PPM-2-3511-SG
PPM-2-3511-SG
    CUIDEVICES
    PPM-2-3511-SG
PPM-2-3511-SG 数据手册
Additional Resources: Product Page | 3D Model date 11/07/2019 page 1 of 2 MODEL: PPM-2-3511-SG │ DESCRIPTION: DC POWER PLUG FEATURES • • • • designed for over-molding spring contacts barrel groove 5A current rating SPECIFICATIONS parameter conditions/description min typ rated voltage rated current contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute units 24 Vdc 5 A 30 mΩ 100 operating temperature MΩ -25 operating humidity RoHS compliant max 500 Vac 70 °C 85 %RH yes MECHANICAL DRAWING units: mm tolerance: ±0.2 mm (unless otherwise noted) cuidevices.com DESCRIPTION MATERIAL PLATING 1 insulator PBT 2 sleeve brass nickel 3 center contact phosphor bronze nickel 4 spacer POM Additional Resources: Product Page CUI Devices │ MODEL: PPM-2-3511-SG │ DESCRIPTION: DC POWER PLUG | 3D Model date 11/07/2019 │ page 2 of 2 REVISION HISTORY rev. description date 1.0 initial release 01/14/2013 1.01 brand update 11/07/2019 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
PPM-2-3511-SG 价格&库存
很抱歉,暂时无法提供与“PPM-2-3511-SG”相匹配的价格&库存,您可以联系我们找货
PPM-2-3511-SG
    • 235+2.78577
    • 500+2.77698
    • 1000+2.76819
    库存:1311
