.18
DF37B-50DP-0.4V(##)
CL0684-3012-9-##
50
11.14
9.6
10.62
11.38
DF37B-60DP-0.4V(##)
CL0684-3013-1-##
60
13.14
11.6
3.2
12.62
13.38
DF37B-70DP-0.4V(##)
CL0684-3014-4-##
70
15.14
13.6
3.6
14.62
15.38
2
2.4
2.8
(##) : (51)
(##) : (53)
8,000pcs
per reel
Unit : mm
HRS No.
No. of
Pos.
A
B
C
DF37C-10DP-0.4V(##)
CL0684-3039-5-##
10
3.14
1.6
0.8
DF37C-16DP-0.4V(##)
CL0684-3058-0-##
16
4.34
2.8
1.2
DF37C-20DP-0.4V(##)
CL0684-3024-8-##
3.6
1.6
DF37C-24DP-0.4V(##)
CL0684-3025-0-##
24
5.94
4.4
DF37C-30DP-0.4V(##)
CL0684-3026-3-##
30
7.14
5.6
DF37C-34DP-0.4V(##)
CL0684-3085-2-##
34
7.94
6.4
DF37C-40DP-0.4V(##)
CL0684-3027-6-##
40
9.14
7.6
DF37C-44DP-0.4V(##)
CL0684-3089-3-##
44
9.94
8.4
DF37C-50DP-0.4V(##)
CL0684-3028-9-##
50
11.14
9.6
DF37C-60DP-0.4V(##)
CL0684-3029-1-##
60
13.14
11.6
3.2
DF37C-70DP-0.4V(##)
CL0684-3030-0-##
70
15.14
13.6
3.6
Part No.
1,000pcs
per reel
11
Purchase Unit
(##) : (51)
Purchase Unit
(##) : (53)
8,000pcs
per reel
1,000pcs
per reel
2
2.4
2.8
Embossed Carrier Tape Dimensions (JIS C 0806 Standard)
Receptacle (Less Than 70 Positions)
2±0.1 4±0.1
F
E±0.15
0.3±0.1
F-F
G
Unreeling Direction
G-G
F
G
Receptacle (70 Positions)
8±0.1
2±0.14±0.1
E±0.15
0.3±0.1
28.4±0.1
B±0.3
A±0.1
.1
+00
F
F-F
1.75±0.1
.5
φ1
B±0.3
A±0.1
.1
+0 0
5
1.
φ
8±0.1
1.75±0.1
G
Unreeling Direction
G-G
G
F
12
Reel Dimensions
Unreeling Direction
φ80±1
Part Number Label
φ380±2
φ1
3±
0.2
C±0.5
D±1
Unit : mm
Part No.
A
B
C
D
E
7.5
16
17.5
21.5
DF37#-10DS-0.4V(##)
DF37#-16DS-0.4V(##)
DF37#-20DS-0.4V(##)
DF37#-24DS-0.4V(##)
DF37#-30DS-0.4V(##)
1.23
DF37#-34DS-0.4V(##)
DF37#-40DS-0.4V(##)
DF37#-44DS-0.4V(##)
11.5
24
25.5
29.5
14.2
32
33.5
37.5
DF37#-50DS-0.4V(##)
DF37#-60DS-0.4V(##)
DF37#-70DS-0.4V(##)
# : NB or NC
Tape and reel packaging (8,000pcs per reel).
Unit : mm
Part No.
DF37#(1.5)-24DS-0.4V(##)
A
B
C
D
7.5
16
17.5
21.5
11.5
24
25.5
29.5
14.2
32
33.5
37.5
E
DF37#(1.5)-30DS-0.4V(##)
DF37#(1.5)-34DS-0.4V(##)
DF37#(1.5)-40DS-0.4V(##)
DF37#(1.5)-50DS-0.4V(##)
DF37#(1.5)-60DS-0.4V(##)
DF37#(1.5)-70DS-0.4V(##)
# : NB or NC
Tape and reel packaging (5,000pcs per reel).
13
1.75
Header
E
Unreeling Direction
E
F-F
Reel Dimensions
Unreeling Direction
φ80±1
Part Number Label
φ380±2
F
φ1
3±
0.2
F
E-E
1±0.15
0.3±0.1
B±0.3
2±0.1 4±0.1
A±0.1
.1
+00
.5
φ1
8±0.1
1.75±0.1
C±0.5
D±1
Unit : mm
Part No.
DF37#-10DP-0.4V(##)
A
B
C
D
5.5
12
13.5
17.5
7.5
16
17.5
21.5
11.5
24
25.5
29.5
DF37#-16DP-0.4V(##)
DF37#-20DP-0.4V(##)
DF37#-24DP-0.4V(##)
DF37#-30DP-0.4V(##)
DF37#-34DP-0.4V(##)
DF37#-40DP-0.4V(##)
DF37#-44DP-0.4V(##)
DF37#-50DP-0.4V(##)
DF37#-60DP-0.4V(##)
DF37#-70DP-0.4V(##)
# : B, C
14
Usage Precautions
1. Recommended
Temperature Profile
Temperature (℃)
250℃
250
220℃
200
60sec Max.
180℃
150 150℃
90~120sec
100
50
Room temperature
100
150
200
250
300
Time (sec.)
【Conditions】
1.Peak Temperature: Maximum of 250℃
2.Heating : 220℃ min. for 60 sec. max.
3.Preheating : 150 to 180℃ , 90 to 120 sec.
4.Number of Reflow Cycles : 2 cycles max.
Note:The temperature refers to the surface temperature of the board near the connector lead.
2. Recommended Manual
Soldering Conditions
Soldering Iron Temperature : 340 ± 10℃ ;
Soldering Time : within 3 seconds
3. Recommended
Metal Mask
Thickness and
Open Area to
PCB Pattern Area Ratio
Thickness : 0.12mm
Open area ratio : Receptacle Side : 80%(NB/NC), Plug Side : 70%
4. Board Warpage
Max. of 0.02mm at the center in reference to both ends of the connector
5. Cleaning
Cleaning is not recommended.
If you clean this product, please evaluate its performance before using it.
(Cleaning may impair the mating/unmating properties and lower resistance to environmental factors)
6. Precautions
■ Be careful when mating/unmating the connector when it is not mounted on the
PCB as it may cause damage/deformation to contacts.
■ Avoid supporting the PCB only with the connectors.
Support it by other means such as bolts, screws, posts, etc.
■ Excessive prying during unmating/mating may result in damage..
■ In the case of hand soldering, please do not apply any flux which could cause flux wicking.
■ This product may have slight color differences due to production lot variability,
but this does not affect the performance.
■ Please refer to the following page for handling precautions when inserting and removing.
■ Because the product can disengage if dropped (or other impact), or by FPC routing,
it is advised to secure the mated connectors to the board with housings and cushioning materials.
15
Handling Precautions for Connector Mating
1) When aligning, look for the guide port without applying excessive force. If excessive force is applied, the housing
may be damaged or shaved resulting in poor contact resistance, so please be careful.
2) When fully aligned the connectors are parallel to each other with restricted longitudinal and lateral movement.
Mate them parallel to each other.
16
Handling Precautions for Connector Removal
1) Pull out the connectors parallel to each other.
2) If the connector cannot be removed by pulling it out parallel to its mating partner, it can be removed by
extracting the connector diagonally in the direction of the pitch as shown in the below figure.
However, there is a risk that the connector may break if the FPC is not rigid.
Please confirm the FPC rigidity at the time of trial production.
3) Do not remove the connector by pulling from the FPC corner as shown below.
Pulling from the FPC corner may result in connector and contact damage.
4) Insufficient FPC rigidity may result in connector breakage as shown in the below figure.
Please check the repeated mechanical operation of the FPC before use.
Please request for evaluation results of FPC rigidity and various items.
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com
※ The contents of this catalog are current as of date of 2/ 2022. Contents are subject to change without notice for the purpose of improvements.
17
