Additional Resources:
Product Page
3D Model
PCB Footprint
date
05/26/2022
page
1 of 8
SERIES: PBO-5C │ DESCRIPTION: INTERNAL AC-DC POWER SUPPLY
FEATURES
wide input range (85 ~ 305 Vac)
wide operating temperature range (-40 to +85 C)
IEC/EN/UL 62368 certified
designed to meet 61558 & 60335 safety standards
1,000,000 hour MTBF
flexible implementations to power a wide array of applications
MODEL
output
voltage
output
current
output
power
ripple
and noise¹
efficiency²
(Vdc)
min
(A)
max
(A)
max
(W)
typ
(mVp-p)
typ
PBO-5C-3
3.3
0.1
1.0
3.3
150
69.0
PBO-5C-5
5.0
0.1
1.0
5.0
150
76.0
PBO-5C-9
9.0
0.056
0.56
5.0
150
77.0
PBO-5C-12
12.0
0.042
0.42
5.0
150
79.0
PBO-5C-15
15.0
0.034
0.34
5.0
150
79.0
PBO-5C-24
24.0
0.021
0.21
5.0
150
81.0
Note:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, see Application Circuit 10% -100% load.
2. At 230 Vac input.
PART NUMBER KEY
PBO-5C - XX
Output Voltage
Base Number
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PBO-5C │ DESCRIPTION: AC-DC POWER SUPPLY
date 05/26/2022 │ page 2 of 8
INPUT
parameter
conditions/description
voltage
ac input
dc input
min
frequency
current
at 115 Vac
at 230 Vac
inrush current
at 115 Vac
at 230 Vac
no load power consumption
at 230 Vac
max
units
85
70
typ
305
430
Vac
Vdc
47
63
Hz
0.2
0.1
A
A
A
A
0.15
W
max
units
2,200
1,500
680
470
330
100
μF
μF
μF
μF
μF
μF
OUTPUT
parameter
capacitive load
3.3 Vdc output models
5 Vdc output models
9 Vdc output models
12 Vdc output models
15 Vdc output models
24 Vdc output models
initial set point accuracy
10% ~ 100% load
line regulation
at rated load
load regulation
10% ~ 100% load
min
temperature coefficient
typ
±5
±1.5
±3
±0.15
%/°C
PROTECTIONS
parameter
min
over current protection
auto recovery
110
short circuit protection
continuous, auto recovery, hiccup
typ
max
units
SAFETY & COMPLIANCE
parameter
min
isolation voltage
input to output for 1 minute, leakage current 200 mA at 100 kHz.
2. Recommended to use a high frequency, low ESR, electrolytic capacitor (
很抱歉,暂时无法提供与“PBO-5C-9”相匹配的价格&库存,您可以联系我们找货
