FC Type Fiber Optic Connectors
Environment
MU
Jan.1.2023 Copyright 2023 HIROSE ELECTRIC
CO., LTD. All Rights Reserved.
Harsh
FC
SC
HRFC Series
■Features
Attenuators
1. JIS, IEC standard compliant and intermateability test certified.
Comply with IEC 61754-13 and JIS C 5970(type F01).
FC intermate test by NTT certified connector.
2.Polishing
Available with PC polishing, advanced PC(AdPC) polishiing and Angled PC(APC) polishing.
3.Flame resistant
Terminators
Satisfies flammability rating UL94V-0.
■Applications
POF / PCF
Public communications lines, CATV, Test equipment, etc.
30
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
HRFC Series●FC Type Fiber Optic Connectors
■Product Specifications
Operating temperature range
Mechanical Characteristics
Return Loss
Test Method (IEC 61300)
-25°C to +70°C
Specifications
(SM)
Wavelength 1310nm (LD)
0.5dB max. (PC, AdPC, APC)
(GI)
Wavelength 1310nm (LED)
0.3dB max. (PC)
(SM)
(GI)
22dB min. (PC), 40dB min. (AdPC), 60dB min. (APC)
22dB min. (PC)
Ferrule withdrawal
Extract zirconia gauge 2.499 ±0.0005mm
dia from split sleeve.
Phosphor bronze split sleeve
Zirconia split sleeve
Cable retention
(Straight pull)
98N tensile load for 1 minute.
1) Insertion loss fluctuation after test: 0.2dB max.
2) No visible damage, dislocation of clamp or cable.
Durability
(cycles, mating/un-mating)
1000 times
Vibration
Frequency: 10 to 55 Hz, single amplitude of 0.75mm,
2 hours in each of the 3 axis.
Shock
Acceleration of 981 m/s2, 6 ms duration,
half sine shock pulse, 10 cycles in each of the 3 axis.
-10°C to 65°C, humidity: 90% to 96% 10 cycles
Change of temperature
-40°C to +75°C 42 cycles
(Complies with Telcordia standard GR-326-CORE)
Dry heat
240 hours at 85°C
Cold
240 hours at -25°C
Salt mist
48 hours in a 5% concentration of salt mist
2) No visible damage, cracks or part dislocation.
Harsh
Environment
Humidity
(Temperature/ humidity- cycles)
2N to 5.9N
2N to 3.9N
MU
Environmental
Characteristics
Insertion Loss
Storage temperature range
FC
No significant corrosion.
■Materials
Part
Material
Plug housing
Brass, Zinc alloy
Spring
Stainless steel
Ferrule
Zirconia
Adapter
Brass
Split sleeve
Zirconia or Phosphor bronze
Receptacle
Brass
Attenuators
Terminators
Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Optical
Characteristics
Item
-25°C to +70°C
SC
Ratings
POF / PCF
31
SC
■FC products
Plug Housing
For 2mm cord,
Molded keying ring type
For 0.9mm fiber,
MU
Harsh
FC
For 3mm cord,
Single mode
Multi mode
Ferrule
HRFC-type
Connector
Environment
Adapter
Round type
Attenuators
Conversion adapter
Receptacle
POF / PCF
Terminators
Dust cap
32
Standard type
FC to SC
Solid Body type
Flange type
FC to SC
■Plug Housing
Please use it with the SC ferrules.
SC
B-%#,*
●For 2mm cable
FC
CL No.
Boot color
Polishing type
HRFC-P8-H2(63)
701-0075-3-63
Blue
PC
HRFC-P8-L2(61)
701-0077-9-61
Light purple
AdPC
HRFC-P8-G2(62)
701-2001-8-62
Green
APC
Boot color
Polishing type
Note: Guide key width is 2.1mm
●For 3mm cable
MU
B-%#,*
Part Number
CL No.
HRFC-P8-H3(62)
701-0074-0-62
Blue
PC
HRFC-P8-L3(61)
701-0078-1-61
Light purple
AdPC
HRFC-P8-G3(61)
701-2002-0-61
Green
APC
Harsh
Environment
●For 0.9mm fiber
B-%#,*
Attenuators
CL No.
Boot color
Polishing type
HRFC-P15-H(62)
Part Number
701-0114-3-62
Blue
PC
HRFC-P15-L(62)
701-0115-6-62
Light purple
AdPC
HRFC-P15-G(61)
701-2004-6-61
Green
APC
Terminators
Part Number
POF / PCF
33
■Adapters
SC
●Solid Body type
■Panel Cutout
B-£%#,*
B-£%#,*
Ø9
FC
2∞M2∞0.4
or 2∞Ø2.4 +0.2
;8"6
h^c
iZg
¢' djc *
8
¢) Zei]
Y
13.4±0.1
Part Number
CL No.
Split sleeve
Remarks
HRFC-PA11-G1(40)
701-0071-2-40
Phosphor bronze
HRFC-PA11-D1(40)
701-0106-5-40
Zirconia
(Note)
Note: Please take utmost care when inserting FC plug into a FC adapter. When applying excessive force to
the FC plug or inserting in an odd angle, the zirconia sleeve within the adapter might be dameged
●Standard Body type
■Panel Cutout
Environment
MU
'B-%#,*
'B'%#)
dg'¢'#) %%#'
;8"6
Harsh
+0.5
¢)8djciZgh^c`YZei]*
Part Number
CL No.
Mark
Split sleeve
Remarks
HRFC-PA1-G1(41)
701-0014-9-41
FC-AP
Phosphor bronze
HRFC-PA1-D1(40)
701-0089-8-40
FC-A
Zirconia
(Note)
the FC plug or inserting in an odd angle, the zirconia slleve within the adapter might be dameged
●Flange type
■Panel Cutout
'B'%#)
dg'¢'#)
Attenuators
'B-%#,*
'¢)8djciZgh^c`YZei]*
Terminators
Part Number
CL No.
Split sleeve
Remarks
HRFC-PA4-G1(40)
701-0068-8-40
Phosphor bronze
HRFC-PA4-D1(40)
701-0112-8-40
Zirconia
(Note)
●Round type
Part Number
POF / PCF
'B-%#,*
CL No.
Split sleeve
Remarks
HRFC-A2-SF(41)
701-0039-0-41
Phosphor bronze
HRFC-A2-SF-D1(40)
701-0140-3-40
Zirconia
(Note)
34
■Conversion adapters
■Panel Cutout
î&
'B-%#,*
'B'%#)
dg'¢'#)
Part Number
CL No.
Split sleeve
HSCJ-HRFCJ-B(43)
704-0021-3-43
Phosphor bronze
FC
13.7
(3.9)
9
12.8
32
Part Number
CL No.
HRFCP-HSCJ-1(61)
7.4
Ø19
9.15
15
●FC / SC
MU
Split sleeve
Polishing type
701-0065-0-61
HRFCP-HSCJ-1AS(61) 701-0108-0-61
HRFCP-HSCJ-2(61)
701-0085-7-61
PC
GI-50/125
AdPC
Phosphor
bronze
PC
HRFCP-HSCJ-2AS(61) 701-0109-3-61
Fiber type
Harsh
Environment
SM-9.5/125
AdPC
The positions of SC guide slot and FC guide key will not be always aligned.
●FC / SC
B-%#,*
Part Number
CL No.
HSCP-HRFCJ-1(61)
Split sleeve
Polishing type
Phosphor
bronze
AdPC
704-0203-0-61
HSCP-HRFCJ-1AS(61) 704-0288-3-61
HSCP-HRFCJ-2(61)
Attenuators
704-0204-3-61
PC
PC
HSCP-HRFCJ-2AS(61) 704-0289-6-61
AdPC
Fiber type
GI-50/125
SM-9.5/125
Terminators
SC
●FC / SC
The positions of SC guide key and FC guide slot will not be always aligned.
■Receptacle
■Panel Cutout
î &*
î .#*
)B'%#)
dg)¢'#)
B-%#,*
POF / PCF
;8"G
¢)8djciZgh^c`YZei]*
Part Number
CL No.
Remarks
HRFC-R1(41)
701-0016-4-41
GI
HRFC-R2(41)
701-0023-0-41
SM
35
■Ferrule
SC
Please use the SC connector's ferrule.
Part Number
HRFC-C1(40)
MU
Harsh
FC
■Dust Cap
■Tool
●Crimp tool
POF / PCF
Terminators
Attenuators
Environment
Please use the SC connector's crimp tool .
36
CL No.
701-0019-2-40
