PB22E06371-0625
PB22E06371-0625
    GANGYUAN(港源)
    插件
    按动开关 直插 100mA 2N 30V -40℃~+85℃
PB22E06371-0625 数据手册
ISO14001: 2004 ISO9001: 2000 APPROVAL SPECIFICATIONS Title. PUSH SWITCH Part NO. PB22E06371-0625 Customer’s Part NO. Model: PB22E06 Customer’s Approval Requested. Please return this copy as a certification of your approval. Checked by: Date: Approved by: Date: APPROVE REVIEW 廖明谷 项永才 WENZHOU GANGYUAN ELECTRONICS CO.,LTD. POLT 王蕾蕾 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION PB22E06371-0625 PUSH SWITCH A 1、 概述 GENERAL 1.2 适用范围 APPLICATION 此规格书适用于机械式按键开关的相关要求 This specification is applied to the requirements for PUSH SWITCH (MECHANICAL CONTACT) 1.3 工作温度范围 Operating Temperature Range -5℃~35℃(在标准大气压、标准湿度条件下) -5℃~35℃(Normal humidity, normal air pressure) 1.4 贮藏温度范围 Storage Temperature Range -30℃~80℃(在标准大气压、标准湿度条件下) -30℃~80℃(Normal humidity, normal air pressure) 1.5 测试条件 Test Conditions 在没有其它特定的条件下,应该在以下的条件下进行测试和测量: Unless otherwise specified, tests and measurement shall be made in the following standard conditions: 常温…………………………………5℃~35℃ Normal temperature………………5℃~35℃ 标准湿度……………………………相对湿度 45%~85% Normal humidity…………………relative humidity 45%~85% 标准大气压…………………………860Pa~1060pa Normal air pressure…………………860pa~1060pa 在制造过程中,测试和测量应该在以下的条件下进行: If any doubt arise from the judgment, tests shall be conducted at the following conditions: 温度…………………………………20℃±2℃ Temperature………………………20℃±2℃ 环境气压…………………………860Pa~1060pa Air pressure…………………………860Pa~1060pa APPROVE BY 廖明谷 14.05.29 CHECKED BY 项永才14.05.29 PRPARE BY 王蕾蕾 14.05.29 Page2 of 7 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER 2、 2.1 2.2 2.3 2.4 2.5 CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION PB22E06371-0625 PUSH SWITCH A 详细说明 Detailed specification 外观:应无影响、降低产品性能的缺陷; Appearance: There should be no defects that affect the serviceability of product. 结构尺寸和安装尺寸:应符合装配图要求; Style and dimension: shall conform to the assemble drawings. 操作形式:有触觉反应的操作 Type of actuating: Tactile feedback. 接触方式: 具体的触点结构在装配图中已绘出; Details of contact arrangement are given in the assembly drawings. 最大功率:DC 30V,0.1A(有效值) Most ratings: 30V DC, 0.1A (effective value) 3.电气性能: ELECTRICAL SPECIFICATION 项 目 ITEM 1 2 APPROVE BY 试 验 条 件 TEST CONDITIONS 要求 REQUIREMENTS 接触电阻 Contact Resistance 在不低于 1KHz 的交流电源的电路中,以一个 等于 2 倍按力的静负荷施加于按钮中心 Applying a static load of 2 times operating force to the center of the button, measurements shall be more than 1KHZ AC small-current contact resistance meter. 100mΩ.max 绝缘电阻 Insulation Resistance 在端子之间施加 DC 500V /1min 的条件下,测 量端间和壳体的电阻值 Measurement shall be made following application of 100V DC potential, across terminals, and across terminals and substance, for one minute. 100MΩ.min 廖明谷 14.05.29 CHECKED BY 项永才14.05.29 PRPARE BY 王蕾蕾 14.05.29 Page 3 of 7 GANGYUAN CUSTOMER CUSTOMER’S P/N 项目 ITEM 3 APPROVAL SPECIFICATIONS GYE’S P/N PRODUCT REVISION PB22E06371-0625 PUSH SWITCH A 试 验 条 件 TEST CONDITIONS 绝缘耐压 Insulation voltage proof 要求 REQUIREMENTS 无击穿、无飞弧 在 端 子 和 壳 体 之 间 施 加 500V AC(50HZ 或 60HZ)/1min There should be no 500V AV (50HZ or 60HZ) shall be applied breakdown and across terminals and substance, for one minute. flashover 4.机械性能: MECHANICAL SPECIFICATION 1 2 3 按力 Operating Force 最大行程 Full Travel 可焊性 Solderability APPROVE BY 开关垂直于操作方向放置,在开关驱动件顶端中心逐 渐施力,测量开关导通所需的最大力度。 Placing the switch such that the direction of switch operation is vertical and then gradually increasing the load applied to the center of the stem, the maximum load required for the switch to come to a stop shall be measured. 按装配图所示 Refer to assembly drawings 开关垂直于操作方向放置,以一个等于 2 倍按力的静 负荷施加在开关驱动件顶端中心,测量顶端移动的距 离。 Placing the switch such that the direction of switch operation is vertical and then applying static load of 2times operating force to the center of the stem; the travel distance for the switch to come to a stop shall be measured. 按装配图所示 Refer to assembly drawings 在以下设定条件下进行测量: Measurements shall be made following the test set forth below: (1) 焊接温度:255±5℃ Solder temperature : 255±5℃ (2) 浸入时间:2s±0.5s Immersion time: 2s±0.5s 对于其它步骤参考《GB 5095.6—86》试验 12a The other steps please refer to《GB 5095.6-86》 TEST 12a 除边缘外涂层应均匀覆 盖 90%以上 Except for the edge, the coating should cover a minimum 90% 廖明谷 14.05.29 CHECKED BY 项永才14.05.29 PRPARE BY 王蕾蕾 14.05.29 Page 4 of 7 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION PB22E06371-0625 PUSH SWITCH A 5、极限电气性能: ENVIRONMENTAL SPECIFICATION 1 样品应放在常温及标准湿度的环境中 1 小时后,根据下 面的测试要求进行测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 低温测试 1 h before measurements are made: Resistance to (1)温度:—20±2℃ low Temperature :-30±2℃ temperature (2)时间:72h Time: 72h (3)水滴应擦去 Dripping should be get rid of. 2 样品应放在常温及标准湿度的环境中 1 小时后,根据下 面的测试要求进行测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:80±2℃ temperature:80±2℃ (2) 时间: 72h time: 72h 高温测试 Heat resistance ① 接 触 电 阻 ﹤ 500m Ω Contact resistance : ﹤500mΩ ②绝缘电阻>10MΩ Insulation Resistance: >10MΩ ③项目 3.3 3 湿温测试 Moisture resistance APPROVE BY 样品应放在常温及标准湿度的环境中 1 小时后,根据下 面的测试要求进行测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:40±2℃ temperature: 40±2℃ (2) 相对湿度:90%~95% relative humidity:90% to 95% (3) 时间:72h time: 72h (4)水滴应擦去 Dripping should be get rid of. 廖明谷 14.05.29 CHECKED BY 项永才14.05.29 PRPARE BY 王蕾蕾 14.05.29 Page 5 of 7 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N 6、极限机械性能: ENDURANCE SPECIFICATION 项目 ITEM 1 2 工作寿命 Operation life 振动 Vibration GYE’S P/N PRODUCT REVISION PB22E06371-0625 PUSH SWITCH A 试 验 条 件 TEST CONDITIONS 要求 REQUIREMENTS 根据下面的测试要求进行测试: Measurement shall be made following the test set forth below: (1) DC 5V,50mA 带负载 DC 5V, 50 mA resistive load (1) 按动速率:15~30 次/min Rate of operation: 15 to 30 times/min (1) 按力:按力的 2 倍 (2) Operating Force: Operating Force 2 double (3) 平均无故障寿命:10,000 次 Average fault-free life: 10000 cycles ①接触电阻﹤500mΩ Contact resistance:﹤ 500mΩ ②绝缘电阻>10MΩ Insulation Resistance: >10MΩ ③按力:初值的±30% Operating Force: initial value±30% ④项目 3.3 Item3.3 根据以下给定条件进行测试: Measurement shall be made following the test set forth below: (1) 振动频率范围:10~55~10Hz Vibration frequency range: 10 to 55 to 10Hz (2) 振幅(峰-峰):1.5mm 项目 3,4.1 Amplitude: 1.5mm Item 3,4.1 (3) 振动方向:包括手柄行程方向在内的三个相互垂 直的方向 Direction of vibration:Three mutually perpendicular direction including the direction of stem travel (4) 测试时间:每次 2hours ,共 6 小时 Duration: Each 2hours.together 6 hours APPROVE BY 廖明谷 14.05.29 CHECKED BY 项永才14.05.29 PRPARE BY 王蕾蕾 14.05.29 Page 6 of 7 APPROVAL SPECIFICATIONS GANGYUAN CUSTOMER CUSTOMER’S P/N GYE’S P/N PRODUCT REVISION PB22E06371-0625 PUSH SWITCH A 7.焊接条件: SOLDERING CONDITIONS: 项目 ITEM 7.1 推 荐 条 件 Recommended conditions 请按以下条件进行焊接: (1) 焊锡温度:≤350℃ 手工焊接 (2) 连续焊接时间:≤3 s Hand soldering Please practice according to below conditions: (1) Soldering temperature: 350℃ Max. (2) Continuous soldering time: 3 s Max. 项目 Items 助焊剂附着量 Flux built-up 7.1 自动浸焊 Conditions for Auto-dip 预热温度 Preheating temperature 条件 Condition 不附着于零部件贴装面的程度 Mounting surface should not be coated with flax 印刷电路板焊接面的周围温度 100℃ max. Ambient temperature of the soldered surface of PC board. 100℃ max. 预热温度时间 Preheating time 焊接温度 Soldering temperature 45s max. 255℃ max. 焊接浸渍时间 Continuous dipping time 5s max. 焊接次数 Number of soldering 2 次以下 2times max. 说明: 1、建议选用含助焊剂 0.2%以下的锡膏,并避免助焊剂进入开关内而导致开关失效。 2、设计按压推柄时,请参考所提供的图低,切勿以尖状物直接按压开关,且压柄需垂直置于开关中心位置按压,并将 压柄摇晃度按制在±3°以内。 3、开关焊接加工时,应特别注意将温度及时间控制在 255℃±2℃、5 秒内,否则过高的温度及过长的时间会导致开关 的损坏或使用寿命减短。 4、焊接加工时开关应保持 OFF 状态,以避免开关损坏。 APPROVE BY 廖明谷 14.05.29 CHECKED BY 项永才14.05.29 PRPARE BY 王蕾蕾 14.05.29 Page 7 of 7
PB22E06371-0625 价格&库存
很抱歉,暂时无法提供与“PB22E06371-0625”相匹配的价格&库存,您可以联系我们找货
PB22E06371-0625
    • 5+0.64898
    • 50+0.51419
    • 150+0.44680
    • 1000+0.39064
    库存:980
    PB22E06371-0625
      • 5+0.72710
      • 50+0.57610
      • 150+0.50060
      • 1000+0.43770
      库存:1045
      PB22E06371-0625
        • 20+0.93500
        • 40+0.66000
        • 80+0.52800
        • 160+0.46200
        库存:2467
