USB1075-30-P-B
USB1075-30-P-B
    GCT
    插件
USB1075-30-P-B 数据手册
NO TR FO E R N CO M EW M E DE ND SIG ED NS 2.57 1.50 H 8.00 2.00 9 8 7 2 1 5 6 9x Ø 4 3 2.00 2.50 0±0 2 xØ 7.00 .05 2. 3 3.07 0±0 .10 13.14 11.78±0.20 16.50 G 0. 7 Designed to comply with physical, electrical and environmental requirements of full size USB Standard Compliance (USB3.0). PCB Edge F 6.00 12.50 Recommended P.C.B Layout as viewed from component side Component Outline Specifications 6.99 (ref.) E Material Plastic Housing: PBT, UL94V-0, Blue Contact Terminal: Copper Alloy Metallic Shell: Copper Alloy Plating Underplating: Nickel Contact Area: 30µ" Gold Solder Tails: 100µ" min. Tin Metallic Shell: Nickel 2.73 3.30 D 4.60 2.35 5.12 1.84 10.25 2.00 11.78 Section A-A 7.00 13.50 2.00±0.10 1.50±0.10 Electrical Voltage Rating: 100V Current Rating: 0.25 A (Signal Pins 2,3,5,6,7,8,9) 1.8 A (Power Pins1,4) Operating Temperature: -55°C to +85°C Contact Resistance: 30 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 100V AC 15.60 A C Ordering Grid USB1075 30 P Request Samples and Quotation B Contact Plating 30 = 30µ" Gold Packing Options B = Tray (100 per tray) Insulator Material P = PBT B 1 9 2 8 3 7 Mechanical & Environmental Mating Force: 35N max. Unmating Force: 10N initial, 8N min. after test Durability: 5,000 Cycles 4 6 5 A A 2.00 Part Number Product Description USB1075 USB 3.0 Receptacle, Type A, Through Hole, Horizontal, 9 Pin, Top Mount, with Kinked Shell Stakes Drawing Date 2.00 16th May 2011 By 7.00 1 2 3 Detail 4 Revision Date 5 CC Tolerances (Except as Noted) USB1075 E PCN E2 28/04/21 X.X° ± 2° X.X ± 0.40 X.XX ± 0.25 X.XX° ± 1° X.XXX ± 0.05 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/2 H NO TR FO E R N CO M EW M E DE ND SIG ED NS 1 USB G F Products P/N PCS/Tray USB1075 100 Trays/Carton PCS/Carton 30 3000 Tray 3 Solder tails face up in the tray Plastic Cover E D 2 30 trays per box 4 Tray Tape Carton Label 210mm C RoHS Label B 51 0m m m 0m 24 Part Number Product Description USB1075 USB 3.0 Receptacle, Type A, Through Hole, Horizontal, 9 Pin, Top Mount, with Kinked Shell Stakes Drawing Date A 16th May 2011 By Detail Revision Date 1 2 3 4 5 CC Tolerances (Except as Noted) USB1075 E PCN E2 28/04/21 X.X° ± 2° X.X ± 0.40 X.XX ± 0.25 X.XX° ± 1° X.XXX ± 0.05 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/2
USB1075-30-P-B 价格&库存
很抱歉,暂时无法提供与“USB1075-30-P-B”相匹配的价格&库存,您可以联系我们找货
USB1075-30-P-B
    • 1+23.71680
    • 10+20.52000
    • 30+18.61920
    库存:1
